[PATCH 1/3] score: Remove _Stack_Adjust_size()
Mon Apr 16 15:45:33 UTC 2012
On 04/16/2012 10:42 AM, Sebastian Huber wrote:
> On 04/16/2012 05:30 PM, Joel Sherrill wrote:
>> The intent was as you all describe -- you ask for N bytes and
>> the heap takes some overhead.
> If you ask the heap to allocate N bytes, you get N bytes or nothing.  There is
> no overhead to take into account.
We are on the third or fourth score heap implementation.
I recall some overhead being in the original implementation.
But if the method is no longer needed, it is no longer needed. :)
Joel Sherrill, Ph.D.             Director of Research&   Development
