Many BSPs Failing to Build
Mon Apr 16 23:36:57 UTC 2012
Hi,
I will fix this if someone can confirm what I think will resolve this.
I think this is due to a clean up change by Jennifer which
rippled exposing incorrect prototypes embedded in C files.
../../../../../../../rtems/c/src/lib/libcpu/arm/pxa255/clock/../../../../libbsp/shared/clockdrv_shell.h:60:11:
error: conflicting types for 'Clock_isr'
../../../../../../../rtems/c/src/lib/libcpu/arm/pxa255/clock/clock.c:89:11:
note: previous declaration of 'Clock_isr' was here
../../../../../../../rtems/c/src/lib/libcpu/arm/pxa255/clock/../../../../libbsp/shared/clockdrv_shell.h:61:11:
shared/clockdrv_shell.h now has this which means when
BSP_FEATURE_IRQ_EXTENSION is defined, we use a different
(and I hope correct) signature for Clock_isr.
+#ifdef BSP_FEATURE_IRQ_EXTENSION
+rtems_isr Clock_isr(void *arg);
+#else
+rtems_isr Clock_isr(rtems_vector_number vector);
+#endif
But the clock drivers actually prototype Clock_isr
like this which was OK because they cast it to
something else.
I am not pretty sure that the "void *" version is correct
for the BSP_FEATURE_IRQ_EXTENSION case but
really should be:
void Clock_isr( rtems_irq_hdl_param arg )
Can someone confirm this before I sweep through the
code?
And since rtems_isr is a typedef for void for documentation
purposes, wouldn't it make sense to use it in rtems/irq.h?
Joel Sherrill, Ph.D.             Director of Research&   Development
URL: <http://lists.rtems.org/pipermail/devel/attachments/20120416/a5a53c86/attachment.html>
