[rtems commit] bsps/stackalloc: Add initialization hook
Gedare Bloom
gedare at rtems.org
Thu Apr 26 12:40:23 UTC 2012
On Thu, Apr 26, 2012 at 5:00 AM, Sebastian Huber <sebh at rtems.org> wrote:
> Module: rtems
> Branch: master
> Commit: ed67d9317125d386ea6be12ee6ec256dd59f838a
> Changeset: http://git.rtems.org/rtems/commit/?id=ed67d9317125d386ea6be12ee6ec256dd59f838a
> Author: Sebastian Huber <sebastian.huber at embedded-brains.de>
> Date: Thu Apr 26 10:03:38 2012 +0200
> c/src/lib/libbsp/shared/include/stackalloc.h | 11 ++++++++++
> c/src/lib/libbsp/shared/src/stackalloc.c | 28 +++++++++++--------------
> 2 files changed, 23 insertions(+), 16 deletions(-)
> diff --git a/c/src/lib/libbsp/shared/include/stackalloc.h b/c/src/lib/libbsp/shared/include/stackalloc.h
> index b8516ef..6ed898f 100644
> --- a/c/src/lib/libbsp/shared/include/stackalloc.h
> +++ b/c/src/lib/libbsp/shared/include/stackalloc.h
> @@ -52,6 +52,12 @@ extern "C" {
> + * @brief Task stack allocator initialization for
> + * @ref CONFIGURE_TASK_STACK_ALLOCATOR_INIT.
> +void bsp_stack_allocate_init(size_t stack_space_size);
For shared BSP code should we adopt the naming conventions of cpukit
and avoid using abbreviations? here it would be
bsp_stack_allocate_initialize. Similar with the macro.
> * @brief Task stack allocator for @ref CONFIGURE_TASK_STACK_ALLOCATOR.
> * In case the designated task stack space from bsp_stack_initialize() is
> @@ -65,6 +71,11 @@ void *bsp_stack_allocate(size_t size);
> void bsp_stack_free(void *stack);
> + * @brief Task stack allocator initialization configuration option.
> +#define CONFIGURE_TASK_STACK_ALLOCATOR_INIT bsp_stack_allocate_init
> * @brief Task stack allocator configuration option.
> #define CONFIGURE_TASK_STACK_ALLOCATOR bsp_stack_allocate
> diff --git a/c/src/lib/libbsp/shared/src/stackalloc.c b/c/src/lib/libbsp/shared/src/stackalloc.c
> index be84057..b8d7b9c 100644
> --- a/c/src/lib/libbsp/shared/src/stackalloc.c
> +++ b/c/src/lib/libbsp/shared/src/stackalloc.c
> @@ -27,30 +27,26 @@
> #include <bsp/linker-symbols.h>
> -#define BSP_STACK_MAGIC 0xdeadbeef
> +static Heap_Control bsp_stack_heap;
> -static Heap_Control bsp_stack_heap = {
> - .page_size = BSP_STACK_MAGIC
> + _Heap_Initialize(
> + &bsp_stack_heap,
> + bsp_section_stack_begin,
> + (uintptr_t) bsp_section_stack_size,
> + CPU_STACK_ALIGNMENT
> void *stack = NULL;
> - if (bsp_stack_heap.page_size == BSP_STACK_MAGIC) {
> - uintptr_t rv = _Heap_Initialize(
> - &bsp_stack_heap,
> - bsp_section_stack_begin,
> - (uintptr_t) bsp_section_stack_size,
> - CPU_STACK_ALIGNMENT
> - if (rv == 0) {
> - return NULL;
> + if (bsp_stack_heap.area_begin != 0) {
> + stack = _Heap_Allocate(&bsp_stack_heap, size);
> - stack = _Heap_Allocate(&bsp_stack_heap, size);
> if (stack == NULL) {
> stack = _Workspace_Allocate(size);
> rtems-vc mailing list
> rtems-vc at rtems.org
> http://www.rtems.org/mailman/listinfo/rtems-vc
