GCC Version Questions
Thomas Doerfler Thomas.Doerfler at embedded-brains.de
Sun Apr 29 09:56:45 UTC 2012
Ralf, Chris,
Am 29.04.2012 06:41, schrieb Ralf Corsepius:
>> I also think the removal of the rtems4.11/arm directory is childish.
> I was following Sebastian's and Thomas's wish, they had repeatedly been
> nagging me with for ca. a years.
> This time, I gave in resistance and followed.
>> You
>> were clearly asked to change rtems4.11/arm to EABI, not to remove it.
> Chris, I have no idea what I shall answer to this.
> Let me reiterate:
> Upstream GCC has abandoned all targets which do not match 'arm-*-*eabi*'
> and wants all target to use a target tuple matching the wildcard pattern
> 'arm-*-*eabi*'.
> I.e. RTEMS is not permitted to use "arm-rtems" for RTEMS "arm-eabi",
> because this contradicts upstream's intention. Apparently, they want a
> clear separation and break between arm-elf and arm-eabi.
I see no problem with the different name. If Ralf thinks that upstream
GCC suggests an explicit naming scheme I dont see harm here. Maybe it
even has the benefit that the RTEMS ARM users really see that the
toolset flavour has changed.
Chris: do you have explicit reasons for your wish to stay with the
rtems4.11/arm/ path?
wkr,
Thomas.
> Ralf
> rtems-devel mailing list
> rtems-devel at rtems.org
Embedded Brains GmbH
Thomas Doerfler           Obere Lagerstr. 30
D-82178 Puchheim          Germany
email: Thomas.Doerfler at embedded-brains.de
Phone: +49-89-18908079-2
Fax:   +49-89-18908079-9
