GCC Version Questions
Mon Apr 30 01:04:47 UTC 2012
On 29/04/12 2:41 PM, Ralf Corsepius wrote:
> On 04/28/2012 12:07 AM, Chris Johns wrote:
>> On 27/04/12 11:15 PM, Chris Johns wrote:
>>> On 27/04/12 7:30 PM, Ralf Corsepius wrote:
>>>> On 04/27/2012 11:14 AM, Chris Johns wrote:
>>>>> On 27/04/12 11:22 AM, Ralf Corsepius wrote:
>> I have no idea what you are using or what you are building.
> Full log:
Thanks. It confirms what I am seeing that
'rtems-4.11-arm-rtemseabi4.11-gcc.spec' is not being generated. The text
'rtems-4.11-arm-rtemseabi4.11-gcc.spec' appears only once in the email
while 'rtems-4.11-sparc-rtems4.11-gcc.spec' for example appears twice.
> # git clone ssh://git.rtems.org/data/git/rtems-crossrpms.git
> Cloning into 'rtems-crossrpms'...
> cd rtems-crossrpms
> # ./configure
> checking build system type... x86_64-unknown-linux-gnu
> checking host system type... x86_64-unknown-linux-gnu
> checking for a BSD-compatible install... /usr/bin/install -c
> checking whether build environment is sane... yes
> checking for a thread-safe mkdir -p... /bin/mkdir -p
> checking for gawk... gawk
> checking whether make sets $(MAKE)... yes
> configure: WARNING: ignoring unsupported target arm-eabi-rtems4.11
> configure: creating ./config.status
> config.status: creating Makefile
> config.status: creating cygwin/Makefile
> config.status: creating cygwin/i686/Makefile
> config.status: creating mingw32/Makefile
> config.status: creating mingw32/i686/Makefile
> config.status: creating mingw32/x86_64/Makefile
> config.status: creating solaris2.7/Makefile
> config.status: creating solaris2.7/sparc/Makefile
> config.status: creating freebsd6.4/Makefile
> config.status: creating freebsd6.4/i586/Makefile
> config.status: creating freebsd7.3/Makefile
> config.status: creating freebsd7.3/i586/Makefile
> config.status: creating freebsd8.2/Makefile
> config.status: creating freebsd8.2/i586/Makefile
> config.status: creating freebsd8.2/x86_64/Makefile
> config.status: creating freebsd9.0/Makefile
> config.status: creating freebsd9.0/i586/Makefile
> config.status: creating freebsd9.0/x86_64/Makefile
> config.status: creating netbsd5.1/Makefile
> config.status: creating netbsd5.1/i386/Makefile
> config.status: creating netbsd5.1/x86_64/Makefile
> config.status: creating rtems4.11/Makefile
> config.status: creating rtems4.11/arm-eabi/Makefile
> config.status: creating rtems4.11/avr/Makefile
> config.status: creating rtems4.11/bfin/Makefile
> config.status: creating rtems4.11/h8300/Makefile
> config.status: creating rtems4.11/i386/Makefile
> config.status: creating rtems4.11/lm32/Makefile
> config.status: creating rtems4.11/m32c/Makefile
> config.status: creating rtems4.11/m32r/Makefile
> config.status: creating rtems4.11/microblaze/Makefile
> config.status: creating rtems4.11/m68k/Makefile
> config.status: creating rtems4.11/mips/Makefile
> config.status: creating rtems4.11/mipstx39/Makefile
> config.status: creating rtems4.11/powerpc/Makefile
> config.status: creating rtems4.11/sh/Makefile
> config.status: creating rtems4.11/sparc/Makefile
> config.status: creating rtems4.11/sparc64/Makefile
> config.status: creating autotools/Makefile
> # make
> CDPATH="${ZSH_VERSION+.}:" && cd . && /bin/sh
> /users/rtems/src/rtems.org/test/rtems-crossrpms/missing --run aclocal-1.11
> cd . && /bin/sh /users/rtems/src/rtems.org/test/rtems-crossrpms/missing
> --run automake-1.11 --gnu
> /users/rtems/src/rtems.org/test/rtems-crossrpms/missing --run autoconf
> /bin/sh ./config.status --recheck
> running CONFIG_SHELL=/bin/sh /bin/sh ./configure --no-create --no-recursion
> Making all in autotools
> make[1]: Entering directory
> `/users/rtems/src/rtems.org/test/rtems-crossrpms/autotools'
> cat ../common/common.add ../autotools/autoconf.add
> ../binutils/rpm-install.add ../common/clean.add
> ../autotools/target-autoconf.add | sed \
> -e "/[@]SOURCES[@]/r ./autoconf-sources.add" \
> -e "/[@]SOURCES[@]/d" \
> -e "s/[@]AUTOCONF_VERS[@]/2.68/" \
> -e "s/[@]AUTOCONF_RPMREL[@]/4%{?dist}/" > autoconf.spec.in
> sed -e "s,[@]rpmprefix[@],rtems-4.11-,g" -e
> "s,[@]_prefix[@],/opt/rtems-4.11,g" -e "s/[@]tool_target[@]//g" -e
> "/^%package -n [@]rpmprefix[@][@]tool_target[@]-gcc/d" -e
> "s/^%sysdir/%dir/g" -e "/[@]PATCH/d" autoconf.spec.in | ../specstrip
> --prefix=/opt/rtems-4.11 > rtems-4.11-autoconf.spec
> cat ../common/common.add ../autotools/automake.add
> ../autotools/target-automake.add | sed \
> -e "/[@]SOURCES[@]/r ./automake-sources.add" \
> -e "s/[@]AUTOMAKE_VERS[@]/1.11.5/g" \
> -e "s/[@]AUTOMAKE_RPMREL[@]/1%{?dist}/g" > automake.spec.in
> "s/^%sysdir/%dir/g" -e "/[@]PATCH/d" automake.spec.in | ../specstrip
> --prefix=/opt/rtems-4.11 > rtems-4.11-automake.spec
> make[1]: Leaving directory
> Making all in rtems4.11/avr
> `/users/rtems/src/rtems.org/test/rtems-crossrpms/rtems4.11/avr'
> cat ../../common/common.add ../../binutils/binutils.add
> ../../binutils/prep.add ../../binutils/build.add
> ../../binutils/install.add ../../binutils/rpm-install.add
> ../../common/clean.add ../../binutils/target-binutils.add
> ../../binutils/base-binutils.add | sed \
> -e "/[@]SOURCES[@]/r ./binutils-sources.add" \
> -e "s/[@]BINUTILS_VERS[@]/2.22/g" \
> -e "s/[@]BINUTILS_PKGVERS[@]/2.22/g" \
> -e "s/[@]BINUTILS_RPMREL[@]/4%{?dist}/g" \
> -e "/--with-sysroot/d" \
> | sed -e "s/[@]tool_target[@]/avr-rtems4.11/g" -e
> "s/[@]rtems_api[@]/4.11/g" > avr-rtems4.11-binutils.spec.in
> "s/[@]tool_target[@]/avr-rtems4.11/g" -e "/^%package -n
> [@]rpmprefix[@][@]tool_target[@]-gcc/d" -e "s/^%sysdir/%dir/g" -e
> "/[@]PATCH/d" avr-rtems4.11-binutils.spec.in | ../../specstrip
> --prefix=/opt/rtems-4.11 > rtems-4.11-avr-rtems4.11-binutils.spec
> cat ../../common/common.add ../../gcc/gccnewlib.add ../../gcc/prep.add
> ../../gcc/build.add ../../gcc/install.add ../../gcc/rpm-install.add
> ../../common/clean.add ../../gcc/target-gcc.add ../../gcc/base-gcc.add
> ../../gcc/target-c++.add ../../gcc/target-gfortran.add
> ../../gcc/base-gfortran.add ../../gcc/base-go.add
> ../../gcc/target-go.add ../../gcc/target-objc.add
> ../../gcc/target-newlib.add ../../gcc/base-newlib.add \
> | sed \
> -e "/[@]SOURCES[@]/r ./gcc-sources.add" \
> -e "/[@]PREP[@]/r ./../gcc-prep.add" \
> -e "/[@]PREP[@]/d" \
> | sed \
> -e "s/[@]GCC_VERS[@]/4.6.3/g" \
> -e "s/[@]GCC_PKGVERS[@]/4.6.3/g" \
> -e "s/[@]GCC_RPMREL[@]/2%{?dist}/g" \
> -e "s/[@]NEWLIB_VERS[@]/1.20.0/g" \
> -e "s/[@]NEWLIB_PKGVERS[@]/1.20.0/g" \
> -e "s/[@]NEWLIB_RPMREL[@]/`expr 2 + 4`%{?dist}/g" \
> -e "/[@]tool_target[@]-sys-root/d" \
> -e "/[@]tool_target[@]-w32api-sys-root/d" \
> "s/[@]rtems_api[@]/4.11/g" > avr-rtems4.11-gcc.spec.in
> "/[@]PATCH/d" avr-rtems4.11-gcc.spec.in | ../../specstrip
> --prefix=/opt/rtems-4.11 --languages=c --newlib >
> rtems-4.11-avr-rtems4.11-gcc.spec
> cat ../../common/common.add ../../gdb/gdb.add ../../gdb/prep.add
> ../../gdb/build.add ../../gdb/install.add ../../gdb/rpm-install.add
> ../../common/clean.add ../../gdb/target-gdb.add ../../gdb/base-gdb.add |
> sed \
> -e "/[@]SOURCES[@]/r ./gdb-sources.add" \
> -e "s/[@]GDB_VERS[@]/7.4/g" \
> -e "s/[@]GDB_PKGVERS[@]/7.4/g" \
> -e "s/[@]GDB_RPMREL[@]/1%{?dist}/g" \
> "s/[@]rtems_api[@]/4.11/g" > avr-rtems4.11-gdb.spec.in
> "/[@]PATCH/d" avr-rtems4.11-gdb.spec.in | ../../specstrip
> --prefix=/opt/rtems-4.11 > rtems-4.11-avr-rtems4.11-gdb.spec
> Making all in rtems4.11/bfin
> `/users/rtems/src/rtems.org/test/rtems-crossrpms/rtems4.11/bfin'
> -e "s/[@]BINUTILS_RPMREL[@]/3%{?dist}/g" \
> | sed -e "s/[@]tool_target[@]/bfin-rtems4.11/g" -e
> "s/[@]rtems_api[@]/4.11/g" > bfin-rtems4.11-binutils.spec.in
> "s/[@]tool_target[@]/bfin-rtems4.11/g" -e "/^%package -n
> "/[@]PATCH/d" bfin-rtems4.11-binutils.spec.in | ../../specstrip
> --prefix=/opt/rtems-4.11 > rtems-4.11-bfin-rtems4.11-binutils.spec
> | sed \
> | sed \
> -e "s/[@]GCC_VERS[@]/4.7.0/g" \
> -e "s/[@]GCC_PKGVERS[@]/4.7.0/g" \
> -e "s/[@]GCC_RPMREL[@]/1%{?dist}/g" \
> -e "s/[@]NEWLIB_RPMREL[@]/`expr 1 + 5`%{?dist}/g" \
> "s/[@]rtems_api[@]/4.11/g" > bfin-rtems4.11-gcc.spec.in
> "/[@]PATCH/d" bfin-rtems4.11-gcc.spec.in | ../../specstrip
> --prefix=/opt/rtems-4.11 --languages=c --newlib --languages=cxx >
> rtems-4.11-bfin-rtems4.11-gcc.spec
> sed \
> "s/[@]rtems_api[@]/4.11/g" > bfin-rtems4.11-gdb.spec.in
> "/[@]PATCH/d" bfin-rtems4.11-gdb.spec.in | ../../specstrip
> --prefix=/opt/rtems-4.11 > rtems-4.11-bfin-rtems4.11-gdb.spec
> Making all in rtems4.11/h8300
> `/users/rtems/src/rtems.org/test/rtems-crossrpms/rtems4.11/h8300'
> | sed -e "s/[@]tool_target[@]/h8300-rtems4.11/g" -e
> "s/[@]rtems_api[@]/4.11/g" > h8300-rtems4.11-binutils.spec.in
> "s/[@]tool_target[@]/h8300-rtems4.11/g" -e "/^%package -n
> "/[@]PATCH/d" h8300-rtems4.11-binutils.spec.in | ../../specstrip
> --prefix=/opt/rtems-4.11 > rtems-4.11-h8300-rtems4.11-binutils.spec
> | sed \
> | sed \
> "s/[@]rtems_api[@]/4.11/g" > h8300-rtems4.11-gcc.spec.in
> "/[@]PATCH/d" h8300-rtems4.11-gcc.spec.in | ../../specstrip
> rtems-4.11-h8300-rtems4.11-gcc.spec
> sed \
> "s/[@]rtems_api[@]/4.11/g" > h8300-rtems4.11-gdb.spec.in
> "/[@]PATCH/d" h8300-rtems4.11-gdb.spec.in | ../../specstrip
> --prefix=/opt/rtems-4.11 > rtems-4.11-h8300-rtems4.11-gdb.spec
> Making all in rtems4.11/i386
> `/users/rtems/src/rtems.org/test/rtems-crossrpms/rtems4.11/i386'
> | sed -e "s/[@]tool_target[@]/i386-rtems4.11/g" -e
> "s/[@]rtems_api[@]/4.11/g" > i386-rtems4.11-binutils.spec.in
> "s/[@]tool_target[@]/i386-rtems4.11/g" -e "/^%package -n
> "/[@]PATCH/d" i386-rtems4.11-binutils.spec.in | ../../specstrip
> --prefix=/opt/rtems-4.11 > rtems-4.11-i386-rtems4.11-binutils.spec
> | sed \
> | sed \
> "s/[@]rtems_api[@]/4.11/g" > i386-rtems4.11-gcc.spec.in
> "/[@]PATCH/d" i386-rtems4.11-gcc.spec.in | ../../specstrip
> rtems-4.11-i386-rtems4.11-gcc.spec
> sed \
> "s/[@]rtems_api[@]/4.11/g" > i386-rtems4.11-gdb.spec.in
> "/[@]PATCH/d" i386-rtems4.11-gdb.spec.in | ../../specstrip
> --prefix=/opt/rtems-4.11 > rtems-4.11-i386-rtems4.11-gdb.spec
> Making all in rtems4.11/lm32
> `/users/rtems/src/rtems.org/test/rtems-crossrpms/rtems4.11/lm32'
> | sed -e "s/[@]tool_target[@]/lm32-rtems4.11/g" -e
> "s/[@]rtems_api[@]/4.11/g" > lm32-rtems4.11-binutils.spec.in
> "s/[@]tool_target[@]/lm32-rtems4.11/g" -e "/^%package -n
> "/[@]PATCH/d" lm32-rtems4.11-binutils.spec.in | ../../specstrip
> --prefix=/opt/rtems-4.11 > rtems-4.11-lm32-rtems4.11-binutils.spec
> | sed \
> | sed \
> -e "s/[@]GCC_VERS[@]/4.5.3/g" \
> -e "s/[@]GCC_PKGVERS[@]/4.5.3/g" \
> -e "s/[@]GCC_RPMREL[@]/26%{?dist}/g" \
> -e "s/[@]NEWLIB_RPMREL[@]/`expr 26 - 22`%{?dist}/g" \
> "s/[@]rtems_api[@]/4.11/g" > lm32-rtems4.11-gcc.spec.in
> "/[@]PATCH/d" lm32-rtems4.11-gcc.spec.in | ../../specstrip
> rtems-4.11-lm32-rtems4.11-gcc.spec
> sed \
> "s/[@]rtems_api[@]/4.11/g" > lm32-rtems4.11-gdb.spec.in
> "/[@]PATCH/d" lm32-rtems4.11-gdb.spec.in | ../../specstrip
> --prefix=/opt/rtems-4.11 > rtems-4.11-lm32-rtems4.11-gdb.spec
> Making all in rtems4.11/m32c
> `/users/rtems/src/rtems.org/test/rtems-crossrpms/rtems4.11/m32c'
> | sed -e "s/[@]tool_target[@]/m32c-rtems4.11/g" -e
> "s/[@]rtems_api[@]/4.11/g" > m32c-rtems4.11-binutils.spec.in
> "s/[@]tool_target[@]/m32c-rtems4.11/g" -e "/^%package -n
> "/[@]PATCH/d" m32c-rtems4.11-binutils.spec.in | ../../specstrip
> --prefix=/opt/rtems-4.11 > rtems-4.11-m32c-rtems4.11-binutils.spec
> | sed \
> | sed \
> "s/[@]rtems_api[@]/4.11/g" > m32c-rtems4.11-gcc.spec.in
> "/[@]PATCH/d" m32c-rtems4.11-gcc.spec.in | ../../specstrip
> rtems-4.11-m32c-rtems4.11-gcc.spec
> sed \
> "s/[@]rtems_api[@]/4.11/g" > m32c-rtems4.11-gdb.spec.in
> "/[@]PATCH/d" m32c-rtems4.11-gdb.spec.in | ../../specstrip
> --prefix=/opt/rtems-4.11 > rtems-4.11-m32c-rtems4.11-gdb.spec
> Making all in rtems4.11/m32r
> `/users/rtems/src/rtems.org/test/rtems-crossrpms/rtems4.11/m32r'
> | sed -e "s/[@]tool_target[@]/m32r-rtems4.11/g" -e
> "s/[@]rtems_api[@]/4.11/g" > m32r-rtems4.11-binutils.spec.in
> "s/[@]tool_target[@]/m32r-rtems4.11/g" -e "/^%package -n
> "/[@]PATCH/d" m32r-rtems4.11-binutils.spec.in | ../../specstrip
> --prefix=/opt/rtems-4.11 > rtems-4.11-m32r-rtems4.11-binutils.spec
> | sed \
> | sed \
> "s/[@]rtems_api[@]/4.11/g" > m32r-rtems4.11-gcc.spec.in
> "/[@]PATCH/d" m32r-rtems4.11-gcc.spec.in | ../../specstrip
> rtems-4.11-m32r-rtems4.11-gcc.spec
> sed \
> "s/[@]rtems_api[@]/4.11/g" > m32r-rtems4.11-gdb.spec.in
> "/[@]PATCH/d" m32r-rtems4.11-gdb.spec.in | ../../specstrip
> --prefix=/opt/rtems-4.11 > rtems-4.11-m32r-rtems4.11-gdb.spec
> Making all in rtems4.11/m68k
> `/users/rtems/src/rtems.org/test/rtems-crossrpms/rtems4.11/m68k'
> | sed -e "s/[@]tool_target[@]/m68k-rtems4.11/g" -e
> "s/[@]rtems_api[@]/4.11/g" > m68k-rtems4.11-binutils.spec.in
> "s/[@]tool_target[@]/m68k-rtems4.11/g" -e "/^%package -n
> "/[@]PATCH/d" m68k-rtems4.11-binutils.spec.in | ../../specstrip
> --prefix=/opt/rtems-4.11 > rtems-4.11-m68k-rtems4.11-binutils.spec
> | sed \
> | sed \
> -e "s/[@]GCC_RPMREL[@]/3%{?dist}/g" \
> -e "s/[@]NEWLIB_RPMREL[@]/`expr 3 + 5`%{?dist}/g" \
> "s/[@]rtems_api[@]/4.11/g" > m68k-rtems4.11-gcc.spec.in
> "/[@]PATCH/d" m68k-rtems4.11-gcc.spec.in | ../../specstrip
> rtems-4.11-m68k-rtems4.11-gcc.spec
> sed \
> "s/[@]rtems_api[@]/4.11/g" > m68k-rtems4.11-gdb.spec.in
> "/[@]PATCH/d" m68k-rtems4.11-gdb.spec.in | ../../specstrip
> --prefix=/opt/rtems-4.11 > rtems-4.11-m68k-rtems4.11-gdb.spec
> Making all in rtems4.11/microblaze
> `/users/rtems/src/rtems.org/test/rtems-crossrpms/rtems4.11/microblaze'
> | sed -e "s/[@]tool_target[@]/microblaze-rtems4.11/g" -e
> "s/[@]rtems_api[@]/4.11/g" > microblaze-rtems4.11-binutils.spec.in
> "s/[@]tool_target[@]/microblaze-rtems4.11/g" -e "/^%package -n
> "/[@]PATCH/d" microblaze-rtems4.11-binutils.spec.in | ../../specstrip
> --prefix=/opt/rtems-4.11 > rtems-4.11-microblaze-rtems4.11-binutils.spec
> | sed \
> | sed \
> "s/[@]rtems_api[@]/4.11/g" > microblaze-rtems4.11-gcc.spec.in
> "/[@]PATCH/d" microblaze-rtems4.11-gcc.spec.in | ../../specstrip
> rtems-4.11-microblaze-rtems4.11-gcc.spec
> sed \
> "s/[@]rtems_api[@]/4.11/g" > microblaze-rtems4.11-gdb.spec.in
> "/[@]PATCH/d" microblaze-rtems4.11-gdb.spec.in | ../../specstrip
> --prefix=/opt/rtems-4.11 > rtems-4.11-microblaze-rtems4.11-gdb.spec
> Making all in rtems4.11/mips
> `/users/rtems/src/rtems.org/test/rtems-crossrpms/rtems4.11/mips'
> | sed -e "s/[@]tool_target[@]/mips-rtems4.11/g" -e
> "s/[@]rtems_api[@]/4.11/g" > mips-rtems4.11-binutils.spec.in
> "s/[@]tool_target[@]/mips-rtems4.11/g" -e "/^%package -n
> "/[@]PATCH/d" mips-rtems4.11-binutils.spec.in | ../../specstrip
> --prefix=/opt/rtems-4.11 > rtems-4.11-mips-rtems4.11-binutils.spec
> | sed \
> | sed \
> "s/[@]rtems_api[@]/4.11/g" > mips-rtems4.11-gcc.spec.in
> "/[@]PATCH/d" mips-rtems4.11-gcc.spec.in | ../../specstrip
> rtems-4.11-mips-rtems4.11-gcc.spec
> sed \
> "s/[@]rtems_api[@]/4.11/g" > mips-rtems4.11-gdb.spec.in
> "/[@]PATCH/d" mips-rtems4.11-gdb.spec.in | ../../specstrip
> --prefix=/opt/rtems-4.11 > rtems-4.11-mips-rtems4.11-gdb.spec
> Making all in rtems4.11/mipstx39
> `/users/rtems/src/rtems.org/test/rtems-crossrpms/rtems4.11/mipstx39'
> sed \
> | sed -e "s/[@]tool_target[@]/mipstx39-rtems4.11/g" -e
> "s/[@]rtems_api[@]/4.11/g" > mipstx39-rtems4.11-gdb.spec.in
> "s/[@]tool_target[@]/mipstx39-rtems4.11/g" -e "/^%package -n
> "/[@]PATCH/d" mipstx39-rtems4.11-gdb.spec.in | ../../specstrip
> --prefix=/opt/rtems-4.11 > rtems-4.11-mipstx39-rtems4.11-gdb.spec
> Making all in rtems4.11/powerpc
> `/users/rtems/src/rtems.org/test/rtems-crossrpms/rtems4.11/powerpc'
> | sed -e "s/[@]tool_target[@]/powerpc-rtems4.11/g" -e
> "s/[@]rtems_api[@]/4.11/g" > powerpc-rtems4.11-binutils.spec.in
> "s/[@]tool_target[@]/powerpc-rtems4.11/g" -e "/^%package -n
> "/[@]PATCH/d" powerpc-rtems4.11-binutils.spec.in | ../../specstrip
> --prefix=/opt/rtems-4.11 > rtems-4.11-powerpc-rtems4.11-binutils.spec
> | sed \
> | sed \
> -e "s/[@]NEWLIB_RPMREL[@]/`expr 2 + 5`%{?dist}/g" \
> "s/[@]rtems_api[@]/4.11/g" > powerpc-rtems4.11-gcc.spec.in
> "/[@]PATCH/d" powerpc-rtems4.11-gcc.spec.in | ../../specstrip
> rtems-4.11-powerpc-rtems4.11-gcc.spec
> sed \
> "s/[@]rtems_api[@]/4.11/g" > powerpc-rtems4.11-gdb.spec.in
> "/[@]PATCH/d" powerpc-rtems4.11-gdb.spec.in | ../../specstrip
> --prefix=/opt/rtems-4.11 > rtems-4.11-powerpc-rtems4.11-gdb.spec
> Making all in rtems4.11/sh
> `/users/rtems/src/rtems.org/test/rtems-crossrpms/rtems4.11/sh'
> | sed -e "s/[@]tool_target[@]/sh-rtems4.11/g" -e
> "s/[@]rtems_api[@]/4.11/g" > sh-rtems4.11-binutils.spec.in
> "s/[@]tool_target[@]/sh-rtems4.11/g" -e "/^%package -n
> "/[@]PATCH/d" sh-rtems4.11-binutils.spec.in | ../../specstrip
> --prefix=/opt/rtems-4.11 > rtems-4.11-sh-rtems4.11-binutils.spec
> | sed \
> | sed \
> "s/[@]rtems_api[@]/4.11/g" > sh-rtems4.11-gcc.spec.in
> "/[@]PATCH/d" sh-rtems4.11-gcc.spec.in | ../../specstrip
> rtems-4.11-sh-rtems4.11-gcc.spec
> sed \
> "s/[@]rtems_api[@]/4.11/g" > sh-rtems4.11-gdb.spec.in
> "/[@]PATCH/d" sh-rtems4.11-gdb.spec.in | ../../specstrip
> --prefix=/opt/rtems-4.11 > rtems-4.11-sh-rtems4.11-gdb.spec
> Making all in rtems4.11/sparc
> `/users/rtems/src/rtems.org/test/rtems-crossrpms/rtems4.11/sparc'
> | sed -e "s/[@]tool_target[@]/sparc-rtems4.11/g" -e
> "s/[@]rtems_api[@]/4.11/g" > sparc-rtems4.11-binutils.spec.in
> "s/[@]tool_target[@]/sparc-rtems4.11/g" -e "/^%package -n
> "/[@]PATCH/d" sparc-rtems4.11-binutils.spec.in | ../../specstrip
> --prefix=/opt/rtems-4.11 > rtems-4.11-sparc-rtems4.11-binutils.spec
> | sed \
> | sed \
> "s/[@]rtems_api[@]/4.11/g" > sparc-rtems4.11-gcc.spec.in
> "/[@]PATCH/d" sparc-rtems4.11-gcc.spec.in | ../../specstrip
> sed \
> "s/[@]rtems_api[@]/4.11/g" > sparc-rtems4.11-gdb.spec.in
> "/[@]PATCH/d" sparc-rtems4.11-gdb.spec.in | ../../specstrip
> --prefix=/opt/rtems-4.11 > rtems-4.11-sparc-rtems4.11-gdb.spec
> Making all in rtems4.11/sparc64
> `/users/rtems/src/rtems.org/test/rtems-crossrpms/rtems4.11/sparc64'
> | sed -e "s/[@]tool_target[@]/sparc64-rtems4.11/g" -e
> "s/[@]rtems_api[@]/4.11/g" > sparc64-rtems4.11-binutils.spec.in
> "s/[@]tool_target[@]/sparc64-rtems4.11/g" -e "/^%package -n
> "/[@]PATCH/d" sparc64-rtems4.11-binutils.spec.in | ../../specstrip
> --prefix=/opt/rtems-4.11 > rtems-4.11-sparc64-rtems4.11-binutils.spec
> | sed \
> | sed \
> "s/[@]rtems_api[@]/4.11/g" > sparc64-rtems4.11-gcc.spec.in
> "/[@]PATCH/d" sparc64-rtems4.11-gcc.spec.in | ../../specstrip
> rtems-4.11-sparc64-rtems4.11-gcc.spec
> sed \
> "s/[@]rtems_api[@]/4.11/g" > sparc64-rtems4.11-gdb.spec.in
> "/[@]PATCH/d" sparc64-rtems4.11-gdb.spec.in | ../../specstrip
> --prefix=/opt/rtems-4.11 > rtems-4.11-sparc64-rtems4.11-gdb.spec
> Making all in freebsd6.4/i586
> `/users/rtems/src/rtems.org/test/rtems-crossrpms/freebsd6.4/i586'
> cat ../../common/common.add ./libs.add ../../gcc/rpm-install.add
> ../../common/clean.add ./target-libs.add | sed \
> -e "s/[@]FREEBSD_VERS[@]/6.4/g" \
> -e "s/[@]FREEBSD_RPMREL[@]/0.20090827.1%{?dist}/g" \
> -e "s,%{gcc_rpmvers},%{freebsd_rpmvers},g" \
>  > i586-pc-freebsd6.4-libs.spec.in
> "s/[@]tool_target[@]/i586-pc-freebsd6.4/g" -e "/^%package -n
> "/[@]PATCH/d" i586-pc-freebsd6.4-libs.spec.in | ../../specstrip
> --prefix=/opt/rtems-4.11 > rtems-4.11-i586-pc-freebsd6.4-libs.spec
> -e "s/[@]BINUTILS_RPMREL[@]/0.20111122.0%{?dist}/g" \
> | sed -e "s/[@]tool_target[@]/i586-pc-freebsd6.4/g" -e
> "s/[@]rtems_api[@]/4.11/g" > i586-pc-freebsd6.4-binutils.spec.in
> "/[@]PATCH/d" i586-pc-freebsd6.4-binutils.spec.in | ../../specstrip
> --prefix=/opt/rtems-4.11 > rtems-4.11-i586-pc-freebsd6.4-binutils.spec
> ../../gcc/base-gfortran.add ../../gcc/target-objc.add \
> | sed \
> | sed \
> -e "s/[@]GCC_VERS[@]/4.5.2/g" \
> -e "s/[@]GCC_PKGVERS[@]/4.5.2/g" \
> -e "s/[@]GCC_RPMREL[@]/0.20120222.0%{?dist}/g" \
> -e "/[@]tool_target[@]-newlib/d" \
> -e "/--with-newlib/d" \
> "s/[@]rtems_api[@]/4.11/g" > i586-pc-freebsd6.4-gcc.spec.in
> "/[@]PATCH/d" i586-pc-freebsd6.4-gcc.spec.in | ../../specstrip
> --prefix=/opt/rtems-4.11 --languages=cxx,fortran,objc >
> rtems-4.11-i586-pc-freebsd6.4-gcc.spec
> Making all in freebsd7.3/i586
> `/users/rtems/src/rtems.org/test/rtems-crossrpms/freebsd7.3/i586'
> -e "s/[@]FREEBSD_VERS[@]/7.3/g" \
> -e "s/[@]FREEBSD_RPMREL[@]/0.20100416.1%{?dist}/g" \
>  > i586-pc-freebsd7.3-libs.spec.in
> "s/[@]tool_target[@]/i586-pc-freebsd7.3/g" -e "/^%package -n
> "/[@]PATCH/d" i586-pc-freebsd7.3-libs.spec.in | ../../specstrip
> --prefix=/opt/rtems-4.11 > rtems-4.11-i586-pc-freebsd7.3-libs.spec
> | sed -e "s/[@]tool_target[@]/i586-pc-freebsd7.3/g" -e
> "s/[@]rtems_api[@]/4.11/g" > i586-pc-freebsd7.3-binutils.spec.in
> "/[@]PATCH/d" i586-pc-freebsd7.3-binutils.spec.in | ../../specstrip
> --prefix=/opt/rtems-4.11 > rtems-4.11-i586-pc-freebsd7.3-binutils.spec
> | sed \
> | sed \
> "s/[@]rtems_api[@]/4.11/g" > i586-pc-freebsd7.3-gcc.spec.in
> "/[@]PATCH/d" i586-pc-freebsd7.3-gcc.spec.in | ../../specstrip
> rtems-4.11-i586-pc-freebsd7.3-gcc.spec
> Making all in freebsd8.2/i586
> `/users/rtems/src/rtems.org/test/rtems-crossrpms/freebsd8.2/i586'
> -e "s/[@]FREEBSD_VERS[@]/8.2/g" \
> -e "s/[@]FREEBSD_RPMREL[@]/0.20110227.0%{?dist}/g" \
>  > i586-pc-freebsd8.2-libs.spec.in
> "s/[@]tool_target[@]/i586-pc-freebsd8.2/g" -e "/^%package -n
> "/[@]PATCH/d" i586-pc-freebsd8.2-libs.spec.in | ../../specstrip
> --prefix=/opt/rtems-4.11 > rtems-4.11-i586-pc-freebsd8.2-libs.spec
> | sed -e "s/[@]tool_target[@]/i586-pc-freebsd8.2/g" -e
> "s/[@]rtems_api[@]/4.11/g" > i586-pc-freebsd8.2-binutils.spec.in
> "/[@]PATCH/d" i586-pc-freebsd8.2-binutils.spec.in | ../../specstrip
> --prefix=/opt/rtems-4.11 > rtems-4.11-i586-pc-freebsd8.2-binutils.spec
> | sed \
> | sed \
> "s/[@]rtems_api[@]/4.11/g" > i586-pc-freebsd8.2-gcc.spec.in
> "/[@]PATCH/d" i586-pc-freebsd8.2-gcc.spec.in | ../../specstrip
> rtems-4.11-i586-pc-freebsd8.2-gcc.spec
> Making all in freebsd8.2/x86_64
> `/users/rtems/src/rtems.org/test/rtems-crossrpms/freebsd8.2/x86_64'
>  > amd64-pc-freebsd8.2-libs.spec.in
> "s/[@]tool_target[@]/amd64-pc-freebsd8.2/g" -e "/^%package -n
> "/[@]PATCH/d" amd64-pc-freebsd8.2-libs.spec.in | ../../specstrip
> --prefix=/opt/rtems-4.11 > rtems-4.11-amd64-pc-freebsd8.2-libs.spec
> | sed -e "s/[@]tool_target[@]/amd64-pc-freebsd8.2/g" -e
> "s/[@]rtems_api[@]/4.11/g" > amd64-pc-freebsd8.2-binutils.spec.in
> "/[@]PATCH/d" amd64-pc-freebsd8.2-binutils.spec.in | ../../specstrip
> --prefix=/opt/rtems-4.11 > rtems-4.11-amd64-pc-freebsd8.2-binutils.spec
> | sed \
> | sed \
> "s/[@]rtems_api[@]/4.11/g" > amd64-pc-freebsd8.2-gcc.spec.in
> "/[@]PATCH/d" amd64-pc-freebsd8.2-gcc.spec.in | ../../specstrip
> rtems-4.11-amd64-pc-freebsd8.2-gcc.spec
> Making all in freebsd9.0/i586
> `/users/rtems/src/rtems.org/test/rtems-crossrpms/freebsd9.0/i586'
> -e "s/[@]FREEBSD_VERS[@]/9.0/g" \
> -e "s/[@]FREEBSD_RPMREL[@]/0.20120112.0%{?dist}/g" \
>  > i586-pc-freebsd9.0-libs.spec.in
> "s/[@]tool_target[@]/i586-pc-freebsd9.0/g" -e "/^%package -n
> "/[@]PATCH/d" i586-pc-freebsd9.0-libs.spec.in | ../../specstrip
> --prefix=/opt/rtems-4.11 > rtems-4.11-i586-pc-freebsd9.0-libs.spec
> | sed -e "s/[@]tool_target[@]/i586-pc-freebsd9.0/g" -e
> "s/[@]rtems_api[@]/4.11/g" > i586-pc-freebsd9.0-binutils.spec.in
> "/[@]PATCH/d" i586-pc-freebsd9.0-binutils.spec.in | ../../specstrip
> --prefix=/opt/rtems-4.11 > rtems-4.11-i586-pc-freebsd9.0-binutils.spec
> | sed \
> | sed \
> "s/[@]rtems_api[@]/4.11/g" > i586-pc-freebsd9.0-gcc.spec.in
> "/[@]PATCH/d" i586-pc-freebsd9.0-gcc.spec.in | ../../specstrip
> rtems-4.11-i586-pc-freebsd9.0-gcc.spec
> Making all in freebsd9.0/x86_64
> `/users/rtems/src/rtems.org/test/rtems-crossrpms/freebsd9.0/x86_64'
> -e "s/[@]FREEBSD_RPMREL[@]/0.20120111.0%{?dist}/g" \
>  > amd64-pc-freebsd9.0-libs.spec.in
> "s/[@]tool_target[@]/amd64-pc-freebsd9.0/g" -e "/^%package -n
> "/[@]PATCH/d" amd64-pc-freebsd9.0-libs.spec.in | ../../specstrip
> --prefix=/opt/rtems-4.11 > rtems-4.11-amd64-pc-freebsd9.0-libs.spec
> | sed -e "s/[@]tool_target[@]/amd64-pc-freebsd9.0/g" -e
> "s/[@]rtems_api[@]/4.11/g" > amd64-pc-freebsd9.0-binutils.spec.in
> "/[@]PATCH/d" amd64-pc-freebsd9.0-binutils.spec.in | ../../specstrip
> --prefix=/opt/rtems-4.11 > rtems-4.11-amd64-pc-freebsd9.0-binutils.spec
> | sed \
> | sed \
> "s/[@]rtems_api[@]/4.11/g" > amd64-pc-freebsd9.0-gcc.spec.in
> "/[@]PATCH/d" amd64-pc-freebsd9.0-gcc.spec.in | ../../specstrip
> rtems-4.11-amd64-pc-freebsd9.0-gcc.spec
> Making all in netbsd5.1/i386
> `/users/rtems/src/rtems.org/test/rtems-crossrpms/netbsd5.1/i386'
> -e "s/[@]NETBSD_VERS[@]/5.1/g" \
> -e "s/[@]NETBSD_RPMREL[@]/0.20110320.0%{?dist}/g" \
> -e "s,%{gcc_rpmvers},%{netbsd_rpmvers},g" \
>  > i386-pc-netbsdelf5.1-libs.spec.in
> "s/[@]tool_target[@]/i386-pc-netbsdelf5.1/g" -e "/^%package -n
> "/[@]PATCH/d" i386-pc-netbsdelf5.1-libs.spec.in | ../../specstrip
> --prefix=/opt/rtems-4.11 > rtems-4.11-i386-pc-netbsdelf5.1-libs.spec
> | sed -e "s/[@]tool_target[@]/i386-pc-netbsdelf5.1/g" -e
> "s/[@]rtems_api[@]/4.11/g" > i386-pc-netbsdelf5.1-binutils.spec.in
> "/[@]PATCH/d" i386-pc-netbsdelf5.1-binutils.spec.in | ../../specstrip
> --prefix=/opt/rtems-4.11 > rtems-4.11-i386-pc-netbsdelf5.1-binutils.spec
> ../../gcc/base-gfortran.add ../../gcc/target-objc.add | sed \
> "s/[@]rtems_api[@]/4.11/g" > i386-pc-netbsdelf5.1-gcc.spec.in
> "/[@]PATCH/d" i386-pc-netbsdelf5.1-gcc.spec.in | ../../specstrip
> --prefix=/opt/rtems-4.11 --languages=c,cxx,fortran,objc >
> rtems-4.11-i386-pc-netbsdelf5.1-gcc.spec
> Making all in netbsd5.1/x86_64
> `/users/rtems/src/rtems.org/test/rtems-crossrpms/netbsd5.1/x86_64'
>  > amd64-pc-netbsdelf5.1-libs.spec.in
> "s/[@]tool_target[@]/amd64-pc-netbsdelf5.1/g" -e "/^%package -n
> "/[@]PATCH/d" amd64-pc-netbsdelf5.1-libs.spec.in | ../../specstrip
> --prefix=/opt/rtems-4.11 > rtems-4.11-amd64-pc-netbsdelf5.1-libs.spec
> | sed -e "s/[@]tool_target[@]/amd64-pc-netbsdelf5.1/g" -e
> "s/[@]rtems_api[@]/4.11/g" > amd64-pc-netbsdelf5.1-binutils.spec.in
> "/[@]PATCH/d" amd64-pc-netbsdelf5.1-binutils.spec.in | ../../specstrip
> --prefix=/opt/rtems-4.11 > rtems-4.11-amd64-pc-netbsdelf5.1-binutils.spec
> "s/[@]rtems_api[@]/4.11/g" > amd64-pc-netbsdelf5.1-gcc.spec.in
> "/[@]PATCH/d" amd64-pc-netbsdelf5.1-gcc.spec.in | ../../specstrip
> rtems-4.11-amd64-pc-netbsdelf5.1-gcc.spec
> Making all in cygwin/i686
> `/users/rtems/src/rtems.org/test/rtems-crossrpms/cygwin/i686'
> -e "s/[@]CYGWIN_VERS[@]/1.7.13-1/g" \
> -e "s/[@]CYGWIN_RPMREL[@]/0.20120413.0%{?dist}/g" \
> -e "s,%{gcc_rpmvers},%{cygwin_rpmvers},g" \
> | sed -e "s/[@]tool_target[@]/i686-pc-cygwin/g" -e
> "s/[@]rtems_api[@]/4.11/g" > i686-pc-cygwin-libs.spec.in
> "s/[@]tool_target[@]/i686-pc-cygwin/g" -e "/^%package -n
> "/[@]PATCH/d" i686-pc-cygwin-libs.spec.in | ../../specstrip
> --prefix=/opt/rtems-4.11 > rtems-4.11-i686-pc-cygwin-libs.spec
> cat ../../common/common.add ./cloog-ppl.add ../../gcc/rpm-install.add
> ../../common/clean.add ./target-cloog-ppl.add | sed \
> -e "s/[@]CLOOG_PPL_VERS[@]/0.15.7-1/g" \
> -e "s/[@]CLOOG_PPL_RPMREL[@]/0.20100204.0%{?dist}/g" \
> -e "s,%{gcc_rpmvers},%{cloog_ppl_rpmvers},g" \
> "s/[@]rtems_api[@]/4.11/g" > i686-pc-cygwin-cloog-ppl.spec.in
> "/[@]PATCH/d" i686-pc-cygwin-cloog-ppl.spec.in | ../../specstrip
> --prefix=/opt/rtems-4.11 > rtems-4.11-i686-pc-cygwin-cloog-ppl.spec
> cat ../../common/common.add ./w32api.add ../../gcc/rpm-install.add
> ../../common/clean.add ./target-w32api.add | sed \
> -e "s/[@]W32API_VERS[@]/3.17-2/g" \
> -e "s/[@]W32API_RPMREL[@]/0.20110427.0%{?dist}/g" \
> -e "s,%{gcc_rpmvers},%{w32api_rpmvers},g" \
> "s/[@]rtems_api[@]/4.11/g" > i686-pc-cygwin-w32api.spec.in
> "/[@]PATCH/d" i686-pc-cygwin-w32api.spec.in | ../../specstrip
> --prefix=/opt/rtems-4.11 > rtems-4.11-i686-pc-cygwin-w32api.spec
> cat ../../common/common.add ./ncurses.add ../../gcc/rpm-install.add
> ../../common/clean.add ./target-ncurses.add | sed \
> -e "s/[@]NCURSES_VERS[@]/5.7-18/g" \
> -e "s/[@]NCURSES_RPMREL[@]/0.20100204.0%{?dist}/g" \
> -e "s,%{gcc_rpmvers},%{ncurses_rpmvers},g" \
> "s/[@]rtems_api[@]/4.11/g" > i686-pc-cygwin-ncurses.spec.in
> "/[@]PATCH/d" i686-pc-cygwin-ncurses.spec.in | ../../specstrip
> --prefix=/opt/rtems-4.11 > rtems-4.11-i686-pc-cygwin-ncurses.spec
> cat ../../common/common.add ./expat.add ../../gcc/rpm-install.add
> ../../common/clean.add ./target-expat.add | sed \
> -e "s/[@]EXPAT_VERS[@]/2.0.1-1/g" \
> -e "s/[@]EXPAT_RPMREL[@]/0.20090903.0%{?dist}/g" \
> -e "s,%{gcc_rpmvers},%{expat_rpmvers},g" \
> "s/[@]rtems_api[@]/4.11/g" > i686-pc-cygwin-expat.spec.in
> "/[@]PATCH/d" i686-pc-cygwin-expat.spec.in | ../../specstrip
> --prefix=/opt/rtems-4.11 > rtems-4.11-i686-pc-cygwin-expat.spec
> cat ../../common/common.add ./readline.add ../../gcc/rpm-install.add
> ../../common/clean.add ./target-readline.add | sed \
> -e "s/[@]READLINE_VERS[@]/6.1.2-2/g" \
> -e "s/[@]READLINE_RPMREL[@]/0.20111214.0%{?dist}/g" \
> -e "s,%{gcc_rpmvers},%{readline_rpmvers},g" \
> "s/[@]rtems_api[@]/4.11/g" > i686-pc-cygwin-readline.spec.in
> "/[@]PATCH/d" i686-pc-cygwin-readline.spec.in | ../../specstrip
> --prefix=/opt/rtems-4.11 > rtems-4.11-i686-pc-cygwin-readline.spec
> cat ../../common/common.add ./termcap.add ../../gcc/rpm-install.add
> ../../common/clean.add ./target-termcap.add | sed \
> -e "s/[@]TERMCAP_VERS[@]/20050421-1/g" \
> -e "s/[@]TERMCAP_RPMREL[@]/0.20090827.0%{?dist}/g" \
> -e "s,%{gcc_rpmvers},%{termcap_rpmvers},g" \
> "s/[@]rtems_api[@]/4.11/g" > i686-pc-cygwin-termcap.spec.in
> "/[@]PATCH/d" i686-pc-cygwin-termcap.spec.in | ../../specstrip
> --prefix=/opt/rtems-4.11 > rtems-4.11-i686-pc-cygwin-termcap.spec
> cat ../../common/common.add ./terminfo.add ../../gcc/rpm-install.add
> ../../common/clean.add ./target-terminfo.add | sed \
> -e "s/[@]TERMINFO_VERS[@]/5.7_20091114-14/g" \
> -e "s/[@]TERMINFO_RPMREL[@]/0.20100726.0%{?dist}/g" \
> -e "s,%{gcc_rpmvers},%{terminfo_rpmvers},g" \
> "s/[@]rtems_api[@]/4.11/g" > i686-pc-cygwin-terminfo.spec.in
> "/[@]PATCH/d" i686-pc-cygwin-terminfo.spec.in | ../../specstrip
> --prefix=/opt/rtems-4.11 > rtems-4.11-i686-pc-cygwin-terminfo.spec
> cat ../../common/common.add ./zlib.add ../../gcc/rpm-install.add
> ../../common/clean.add ./target-zlib.add | sed \
> -e "s/[@]ZLIB_VERS[@]/1.2.5-1/g" \
> -e "s/[@]ZLIB_RPMREL[@]/0.20110427.0%{?dist}/g" \
> -e "s,%{gcc_rpmvers},%{zlib_rpmvers},g" \
> "s/[@]rtems_api[@]/4.11/g" > i686-pc-cygwin-zlib.spec.in
> "/[@]PATCH/d" i686-pc-cygwin-zlib.spec.in | ../../specstrip
> --prefix=/opt/rtems-4.11 > rtems-4.11-i686-pc-cygwin-zlib.spec
> cat ../../common/common.add ./gmp.add ../../gcc/rpm-install.add
> ../../common/clean.add ./target-gmp.add | sed \
> -e "s/[@]GMP_VERS[@]/4.3.2-1/g" \
> -e "s/[@]GMP_RPMREL[@]/0.20120413.0%{?dist}/g" \
> -e "s,%{gcc_rpmvers},%{gmp_rpmvers},g" \
> "s/[@]rtems_api[@]/4.11/g" > i686-pc-cygwin-gmp.spec.in
> "/[@]PATCH/d" i686-pc-cygwin-gmp.spec.in | ../../specstrip
> --prefix=/opt/rtems-4.11 > rtems-4.11-i686-pc-cygwin-gmp.spec
> cat ../../common/common.add ./mpc.add ../../gcc/rpm-install.add
> ../../common/clean.add ./target-mpc.add | sed \
> -e "s/[@]MPC_VERS[@]/0.8-1/g" \
> -e "s/[@]MPC_RPMREL[@]/0.20100322.0%{?dist}/g" \
> -e "s,%{gcc_rpmvers},%{mpc_rpmvers},g" \
> "s/[@]rtems_api[@]/4.11/g" > i686-pc-cygwin-mpc.spec.in
> "/[@]PATCH/d" i686-pc-cygwin-mpc.spec.in | ../../specstrip
> --prefix=/opt/rtems-4.11 > rtems-4.11-i686-pc-cygwin-mpc.spec
> cat ../../common/common.add ./mpfr.add ../../gcc/rpm-install.add
> ../../common/clean.add ./target-mpfr.add | sed \
> -e "s/[@]MPFR_VERS[@]/2.4.1-4/g" \
> -e "s/[@]MPFR_RPMREL[@]/0.20100204.0%{?dist}/g" \
> -e "s,%{gcc_rpmvers},%{mpfr_rpmvers},g" \
> "s/[@]rtems_api[@]/4.11/g" > i686-pc-cygwin-mpfr.spec.in
> "/[@]PATCH/d" i686-pc-cygwin-mpfr.spec.in | ../../specstrip
> --prefix=/opt/rtems-4.11 > rtems-4.11-i686-pc-cygwin-mpfr.spec
> "s/[@]rtems_api[@]/4.11/g" \
> -e "s/[@]BINUTILS_VERS[@]/2.21.53-2/g" \
> -e "s/[@]BINUTILS_PKGVERS[@]/2.21.53-2/g" \
> -e "s/[@]BINUTILS_RPMREL[@]/0.20120413.0%{?dist}/g" \
>  > i686-pc-cygwin-binutils.spec.in
> "/[@]PATCH/d" i686-pc-cygwin-binutils.spec.in | ../../specstrip
> --prefix=/opt/rtems-4.11 --disable-infos >
> rtems-4.11-i686-pc-cygwin-binutils.spec
> -e "s/[@]GCC_VERS[@]/3.4.4/g" \
> -e "s/[@]GCC_PKGVERS[@]/3.4.4/g" \
> -e "s/[@]GCC_RPMREL[@]/0.20110310.0%{?dist}/g" \
> -e "/^BuildRequ.*[@]tool_target[@]-w32api-sys-root/d" \
> -e "s,[@]tool_target[@]-w32api-sys-root, at tool_target@-w32api," \
> "s/[@]rtems_api[@]/4.11/g" > i686-pc-cygwin-gcc.spec.in
> "/[@]PATCH/d" i686-pc-cygwin-gcc.spec.in | ../../specstrip
> --prefix=/opt/rtems-4.11 --languages=c,cxx --disable-infos >
> rtems-4.11-i686-pc-cygwin-gcc.spec
> Making all in mingw32/i686
> `/users/rtems/src/rtems.org/test/rtems-crossrpms/mingw32/i686'
> "s/[@]tool_target[@]/i686-w64-mingw32/g" -e "/^%package -n
> "/[@]PATCH/d" mingw-gmp.spec.in | ../../specstrip
> --prefix=/opt/rtems-4.11 > mingw-gmp.spec
> "/[@]PATCH/d" mingw32-binutils-helper.spec.in | ../../specstrip
> --prefix=/opt/rtems-4.11 > rtems-4.11-mingw32-binutils-helper.spec
> "/[@]PATCH/d" mingw32-curses-helper.spec.in | ../../specstrip
> --prefix=/opt/rtems-4.11 > rtems-4.11-mingw32-curses-helper.spec
> "/[@]PATCH/d" mingw32-expat-helper.spec.in | ../../specstrip
> --prefix=/opt/rtems-4.11 > rtems-4.11-mingw32-expat-helper.spec
> "/[@]PATCH/d" mingw32-gcc-helper.spec.in | ../../specstrip
> --prefix=/opt/rtems-4.11 > rtems-4.11-mingw32-gcc-helper.spec
> "/[@]PATCH/d" mingw32-gmp-helper.spec.in | ../../specstrip
> --prefix=/opt/rtems-4.11 > rtems-4.11-mingw32-gmp-helper.spec
> "/[@]PATCH/d" mingw32-libs-helper.spec.in | ../../specstrip
> --prefix=/opt/rtems-4.11 > rtems-4.11-mingw32-libs-helper.spec
> "/[@]PATCH/d" mingw32-mpc-helper.spec.in | ../../specstrip
> --prefix=/opt/rtems-4.11 > rtems-4.11-mingw32-mpc-helper.spec
> "/[@]PATCH/d" mingw32-mpfr-helper.spec.in | ../../specstrip
> --prefix=/opt/rtems-4.11 > rtems-4.11-mingw32-mpfr-helper.spec
> "/[@]PATCH/d" mingw32-readline-helper.spec.in | ../../specstrip
> --prefix=/opt/rtems-4.11 > rtems-4.11-mingw32-readline-helper.spec
> "/[@]PATCH/d" mingw32-termcap-helper.spec.in | ../../specstrip
> --prefix=/opt/rtems-4.11 > rtems-4.11-mingw32-termcap-helper.spec
> "/[@]PATCH/d" mingw32-zlib-helper.spec.in | ../../specstrip
> --prefix=/opt/rtems-4.11 > rtems-4.11-mingw32-zlib-helper.spec
> Making all in mingw32/x86_64
> `/users/rtems/src/rtems.org/test/rtems-crossrpms/mingw32/x86_64'
> "s/[@]tool_target[@]/x86_64-w64-mingw32/g" -e "/^%package -n
> "/[@]PATCH/d" mingw64-binutils-helper.spec.in | ../../specstrip
> --prefix=/opt/rtems-4.11 > rtems-4.11-mingw64-binutils-helper.spec
> "/[@]PATCH/d" mingw64-curses-helper.spec.in | ../../specstrip
> --prefix=/opt/rtems-4.11 > rtems-4.11-mingw64-curses-helper.spec
> "/[@]PATCH/d" mingw64-expat-helper.spec.in | ../../specstrip
> --prefix=/opt/rtems-4.11 > rtems-4.11-mingw64-expat-helper.spec
> "/[@]PATCH/d" mingw64-gcc-helper.spec.in | ../../specstrip
> --prefix=/opt/rtems-4.11 > rtems-4.11-mingw64-gcc-helper.spec
> "/[@]PATCH/d" mingw64-gmp-helper.spec.in | ../../specstrip
> --prefix=/opt/rtems-4.11 > rtems-4.11-mingw64-gmp-helper.spec
> "/[@]PATCH/d" mingw64-libs-helper.spec.in | ../../specstrip
> --prefix=/opt/rtems-4.11 > rtems-4.11-mingw64-libs-helper.spec
> "/[@]PATCH/d" mingw64-mpc-helper.spec.in | ../../specstrip
> --prefix=/opt/rtems-4.11 > rtems-4.11-mingw64-mpc-helper.spec
> "/[@]PATCH/d" mingw64-mpfr-helper.spec.in | ../../specstrip
> --prefix=/opt/rtems-4.11 > rtems-4.11-mingw64-mpfr-helper.spec
> "/[@]PATCH/d" mingw64-readline-helper.spec.in | ../../specstrip
> --prefix=/opt/rtems-4.11 > rtems-4.11-mingw64-readline-helper.spec
> "/[@]PATCH/d" mingw64-termcap-helper.spec.in | ../../specstrip
> --prefix=/opt/rtems-4.11 > rtems-4.11-mingw64-termcap-helper.spec
> "/[@]PATCH/d" mingw64-zlib-helper.spec.in | ../../specstrip
> --prefix=/opt/rtems-4.11 > rtems-4.11-mingw64-zlib-helper.spec
> Making all in solaris2.7/sparc
> `/users/rtems/src/rtems.org/test/rtems-crossrpms/solaris2.7/sparc'
> -e "s/[@]SOLARIS_VERS[@]/2.7/g" \
> -e "s/[@]SOLARIS_RPMREL[@]/0.20091130.1%{?dist}/g" \
> -e "s,%{gcc_rpmvers},%{solaris_rpmvers},g" \
>  > sparc-sun-solaris2.7-libs.spec.in
> "s/[@]tool_target[@]/sparc-sun-solaris2.7/g" -e "/^%package -n
> "/[@]PATCH/d" sparc-sun-solaris2.7-libs.spec.in | ../../specstrip
> --prefix=/opt/rtems-4.11 > rtems-4.11-sparc-sun-solaris2.7-libs.spec
> | sed -e "s/[@]tool_target[@]/sparc-sun-solaris2.7/g" -e
> "s/[@]rtems_api[@]/4.11/g" > sparc-sun-solaris2.7-binutils.spec.in
> "/[@]PATCH/d" sparc-sun-solaris2.7-binutils.spec.in | ../../specstrip
> --prefix=/opt/rtems-4.11 > rtems-4.11-sparc-sun-solaris2.7-binutils.spec
> | sed \
> | sed \
> -e "s/[@]GCC_VERS[@]/4.4.6/g" \
> -e "s/[@]GCC_PKGVERS[@]/4.4.6/g" \
> -e "s/[@]GCC_RPMREL[@]/0.20111123.0%{?dist}/g" \
> "s/[@]rtems_api[@]/4.11/g" > sparc-sun-solaris2.7-gcc.spec.in
> "/[@]PATCH/d" sparc-sun-solaris2.7-gcc.spec.in | ../../specstrip
> rtems-4.11-sparc-sun-solaris2.7-gcc.spec
> `/users/rtems/src/rtems.org/test/rtems-crossrpms'
> make[1]: Nothing to be done for `all-am'.
> # find -name '*spec'
> ./netbsd5.1/i386/rtems-4.11-i386-pc-netbsdelf5.1-gcc.spec
> ./netbsd5.1/i386/i386-pc-netbsdelf5.1-binutils.spec
> ./netbsd5.1/i386/i386-pc-netbsdelf5.1-gcc.spec
> ./netbsd5.1/i386/rtems-4.11-i386-pc-netbsdelf5.1-libs.spec
> ./netbsd5.1/i386/i386-pc-netbsdelf5.1-libs.spec
> ./netbsd5.1/i386/rtems-4.11-i386-pc-netbsdelf5.1-binutils.spec
> ./netbsd5.1/x86_64/rtems-4.11-amd64-pc-netbsdelf5.1-binutils.spec
> ./netbsd5.1/x86_64/rtems-4.11-amd64-pc-netbsdelf5.1-libs.spec
> ./netbsd5.1/x86_64/rtems-4.11-amd64-pc-netbsdelf5.1-gcc.spec
> ./netbsd5.1/x86_64/amd64-pc-netbsdelf5.1-libs.spec
> ./netbsd5.1/x86_64/amd64-pc-netbsdelf5.1-binutils.spec
> ./netbsd5.1/x86_64/amd64-pc-netbsdelf5.1-gcc.spec
> ./solaris2.7/sparc/sparc-sun-solaris2.7-libs.spec
> ./solaris2.7/sparc/rtems-4.11-sparc-sun-solaris2.7-gcc.spec
> ./solaris2.7/sparc/sparc-sun-solaris2.7-gcc.spec
> ./solaris2.7/sparc/sparc-sun-solaris2.7-binutils.spec
> ./solaris2.7/sparc/rtems-4.11-sparc-sun-solaris2.7-binutils.spec
> ./solaris2.7/sparc/rtems-4.11-sparc-sun-solaris2.7-libs.spec
> ./freebsd9.0/x86_64/amd64-pc-freebsd9.0-gcc.spec
> ./freebsd9.0/x86_64/amd64-pc-freebsd9.0-binutils.spec
> ./freebsd9.0/x86_64/rtems-4.11-amd64-pc-freebsd9.0-binutils.spec
> ./freebsd9.0/x86_64/rtems-4.11-amd64-pc-freebsd9.0-libs.spec
> ./freebsd9.0/x86_64/amd64-pc-freebsd9.0-libs.spec
> ./freebsd9.0/x86_64/rtems-4.11-amd64-pc-freebsd9.0-gcc.spec
> ./freebsd9.0/i586/rtems-4.11-i586-pc-freebsd9.0-gcc.spec
> ./freebsd9.0/i586/i586-pc-freebsd9.0-gcc.spec
> ./freebsd9.0/i586/rtems-4.11-i586-pc-freebsd9.0-libs.spec
> ./freebsd9.0/i586/i586-pc-freebsd9.0-libs.spec
> ./freebsd9.0/i586/rtems-4.11-i586-pc-freebsd9.0-binutils.spec
> ./freebsd9.0/i586/i586-pc-freebsd9.0-binutils.spec
> ./freebsd8.2/x86_64/amd64-pc-freebsd8.2-libs.spec
> ./freebsd8.2/x86_64/amd64-pc-freebsd8.2-binutils.spec
> ./freebsd8.2/x86_64/rtems-4.11-amd64-pc-freebsd8.2-binutils.spec
> ./freebsd8.2/x86_64/amd64-pc-freebsd8.2-gcc.spec
> ./freebsd8.2/x86_64/rtems-4.11-amd64-pc-freebsd8.2-gcc.spec
> ./freebsd8.2/x86_64/rtems-4.11-amd64-pc-freebsd8.2-libs.spec
> ./freebsd8.2/i586/rtems-4.11-i586-pc-freebsd8.2-gcc.spec
> ./freebsd8.2/i586/i586-pc-freebsd8.2-binutils.spec
> ./freebsd8.2/i586/rtems-4.11-i586-pc-freebsd8.2-binutils.spec
> ./freebsd8.2/i586/i586-pc-freebsd8.2-gcc.spec
> ./freebsd8.2/i586/rtems-4.11-i586-pc-freebsd8.2-libs.spec
> ./freebsd8.2/i586/i586-pc-freebsd8.2-libs.spec
> ./cygwin/i686/i686-pc-cygwin-readline.spec
> ./cygwin/i686/rtems-4.11-i686-pc-cygwin-expat.spec
> ./cygwin/i686/rtems-4.11-i686-pc-cygwin-cloog-ppl.spec
> ./cygwin/i686/i686-pc-cygwin-termcap.spec
> ./cygwin/i686/i686-pc-cygwin-w32api.spec
> ./cygwin/i686/i686-pc-cygwin-terminfo.spec
> ./cygwin/i686/rtems-4.11-i686-pc-cygwin-mpc.spec
> ./cygwin/i686/i686-pc-cygwin-mpfr.spec
> ./cygwin/i686/i686-pc-cygwin-cloog-ppl.spec
> ./cygwin/i686/rtems-4.11-i686-pc-cygwin-mpfr.spec
> ./cygwin/i686/rtems-4.11-i686-pc-cygwin-gcc.spec
> ./cygwin/i686/rtems-4.11-i686-pc-cygwin-ncurses.spec
> ./cygwin/i686/rtems-4.11-i686-pc-cygwin-binutils.spec
> ./cygwin/i686/i686-pc-cygwin-gmp.spec
> ./cygwin/i686/i686-pc-cygwin-zlib.spec
> ./cygwin/i686/rtems-4.11-i686-pc-cygwin-terminfo.spec
> ./cygwin/i686/rtems-4.11-i686-pc-cygwin-w32api.spec
> ./cygwin/i686/i686-pc-cygwin-expat.spec
> ./cygwin/i686/rtems-4.11-i686-pc-cygwin-gmp.spec
> ./cygwin/i686/rtems-4.11-i686-pc-cygwin-readline.spec
> ./cygwin/i686/i686-pc-cygwin-binutils.spec
> ./cygwin/i686/i686-pc-cygwin-libs.spec
> ./cygwin/i686/i686-pc-cygwin-gcc.spec
> ./cygwin/i686/i686-pc-cygwin-ncurses.spec
> ./cygwin/i686/rtems-4.11-i686-pc-cygwin-termcap.spec
> ./cygwin/i686/i686-pc-cygwin-mpc.spec
> ./cygwin/i686/rtems-4.11-i686-pc-cygwin-libs.spec
> ./cygwin/i686/rtems-4.11-i686-pc-cygwin-zlib.spec
> ./mingw32/i686/mingw32-curses-helper.spec
> ./mingw32/i686/mingw32-mpfr-helper.spec
> ./mingw32/i686/mingw32-termcap-helper.spec
> ./mingw32/i686/rtems-4.11-mingw32-mpfr-helper.spec
> ./mingw32/i686/mingw-gmp.spec
> ./mingw32/i686/rtems-4.11-mingw32-mpc-helper.spec
> ./mingw32/i686/mingw32-libs-helper.spec
> ./mingw32/i686/mingw32-gmp-helper.spec
> ./mingw32/i686/mingw32-zlib-helper.spec
> ./mingw32/i686/rtems-4.11-mingw32-libs-helper.spec
> ./mingw32/i686/rtems-4.11-mingw32-curses-helper.spec
> ./mingw32/i686/mingw32-expat-helper.spec
> ./mingw32/i686/rtems-4.11-mingw32-readline-helper.spec
> ./mingw32/i686/mingw32-gcc-helper.spec
> ./mingw32/i686/mingw-mpc.spec
> ./mingw32/i686/rtems-4.11-mingw32-binutils-helper.spec
> ./mingw32/i686/rtems-4.11-mingw32-gmp-helper.spec
> ./mingw32/i686/rtems-4.11-mingw32-termcap-helper.spec
> ./mingw32/i686/rtems-4.11-mingw32-zlib-helper.spec
> ./mingw32/i686/mingw32-mpc-helper.spec
> ./mingw32/i686/mingw32-readline-helper.spec
> ./mingw32/i686/rtems-4.11-mingw32-gcc-helper.spec
> ./mingw32/i686/rtems-4.11-mingw32-expat-helper.spec
> ./mingw32/i686/mingw-mpfr.spec
> ./mingw32/i686/mingw32-binutils-helper.spec
> ./mingw32/x86_64/rtems-4.11-mingw64-termcap-helper.spec
> ./mingw32/x86_64/rtems-4.11-mingw64-gmp-helper.spec
> ./mingw32/x86_64/mingw-gmp.spec
> ./mingw32/x86_64/rtems-4.11-mingw64-zlib-helper.spec
> ./mingw32/x86_64/mingw64-mpfr-helper.spec
> ./mingw32/x86_64/mingw64-binutils-helper.spec
> ./mingw32/x86_64/mingw-mpc.spec
> ./mingw32/x86_64/rtems-4.11-mingw64-libs-helper.spec
> ./mingw32/x86_64/mingw64-gmp-helper.spec
> ./mingw32/x86_64/mingw64-expat-helper.spec
> ./mingw32/x86_64/mingw64-libs-helper.spec
> ./mingw32/x86_64/mingw64-mpc-helper.spec
> ./mingw32/x86_64/rtems-4.11-mingw64-readline-helper.spec
> ./mingw32/x86_64/rtems-4.11-mingw64-binutils-helper.spec
> ./mingw32/x86_64/mingw64-gcc-helper.spec
> ./mingw32/x86_64/mingw64-zlib-helper.spec
> ./mingw32/x86_64/rtems-4.11-mingw64-expat-helper.spec
> ./mingw32/x86_64/rtems-4.11-mingw64-curses-helper.spec
> ./mingw32/x86_64/mingw64-termcap-helper.spec
> ./mingw32/x86_64/rtems-4.11-mingw64-mpc-helper.spec
> ./mingw32/x86_64/rtems-4.11-mingw64-mpfr-helper.spec
> ./mingw32/x86_64/rtems-4.11-mingw64-gcc-helper.spec
> ./mingw32/x86_64/mingw64-readline-helper.spec
> ./mingw32/x86_64/mingw64-curses-helper.spec
> ./mingw32/x86_64/mingw-mpfr.spec
> ./autotools/rtems-4.11-automake.spec
> ./autotools/rtems-4.11-autoconf.spec
> ./freebsd7.3/i586/rtems-4.11-i586-pc-freebsd7.3-libs.spec
> ./freebsd7.3/i586/i586-pc-freebsd7.3-binutils.spec
> ./freebsd7.3/i586/i586-pc-freebsd7.3-libs.spec
> ./freebsd7.3/i586/rtems-4.11-i586-pc-freebsd7.3-gcc.spec
> ./freebsd7.3/i586/rtems-4.11-i586-pc-freebsd7.3-binutils.spec
> ./freebsd7.3/i586/i586-pc-freebsd7.3-gcc.spec
> ./freebsd6.4/i586/i586-pc-freebsd6.4-binutils.spec
> ./freebsd6.4/i586/rtems-4.11-i586-pc-freebsd6.4-libs.spec
> ./freebsd6.4/i586/i586-pc-freebsd6.4-libs.spec
> ./freebsd6.4/i586/rtems-4.11-i586-pc-freebsd6.4-gcc.spec
> ./freebsd6.4/i586/rtems-4.11-i586-pc-freebsd6.4-binutils.spec
> ./freebsd6.4/i586/i586-pc-freebsd6.4-gcc.spec
> ./rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-gdb.spec
> ./rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-cpukit.spec
> ./rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-binutils.spec
> ./rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-gcc.spec
> ./rtems4.11/arm-eabi/rtems-4.11-arm-rtemseabi4.11-gcc.spec
> ./rtems4.11/arm-eabi/rtems-4.11-arm-rtemseabi4.11-gdb.spec
> ./rtems4.11/arm-eabi/rtems-4.11-arm-rtemseabi4.11-cpukit.spec
> ./rtems4.11/arm-eabi/rtems-4.11-arm-rtemseabi4.11-binutils.spec
> ./rtems4.11/lm32/rtems-4.11-lm32-rtems4.11-gdb.spec
> ./rtems4.11/lm32/rtems-4.11-lm32-rtems4.11-gcc.spec
> ./rtems4.11/lm32/rtems-4.11-lm32-rtems4.11-binutils.spec
> ./rtems4.11/mipstx39/rtems-4.11-mipstx39-rtems4.11-gdb.spec
> ./rtems4.11/sparc/rtems-4.11-sparc-rtems4.11-gdb.spec
> ./rtems4.11/sparc/rtems-4.11-sparc-rtems4.11-cpukit.spec
> ./rtems4.11/sparc/rtems-4.11-sparc-rtems4.11-gcc.spec
> ./rtems4.11/sparc/rtems-4.11-sparc-rtems4.11-binutils.spec
> ./rtems4.11/mips/rtems-4.11-mips-rtems4.11-binutils.spec
> ./rtems4.11/mips/rtems-4.11-mips-rtems4.11-cpukit.spec
> ./rtems4.11/mips/rtems-4.11-mips-rtems4.11-gcc.spec
> ./rtems4.11/mips/rtems-4.11-mips-rtems4.11-gdb.spec
> ./rtems4.11/m68k/rtems-4.11-m68k-rtems4.11-gdb.spec
> ./rtems4.11/m68k/rtems-4.11-m68k-rtems4.11-binutils.spec
> ./rtems4.11/m68k/rtems-4.11-m68k-rtems4.11-gcc.spec
> ./rtems4.11/m68k/rtems-4.11-m68k-rtems4.11-cpukit.spec
> ./rtems4.11/bfin/rtems-4.11-bfin-rtems4.11-binutils.spec
> ./rtems4.11/bfin/rtems-4.11-bfin-rtems4.11-gdb.spec
> ./rtems4.11/bfin/rtems-4.11-bfin-rtems4.11-gcc.spec
> ./rtems4.11/bfin/rtems-4.11-bfin-rtems4.11-cpukit.spec
> ./rtems4.11/i386/rtems-4.11-i386-rtems4.11-cpukit.spec
> ./rtems4.11/i386/rtems-4.11-i386-rtems4.11-gcc.spec
> ./rtems4.11/i386/rtems-4.11-i386-rtems4.11-gdb.spec
> ./rtems4.11/i386/rtems-4.11-i386-rtems4.11-binutils.spec
> ./rtems4.11/sparc64/rtems-4.11-sparc64-rtems4.11-binutils.spec
> ./rtems4.11/sparc64/rtems-4.11-sparc64-rtems4.11-gcc.spec
> ./rtems4.11/sparc64/rtems-4.11-sparc64-rtems4.11-gdb.spec
> ./rtems4.11/m32r/rtems-4.11-m32r-rtems4.11-gcc.spec
> ./rtems4.11/m32r/rtems-4.11-m32r-rtems4.11-gdb.spec
> ./rtems4.11/m32r/rtems-4.11-m32r-rtems4.11-cpukit.spec
> ./rtems4.11/m32r/rtems-4.11-m32r-rtems4.11-binutils.spec
> ./rtems4.11/m32c/rtems-4.11-m32c-rtems4.11-binutils.spec
> ./rtems4.11/m32c/rtems-4.11-m32c-rtems4.11-gdb.spec
> ./rtems4.11/m32c/rtems-4.11-m32c-rtems4.11-cpukit.spec
> ./rtems4.11/m32c/rtems-4.11-m32c-rtems4.11-gcc.spec
> ./rtems4.11/sh/rtems-4.11-sh-rtems4.11-gcc.spec
> ./rtems4.11/sh/rtems-4.11-sh-rtems4.11-binutils.spec
> ./rtems4.11/sh/rtems-4.11-sh-rtems4.11-gdb.spec
> ./rtems4.11/sh/rtems-4.11-sh-rtems4.11-cpukit.spec
> ./rtems4.11/h8300/rtems-4.11-h8300-rtems4.11-gdb.spec
> ./rtems4.11/h8300/rtems-4.11-h8300-rtems4.11-gcc.spec
> ./rtems4.11/h8300/rtems-4.11-h8300-rtems4.11-binutils.spec
> ./rtems4.11/h8300/rtems-4.11-h8300-rtems4.11-cpukit.spec
> ./rtems4.11/avr/rtems-4.11-avr-rtems4.11-cpukit.spec
> ./rtems4.11/avr/rtems-4.11-avr-rtems4.11-binutils.spec
> ./rtems4.11/avr/rtems-4.11-avr-rtems4.11-gcc.spec
> ./rtems4.11/avr/rtems-4.11-avr-rtems4.11-gdb.spec
> ./rtems4.11/microblaze/rtems-4.11-microblaze-rtems4.11-gcc.spec
> ./rtems4.11/microblaze/rtems-4.11-microblaze-rtems4.11-binutils.spec
> ./rtems4.11/microblaze/rtems-4.11-microblaze-rtems4.11-gdb.spec
>  > You have a
>> bug in the aclocal.m4 m4 stuff you use.
> None that I am aware about.
> There is a minor issue arm-eabi's handling in configure, which I am
> likely going to remove pretty soon.
>> I also think the removal of the rtems4.11/arm directory is childish.
> I was following Sebastian's and Thomas's wish, they had repeatedly been
> nagging me with for ca. a years.
> This time, I gave in resistance and followed.
>> You
>> were clearly asked to change rtems4.11/arm to EABI, not to remove it.
> Chris, I have no idea what I shall answer to this.
> Let me reiterate:
> Upstream GCC has abandoned all targets which do not match 'arm-*-*eabi*'
> and wants all target to use a target tuple matching the wildcard pattern
> 'arm-*-*eabi*'.
> I.e. RTEMS is not permitted to use "arm-rtems" for RTEMS "arm-eabi",
> because this contradicts upstream's intention. Apparently, they want a
> clear separation and break between arm-elf and arm-eabi.
> Ralf
