[PATCH 33.3 4/5] LEON3: Network initialization code updated to new AMBAPP layer
Sun Apr 15 18:40:14 UTC 2012
Looks ok.
On Tue, Apr 10, 2012 at 7:33 AM, Daniel Hellstrom <daniel at gaisler.com> wrote:
> Updated SMC91111, GRETH and open_eth driver registration
> code to use new AMBAPP Layer.
> Signed-off-by: Daniel Hellstrom <daniel at gaisler.com>
>  .../lib/libbsp/sparc/leon3/leon_greth/leon_greth.c |   16 +++++----
>  .../sparc/leon3/leon_open_eth/leon_open_eth.c      |   35 +++++++++-----------
>  .../sparc/leon3/leon_smc91111/leon_smc91111.c      |   24 +++++++------
>  3 files changed, 38 insertions(+), 37 deletions(-)
> diff --git a/c/src/lib/libbsp/sparc/leon3/leon_greth/leon_greth.c b/c/src/lib/libbsp/sparc/leon3/leon_greth/leon_greth.c
> index 5641575..4c4c0b1 100644
> --- a/c/src/lib/libbsp/sparc/leon3/leon_greth/leon_greth.c
> +++ b/c/src/lib/libbsp/sparc/leon3/leon_greth/leon_greth.c
> @@ -31,17 +31,19 @@ int rtems_leon_greth_driver_attach(
>   int attach
> -  int device_found = 0;
>   unsigned int base_addr = 0; /* avoid warnings */
>   unsigned int eth_irq = 0;   /* avoid warnings */
> -       amba_apb_device apbgreth;
> +  struct ambapp_dev *adev;
> +  struct ambapp_apb_info *apb;
>   /* Scan for MAC AHB slave interface */
> -       device_found = amba_find_apbslv(&amba_conf,VENDOR_GAISLER,GAISLER_ETHMAC,&apbgreth);
> -  if (device_found == 1)
> -               base_addr = apbgreth.start;
> -               eth_irq = apbgreth.irq;
> +  adev = (void *)ambapp_for_each(&ambapp_plb, (OPTIONS_ALL|OPTIONS_APB_SLVS),
> +                                 VENDOR_GAISLER, GAISLER_ETHMAC,
> +                                 ambapp_find_by_idx, NULL);
> +  if (adev) {
> +    apb = DEV_TO_APB(adev);
> +    base_addr = apb->start;
> +    eth_irq = apb->irq;
>     /* clear control register and reset NIC */
>     *(volatile int *) base_addr = 0;
> diff --git a/c/src/lib/libbsp/sparc/leon3/leon_open_eth/leon_open_eth.c b/c/src/lib/libbsp/sparc/leon3/leon_open_eth/leon_open_eth.c
> index 5799f83..a6bb848 100644
> --- a/c/src/lib/libbsp/sparc/leon3/leon_open_eth/leon_open_eth.c
> +++ b/c/src/lib/libbsp/sparc/leon3/leon_open_eth/leon_open_eth.c
> @@ -31,31 +31,27 @@ int rtems_leon_open_eth_driver_attach(
>   int attach
> -  int i;
> -  unsigned int conf, iobar;
> +  struct ambapp_ahb_info *ahb;
> -  for (i = 0; i < amba_conf.ahbslv.devnr; i++)
> -    conf = amba_get_confword(amba_conf.ahbslv, i, 0);
> -    if (((amba_vendor(conf) == VENDOR_OPENCORES) && (amba_device(conf) == OPENCORES_ETHMAC)) ||
> -        ((amba_vendor(conf) == VENDOR_GAISLER) && (amba_device(conf) == GAISLER_ETHAHB)))
> -      iobar = amba_ahb_get_membar(amba_conf.ahbslv, i, 0);
> -      base_addr = amba_iobar_start(LEON3_IO_AREA, iobar);
> -      eth_irq = amba_irq(conf);
> -      device_found = 1;
> -      break;
> +  adev = (void *)ambapp_for_each(&ambapp_plb, (OPTIONS_ALL|OPTIONS_AHB_SLVS),
> +                                 VENDOR_OPENCORES, OPENCORES_ETHMAC,
> +  if (!adev) {
> +                                   VENDOR_GAISLER, GAISLER_ETHAHB,
> -  if (device_found)
> +  if (adev)
> +    ahb = DEV_TO_AHB(adev);
> +    base_addr = ahb->start[0];
> +    eth_irq = ahb->irq;
>     *(volatile int *) base_addr = 0x800;
> @@ -65,7 +61,8 @@ int rtems_leon_open_eth_driver_attach(
>     leon_open_eth_configuration.txd_count = TDA_COUNT;
>     leon_open_eth_configuration.rxd_count = RDA_COUNT;
>     /* enable 100 MHz operation only if cpu frequency >= 50 MHz */
> -    if (LEON3_Timer_Regs->scaler_reload >= 49) leon_open_eth_configuration.en100MHz = 1;
> +    if (LEON3_Timer_Regs->scaler_reload >= 49)
> +      leon_open_eth_configuration.en100MHz = 1;
>     if (rtems_open_eth_driver_attach( config, &leon_open_eth_configuration )) {
>       LEON_Clear_interrupt(eth_irq);
>       LEON_Unmask_interrupt(eth_irq);
> diff --git a/c/src/lib/libbsp/sparc/leon3/leon_smc91111/leon_smc91111.c b/c/src/lib/libbsp/sparc/leon3/leon_smc91111/leon_smc91111.c
> index 841c4b6..83f751d 100644
> --- a/c/src/lib/libbsp/sparc/leon3/leon_smc91111/leon_smc91111.c
> +++ b/c/src/lib/libbsp/sparc/leon3/leon_smc91111/leon_smc91111.c
> @@ -5,7 +5,7 @@
>  #include <bsp.h>
>  #include <libchip/smc91111exp.h>
>  #include <rtems/bspIo.h>
> +#include <ambapp.h>
>  #define SMC91111_BASE_ADDR (void*)0x20000300
>  #define SMC91111_BASE_IRQ  4
> @@ -32,21 +32,24 @@ rtems_smc91111_driver_attach_leon3 (struct rtems_bsdnet_ifconfig *config,
>   unsigned long addr_mctrl = 0;
>   LEON3_IOPORT_Regs_Map *io;
> +  struct ambapp_apb_info apbpio;
> +  struct ambapp_apb_info apbmctrl;
> -  amba_apb_device apbpio;
> -  amba_ahb_device apbmctrl;
> -  if ( amba_find_apbslv(&amba_conf,VENDOR_GAISLER,GAISLER_PIOPORT,&apbpio) != 1 ){
> +  if (ambapp_find_apbslv(&ambapp_plb,VENDOR_GAISLER,GAISLER_GPIO,&apbpio) != 1) {
>     printk("SMC9111_leon3: didn't find PIO\n");
>     return 0;
>   /* Find LEON2 memory controller */
> -  if ( amba_find_ahbslv(&amba_conf,VENDOR_ESA,ESA_MCTRL,&apbmctrl) != 1 ){
> +  if (ambapp_find_apbslv(&ambapp_plb,VENDOR_ESA,ESA_MCTRL,&apbmctrl) != 1) {
>     /* LEON2 memory controller not found, search for fault tolerant memory controller */
> -    if ( amba_find_ahbslv(&amba_conf,VENDOR_GAISLER,GAISLER_FTMCTRL,&apbmctrl) != 1 ) {
> -      printk("SMC9111_leon3: didn't find any memory controller\n");
> -      return 0;
> +    if (ambapp_find_apbslv(&ambapp_plb,VENDOR_GAISLER,GAISLER_FTMCTRL,&apbmctrl) != 1) {
> +      if (ambapp_find_apbslv(&ambapp_plb,VENDOR_GAISLER,GAISLER_FTSRCTRL,&apbmctrl) != 1) {
> +        if (ambapp_find_apbslv(&ambapp_plb,VENDOR_GAISLER,GAISLER_FTSRCTRL8,&apbmctrl) != 1) {
> +          printk("SMC9111_leon3: didn't find any memory controller\n");
> +          return 0;
> @@ -68,6 +71,5 @@ rtems_smc91111_driver_attach_leon3 (struct rtems_bsdnet_ifconfig *config,
>   /* Setup memory controller I/O waitstates */
>   *((volatile unsigned int *) addr_mctrl) |= 0x10f80000;       /* enable I/O area access */
> -    return _rtems_smc91111_driver_attach (config,
> -            &leon_scmv91111_configuration);
> +  return _rtems_smc91111_driver_attach (config, &leon_scmv91111_configuration);
> 1.7.0.4
> rtems-devel mailing list
> rtems-devel at rtems.org
