[PATCH 33.3 4/5] LEON3: Network initialization code updated to new AMBAPP layer
Joel Sherrill
joel.sherrill at OARcorp.com
Sun Apr 15 22:56:22 UTC 2012
Same comments as for 2/5. OK but check arg spacing.
On 04/15/2012 01:40 PM, Gedare Bloom wrote:
> Looks ok.
> On Tue, Apr 10, 2012 at 7:33 AM, Daniel Hellstrom<daniel at gaisler.com> wrote:
>> Updated SMC91111, GRETH and open_eth driver registration
>> code to use new AMBAPP Layer.
>> Signed-off-by: Daniel Hellstrom<daniel at gaisler.com>
>> .../lib/libbsp/sparc/leon3/leon_greth/leon_greth.c | 16 +++++----
>> .../sparc/leon3/leon_open_eth/leon_open_eth.c | 35 +++++++++-----------
>> .../sparc/leon3/leon_smc91111/leon_smc91111.c | 24 +++++++------
>> 3 files changed, 38 insertions(+), 37 deletions(-)
>> diff --git a/c/src/lib/libbsp/sparc/leon3/leon_greth/leon_greth.c b/c/src/lib/libbsp/sparc/leon3/leon_greth/leon_greth.c
>> index 5641575..4c4c0b1 100644
>> --- a/c/src/lib/libbsp/sparc/leon3/leon_greth/leon_greth.c
>> +++ b/c/src/lib/libbsp/sparc/leon3/leon_greth/leon_greth.c
>> @@ -31,17 +31,19 @@ int rtems_leon_greth_driver_attach(
>> int attach
>> - int device_found = 0;
>> unsigned int base_addr = 0; /* avoid warnings */
>> unsigned int eth_irq = 0; /* avoid warnings */
>> - amba_apb_device apbgreth;
>> + struct ambapp_dev *adev;
>> + struct ambapp_apb_info *apb;
>> /* Scan for MAC AHB slave interface */
>> - device_found = amba_find_apbslv(&amba_conf,VENDOR_GAISLER,GAISLER_ETHMAC,&apbgreth);
>> - if (device_found == 1)
>> - base_addr = apbgreth.start;
>> - eth_irq = apbgreth.irq;
>> + adev = (void *)ambapp_for_each(&ambapp_plb, (OPTIONS_ALL|OPTIONS_APB_SLVS),
>> + VENDOR_GAISLER, GAISLER_ETHMAC,
>> + ambapp_find_by_idx, NULL);
>> + if (adev) {
>> + apb = DEV_TO_APB(adev);
>> + base_addr = apb->start;
>> + eth_irq = apb->irq;
>> /* clear control register and reset NIC */
>> *(volatile int *) base_addr = 0;
>> diff --git a/c/src/lib/libbsp/sparc/leon3/leon_open_eth/leon_open_eth.c b/c/src/lib/libbsp/sparc/leon3/leon_open_eth/leon_open_eth.c
>> index 5799f83..a6bb848 100644
>> --- a/c/src/lib/libbsp/sparc/leon3/leon_open_eth/leon_open_eth.c
>> +++ b/c/src/lib/libbsp/sparc/leon3/leon_open_eth/leon_open_eth.c
>> @@ -31,31 +31,27 @@ int rtems_leon_open_eth_driver_attach(
>> int attach
>> - int i;
>> - unsigned int conf, iobar;
>> + struct ambapp_ahb_info *ahb;
>> - for (i = 0; i< amba_conf.ahbslv.devnr; i++)
>> - conf = amba_get_confword(amba_conf.ahbslv, i, 0);
>> - if (((amba_vendor(conf) == VENDOR_OPENCORES)&& (amba_device(conf) == OPENCORES_ETHMAC)) ||
>> - ((amba_vendor(conf) == VENDOR_GAISLER)&& (amba_device(conf) == GAISLER_ETHAHB)))
>> - iobar = amba_ahb_get_membar(amba_conf.ahbslv, i, 0);
>> - base_addr = amba_iobar_start(LEON3_IO_AREA, iobar);
>> - eth_irq = amba_irq(conf);
>> - device_found = 1;
>> - break;
>> + adev = (void *)ambapp_for_each(&ambapp_plb, (OPTIONS_ALL|OPTIONS_AHB_SLVS),
>> + VENDOR_OPENCORES, OPENCORES_ETHMAC,
>> + if (!adev) {
>> + VENDOR_GAISLER, GAISLER_ETHAHB,
>> - if (device_found)
>> + if (adev)
>> + ahb = DEV_TO_AHB(adev);
>> + base_addr = ahb->start[0];
>> + eth_irq = ahb->irq;
>> *(volatile int *) base_addr = 0x800;
>> @@ -65,7 +61,8 @@ int rtems_leon_open_eth_driver_attach(
>> leon_open_eth_configuration.txd_count = TDA_COUNT;
>> leon_open_eth_configuration.rxd_count = RDA_COUNT;
>> /* enable 100 MHz operation only if cpu frequency>= 50 MHz */
>> - if (LEON3_Timer_Regs->scaler_reload>= 49) leon_open_eth_configuration.en100MHz = 1;
>> + if (LEON3_Timer_Regs->scaler_reload>= 49)
>> + leon_open_eth_configuration.en100MHz = 1;
>> if (rtems_open_eth_driver_attach( config,&leon_open_eth_configuration )) {
>> LEON_Clear_interrupt(eth_irq);
>> LEON_Unmask_interrupt(eth_irq);
>> diff --git a/c/src/lib/libbsp/sparc/leon3/leon_smc91111/leon_smc91111.c b/c/src/lib/libbsp/sparc/leon3/leon_smc91111/leon_smc91111.c
>> index 841c4b6..83f751d 100644
>> --- a/c/src/lib/libbsp/sparc/leon3/leon_smc91111/leon_smc91111.c
>> +++ b/c/src/lib/libbsp/sparc/leon3/leon_smc91111/leon_smc91111.c
>> @@ -5,7 +5,7 @@
>> #include<bsp.h>
>> #include<libchip/smc91111exp.h>
>> #include<rtems/bspIo.h>
>> +#include<ambapp.h>
>> #define SMC91111_BASE_ADDR (void*)0x20000300
>> #define SMC91111_BASE_IRQ 4
>> @@ -32,21 +32,24 @@ rtems_smc91111_driver_attach_leon3 (struct rtems_bsdnet_ifconfig *config,
>> unsigned long addr_mctrl = 0;
>> LEON3_IOPORT_Regs_Map *io;
>> + struct ambapp_apb_info apbpio;
>> + struct ambapp_apb_info apbmctrl;
>> - amba_apb_device apbpio;
>> - amba_ahb_device apbmctrl;
>> - if ( amba_find_apbslv(&amba_conf,VENDOR_GAISLER,GAISLER_PIOPORT,&apbpio) != 1 ){
>> + if (ambapp_find_apbslv(&ambapp_plb,VENDOR_GAISLER,GAISLER_GPIO,&apbpio) != 1) {
>> printk("SMC9111_leon3: didn't find PIO\n");
>> return 0;
>> /* Find LEON2 memory controller */
>> - if ( amba_find_ahbslv(&amba_conf,VENDOR_ESA,ESA_MCTRL,&apbmctrl) != 1 ){
>> + if (ambapp_find_apbslv(&ambapp_plb,VENDOR_ESA,ESA_MCTRL,&apbmctrl) != 1) {
>> /* LEON2 memory controller not found, search for fault tolerant memory controller */
>> - if ( amba_find_ahbslv(&amba_conf,VENDOR_GAISLER,GAISLER_FTMCTRL,&apbmctrl) != 1 ) {
>> - printk("SMC9111_leon3: didn't find any memory controller\n");
>> - return 0;
>> + if (ambapp_find_apbslv(&ambapp_plb,VENDOR_GAISLER,GAISLER_FTMCTRL,&apbmctrl) != 1) {
>> + if (ambapp_find_apbslv(&ambapp_plb,VENDOR_GAISLER,GAISLER_FTSRCTRL,&apbmctrl) != 1) {
>> + if (ambapp_find_apbslv(&ambapp_plb,VENDOR_GAISLER,GAISLER_FTSRCTRL8,&apbmctrl) != 1) {
>> + printk("SMC9111_leon3: didn't find any memory controller\n");
>> + return 0;
>> @@ -68,6 +71,5 @@ rtems_smc91111_driver_attach_leon3 (struct rtems_bsdnet_ifconfig *config,
>> /* Setup memory controller I/O waitstates */
>> *((volatile unsigned int *) addr_mctrl) |= 0x10f80000; /* enable I/O area access */
>> - return _rtems_smc91111_driver_attach (config,
>> -&leon_scmv91111_configuration);
>> + return _rtems_smc91111_driver_attach (config,&leon_scmv91111_configuration);
>> 1.7.0.4
>> rtems-devel mailing list
>> rtems-devel at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-devel
