[PATCH 33.2 3/5] LEON3: updated console driver for new AMBAPP layer
Sun Apr 15 18:53:26 UTC 2012
This seems ok. I found BSP_NUMBER_OF_TERMIOS_PORTS a little
confusing--does it have any relation with
CONFIGURE_NUMBER_OF_TERMIOS_PORTS or just is it similar in name?
-Gedare
On Tue, Apr 10, 2012 at 7:33 AM, Daniel Hellstrom <daniel at gaisler.com> wrote:
> Signed-off-by: Daniel Hellstrom <daniel at gaisler.com>
>  c/src/lib/libbsp/sparc/leon3/amba/amba.c         |    5 --
>  c/src/lib/libbsp/sparc/leon3/console/console.c   |   51 +++++++++++++++++++---
>  c/src/lib/libbsp/sparc/leon3/console/debugputs.c |   42 ++++++++---------
>  c/src/lib/libbsp/sparc/leon3/include/amba.h      |    1 -
>  c/src/lib/libbsp/sparc/leon3/include/bsp.h       |    3 +
>  c/src/lib/libbsp/sparc/leon3/include/leon.h      |    7 ---
>  c/src/lib/libbsp/sparc/leon3/startup/bspstart.c  |    9 +++-
>  7 files changed, 75 insertions(+), 43 deletions(-)
> diff --git a/c/src/lib/libbsp/sparc/leon3/amba/amba.c b/c/src/lib/libbsp/sparc/leon3/amba/amba.c
> index e41d0aa..60281f3 100644
> --- a/c/src/lib/libbsp/sparc/leon3/amba/amba.c
> +++ b/c/src/lib/libbsp/sparc/leon3/amba/amba.c
> @@ -39,8 +39,6 @@ volatile LEON3_IrqCtrl_Regs_Map *LEON3_IrqCtrl_Regs;
>  *  amba_ahb_masters, amba_ahb_slaves and amba.
> -extern int scan_uarts(void);
>  void amba_initialize(void)
>   int icsel;
> @@ -95,7 +93,4 @@ void amba_initialize(void)
>     ambapp_freq_init(&ambapp_plb, adev,
>                      (LEON3_Timer_Regs->scaler_reload + 1) * 1000000);
> -  /* find UARTS */
> -  scan_uarts();
> diff --git a/c/src/lib/libbsp/sparc/leon3/console/console.c b/c/src/lib/libbsp/sparc/leon3/console/console.c
> index 320aa37..fa67d37 100644
> --- a/c/src/lib/libbsp/sparc/leon3/console/console.c
> +++ b/c/src/lib/libbsp/sparc/leon3/console/console.c
> @@ -62,6 +62,12 @@ extern int apbuart_inbyte_nonblocking(ambapp_apb_uart *regs);
>  /* body is in debugputs.c */
> +struct apbuart_priv {
> +  ambapp_apb_uart *regs;
> +  unsigned int freq_hz;
> +static struct apbuart_priv apbuarts[BSP_NUMBER_OF_TERMIOS_PORTS];
> +static int uarts = 0;
>  *  Console Termios Support Entry Points
> @@ -78,7 +84,7 @@ ssize_t console_write_support (int minor, const char *buf, size_t len)
>     port = minor - 1;
>   while (nwrite < len) {
> -    apbuart_outbyte_polled((ambapp_apb_uart*)LEON3_Console_Uart[port], *buf++);
> +    apbuart_outbyte_polled(apbuarts[port].regs, *buf++);
>     nwrite++;
>   return nwrite;
> @@ -93,15 +99,44 @@ int console_pollRead(int minor)
>   else
>     port = minor - 1;
> -  return apbuart_inbyte_nonblocking((ambapp_apb_uart*)LEON3_Console_Uart[port]);
> +  return apbuart_inbyte_nonblocking(apbuarts[port].regs);
> +/* AMBA PP find routine. Extract AMBA PnP information into data structure. */
> +int find_matching_apbuart(struct ambapp_dev *dev, int index, void *arg)
> +  struct ambapp_apb_info *apb = (struct ambapp_apb_info *)dev->devinfo;
> +  /* Extract needed information of one APBUART */
> +  apbuarts[uarts].regs = (ambapp_apb_uart *)apb->start;
> +  /* Get APBUART core frequency, it is assumed that it is the same
> +   * as Bus frequency where the UART is situated
> +  apbuarts[uarts].freq_hz = ambapp_freq_get(&ambapp_plb, dev);
> +  uarts++;
> +  if (uarts >= BSP_NUMBER_OF_TERMIOS_PORTS)
> +    return 1; /* Satisfied number of UARTs, stop search */
> +  else
> +    return 0; /* Continue searching for more UARTs */
> +/* Find all UARTs */
> +int console_scan_uarts(void)
> +  memset(apbuarts, 0, sizeof(apbuarts));
> +  /* Find APBUART cores */
> +  ambapp_for_each(&ambapp_plb, (OPTIONS_ALL|OPTIONS_APB_SLVS), VENDOR_GAISLER,
> +                  GAISLER_APBUART, find_matching_apbuart, NULL);
> +  return uarts;
>  *  Console Device Driver Entry Points
> -int uarts = 0;
> -volatile LEON3_UART_Regs_Map *LEON3_Console_Uart[LEON3_APBUARTS];
>  rtems_device_driver console_initialize(
>   rtems_device_major_number  major,
> @@ -115,6 +150,9 @@ rtems_device_driver console_initialize(
>   rtems_termios_initialize();
> +  /* Find UARTs */
> +  console_scan_uarts();
>   /* Update syscon_uart_index to index used as /dev/console
>    * Let user select System console by setting syscon_uart_index. If the
>    * BSP is to provide the default UART (syscon_uart_index==0):
> @@ -190,9 +228,8 @@ rtems_device_driver console_open(
>     port = minor - 1;
>   /* Initialize UART on opening */
> -  LEON3_Console_Uart[port]->ctrl |= LEON_REG_UART_CTRL_RE |
> -                                     LEON_REG_UART_CTRL_TE;
> -  LEON3_Console_Uart[port]->status = 0;
> +  apbuarts[port]->regs->ctrl |= LEON_REG_UART_CTRL_RE | LEON_REG_UART_CTRL_TE;
> +  apbuarts[port]->regs->status = 0;
>   return RTEMS_SUCCESSFUL;
> diff --git a/c/src/lib/libbsp/sparc/leon3/console/debugputs.c b/c/src/lib/libbsp/sparc/leon3/console/debugputs.c
> index 43c6d7d..c6e0648 100644
> --- a/c/src/lib/libbsp/sparc/leon3/console/debugputs.c
> +++ b/c/src/lib/libbsp/sparc/leon3/console/debugputs.c
> @@ -23,11 +23,6 @@
>  #include <assert.h>
>  #include <stdio.h>
> - * Number of uarts on AMBA bus
> -extern int uarts;
>  static int isinit = 0;
>  /* Let user override which on-chip APBUART will be debug UART
> @@ -40,24 +35,16 @@ static int isinit = 0;
>  int debug_uart_index __attribute__((weak)) = 0;
>  ambapp_apb_uart *dbg_uart = NULL;
> - *  Scan for UARTS in configuration
> +/* Initialize the BSP system debug console layer. It will scan AMBA Plu&Play
> + * for a debug APBUART and enable RX/TX for that UART.
> -int scan_uarts(void)
> +int bsp_debug_uart_init(void)
>   int i;
> -  amba_apb_device apbuarts[LEON3_APBUARTS];
> +  struct ambapp_dev *adev;
> +  struct ambapp_apb_info *apb;
>   if (isinit == 0) {
> -    i = 0;
> -    uarts = 0;
> -    uarts = amba_find_apbslvs(
> -      &amba_conf, VENDOR_GAISLER, GAISLER_APBUART, apbuarts, LEON3_APBUARTS);
> -    for(i=0; i<uarts; i++) {
> -      LEON3_Console_Uart[i] = (volatile LEON3_UART_Regs_Map *)apbuarts[i].start;
>     /* Update debug_uart_index to index used as debug console.
>      * Let user select Debug console by setting debug_uart_index. If the
>      * BSP is to provide the default UART (debug_uart_index==0):
> @@ -74,16 +61,27 @@ int scan_uarts(void)
>       debug_uart_index = debug_uart_index - 1; /* User selected dbg-console */
> -    /* initialize debug uart if present for printk */
> -    if (debug_uart_index < uarts) {
> -      dbg_uart = (ambapp_apb_uart *)LEON3_Console_Uart[debug_uart_index];
> +    /* Find APBUART core for System Debug Console */
> +    i = debug_uart_index;
> +    adev = (void *)ambapp_for_each(&ambapp_plb, (OPTIONS_ALL|OPTIONS_APB_SLVS),
> +                                   VENDOR_GAISLER, GAISLER_APBUART,
> +                                   ambapp_find_by_idx, (void *)&i);
> +    if (adev) {
> +      /* Found a matching debug console, initialize debug uart if present
> +       * for printk
> +      apb = (struct ambapp_apb_info *)adev->devinfo;
> +      dbg_uart = (ambapp_apb_uart *)apb->start;
>       dbg_uart->ctrl |= LEON_REG_UART_CTRL_RE | LEON_REG_UART_CTRL_TE;
>       dbg_uart->status = 0;
>     isinit = 1;
> -  return uarts;
> +  if (dbg_uart == NULL)
> +    return 0;
> +  else
> +    return 1;
> diff --git a/c/src/lib/libbsp/sparc/leon3/include/amba.h b/c/src/lib/libbsp/sparc/leon3/include/amba.h
> index aa13f2c..32b4a42 100644
> --- a/c/src/lib/libbsp/sparc/leon3/include/amba.h
> +++ b/c/src/lib/libbsp/sparc/leon3/include/amba.h
> @@ -25,7 +25,6 @@
>  #define LEON3_AHB_MASTERS 64
>  #define LEON3_AHB_SLAVES 64
>  #define LEON3_APB_SLAVES 16
> -#define LEON3_APBUARTS 8
>  #include <ambapp.h>
> diff --git a/c/src/lib/libbsp/sparc/leon3/include/bsp.h b/c/src/lib/libbsp/sparc/leon3/include/bsp.h
> index e5ae2c1..d883064 100644
> --- a/c/src/lib/libbsp/sparc/leon3/include/bsp.h
> +++ b/c/src/lib/libbsp/sparc/leon3/include/bsp.h
> @@ -41,6 +41,9 @@ extern "C" {
>  void *bsp_idle_thread( uintptr_t ignored );
>  #define BSP_IDLE_TASK_BODY bsp_idle_thread
> +/* Maximum supported APBUARTs by BSP */
> +#define BSP_NUMBER_OF_TERMIOS_PORTS 8
>  * Network driver configuration
> diff --git a/c/src/lib/libbsp/sparc/leon3/include/leon.h b/c/src/lib/libbsp/sparc/leon3/include/leon.h
> index 819800c..da752b2 100644
> --- a/c/src/lib/libbsp/sparc/leon3/include/leon.h
> +++ b/c/src/lib/libbsp/sparc/leon3/include/leon.h
> @@ -47,12 +47,6 @@ extern "C" {
>     (_trap) <= 0x1F )
>  typedef struct {
> -  volatile unsigned int data;
> -  volatile unsigned int status;
> -  volatile unsigned int ctrl;
> -} LEON3_UART_Regs_Map;
> -typedef struct {
>   volatile unsigned int value;
>   volatile unsigned int reload;
>   volatile unsigned int conf;
> @@ -147,7 +141,6 @@ typedef struct {
>  extern volatile LEON3_IrqCtrl_Regs_Map *LEON3_IrqCtrl_Regs;  /* LEON3 Interrupt Controller */
>  extern volatile LEON3_Timer_Regs_Map *LEON3_Timer_Regs; /* LEON3 GP Timer */
> -extern volatile LEON3_UART_Regs_Map *LEON3_Console_Uart[LEON3_APBUARTS];
>  /* LEON3 CPU Index of boot CPU */
>  extern int LEON3_Cpu_Index;
> diff --git a/c/src/lib/libbsp/sparc/leon3/startup/bspstart.c b/c/src/lib/libbsp/sparc/leon3/startup/bspstart.c
> index 9cad164..50fa5e5 100644
> --- a/c/src/lib/libbsp/sparc/leon3/startup/bspstart.c
> +++ b/c/src/lib/libbsp/sparc/leon3/startup/bspstart.c
> @@ -31,6 +31,7 @@ int CPU_SPARC_HAS_SNOOPING;
>  int LEON3_Cpu_Index = 0;
>  extern void amba_initialize(void);
> +extern void bsp_debug_uart_init(void);
>  * set_snooping
> @@ -75,6 +76,12 @@ void bsp_start( void )
>   LEON3_Cpu_Index = (get_asr17() >> 28) & 3;
> -  /* Find UARTs */
> +  /* Scan AMBA Plug&Play and parse it into a RAM description (ambapp_plb),
> +   * find GPTIMER for bus frequency, find IRQ Controller and initialize
> +   * interrupt support
>   amba_initialize();
> +  /* find debug UART for printk() */
> +  bsp_debug_uart_init();
> 1.7.0.4
> rtems-devel mailing list
> rtems-devel at rtems.org
