[PATCH 33.2 3/5] LEON3: updated console driver for new AMBAPP layer
Joel Sherrill
joel.sherrill at OARcorp.com
Sun Apr 15 23:21:01 UTC 2012
On 04/15/2012 01:53 PM, Gedare Bloom wrote:
> This seems ok. I found BSP_NUMBER_OF_TERMIOS_PORTS a little
> confusing--does it have any relation with
> CONFIGURE_NUMBER_OF_TERMIOS_PORTS or just is it similar in name?
It is intended to be the number known to be on the board
as a minimum. So rather than CONFIGURE_NUMBER_OF_TERMIOS_PORTS
defaulting to 1 when you enable console, it defaults to that
number.
It may make sense to do away with that and let the user
just fail if they under configure.
It is a component into CONFIGURE_NUMBER_OF_TERMIOS_PORTS.
Dropping it would be OK if it doesn't stop a console from
initializing at all on a board with N>1 ports when running
hello world
> -Gedare
> On Tue, Apr 10, 2012 at 7:33 AM, Daniel Hellstrom<daniel at gaisler.com> wrote:
>> Signed-off-by: Daniel Hellstrom<daniel at gaisler.com>
>> c/src/lib/libbsp/sparc/leon3/amba/amba.c | 5 --
>> c/src/lib/libbsp/sparc/leon3/console/console.c | 51 +++++++++++++++++++---
>> c/src/lib/libbsp/sparc/leon3/console/debugputs.c | 42 ++++++++---------
>> c/src/lib/libbsp/sparc/leon3/include/amba.h | 1 -
>> c/src/lib/libbsp/sparc/leon3/include/bsp.h | 3 +
>> c/src/lib/libbsp/sparc/leon3/include/leon.h | 7 ---
>> c/src/lib/libbsp/sparc/leon3/startup/bspstart.c | 9 +++-
>> 7 files changed, 75 insertions(+), 43 deletions(-)
>> diff --git a/c/src/lib/libbsp/sparc/leon3/amba/amba.c b/c/src/lib/libbsp/sparc/leon3/amba/amba.c
>> index e41d0aa..60281f3 100644
>> --- a/c/src/lib/libbsp/sparc/leon3/amba/amba.c
>> +++ b/c/src/lib/libbsp/sparc/leon3/amba/amba.c
>> @@ -39,8 +39,6 @@ volatile LEON3_IrqCtrl_Regs_Map *LEON3_IrqCtrl_Regs;
>> * amba_ahb_masters, amba_ahb_slaves and amba.
>> -extern int scan_uarts(void);
>> void amba_initialize(void)
>> int icsel;
>> @@ -95,7 +93,4 @@ void amba_initialize(void)
>> ambapp_freq_init(&ambapp_plb, adev,
>> (LEON3_Timer_Regs->scaler_reload + 1) * 1000000);
>> - /* find UARTS */
>> - scan_uarts();
>> diff --git a/c/src/lib/libbsp/sparc/leon3/console/console.c b/c/src/lib/libbsp/sparc/leon3/console/console.c
>> index 320aa37..fa67d37 100644
>> --- a/c/src/lib/libbsp/sparc/leon3/console/console.c
>> +++ b/c/src/lib/libbsp/sparc/leon3/console/console.c
>> @@ -62,6 +62,12 @@ extern int apbuart_inbyte_nonblocking(ambapp_apb_uart *regs);
>> /* body is in debugputs.c */
>> +struct apbuart_priv {
>> + ambapp_apb_uart *regs;
>> + unsigned int freq_hz;
>> +static struct apbuart_priv apbuarts[BSP_NUMBER_OF_TERMIOS_PORTS];
>> +static int uarts = 0;
>> * Console Termios Support Entry Points
>> @@ -78,7 +84,7 @@ ssize_t console_write_support (int minor, const char *buf, size_t len)
>> port = minor - 1;
>> while (nwrite< len) {
>> - apbuart_outbyte_polled((ambapp_apb_uart*)LEON3_Console_Uart[port], *buf++);
>> + apbuart_outbyte_polled(apbuarts[port].regs, *buf++);
>> nwrite++;
>> return nwrite;
>> @@ -93,15 +99,44 @@ int console_pollRead(int minor)
>> else
>> port = minor - 1;
>> - return apbuart_inbyte_nonblocking((ambapp_apb_uart*)LEON3_Console_Uart[port]);
>> + return apbuart_inbyte_nonblocking(apbuarts[port].regs);
>> +/* AMBA PP find routine. Extract AMBA PnP information into data structure. */
>> +int find_matching_apbuart(struct ambapp_dev *dev, int index, void *arg)
>> + struct ambapp_apb_info *apb = (struct ambapp_apb_info *)dev->devinfo;
>> + /* Extract needed information of one APBUART */
>> + apbuarts[uarts].regs = (ambapp_apb_uart *)apb->start;
>> + /* Get APBUART core frequency, it is assumed that it is the same
>> + * as Bus frequency where the UART is situated
>> + apbuarts[uarts].freq_hz = ambapp_freq_get(&ambapp_plb, dev);
>> + uarts++;
>> + if (uarts>= BSP_NUMBER_OF_TERMIOS_PORTS)
>> + return 1; /* Satisfied number of UARTs, stop search */
>> + else
>> + return 0; /* Continue searching for more UARTs */
>> +/* Find all UARTs */
>> +int console_scan_uarts(void)
>> + memset(apbuarts, 0, sizeof(apbuarts));
>> + /* Find APBUART cores */
>> + ambapp_for_each(&ambapp_plb, (OPTIONS_ALL|OPTIONS_APB_SLVS), VENDOR_GAISLER,
>> + GAISLER_APBUART, find_matching_apbuart, NULL);
>> + return uarts;
>> * Console Device Driver Entry Points
>> -int uarts = 0;
>> -volatile LEON3_UART_Regs_Map *LEON3_Console_Uart[LEON3_APBUARTS];
>> rtems_device_driver console_initialize(
>> rtems_device_major_number major,
>> @@ -115,6 +150,9 @@ rtems_device_driver console_initialize(
>> rtems_termios_initialize();
>> + /* Find UARTs */
>> + console_scan_uarts();
>> /* Update syscon_uart_index to index used as /dev/console
>> * Let user select System console by setting syscon_uart_index. If the
>> * BSP is to provide the default UART (syscon_uart_index==0):
>> @@ -190,9 +228,8 @@ rtems_device_driver console_open(
>> port = minor - 1;
>> /* Initialize UART on opening */
>> - LEON3_Console_Uart[port]->ctrl |= LEON_REG_UART_CTRL_RE |
>> - LEON_REG_UART_CTRL_TE;
>> - LEON3_Console_Uart[port]->status = 0;
>> + apbuarts[port]->regs->ctrl |= LEON_REG_UART_CTRL_RE | LEON_REG_UART_CTRL_TE;
>> + apbuarts[port]->regs->status = 0;
>> return RTEMS_SUCCESSFUL;
>> diff --git a/c/src/lib/libbsp/sparc/leon3/console/debugputs.c b/c/src/lib/libbsp/sparc/leon3/console/debugputs.c
>> index 43c6d7d..c6e0648 100644
>> --- a/c/src/lib/libbsp/sparc/leon3/console/debugputs.c
>> +++ b/c/src/lib/libbsp/sparc/leon3/console/debugputs.c
>> @@ -23,11 +23,6 @@
>> #include<assert.h>
>> #include<stdio.h>
>> - * Number of uarts on AMBA bus
>> -extern int uarts;
>> static int isinit = 0;
>> /* Let user override which on-chip APBUART will be debug UART
>> @@ -40,24 +35,16 @@ static int isinit = 0;
>> int debug_uart_index __attribute__((weak)) = 0;
>> ambapp_apb_uart *dbg_uart = NULL;
>> - * Scan for UARTS in configuration
>> +/* Initialize the BSP system debug console layer. It will scan AMBA Plu&Play
>> + * for a debug APBUART and enable RX/TX for that UART.
>> -int scan_uarts(void)
>> +int bsp_debug_uart_init(void)
>> int i;
>> - amba_apb_device apbuarts[LEON3_APBUARTS];
>> + struct ambapp_dev *adev;
>> + struct ambapp_apb_info *apb;
>> if (isinit == 0) {
>> - i = 0;
>> - uarts = 0;
>> - uarts = amba_find_apbslvs(
>> -&amba_conf, VENDOR_GAISLER, GAISLER_APBUART, apbuarts, LEON3_APBUARTS);
>> - for(i=0; i<uarts; i++) {
>> - LEON3_Console_Uart[i] = (volatile LEON3_UART_Regs_Map *)apbuarts[i].start;
>> /* Update debug_uart_index to index used as debug console.
>> * Let user select Debug console by setting debug_uart_index. If the
>> * BSP is to provide the default UART (debug_uart_index==0):
>> @@ -74,16 +61,27 @@ int scan_uarts(void)
>> debug_uart_index = debug_uart_index - 1; /* User selected dbg-console */
>> - /* initialize debug uart if present for printk */
>> - if (debug_uart_index< uarts) {
>> - dbg_uart = (ambapp_apb_uart *)LEON3_Console_Uart[debug_uart_index];
>> + /* Find APBUART core for System Debug Console */
>> + i = debug_uart_index;
>> + adev = (void *)ambapp_for_each(&ambapp_plb, (OPTIONS_ALL|OPTIONS_APB_SLVS),
>> + VENDOR_GAISLER, GAISLER_APBUART,
>> + ambapp_find_by_idx, (void *)&i);
>> + if (adev) {
>> + /* Found a matching debug console, initialize debug uart if present
>> + * for printk
>> + apb = (struct ambapp_apb_info *)adev->devinfo;
>> + dbg_uart = (ambapp_apb_uart *)apb->start;
>> dbg_uart->ctrl |= LEON_REG_UART_CTRL_RE | LEON_REG_UART_CTRL_TE;
>> dbg_uart->status = 0;
>> isinit = 1;
>> - return uarts;
>> + if (dbg_uart == NULL)
>> + return 0;
>> + else
>> + return 1;
>> diff --git a/c/src/lib/libbsp/sparc/leon3/include/amba.h b/c/src/lib/libbsp/sparc/leon3/include/amba.h
>> index aa13f2c..32b4a42 100644
>> --- a/c/src/lib/libbsp/sparc/leon3/include/amba.h
>> +++ b/c/src/lib/libbsp/sparc/leon3/include/amba.h
>> @@ -25,7 +25,6 @@
>> #define LEON3_AHB_MASTERS 64
>> #define LEON3_AHB_SLAVES 64
>> #define LEON3_APB_SLAVES 16
>> -#define LEON3_APBUARTS 8
>> #include<ambapp.h>
>> diff --git a/c/src/lib/libbsp/sparc/leon3/include/bsp.h b/c/src/lib/libbsp/sparc/leon3/include/bsp.h
>> index e5ae2c1..d883064 100644
>> --- a/c/src/lib/libbsp/sparc/leon3/include/bsp.h
>> +++ b/c/src/lib/libbsp/sparc/leon3/include/bsp.h
>> @@ -41,6 +41,9 @@ extern "C" {
>> void *bsp_idle_thread( uintptr_t ignored );
>> #define BSP_IDLE_TASK_BODY bsp_idle_thread
>> +/* Maximum supported APBUARTs by BSP */
>> +#define BSP_NUMBER_OF_TERMIOS_PORTS 8
>> * Network driver configuration
>> diff --git a/c/src/lib/libbsp/sparc/leon3/include/leon.h b/c/src/lib/libbsp/sparc/leon3/include/leon.h
>> index 819800c..da752b2 100644
>> --- a/c/src/lib/libbsp/sparc/leon3/include/leon.h
>> +++ b/c/src/lib/libbsp/sparc/leon3/include/leon.h
>> @@ -47,12 +47,6 @@ extern "C" {
>> (_trap)<= 0x1F )
>> typedef struct {
>> - volatile unsigned int data;
>> - volatile unsigned int status;
>> - volatile unsigned int ctrl;
>> -} LEON3_UART_Regs_Map;
>> -typedef struct {
>> volatile unsigned int value;
>> volatile unsigned int reload;
>> volatile unsigned int conf;
>> @@ -147,7 +141,6 @@ typedef struct {
>> extern volatile LEON3_IrqCtrl_Regs_Map *LEON3_IrqCtrl_Regs; /* LEON3 Interrupt Controller */
>> extern volatile LEON3_Timer_Regs_Map *LEON3_Timer_Regs; /* LEON3 GP Timer */
>> -extern volatile LEON3_UART_Regs_Map *LEON3_Console_Uart[LEON3_APBUARTS];
>> /* LEON3 CPU Index of boot CPU */
>> extern int LEON3_Cpu_Index;
>> diff --git a/c/src/lib/libbsp/sparc/leon3/startup/bspstart.c b/c/src/lib/libbsp/sparc/leon3/startup/bspstart.c
>> index 9cad164..50fa5e5 100644
>> --- a/c/src/lib/libbsp/sparc/leon3/startup/bspstart.c
>> +++ b/c/src/lib/libbsp/sparc/leon3/startup/bspstart.c
>> @@ -31,6 +31,7 @@ int CPU_SPARC_HAS_SNOOPING;
>> int LEON3_Cpu_Index = 0;
>> extern void amba_initialize(void);
>> +extern void bsp_debug_uart_init(void);
>> * set_snooping
>> @@ -75,6 +76,12 @@ void bsp_start( void )
>> LEON3_Cpu_Index = (get_asr17()>> 28)& 3;
>> - /* Find UARTs */
>> + /* Scan AMBA Plug&Play and parse it into a RAM description (ambapp_plb),
>> + * find GPTIMER for bus frequency, find IRQ Controller and initialize
>> + * interrupt support
>> amba_initialize();
>> + /* find debug UART for printk() */
>> + bsp_debug_uart_init();
>> 1.7.0.4
>> rtems-devel mailing list
>> rtems-devel at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-devel
