[PATCH 33.2 3/5] LEON3: updated console driver for new AMBAPP layer
Mon Apr 16 15:31:24 UTC 2012
On 04/16/2012 10:09 AM, Gedare Bloom wrote:
> On Mon, Apr 16, 2012 at 4:49 AM, Daniel Hellstrom<daniel at gaisler.com>  wrote:
>> On 04/16/2012 01:21 AM, Joel Sherrill wrote:
>>> On 04/15/2012 01:53 PM, Gedare Bloom wrote:
>>>> This seems ok. I found BSP_NUMBER_OF_TERMIOS_PORTS a little
>>>> confusing--does it have any relation with
>>>> CONFIGURE_NUMBER_OF_TERMIOS_PORTS or just is it similar in name?
>>> It is intended to be the number known to be on the board
>>> as a minimum. So rather than CONFIGURE_NUMBER_OF_TERMIOS_PORTS
>>> defaulting to 1 when you enable console, it defaults to that
>>> number.
>>> It may make sense to do away with that and let the user
>>> just fail if they under configure.
>>> It is a component into CONFIGURE_NUMBER_OF_TERMIOS_PORTS.
>>> Dropping it would be OK if it doesn't stop a console from
>>> initializing at all on a board with N>1 ports when running
>>> hello world
>> BSP_NUMBER_OF_TERMIOS_PORTS is the maximum number of UARTs the BSP supports.
>> CONFIGURE_NUMBER_OF_TERMIOS_PORTS is termios-internal and is not available
>> when the BSP builds?
> I believe that is the case. The big no-no is for the BSP to define
> that number itself.
Right. Consider a PC or any other board which can take add-on cards.
The BSP knows the UARTs on the base board but cannot account for
any add-ons.
For example, I know of an RTEMS application with an embedded PC
that has almost 40 serial ports.
>> Now that the bsp_early_malloc() patch has been accepted, I might change this
>> behavior in a future patch so that the private structures are allocated
>> dynamically after probing how many UARTs are available. Probably it is not
>> worth probing it, since it may take more space with the extra instructions
>> than the current excess private data. On the other hand it is one single
>> function call with the new AMBAPP layer to find the number of cores.
>> Another possibility would be if CONFIGURE_NUMBER_OF_TERMIOS_PORTS were saved
>> in a "configuration structure" I could have dynamically supported the user's
>> configuration, by using bsp_early_malloc(sizeof(priv) * config->no_ports) in
>> my UART init code... in the future :)
> Yes that might be nice. It should be in one of the configuration
> structures defined in confdefs. I'm not sure exactly what you have to
> pull in to use it, I think config.h in the sapi has those structure
> definitions.
CONFIGURE_NUMBER_OF_TERMIOS_PORTS is only used to
reserve enough RTEMS workspace so you can open all
termios ports concurrently.  This is currently the only use
since termios only uses semaphores.
#define CONFIGURE_TERMIOS_SEMAPHORES \
     ((CONFIGURE_NUMBER_OF_TERMIOS_PORTS * 4) + 1)
Daniel.. if the user has PCI and plugs in an 8-port UART board,
then your allocation of memory for those 8 ports is unnecessary.
And whether the hardware has N termios ports or not, the
application may choose not to use them all and not need
the reserved workspace.
I would lean to eliminating BSP_NUMBER_OF_TERMIOS_PORTS
>> Thanks,
>> Daniel
>>>> -Gedare
>>>> On Tue, Apr 10, 2012 at 7:33 AM, Daniel Hellstrom<daniel at gaisler.com>
>>>>   wrote:
>>>>> Signed-off-by: Daniel Hellstrom<daniel at gaisler.com>
>>>>>   c/src/lib/libbsp/sparc/leon3/amba/amba.c         |    5 --
>>>>>   c/src/lib/libbsp/sparc/leon3/console/console.c   |   51
>>>>>   c/src/lib/libbsp/sparc/leon3/console/debugputs.c |   42
>>>>>   c/src/lib/libbsp/sparc/leon3/include/amba.h      |    1 -
>>>>>   c/src/lib/libbsp/sparc/leon3/include/bsp.h       |    3 +
>>>>>   c/src/lib/libbsp/sparc/leon3/include/leon.h      |    7 ---
>>>>>   c/src/lib/libbsp/sparc/leon3/startup/bspstart.c  |    9 +++-
>>>>>   7 files changed, 75 insertions(+), 43 deletions(-)
>>>>> diff --git a/c/src/lib/libbsp/sparc/leon3/amba/amba.c
>>>>> b/c/src/lib/libbsp/sparc/leon3/amba/amba.c
>>>>> index e41d0aa..60281f3 100644
>>>>> --- a/c/src/lib/libbsp/sparc/leon3/amba/amba.c
>>>>> +++ b/c/src/lib/libbsp/sparc/leon3/amba/amba.c
>>>>> @@ -39,8 +39,6 @@ volatile LEON3_IrqCtrl_Regs_Map *LEON3_IrqCtrl_Regs;
>>>>>   *  amba_ahb_masters, amba_ahb_slaves and amba.
>>>>> -extern int scan_uarts(void);
>>>>>   void amba_initialize(void)
>>>>>    int icsel;
>>>>> @@ -95,7 +93,4 @@ void amba_initialize(void)
>>>>>      ambapp_freq_init(&ambapp_plb, adev,
>>>>>                       (LEON3_Timer_Regs->scaler_reload + 1) * 1000000);
>>>>> -  /* find UARTS */
>>>>> -  scan_uarts();
>>>>> diff --git a/c/src/lib/libbsp/sparc/leon3/console/console.c
>>>>> b/c/src/lib/libbsp/sparc/leon3/console/console.c
>>>>> index 320aa37..fa67d37 100644
>>>>> --- a/c/src/lib/libbsp/sparc/leon3/console/console.c
>>>>> +++ b/c/src/lib/libbsp/sparc/leon3/console/console.c
>>>>> @@ -62,6 +62,12 @@ extern int apbuart_inbyte_nonblocking(ambapp_apb_uart
>>>>> *regs);
>>>>>   /* body is in debugputs.c */
>>>>> +struct apbuart_priv {
>>>>> +  ambapp_apb_uart *regs;
>>>>> +  unsigned int freq_hz;
>>>>> +static struct apbuart_priv apbuarts[BSP_NUMBER_OF_TERMIOS_PORTS];
>>>>> +static int uarts = 0;
>>>>>   *  Console Termios Support Entry Points
>>>>> @@ -78,7 +84,7 @@ ssize_t console_write_support (int minor, const char
>>>>> *buf, size_t len)
>>>>>      port = minor - 1;
>>>>>    while (nwrite<   len) {
>>>>> -    apbuart_outbyte_polled((ambapp_apb_uart*)LEON3_Console_Uart[port],
>>>>> *buf++);
>>>>> +    apbuart_outbyte_polled(apbuarts[port].regs, *buf++);
>>>>>      nwrite++;
>>>>>    return nwrite;
>>>>> @@ -93,15 +99,44 @@ int console_pollRead(int minor)
>>>>>    else
>>>>>      port = minor - 1;
>>>>> -  return
>>>>> apbuart_inbyte_nonblocking((ambapp_apb_uart*)LEON3_Console_Uart[port]);
>>>>> +  return apbuart_inbyte_nonblocking(apbuarts[port].regs);
>>>>> +/* AMBA PP find routine. Extract AMBA PnP information into data
>>>>> structure. */
>>>>> +int find_matching_apbuart(struct ambapp_dev *dev, int index, void *arg)
>>>>> +  struct ambapp_apb_info *apb = (struct ambapp_apb_info *)dev->devinfo;
>>>>> +  /* Extract needed information of one APBUART */
>>>>> +  apbuarts[uarts].regs = (ambapp_apb_uart *)apb->start;
>>>>> +  /* Get APBUART core frequency, it is assumed that it is the same
>>>>> +   * as Bus frequency where the UART is situated
>>>>> +  apbuarts[uarts].freq_hz = ambapp_freq_get(&ambapp_plb, dev);
>>>>> +  uarts++;
>>>>> +  if (uarts>= BSP_NUMBER_OF_TERMIOS_PORTS)
>>>>> +    return 1; /* Satisfied number of UARTs, stop search */
>>>>> +  else
>>>>> +    return 0; /* Continue searching for more UARTs */
>>>>> +/* Find all UARTs */
>>>>> +int console_scan_uarts(void)
>>>>> +  memset(apbuarts, 0, sizeof(apbuarts));
>>>>> +  /* Find APBUART cores */
>>>>> +  ambapp_for_each(&ambapp_plb, (OPTIONS_ALL|OPTIONS_APB_SLVS),
>>>>> VENDOR_GAISLER,
>>>>> +                  GAISLER_APBUART, find_matching_apbuart, NULL);
>>>>> +  return uarts;
>>>>>   *  Console Device Driver Entry Points
>>>>> -int uarts = 0;
>>>>> -volatile LEON3_UART_Regs_Map *LEON3_Console_Uart[LEON3_APBUARTS];
>>>>>   rtems_device_driver console_initialize(
>>>>>    rtems_device_major_number  major,
>>>>> @@ -115,6 +150,9 @@ rtems_device_driver console_initialize(
>>>>>    rtems_termios_initialize();
>>>>> +  /* Find UARTs */
>>>>> +  console_scan_uarts();
>>>>>    /* Update syscon_uart_index to index used as /dev/console
>>>>>     * Let user select System console by setting syscon_uart_index. If the
>>>>>     * BSP is to provide the default UART (syscon_uart_index==0):
>>>>> @@ -190,9 +228,8 @@ rtems_device_driver console_open(
>>>>>      port = minor - 1;
>>>>>    /* Initialize UART on opening */
>>>>> -  LEON3_Console_Uart[port]->ctrl |= LEON_REG_UART_CTRL_RE |
>>>>> -                                     LEON_REG_UART_CTRL_TE;
>>>>> -  LEON3_Console_Uart[port]->status = 0;
>>>>> +  apbuarts[port]->regs->ctrl |= LEON_REG_UART_CTRL_RE |
>>>>> +  apbuarts[port]->regs->status = 0;
>>>>>    return RTEMS_SUCCESSFUL;
>>>>> diff --git a/c/src/lib/libbsp/sparc/leon3/console/debugputs.c
>>>>> b/c/src/lib/libbsp/sparc/leon3/console/debugputs.c
>>>>> index 43c6d7d..c6e0648 100644
>>>>> --- a/c/src/lib/libbsp/sparc/leon3/console/debugputs.c
>>>>> +++ b/c/src/lib/libbsp/sparc/leon3/console/debugputs.c
>>>>> @@ -23,11 +23,6 @@
>>>>>   #include<assert.h>
>>>>>   #include<stdio.h>
>>>>> - * Number of uarts on AMBA bus
>>>>> -extern int uarts;
>>>>>   static int isinit = 0;
>>>>>   /* Let user override which on-chip APBUART will be debug UART
>>>>> @@ -40,24 +35,16 @@ static int isinit = 0;
>>>>>   int debug_uart_index __attribute__((weak)) = 0;
>>>>>   ambapp_apb_uart *dbg_uart = NULL;
>>>>> - *  Scan for UARTS in configuration
>>>>> +/* Initialize the BSP system debug console layer. It will scan AMBA
>>>>> Plu&Play
>>>>> + * for a debug APBUART and enable RX/TX for that UART.
>>>>> -int scan_uarts(void)
>>>>> +int bsp_debug_uart_init(void)
>>>>>    int i;
>>>>> -  amba_apb_device apbuarts[LEON3_APBUARTS];
>>>>> +  struct ambapp_dev *adev;
>>>>> +  struct ambapp_apb_info *apb;
>>>>>    if (isinit == 0) {
>>>>> -    i = 0;
>>>>> -    uarts = 0;
>>>>> -    uarts = amba_find_apbslvs(
>>>>> -&amba_conf, VENDOR_GAISLER, GAISLER_APBUART, apbuarts, LEON3_APBUARTS);
>>>>> -    for(i=0; i<uarts; i++) {
>>>>> -      LEON3_Console_Uart[i] = (volatile LEON3_UART_Regs_Map
>>>>> *)apbuarts[i].start;
>>>>>      /* Update debug_uart_index to index used as debug console.
>>>>>       * Let user select Debug console by setting debug_uart_index. If the
>>>>>       * BSP is to provide the default UART (debug_uart_index==0):
>>>>> @@ -74,16 +61,27 @@ int scan_uarts(void)
>>>>>        debug_uart_index = debug_uart_index - 1; /* User selected
>>>>> dbg-console */
>>>>> -    /* initialize debug uart if present for printk */
>>>>> -    if (debug_uart_index<   uarts) {
>>>>> -      dbg_uart = (ambapp_apb_uart
>>>>> *)LEON3_Console_Uart[debug_uart_index];
>>>>> +    /* Find APBUART core for System Debug Console */
>>>>> +    i = debug_uart_index;
>>>>> +    adev = (void *)ambapp_for_each(&ambapp_plb,
>>>>> +                                   VENDOR_GAISLER, GAISLER_APBUART,
>>>>> +                                   ambapp_find_by_idx, (void *)&i);
>>>>> +    if (adev) {
>>>>> +      /* Found a matching debug console, initialize debug uart if
>>>>> present
>>>>> +       * for printk
>>>>> +      apb = (struct ambapp_apb_info *)adev->devinfo;
>>>>> +      dbg_uart = (ambapp_apb_uart *)apb->start;
>>>>>        dbg_uart->ctrl |= LEON_REG_UART_CTRL_RE | LEON_REG_UART_CTRL_TE;
>>>>>        dbg_uart->status = 0;
>>>>>      isinit = 1;
>>>>> -  return uarts;
>>>>> +  if (dbg_uart == NULL)
>>>>> +    return 0;
>>>>> +  else
>>>>> +    return 1;
>>>>> diff --git a/c/src/lib/libbsp/sparc/leon3/include/amba.h
>>>>> b/c/src/lib/libbsp/sparc/leon3/include/amba.h
>>>>> index aa13f2c..32b4a42 100644
>>>>> --- a/c/src/lib/libbsp/sparc/leon3/include/amba.h
>>>>> +++ b/c/src/lib/libbsp/sparc/leon3/include/amba.h
>>>>> @@ -25,7 +25,6 @@
>>>>>   #define LEON3_AHB_MASTERS 64
>>>>>   #define LEON3_AHB_SLAVES 64
>>>>>   #define LEON3_APB_SLAVES 16
>>>>> -#define LEON3_APBUARTS 8
>>>>>   #include<ambapp.h>
>>>>> diff --git a/c/src/lib/libbsp/sparc/leon3/include/bsp.h
>>>>> b/c/src/lib/libbsp/sparc/leon3/include/bsp.h
>>>>> index e5ae2c1..d883064 100644
>>>>> --- a/c/src/lib/libbsp/sparc/leon3/include/bsp.h
>>>>> +++ b/c/src/lib/libbsp/sparc/leon3/include/bsp.h
>>>>> @@ -41,6 +41,9 @@ extern "C" {
>>>>>   void *bsp_idle_thread( uintptr_t ignored );
>>>>>   #define BSP_IDLE_TASK_BODY bsp_idle_thread
>>>>> +/* Maximum supported APBUARTs by BSP */
>>>>> +#define BSP_NUMBER_OF_TERMIOS_PORTS 8
>>>>>   * Network driver configuration
>>>>> diff --git a/c/src/lib/libbsp/sparc/leon3/include/leon.h
>>>>> b/c/src/lib/libbsp/sparc/leon3/include/leon.h
>>>>> index 819800c..da752b2 100644
>>>>> --- a/c/src/lib/libbsp/sparc/leon3/include/leon.h
>>>>> +++ b/c/src/lib/libbsp/sparc/leon3/include/leon.h
>>>>> @@ -47,12 +47,6 @@ extern "C" {
>>>>>      (_trap)<= 0x1F )
>>>>>   typedef struct {
>>>>> -  volatile unsigned int data;
>>>>> -  volatile unsigned int status;
>>>>> -  volatile unsigned int ctrl;
>>>>> -} LEON3_UART_Regs_Map;
>>>>> -typedef struct {
>>>>>    volatile unsigned int value;
>>>>>    volatile unsigned int reload;
>>>>>    volatile unsigned int conf;
>>>>> @@ -147,7 +141,6 @@ typedef struct {
>>>>>   extern volatile LEON3_IrqCtrl_Regs_Map *LEON3_IrqCtrl_Regs;  /* LEON3
>>>>> Interrupt Controller */
>>>>>   extern volatile LEON3_Timer_Regs_Map *LEON3_Timer_Regs; /* LEON3 GP
>>>>> Timer */
>>>>> -extern volatile LEON3_UART_Regs_Map
>>>>>   /* LEON3 CPU Index of boot CPU */
>>>>>   extern int LEON3_Cpu_Index;
>>>>> diff --git a/c/src/lib/libbsp/sparc/leon3/startup/bspstart.c
>>>>> b/c/src/lib/libbsp/sparc/leon3/startup/bspstart.c
>>>>> index 9cad164..50fa5e5 100644
>>>>> --- a/c/src/lib/libbsp/sparc/leon3/startup/bspstart.c
>>>>> +++ b/c/src/lib/libbsp/sparc/leon3/startup/bspstart.c
>>>>> @@ -31,6 +31,7 @@ int CPU_SPARC_HAS_SNOOPING;
>>>>>   int LEON3_Cpu_Index = 0;
>>>>>   extern void amba_initialize(void);
>>>>> +extern void bsp_debug_uart_init(void);
>>>>>   * set_snooping
>>>>> @@ -75,6 +76,12 @@ void bsp_start( void )
>>>>>    LEON3_Cpu_Index = (get_asr17()>>   28)&   3;
>>>>> -  /* Find UARTs */
>>>>> +  /* Scan AMBA Plug&Play and parse it into a RAM description
>>>>> (ambapp_plb),
>>>>> +   * find GPTIMER for bus frequency, find IRQ Controller and initialize
>>>>> +   * interrupt support
>>>>>    amba_initialize();
>>>>> +  /* find debug UART for printk() */
>>>>> +  bsp_debug_uart_init();
>>>>> 1.7.0.4
>>>>> _______________________________________________
>>>>> rtems-devel mailing list
>>>>> rtems-devel at rtems.org
>>>>> http://www.rtems.org/mailman/listinfo/rtems-devel
Joel Sherrill, Ph.D.             Director of Research&   Development
