[PATCH 33.2 3/5] LEON3: updated console driver for new AMBAPP layer
Daniel Hellstrom
daniel at gaisler.com
Tue Apr 17 11:40:53 UTC 2012
On 04/16/2012 05:31 PM, Joel Sherrill wrote:
> On 04/16/2012 10:09 AM, Gedare Bloom wrote:
>> On Mon, Apr 16, 2012 at 4:49 AM, Daniel Hellstrom<daniel at gaisler.com> wrote:
>>> On 04/16/2012 01:21 AM, Joel Sherrill wrote:
>>>> On 04/15/2012 01:53 PM, Gedare Bloom wrote:
>>>>> This seems ok. I found BSP_NUMBER_OF_TERMIOS_PORTS a little
>>>>> confusing--does it have any relation with
>>>>> CONFIGURE_NUMBER_OF_TERMIOS_PORTS or just is it similar in name?
>>>> It is intended to be the number known to be on the board
>>>> as a minimum. So rather than CONFIGURE_NUMBER_OF_TERMIOS_PORTS
>>>> defaulting to 1 when you enable console, it defaults to that
>>>> number.
>>>> It may make sense to do away with that and let the user
>>>> just fail if they under configure.
>>>> It is a component into CONFIGURE_NUMBER_OF_TERMIOS_PORTS.
>>>> Dropping it would be OK if it doesn't stop a console from
>>>> initializing at all on a board with N>1 ports when running
>>>> hello world
>>> BSP_NUMBER_OF_TERMIOS_PORTS is the maximum number of UARTs the BSP supports.
>>> CONFIGURE_NUMBER_OF_TERMIOS_PORTS is termios-internal and is not available
>>> when the BSP builds?
>> I believe that is the case. The big no-no is for the BSP to define
>> that number itself.
> Right. Consider a PC or any other board which can take add-on cards.
> The BSP knows the UARTs on the base board but cannot account for
> any add-ons.
I agree, and with LEON the on-chip peripherals are plug-and-played like add-on boards.
> For example, I know of an RTEMS application with an embedded PC
> that has almost 40 serial ports.
>>> Now that the bsp_early_malloc() patch has been accepted, I might change this
>>> behavior in a future patch so that the private structures are allocated
>>> dynamically after probing how many UARTs are available. Probably it is not
>>> worth probing it, since it may take more space with the extra instructions
>>> than the current excess private data. On the other hand it is one single
>>> function call with the new AMBAPP layer to find the number of cores.
>>> Another possibility would be if CONFIGURE_NUMBER_OF_TERMIOS_PORTS were saved
>>> in a "configuration structure" I could have dynamically supported the user's
>>> configuration, by using bsp_early_malloc(sizeof(priv) * config->no_ports) in
>>> my UART init code... in the future :)
>> Yes that might be nice. It should be in one of the configuration
>> structures defined in confdefs. I'm not sure exactly what you have to
>> pull in to use it, I think config.h in the sapi has those structure
>> definitions.
> CONFIGURE_NUMBER_OF_TERMIOS_PORTS is only used to
> reserve enough RTEMS workspace so you can open all
> termios ports concurrently. This is currently the only use
> since termios only uses semaphores.
> #define CONFIGURE_TERMIOS_SEMAPHORES \
> ((CONFIGURE_NUMBER_OF_TERMIOS_PORTS * 4) + 1)
Ok, I see.
> Daniel.. if the user has PCI and plugs in an 8-port UART board,
> then your allocation of memory for those 8 ports is unnecessary.
If a PCI UART add-on board is added, another driver must be used. Since it will probably not be a APBUART on PCI, and the APBUART driver only supports on-chip APBUARTs. However, together with our
driver manager I am able to reuse the code in the APBUART driver for both on-chip and AMBA-over-PCI devices, in order to support that I have introduced a new console.c (called cons.c).
> And whether the hardware has N termios ports or not, the
> application may choose not to use them all and not need
> the reserved workspace.
> I would lean to eliminating BSP_NUMBER_OF_TERMIOS_PORTS
Note that I'm not introducing a new limitation here, the old code has always been limited to LEON3_APBUARTS uarts. I have just renamed it to BSP_NUMBER_OF_TERMIOS_PORTS, perhaps I should not have done
that. Old code:
int uarts = 0;
volatile LEON3_UART_Regs_Map *LEON3_Console_Uart[LEON3_APBUARTS];
I will try to eliminate BSP_NUMBER_OF_TERMIOS_PORTS as soon as I can, now that bsp_early_malloc() is in the BSP, I can make this dynamic. And as Joel say, the number of BSP UARTs should not depend on
the TERMIOS layer.
Daniel
>>> Thanks,
>>> Daniel
>>>>> -Gedare
>>>>> On Tue, Apr 10, 2012 at 7:33 AM, Daniel Hellstrom<daniel at gaisler.com>
>>>>> wrote:
>>>>>> Signed-off-by: Daniel Hellstrom<daniel at gaisler.com>
>>>>>> c/src/lib/libbsp/sparc/leon3/amba/amba.c | 5 --
>>>>>> c/src/lib/libbsp/sparc/leon3/console/console.c | 51
>>>>>> c/src/lib/libbsp/sparc/leon3/console/debugputs.c | 42
>>>>>> c/src/lib/libbsp/sparc/leon3/include/amba.h | 1 -
>>>>>> c/src/lib/libbsp/sparc/leon3/include/bsp.h | 3 +
>>>>>> c/src/lib/libbsp/sparc/leon3/include/leon.h | 7 ---
>>>>>> c/src/lib/libbsp/sparc/leon3/startup/bspstart.c | 9 +++-
>>>>>> 7 files changed, 75 insertions(+), 43 deletions(-)
>>>>>> diff --git a/c/src/lib/libbsp/sparc/leon3/amba/amba.c
>>>>>> b/c/src/lib/libbsp/sparc/leon3/amba/amba.c
>>>>>> index e41d0aa..60281f3 100644
>>>>>> --- a/c/src/lib/libbsp/sparc/leon3/amba/amba.c
>>>>>> +++ b/c/src/lib/libbsp/sparc/leon3/amba/amba.c
>>>>>> @@ -39,8 +39,6 @@ volatile LEON3_IrqCtrl_Regs_Map *LEON3_IrqCtrl_Regs;
>>>>>> * amba_ahb_masters, amba_ahb_slaves and amba.
>>>>>> -extern int scan_uarts(void);
>>>>>> void amba_initialize(void)
>>>>>> int icsel;
>>>>>> @@ -95,7 +93,4 @@ void amba_initialize(void)
>>>>>> ambapp_freq_init(&ambapp_plb, adev,
>>>>>> (LEON3_Timer_Regs->scaler_reload + 1) * 1000000);
>>>>>> - /* find UARTS */
>>>>>> - scan_uarts();
>>>>>> diff --git a/c/src/lib/libbsp/sparc/leon3/console/console.c
>>>>>> b/c/src/lib/libbsp/sparc/leon3/console/console.c
>>>>>> index 320aa37..fa67d37 100644
>>>>>> --- a/c/src/lib/libbsp/sparc/leon3/console/console.c
>>>>>> +++ b/c/src/lib/libbsp/sparc/leon3/console/console.c
>>>>>> @@ -62,6 +62,12 @@ extern int apbuart_inbyte_nonblocking(ambapp_apb_uart
>>>>>> *regs);
>>>>>> /* body is in debugputs.c */
>>>>>> +struct apbuart_priv {
>>>>>> + ambapp_apb_uart *regs;
>>>>>> + unsigned int freq_hz;
>>>>>> +static struct apbuart_priv apbuarts[BSP_NUMBER_OF_TERMIOS_PORTS];
>>>>>> +static int uarts = 0;
>>>>>> * Console Termios Support Entry Points
>>>>>> @@ -78,7 +84,7 @@ ssize_t console_write_support (int minor, const char
>>>>>> *buf, size_t len)
>>>>>> port = minor - 1;
>>>>>> while (nwrite< len) {
>>>>>> - apbuart_outbyte_polled((ambapp_apb_uart*)LEON3_Console_Uart[port],
>>>>>> *buf++);
>>>>>> + apbuart_outbyte_polled(apbuarts[port].regs, *buf++);
>>>>>> nwrite++;
>>>>>> return nwrite;
>>>>>> @@ -93,15 +99,44 @@ int console_pollRead(int minor)
>>>>>> else
>>>>>> port = minor - 1;
>>>>>> - return
>>>>>> apbuart_inbyte_nonblocking((ambapp_apb_uart*)LEON3_Console_Uart[port]);
>>>>>> + return apbuart_inbyte_nonblocking(apbuarts[port].regs);
>>>>>> +/* AMBA PP find routine. Extract AMBA PnP information into data
>>>>>> structure. */
>>>>>> +int find_matching_apbuart(struct ambapp_dev *dev, int index, void *arg)
>>>>>> + struct ambapp_apb_info *apb = (struct ambapp_apb_info *)dev->devinfo;
>>>>>> + /* Extract needed information of one APBUART */
>>>>>> + apbuarts[uarts].regs = (ambapp_apb_uart *)apb->start;
>>>>>> + /* Get APBUART core frequency, it is assumed that it is the same
>>>>>> + * as Bus frequency where the UART is situated
>>>>>> + apbuarts[uarts].freq_hz = ambapp_freq_get(&ambapp_plb, dev);
>>>>>> + uarts++;
>>>>>> + if (uarts>= BSP_NUMBER_OF_TERMIOS_PORTS)
>>>>>> + return 1; /* Satisfied number of UARTs, stop search */
>>>>>> + else
>>>>>> + return 0; /* Continue searching for more UARTs */
>>>>>> +/* Find all UARTs */
>>>>>> +int console_scan_uarts(void)
>>>>>> + memset(apbuarts, 0, sizeof(apbuarts));
>>>>>> + /* Find APBUART cores */
>>>>>> + ambapp_for_each(&ambapp_plb, (OPTIONS_ALL|OPTIONS_APB_SLVS),
>>>>>> VENDOR_GAISLER,
>>>>>> + GAISLER_APBUART, find_matching_apbuart, NULL);
>>>>>> + return uarts;
>>>>>> * Console Device Driver Entry Points
>>>>>> -int uarts = 0;
>>>>>> -volatile LEON3_UART_Regs_Map *LEON3_Console_Uart[LEON3_APBUARTS];
>>>>>> rtems_device_driver console_initialize(
>>>>>> rtems_device_major_number major,
>>>>>> @@ -115,6 +150,9 @@ rtems_device_driver console_initialize(
>>>>>> rtems_termios_initialize();
>>>>>> + /* Find UARTs */
>>>>>> + console_scan_uarts();
>>>>>> /* Update syscon_uart_index to index used as /dev/console
>>>>>> * Let user select System console by setting syscon_uart_index. If the
>>>>>> * BSP is to provide the default UART (syscon_uart_index==0):
>>>>>> @@ -190,9 +228,8 @@ rtems_device_driver console_open(
>>>>>> port = minor - 1;
>>>>>> /* Initialize UART on opening */
>>>>>> - LEON3_Console_Uart[port]->ctrl |= LEON_REG_UART_CTRL_RE |
>>>>>> - LEON_REG_UART_CTRL_TE;
>>>>>> - LEON3_Console_Uart[port]->status = 0;
>>>>>> + apbuarts[port]->regs->ctrl |= LEON_REG_UART_CTRL_RE |
>>>>>> + apbuarts[port]->regs->status = 0;
>>>>>> return RTEMS_SUCCESSFUL;
>>>>>> diff --git a/c/src/lib/libbsp/sparc/leon3/console/debugputs.c
>>>>>> b/c/src/lib/libbsp/sparc/leon3/console/debugputs.c
>>>>>> index 43c6d7d..c6e0648 100644
>>>>>> --- a/c/src/lib/libbsp/sparc/leon3/console/debugputs.c
>>>>>> +++ b/c/src/lib/libbsp/sparc/leon3/console/debugputs.c
>>>>>> @@ -23,11 +23,6 @@
>>>>>> #include<assert.h>
>>>>>> #include<stdio.h>
>>>>>> - * Number of uarts on AMBA bus
>>>>>> -extern int uarts;
>>>>>> static int isinit = 0;
>>>>>> /* Let user override which on-chip APBUART will be debug UART
>>>>>> @@ -40,24 +35,16 @@ static int isinit = 0;
>>>>>> int debug_uart_index __attribute__((weak)) = 0;
>>>>>> ambapp_apb_uart *dbg_uart = NULL;
>>>>>> - * Scan for UARTS in configuration
>>>>>> +/* Initialize the BSP system debug console layer. It will scan AMBA
>>>>>> Plu&Play
>>>>>> + * for a debug APBUART and enable RX/TX for that UART.
>>>>>> -int scan_uarts(void)
>>>>>> +int bsp_debug_uart_init(void)
>>>>>> int i;
>>>>>> - amba_apb_device apbuarts[LEON3_APBUARTS];
>>>>>> + struct ambapp_dev *adev;
>>>>>> + struct ambapp_apb_info *apb;
>>>>>> if (isinit == 0) {
>>>>>> - i = 0;
>>>>>> - uarts = 0;
>>>>>> - uarts = amba_find_apbslvs(
>>>>>> -&amba_conf, VENDOR_GAISLER, GAISLER_APBUART, apbuarts, LEON3_APBUARTS);
>>>>>> - for(i=0; i<uarts; i++) {
>>>>>> - LEON3_Console_Uart[i] = (volatile LEON3_UART_Regs_Map
>>>>>> *)apbuarts[i].start;
>>>>>> /* Update debug_uart_index to index used as debug console.
>>>>>> * Let user select Debug console by setting debug_uart_index. If the
>>>>>> * BSP is to provide the default UART (debug_uart_index==0):
>>>>>> @@ -74,16 +61,27 @@ int scan_uarts(void)
>>>>>> debug_uart_index = debug_uart_index - 1; /* User selected
>>>>>> dbg-console */
>>>>>> - /* initialize debug uart if present for printk */
>>>>>> - if (debug_uart_index< uarts) {
>>>>>> - dbg_uart = (ambapp_apb_uart
>>>>>> *)LEON3_Console_Uart[debug_uart_index];
>>>>>> + /* Find APBUART core for System Debug Console */
>>>>>> + i = debug_uart_index;
>>>>>> + adev = (void *)ambapp_for_each(&ambapp_plb,
>>>>>> + VENDOR_GAISLER, GAISLER_APBUART,
>>>>>> + ambapp_find_by_idx, (void *)&i);
>>>>>> + if (adev) {
>>>>>> + /* Found a matching debug console, initialize debug uart if
>>>>>> present
>>>>>> + * for printk
>>>>>> + apb = (struct ambapp_apb_info *)adev->devinfo;
>>>>>> + dbg_uart = (ambapp_apb_uart *)apb->start;
>>>>>> dbg_uart->ctrl |= LEON_REG_UART_CTRL_RE | LEON_REG_UART_CTRL_TE;
>>>>>> dbg_uart->status = 0;
>>>>>> isinit = 1;
>>>>>> - return uarts;
>>>>>> + if (dbg_uart == NULL)
>>>>>> + return 0;
>>>>>> + else
>>>>>> + return 1;
>>>>>> diff --git a/c/src/lib/libbsp/sparc/leon3/include/amba.h
>>>>>> b/c/src/lib/libbsp/sparc/leon3/include/amba.h
>>>>>> index aa13f2c..32b4a42 100644
>>>>>> --- a/c/src/lib/libbsp/sparc/leon3/include/amba.h
>>>>>> +++ b/c/src/lib/libbsp/sparc/leon3/include/amba.h
>>>>>> @@ -25,7 +25,6 @@
>>>>>> #define LEON3_AHB_MASTERS 64
>>>>>> #define LEON3_AHB_SLAVES 64
>>>>>> #define LEON3_APB_SLAVES 16
>>>>>> -#define LEON3_APBUARTS 8
>>>>>> #include<ambapp.h>
>>>>>> diff --git a/c/src/lib/libbsp/sparc/leon3/include/bsp.h
>>>>>> b/c/src/lib/libbsp/sparc/leon3/include/bsp.h
>>>>>> index e5ae2c1..d883064 100644
>>>>>> --- a/c/src/lib/libbsp/sparc/leon3/include/bsp.h
>>>>>> +++ b/c/src/lib/libbsp/sparc/leon3/include/bsp.h
>>>>>> @@ -41,6 +41,9 @@ extern "C" {
>>>>>> void *bsp_idle_thread( uintptr_t ignored );
>>>>>> #define BSP_IDLE_TASK_BODY bsp_idle_thread
>>>>>> +/* Maximum supported APBUARTs by BSP */
>>>>>> +#define BSP_NUMBER_OF_TERMIOS_PORTS 8
>>>>>> * Network driver configuration
>>>>>> diff --git a/c/src/lib/libbsp/sparc/leon3/include/leon.h
>>>>>> b/c/src/lib/libbsp/sparc/leon3/include/leon.h
>>>>>> index 819800c..da752b2 100644
>>>>>> --- a/c/src/lib/libbsp/sparc/leon3/include/leon.h
>>>>>> +++ b/c/src/lib/libbsp/sparc/leon3/include/leon.h
>>>>>> @@ -47,12 +47,6 @@ extern "C" {
>>>>>> (_trap)<= 0x1F )
>>>>>> typedef struct {
>>>>>> - volatile unsigned int data;
>>>>>> - volatile unsigned int status;
>>>>>> - volatile unsigned int ctrl;
>>>>>> -} LEON3_UART_Regs_Map;
>>>>>> -typedef struct {
>>>>>> volatile unsigned int value;
>>>>>> volatile unsigned int reload;
>>>>>> volatile unsigned int conf;
>>>>>> @@ -147,7 +141,6 @@ typedef struct {
>>>>>> extern volatile LEON3_IrqCtrl_Regs_Map *LEON3_IrqCtrl_Regs; /* LEON3
>>>>>> Interrupt Controller */
>>>>>> extern volatile LEON3_Timer_Regs_Map *LEON3_Timer_Regs; /* LEON3 GP
>>>>>> Timer */
>>>>>> -extern volatile LEON3_UART_Regs_Map
>>>>>> /* LEON3 CPU Index of boot CPU */
>>>>>> extern int LEON3_Cpu_Index;
>>>>>> diff --git a/c/src/lib/libbsp/sparc/leon3/startup/bspstart.c
>>>>>> b/c/src/lib/libbsp/sparc/leon3/startup/bspstart.c
>>>>>> index 9cad164..50fa5e5 100644
>>>>>> --- a/c/src/lib/libbsp/sparc/leon3/startup/bspstart.c
>>>>>> +++ b/c/src/lib/libbsp/sparc/leon3/startup/bspstart.c
>>>>>> @@ -31,6 +31,7 @@ int CPU_SPARC_HAS_SNOOPING;
>>>>>> int LEON3_Cpu_Index = 0;
>>>>>> extern void amba_initialize(void);
>>>>>> +extern void bsp_debug_uart_init(void);
>>>>>> * set_snooping
>>>>>> @@ -75,6 +76,12 @@ void bsp_start( void )
>>>>>> LEON3_Cpu_Index = (get_asr17()>> 28)& 3;
>>>>>> - /* Find UARTs */
>>>>>> + /* Scan AMBA Plug&Play and parse it into a RAM description
>>>>>> (ambapp_plb),
>>>>>> + * find GPTIMER for bus frequency, find IRQ Controller and initialize
>>>>>> + * interrupt support
>>>>>> amba_initialize();
>>>>>> + /* find debug UART for printk() */
>>>>>> + bsp_debug_uart_init();
>>>>>> 1.7.0.4
>>>>>> _______________________________________________
>>>>>> rtems-devel mailing list
>>>>>> rtems-devel at rtems.org
>>>>>> http://www.rtems.org/mailman/listinfo/rtems-devel
