[rtems commit] PR1908: QoS library for CBS scheduler
Mon Apr 16 17:15:14 UTC 2012
On 04/16/2012 09:45 AM, Sebastian Huber wrote:
> On 04/16/2012 04:41 PM, Gedare Bloom wrote:
>>> * qreslib.inl is installed into $(includedir).
>>>>   We have a convention to install *.inl's into inline subdirectories.
>> Will see if qreslib.inl stays around or not.
> Why do we have these *.inl files at all?
To indicate they are where inline functions go.
Also if you notice they are not included unless
you are violating kernel visibility.
The POSIX API implementation has a harder
line between public and private .h files. The Classic
wasn't implemented with that in mind. It might be a
good (and thankless) clean up activity to make
the public Classic API .h files not include score .h files
at all. As a minimum, this would involve moving
the Classic API _Control structures to private .h files
along with helper method and data definitions.
Joel Sherrill, Ph.D.             Director of Research&   Development
