[PATCH 37] LEON3: renamed console/debugputs.c to printk_support.c
Daniel Hellstrom daniel at gaisler.com
Thu Apr 19 13:21:28 UTC 2012
Signed-off-by: Daniel Hellstrom <daniel at gaisler.com>
 c/src/lib/libbsp/sparc/leon3/Makefile.am           |    2 +-
 c/src/lib/libbsp/sparc/leon3/console/debugputs.c   |  169 --------------------
 .../libbsp/sparc/leon3/console/printk_support.c    |  169 ++++++++++++++++++++
 3 files changed, 170 insertions(+), 170 deletions(-)
 delete mode 100644 c/src/lib/libbsp/sparc/leon3/console/debugputs.c
 create mode 100644 c/src/lib/libbsp/sparc/leon3/console/printk_support.c
diff --git a/c/src/lib/libbsp/sparc/leon3/Makefile.am b/c/src/lib/libbsp/sparc/leon3/Makefile.am
index 09d8b8e..a9badce 100644
--- a/c/src/lib/libbsp/sparc/leon3/Makefile.am
+++ b/c/src/lib/libbsp/sparc/leon3/Makefile.am
@@ -63,7 +63,7 @@ libbsp_a_SOURCES += ../../sparc/shared/amba/ambapp_show.c
 # console
 libbsp_a_SOURCES += console/console.c
 # debugio
-libbsp_a_SOURCES += console/debugputs.c
+libbsp_a_SOURCES += console/printk_support.c
 # clock
 libbsp_a_SOURCES += clock/ckinit.c
 libbsp_a_SOURCES += ../../shared/clockdrv_shell.h
diff --git a/c/src/lib/libbsp/sparc/leon3/console/debugputs.c b/c/src/lib/libbsp/sparc/leon3/console/debugputs.c
deleted file mode 100644
index 9815053..0000000
--- a/c/src/lib/libbsp/sparc/leon3/console/debugputs.c
+++ /dev/null
@@ -1,169 +0,0 @@
- *  This file contains the TTY driver for the serial ports on the LEON.
- *  This driver uses the termios pseudo driver.
- *  COPYRIGHT (c) 1989-1999.
- *  On-Line Applications Research Corporation (OAR).
- *  Modified for LEON3 BSP.
- *  COPYRIGHT (c) 2011.
- *  Aeroflex Gaisler.
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.com/license/LICENSE.
-#include <bsp.h>
-#include <rtems/libio.h>
-#include <stdlib.h>
-#include <assert.h>
-#include <stdio.h>
-/* Let user override which on-chip APBUART will be debug UART
- * 0 = Default APBUART. On MP system CPU0=APBUART0, CPU1=APBUART1...
- * 1 = APBUART[0]
- * 2 = APBUART[1]
- * 3 = APBUART[2]
-int debug_uart_index __attribute__((weak)) = 0;
-struct apbuart_regs *dbg_uart = NULL;
-/* Before UART driver has registered (or when no UART is available), calls to
- * printk that gets to bsp_out_char() will be filling data into the
- * pre_printk_dbgbuf[] buffer, hopefully the buffer can help debugging the
- * early BSP boot.. At least the last printk() will be caught.
-char pre_printk_dbgbuf[32] = {0};
-int pre_printk_pos = 0;
-/* Initialize the BSP system debug console layer. It will scan AMBA Plu&Play
- * for a debug APBUART and enable RX/TX for that UART.
-int bsp_debug_uart_init(void)
-  int i;
-  struct ambapp_dev *adev;
-  struct ambapp_apb_info *apb;
-  /* Update debug_uart_index to index used as debug console.
-   * Let user select Debug console by setting debug_uart_index. If the
-   * BSP is to provide the default UART (debug_uart_index==0):
-   *   non-MP: APBUART[0] is debug console
-   *   MP: LEON CPU index select UART
-  if (debug_uart_index == 0) {
-#if defined(RTEMS_MULTIPROCESSING)
-    debug_uart_index = LEON3_Cpu_Index;
-#else
-    debug_uart_index = 0;
-#endif
-  } else {
-    debug_uart_index = debug_uart_index - 1; /* User selected dbg-console */
-  /* Find APBUART core for System Debug Console */
-  i = debug_uart_index;
-  adev = (void *)ambapp_for_each(&ambapp_plb, (OPTIONS_ALL|OPTIONS_APB_SLVS),
-                                 VENDOR_GAISLER, GAISLER_APBUART,
-                                 ambapp_find_by_idx, (void *)&i);
-  if (adev) {
-    /* Found a matching debug console, initialize debug uart if present
-     * for printk
-    apb = (struct ambapp_apb_info *)adev->devinfo;
-    dbg_uart = (struct apbuart_regs *)apb->start;
-    dbg_uart->ctrl |= LEON_REG_UART_CTRL_RE | LEON_REG_UART_CTRL_TE;
-    dbg_uart->status = 0;
-    return 1;
-  } else
-    return 0;
- *  apbuart_outbyte_polled
- *  This routine transmits a character using polling.
-void apbuart_outbyte_polled(
-  struct apbuart_regs *regs,
-  unsigned char ch,
-  int do_cr_on_newline,
-  int wait_sent
-send:
-  while ( (regs->status & LEON_REG_UART_STATUS_THE) == 0 ) {
-    /* Lower bus utilization while waiting for UART */
-    asm volatile ("nop"::); asm volatile ("nop"::);
-  regs->data = (unsigned int) ch;
-  if ((ch == '\n') && do_cr_on_newline) {
-    ch = '\r';
-    goto send;
-  /* Wait until the character has been sent? */
-  if (wait_sent) {
-    while ((regs->status & LEON_REG_UART_STATUS_THE) == 0)
- *  apbuart_inbyte_nonblocking
- *  This routine polls for a character.
-int apbuart_inbyte_nonblocking(struct apbuart_regs *regs)
-  /* Clear errors */
-  if (regs->status & LEON_REG_UART_STATUS_ERR)
-    regs->status = ~LEON_REG_UART_STATUS_ERR;
-  if ((regs->status & LEON_REG_UART_STATUS_DR) == 0)
-    return EOF;
-  else
-    return (int) regs->data;
-/* putchar/getchar for printk */
-static void bsp_out_char(char c)
-  if (dbg_uart == NULL) {
-    /* Local debug buffer when UART driver has not registered */
-    pre_printk_dbgbuf[pre_printk_pos++] = c;
-    pre_printk_pos = pre_printk_pos & (sizeof(pre_printk_dbgbuf)-1);
-    return;
-  apbuart_outbyte_polled(dbg_uart, c, 1, 1);
- *  To support printk
-#include <rtems/bspIo.h>
-BSP_output_char_function_type BSP_output_char = bsp_out_char;
-static int bsp_in_char(void)
-  int tmp;
-    return EOF;
-  while ((tmp = apbuart_inbyte_nonblocking(dbg_uart)) < 0)
-  return tmp;
-BSP_polling_getchar_function_type BSP_poll_char = bsp_in_char;
diff --git a/c/src/lib/libbsp/sparc/leon3/console/printk_support.c b/c/src/lib/libbsp/sparc/leon3/console/printk_support.c
new file mode 100644
index 0000000..9815053
--- /dev/null
+++ b/c/src/lib/libbsp/sparc/leon3/console/printk_support.c
@@ -0,0 +1,169 @@
+ *  This file contains the TTY driver for the serial ports on the LEON.
+ *  This driver uses the termios pseudo driver.
+ *  COPYRIGHT (c) 1989-1999.
+ *  On-Line Applications Research Corporation (OAR).
+ *  Modified for LEON3 BSP.
+ *  COPYRIGHT (c) 2011.
+ *  Aeroflex Gaisler.
+ *  The license and distribution terms for this file may be
+ *  found in the file LICENSE in this distribution or at
+ *  http://www.rtems.com/license/LICENSE.
+#include <bsp.h>
+#include <rtems/libio.h>
+#include <stdlib.h>
+#include <assert.h>
+#include <stdio.h>
+/* Let user override which on-chip APBUART will be debug UART
+ * 0 = Default APBUART. On MP system CPU0=APBUART0, CPU1=APBUART1...
+ * 1 = APBUART[0]
+ * 2 = APBUART[1]
+ * 3 = APBUART[2]
+int debug_uart_index __attribute__((weak)) = 0;
+struct apbuart_regs *dbg_uart = NULL;
+/* Before UART driver has registered (or when no UART is available), calls to
+ * printk that gets to bsp_out_char() will be filling data into the
+ * pre_printk_dbgbuf[] buffer, hopefully the buffer can help debugging the
+ * early BSP boot.. At least the last printk() will be caught.
+char pre_printk_dbgbuf[32] = {0};
+int pre_printk_pos = 0;
+/* Initialize the BSP system debug console layer. It will scan AMBA Plu&Play
+ * for a debug APBUART and enable RX/TX for that UART.
+int bsp_debug_uart_init(void)
+  int i;
+  struct ambapp_dev *adev;
+  struct ambapp_apb_info *apb;
+  /* Update debug_uart_index to index used as debug console.
+   * Let user select Debug console by setting debug_uart_index. If the
+   * BSP is to provide the default UART (debug_uart_index==0):
+   *   non-MP: APBUART[0] is debug console
+   *   MP: LEON CPU index select UART
+  if (debug_uart_index == 0) {
+#if defined(RTEMS_MULTIPROCESSING)
+    debug_uart_index = LEON3_Cpu_Index;
+#else
+    debug_uart_index = 0;
+#endif
+  } else {
+    debug_uart_index = debug_uart_index - 1; /* User selected dbg-console */
+  /* Find APBUART core for System Debug Console */
+  i = debug_uart_index;
+  adev = (void *)ambapp_for_each(&ambapp_plb, (OPTIONS_ALL|OPTIONS_APB_SLVS),
+                                 VENDOR_GAISLER, GAISLER_APBUART,
+                                 ambapp_find_by_idx, (void *)&i);
+  if (adev) {
+    /* Found a matching debug console, initialize debug uart if present
+     * for printk
+    apb = (struct ambapp_apb_info *)adev->devinfo;
+    dbg_uart = (struct apbuart_regs *)apb->start;
+    dbg_uart->ctrl |= LEON_REG_UART_CTRL_RE | LEON_REG_UART_CTRL_TE;
+    dbg_uart->status = 0;
+    return 1;
+  } else
+    return 0;
+ *  apbuart_outbyte_polled
+ *  This routine transmits a character using polling.
+void apbuart_outbyte_polled(
+  struct apbuart_regs *regs,
+  unsigned char ch,
+  int do_cr_on_newline,
+  int wait_sent
+send:
+  while ( (regs->status & LEON_REG_UART_STATUS_THE) == 0 ) {
+    /* Lower bus utilization while waiting for UART */
+    asm volatile ("nop"::); asm volatile ("nop"::);
+  regs->data = (unsigned int) ch;
+  if ((ch == '\n') && do_cr_on_newline) {
+    ch = '\r';
+    goto send;
+  /* Wait until the character has been sent? */
+  if (wait_sent) {
+    while ((regs->status & LEON_REG_UART_STATUS_THE) == 0)
+ *  apbuart_inbyte_nonblocking
+ *  This routine polls for a character.
+int apbuart_inbyte_nonblocking(struct apbuart_regs *regs)
+  /* Clear errors */
+  if (regs->status & LEON_REG_UART_STATUS_ERR)
+    regs->status = ~LEON_REG_UART_STATUS_ERR;
+  if ((regs->status & LEON_REG_UART_STATUS_DR) == 0)
+    return EOF;
+  else
+    return (int) regs->data;
+/* putchar/getchar for printk */
+static void bsp_out_char(char c)
+  if (dbg_uart == NULL) {
+    /* Local debug buffer when UART driver has not registered */
+    pre_printk_dbgbuf[pre_printk_pos++] = c;
+    pre_printk_pos = pre_printk_pos & (sizeof(pre_printk_dbgbuf)-1);
+    return;
+  apbuart_outbyte_polled(dbg_uart, c, 1, 1);
+ *  To support printk
+#include <rtems/bspIo.h>
+BSP_output_char_function_type BSP_output_char = bsp_out_char;
+static int bsp_in_char(void)
+  int tmp;
+    return EOF;
+  while ((tmp = apbuart_inbyte_nonblocking(dbg_uart)) < 0)
+  return tmp;
+BSP_polling_getchar_function_type BSP_poll_char = bsp_in_char;
1.7.0.4
