[PATCH 36 v2] LEON3: GPTIMER timer watchdog driver
Fri Apr 20 15:37:54 UTC 2012
On Fri, Apr 20, 2012 at 2:22 AM, Daniel Hellstrom <daniel at gaisler.com> wrote:
> On 04/19/2012 06:08 PM, Gedare Bloom wrote:
>> Looking at this from the perspective of generalizing to a shared BSP
>> infrastructure I have a couple of nit-picky comments.
>> On Thu, Apr 19, 2012 at 9:21 AM, Daniel Hellstrom<daniel at gaisler.com>
>>  wrote:
>>> Last timer instance of GPTIMER is sometimes a watchdog timer that
>>> can reset the system on timer underflow.
>>> Signed-off-by: Daniel Hellstrom<daniel at gaisler.com>
>>>  c/src/lib/libbsp/sparc/leon3/Makefile.am        |    2 +
>>>  c/src/lib/libbsp/sparc/leon3/include/watchdog.h |   49 ++++++++++++
>>>  c/src/lib/libbsp/sparc/leon3/preinstall.am      |    4 +
>>>  c/src/lib/libbsp/sparc/leon3/timer/watchdog.c   |   90
>>>  4 files changed, 145 insertions(+), 0 deletions(-)
>>>  create mode 100644 c/src/lib/libbsp/sparc/leon3/include/watchdog.h
>>>  create mode 100644 c/src/lib/libbsp/sparc/leon3/timer/watchdog.c
>>> diff --git a/c/src/lib/libbsp/sparc/leon3/Makefile.am
>>> b/c/src/lib/libbsp/sparc/leon3/Makefile.am
>>> index cc25993..09d8b8e 100644
>>> --- a/c/src/lib/libbsp/sparc/leon3/Makefile.am
>>> +++ b/c/src/lib/libbsp/sparc/leon3/Makefile.am
>>> @@ -115,6 +115,8 @@ libbsp_a_SOURCES += ../../sparc/shared/i2c/i2cmst.c
>>>  # timer
>>>  libbsp_a_SOURCES += timer/timer.c
>>> +libbsp_a_SOURCES += timer/watchdog.c
>>> +include_HEADERS += include/watchdog.h
>> This new file perhaps should be named bspwatchdog.h
> Makes sens, only copied naming from another BSP.
>>>  if HAS_SMP
>>>  libbsp_a_SOURCES += smp/getcpuid.c
>>> diff --git a/c/src/lib/libbsp/sparc/leon3/include/watchdog.h
>>> b/c/src/lib/libbsp/sparc/leon3/include/watchdog.h
>>> new file mode 100644
>>> index 0000000..8110efd
>>> --- /dev/null
>>> +++ b/c/src/lib/libbsp/sparc/leon3/include/watchdog.h
>>> @@ -0,0 +1,49 @@
>>> +/*  watchdog.h
>>> + *  The LEON3 BSP timer watch-dog interface
>>> + *  COPYRIGHT (c) 2012
>>> + *  Aeroflex Gaisler
>>> + *  The license and distribution terms for this file may be
>>> + *  found in the file LICENSE in this distribution or at
>>> + *  http://www.rtems.com/license/LICENSE.
>>> +#ifndef __WATCHDOG_H__
>>> +#define __WATCHDOG_H__
>>> +#ifdef __cplusplus
>>> +extern "C" {
>>> +#endif
>>> +/* Initialize BSP watchdog routines. Returns number of watchdog timers
>>> found.
>>> + * Currently only one is supported.
>>> +int bsp_watchdog_init(void);
>> Please name bsp_watchdog_initialize() -- for shared code we prefer to
>> avoid abbreviations.
> Ok.
>>> +/* Reload watchdog (last timer on the first GPTIMER core), all systems
>>> does not
>>> + * feature a watchdog, it is expected that if this function is called
>>> the
>>> + * user knows that there is a watchdog available.
>>> + * The prescaler is normally set to number of MHz of system, this is to
>>> + * make the system clock tick be stable.
>>> + * Arguments
>>> + *  watchdog       - Always 0 for now
>>> + *  reload_value   - Number of timer clocks (after prescaler) to count
>>> before
>>> + *                   watchdog is woken.
>>> +void bsp_watchdog_reload(int watchdog, unsigned int reload_value);
>>> +/* Stop watchdog timer */
>>> +void bsp_watchdog_stop(int watchdog);
>>> +/* Use watchdog0 timer to reset the system */
>>> +void bsp_watchdog_system_reset(void);
>> Why not pass the watchdog number to use in this function also?
> My intention was that it is up to the BSP to select a appropriate watchdog,
> like the primary watchdog in Joel's driver. Partly the problem is that BSP
> compile-time code may invoke the watchdog, for example the reboot code.
> However, perhaps it is good to let the user configure it some how.
The BSP can choose to ignore the watchdog parameter if it makes sense to do so.
>>> +#ifdef __cplusplus
>>> +#endif
>>> +#endif
>>> diff --git a/c/src/lib/libbsp/sparc/leon3/preinstall.am
>>> b/c/src/lib/libbsp/sparc/leon3/preinstall.am
>>> index dffbb5a..b55cf35 100644
>>> --- a/c/src/lib/libbsp/sparc/leon3/preinstall.am
>>> +++ b/c/src/lib/libbsp/sparc/leon3/preinstall.am
>>> @@ -149,3 +149,7 @@ $(PROJECT_INCLUDE)/i2cmst.h:
>>> ../../sparc/shared/include/i2cmst.h $(PROJECT_INCLU
>>>        $(INSTALL_DATA) $<  $(PROJECT_INCLUDE)/i2cmst.h
>>>  PREINSTALL_FILES += $(PROJECT_INCLUDE)/i2cmst.h
>>> +$(PROJECT_INCLUDE)/watchdog.h: include/watchdog.h
>>> $(PROJECT_INCLUDE)/$(dirstamp)
>>> +       $(INSTALL_DATA) $<  $(PROJECT_INCLUDE)/watchdog.h
>>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/watchdog.h
>>> diff --git a/c/src/lib/libbsp/sparc/leon3/timer/watchdog.c
>>> b/c/src/lib/libbsp/sparc/leon3/timer/watchdog.c
>>> index 0000000..b09ab9c
>>> --- /dev/null
>>> +++ b/c/src/lib/libbsp/sparc/leon3/timer/watchdog.c
>>> @@ -0,0 +1,90 @@
>>> +/*  GPTIMER Watchdog timer routines. On some systems the first GPTIMER
>>> + *  core's last Timer instance underflow signal is connected to system
>>> + *  reset.
>>> +#include<bsp.h>
>>> +#include<watchdog.h>
>>> +#include<grlib.h>
>>> +extern volatile struct gptimer_regs *LEON3_Timer_Regs;
>>> +struct gptimer_watchdog_priv {
>>> +  struct gptimer_regs *regs;
>>> +  struct gptimer_timer_regs *timer;
>>> +  int timerno;
>>> +struct gptimer_watchdog_priv bsp_watchdogs[1];
>>> +int bsp_watchdog_count = 0;
>>> +  int timercnt;
>>> +  if (!LEON3_Timer_Regs)
>>> +    return 0;
>>> +  /* Get Watchdogs in system, this is implemented for one GPTIMER core
>>> +   * only.
>>> +   * First watchdog is a special case, we can get the first timer core
>>> by
>>> +   * looking at LEON3_Timer_Regs, the watchdog within a timer core is
>>> +   * always the last timer. Unfortunately we can not know it the
>>> watchdog
>>> +   * functionality is available or not, we assume that it is if we
>>> +   * reached this function.
>>> +  bsp_watchdogs[0].regs = (struct gptimer_regs *)LEON3_Timer_Regs;
>>> +  /* Find Timer that has watchdog functionality */
>>> +  timercnt = bsp_watchdogs[0].regs->cfg&  0x7;
>>> +  if (timercnt<  2) /* First timer system clock timer */
>>> +    return 0;
>>> +  bsp_watchdogs[0].timerno = timercnt - 1;
>>> =&bsp_watchdogs[0].regs->timer[bsp_watchdogs[0].timerno];
>>> +  bsp_watchdog_count = 1;
>> Can we get rid of this global var?
>>> +  return bsp_watchdog_count;
>>> +  if (bsp_watchdog_count == 0)
>>> +    bsp_watchdog_init();
>>> +  if (bsp_watchdog_count<= watchdog)
>>> +    return;
>>> +  /* Kick watchdog, and clear interrupt pending bit */
>>> +  bsp_watchdogs[watchdog].timer->reload = reload_value;
>>> +  bsp_watchdogs[watchdog].timer->ctrl =
>>> +    (LEON3_GPTIMER_LD | LEON3_GPTIMER_EN) |
>>> +    (bsp_watchdogs[watchdog].timer->ctrl&  ~(1<<4));
>>> +    return;
>>> +  /* Stop watchdog timer */
>>> +  bsp_watchdogs[watchdog].timer->ctrl = 0;
>>> +/* Use watchdog timer to reset system */
>>> +  sparc_disable_interrupts();
>>> +  bsp_watchdog_reload(0, 1);
>>> 1.7.0.4
