[PATCH 35 v3] LEON: moved register definitions into grlib header file
Joel Sherrill
joel.sherrill at OARcorp.com
Fri Apr 20 11:19:45 UTC 2012
Grrr... ok but reference to debugputs.c which is renamed now.
Ok to commit if a quick follow up addresses that
Daniel Hellstrom <daniel at gaisler.com> wrote:
>Some register layout definitions for LEON3 reside in ambapp.h which
>does not really has anything to do with device registers. The
>register structures has been incorrectly named LEON3_*, the cores
>are not only used on LEON3 but on LEON4 and perhaps on LEON5 when
>that day comes. Some structures has been renamed according to the
>GRLIB core name instead, which CPU that actually use it is not
>relevant. Drivers has been updated with the new names.
>Signed-off-by: Daniel Hellstrom <daniel at gaisler.com>
> c/src/lib/libbsp/sparc/Makefile.am | 1 +
> c/src/lib/libbsp/sparc/leon2/Makefile.am | 1 +
> c/src/lib/libbsp/sparc/leon2/preinstall.am | 4 +
> c/src/lib/libbsp/sparc/leon2/rasta/rasta.c | 29 +------
> c/src/lib/libbsp/sparc/leon3/Makefile.am | 1 +
> c/src/lib/libbsp/sparc/leon3/amba/amba.c | 7 +-
> c/src/lib/libbsp/sparc/leon3/clock/ckinit.c | 10 +-
> c/src/lib/libbsp/sparc/leon3/console/console.c | 8 +-
> .../libbsp/sparc/leon3/console/printk_support.c | 8 +-
> c/src/lib/libbsp/sparc/leon3/include/amba.h | 1 +
> c/src/lib/libbsp/sparc/leon3/include/leon.h | 28 +------
> .../sparc/leon3/leon_smc91111/leon_smc91111.c | 12 ++--
> c/src/lib/libbsp/sparc/leon3/preinstall.am | 4 +
> c/src/lib/libbsp/sparc/leon3/timer/timer.c | 4 +-
> c/src/lib/libbsp/sparc/shared/can/grcan.c | 5 +-
> c/src/lib/libbsp/sparc/shared/can/occan.c | 5 +-
> c/src/lib/libbsp/sparc/shared/i2c/i2cmst.c | 5 +-
> c/src/lib/libbsp/sparc/shared/include/ambapp.h | 43 ---------
> c/src/lib/libbsp/sparc/shared/include/grlib.h | 91 ++++++++++++++++++++
> c/src/lib/libbsp/sparc/shared/spw/grspw.c | 5 +-
> c/src/lib/libbsp/sparc/shared/uart/apbuart.c | 13 ++--
> 21 files changed, 152 insertions(+), 133 deletions(-)
> create mode 100644 c/src/lib/libbsp/sparc/shared/include/grlib.h
>diff --git a/c/src/lib/libbsp/sparc/Makefile.am b/c/src/lib/libbsp/sparc/Makefile.am
>index 2b9909c..e0c7de6 100644
>--- a/c/src/lib/libbsp/sparc/Makefile.am
>+++ b/c/src/lib/libbsp/sparc/Makefile.am
>@@ -18,6 +18,7 @@ EXTRA_DIST += shared/irq/irq-shared.c
> # AMBA Plug&Play bus
> EXTRA_DIST += shared/include/ambapp.h
> EXTRA_DIST += shared/include/ambapp_ids.h
>+EXTRA_DIST += shared/include/grlib.h
> EXTRA_DIST += shared/amba/ambapp.c
> EXTRA_DIST += shared/amba/ambapp_alloc.c
> EXTRA_DIST += shared/amba/ambapp_count.c
>diff --git a/c/src/lib/libbsp/sparc/leon2/Makefile.am b/c/src/lib/libbsp/sparc/leon2/Makefile.am
>index c2310bc..d4135fa 100644
>--- a/c/src/lib/libbsp/sparc/leon2/Makefile.am
>+++ b/c/src/lib/libbsp/sparc/leon2/Makefile.am
>@@ -82,6 +82,7 @@ libbsp_a_SOURCES += \
> # AMBA bus
> include_HEADERS += ../../sparc/shared/include/ambapp.h
> include_HEADERS += ../../sparc/shared/include/ambapp_ids.h
>+include_HEADERS += ../../sparc/shared/include/grlib.h
> libbsp_a_SOURCES += ../../sparc/shared/amba/ambapp.c
> libbsp_a_SOURCES += ../../sparc/shared/amba/ambapp_alloc.c
> libbsp_a_SOURCES += ../../sparc/shared/amba/ambapp_count.c
>diff --git a/c/src/lib/libbsp/sparc/leon2/preinstall.am b/c/src/lib/libbsp/sparc/leon2/preinstall.am
>index 2978d58..84aa2b4 100644
>--- a/c/src/lib/libbsp/sparc/leon2/preinstall.am
>+++ b/c/src/lib/libbsp/sparc/leon2/preinstall.am
>@@ -161,6 +161,10 @@ $(PROJECT_INCLUDE)/ambapp_ids.h: ../../sparc/shared/include/ambapp_ids.h $(PROJE
> $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/ambapp_ids.h
> PREINSTALL_FILES += $(PROJECT_INCLUDE)/ambapp_ids.h
>+$(PROJECT_INCLUDE)/grlib.h: ../../sparc/shared/include/grlib.h $(PROJECT_INCLUDE)/$(dirstamp)
>+ $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/grlib.h
>+PREINSTALL_FILES += $(PROJECT_INCLUDE)/grlib.h
> $(PROJECT_INCLUDE)/i2cmst.h: ../../sparc/shared/include/i2cmst.h $(PROJECT_INCLUDE)/$(dirstamp)
> $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/i2cmst.h
> PREINSTALL_FILES += $(PROJECT_INCLUDE)/i2cmst.h
>diff --git a/c/src/lib/libbsp/sparc/leon2/rasta/rasta.c b/c/src/lib/libbsp/sparc/leon2/rasta/rasta.c
>index 0be7e4b..087f9be 100644
>--- a/c/src/lib/libbsp/sparc/leon2/rasta/rasta.c
>+++ b/c/src/lib/libbsp/sparc/leon2/rasta/rasta.c
>@@ -10,6 +10,7 @@
> #include <pci.h>
> #include <rasta.h>
> #include <ambapp.h>
>+#include <grlib.h>
> #include <grcan_rasta.h>
> #include <grspw_rasta.h>
> #include <b1553brm_rasta.h>
>@@ -41,32 +42,10 @@
> #define DBG(x...)
> #endif
>-typedef struct {
>- volatile unsigned int ilevel;
>- volatile unsigned int ipend;
>- volatile unsigned int iforce;
>- volatile unsigned int iclear;
>- volatile unsigned int mpstat;
>- volatile unsigned int notused01;
>- volatile unsigned int notused02;
>- volatile unsigned int notused03;
>- volatile unsigned int notused10;
>- volatile unsigned int notused11;
>- volatile unsigned int notused12;
>- volatile unsigned int notused13;
>- volatile unsigned int notused20;
>- volatile unsigned int notused21;
>- volatile unsigned int notused22;
>- volatile unsigned int notused23;
>- volatile unsigned int mask[16];
>- volatile unsigned int force[16];
>-} LEON3_IrqCtrl_Regs_Map;
> static int bus, dev, fun;
>-LEON3_IrqCtrl_Regs_Map *irq = NULL;
>-LEON_Register_Map *regs = (LEON_Register_Map *)0x80000000;
>+struct irqmp_regs *irq = NULL;
>+LEON_Register_Map *regs = (LEON_Register_Map *)0x80000000;
> struct gpio_reg *gpio0, *gpio1;
>@@ -291,7 +270,7 @@ int rasta_register(void)
> apb_base[2] = 0x000e8000;
> #endif
> /* Set up rasta irq controller */
>- irq = (LEON3_IrqCtrl_Regs_Map *) (bar0+IRQ_OFFSET);
>+ irq = (struct irqmp_regs *) (bar0+IRQ_OFFSET);
> irq->iclear = 0xffff;
> irq->ilevel = 0;
> irq->mask[0] = 0xffff & ~(UART0_IRQ|UART1_IRQ|SPW0_IRQ|SPW1_IRQ|SPW2_IRQ|GRCAN_IRQ|BRM_IRQ);
>diff --git a/c/src/lib/libbsp/sparc/leon3/Makefile.am b/c/src/lib/libbsp/sparc/leon3/Makefile.am
>index f3153f1..e6a04d9 100644
>--- a/c/src/lib/libbsp/sparc/leon3/Makefile.am
>+++ b/c/src/lib/libbsp/sparc/leon3/Makefile.am
>@@ -48,6 +48,7 @@ libbsp_a_SOURCES += gnatsupp/gnatsupp.c ../../sparc/shared/gnatcommon.c
> include_HEADERS += include/amba.h
> libbsp_a_SOURCES += amba/amba.c
>diff --git a/c/src/lib/libbsp/sparc/leon3/amba/amba.c b/c/src/lib/libbsp/sparc/leon3/amba/amba.c
>index 60281f3..d782d76 100644
>--- a/c/src/lib/libbsp/sparc/leon3/amba/amba.c
>+++ b/c/src/lib/libbsp/sparc/leon3/amba/amba.c
>@@ -27,7 +27,7 @@ struct ambapp_bus ambapp_plb;
> extern void leon3_ext_irq_init(void);
> /* Pointers to Interrupt Controller configuration registers */
>-volatile LEON3_IrqCtrl_Regs_Map *LEON3_IrqCtrl_Regs;
>+volatile struct irqmp_regs *LEON3_IrqCtrl_Regs;
> * amba_initialize
>@@ -63,8 +63,7 @@ void amba_initialize(void)
> asm volatile( "mov 1, %g1; ta 0x0" );
>- LEON3_IrqCtrl_Regs = (volatile LEON3_IrqCtrl_Regs_Map *)
>- DEV_TO_APB(adev)->start;
>+ LEON3_IrqCtrl_Regs = (volatile struct irqmp_regs *)DEV_TO_APB(adev)->start;
> if ((LEON3_IrqCtrl_Regs->ampctrl >> 28) > 0) {
> /* IRQ Controller has support for multiple IRQ Controllers, each
> * CPU can be routed to different Controllers, we find out which
>@@ -87,7 +86,7 @@ void amba_initialize(void)
> VENDOR_GAISLER, GAISLER_GPTIMER,
> ambapp_find_by_idx, NULL);
> if (adev) {
>- LEON3_Timer_Regs = (volatile LEON3_Timer_Regs_Map *)DEV_TO_APB(adev)->start;
>+ LEON3_Timer_Regs = (volatile struct gptimer_regs *)DEV_TO_APB(adev)->start;
> /* Register AMBA Bus Frequency */
> ambapp_freq_init(&ambapp_plb, adev,
>diff --git a/c/src/lib/libbsp/sparc/leon3/clock/ckinit.c b/c/src/lib/libbsp/sparc/leon3/clock/ckinit.c
>index 2a75a35..ce47cb6 100644
>--- a/c/src/lib/libbsp/sparc/leon3/clock/ckinit.c
>+++ b/c/src/lib/libbsp/sparc/leon3/clock/ckinit.c
>@@ -38,7 +38,7 @@
> #endif
>-volatile LEON3_Timer_Regs_Map *LEON3_Timer_Regs = 0;
>+volatile struct gptimer_regs *LEON3_Timer_Regs = 0;
> static int clkirq;
> #define CLOCK_VECTOR LEON_TRAP_TYPE( clkirq )
>@@ -65,9 +65,9 @@ static int clkirq;
> VENDOR_GAISLER, GAISLER_GPTIMER, ambapp_find_by_idx, NULL); \
> if (adev) { \
> /* Found APB GPTIMER Timer */ \
>- LEON3_Timer_Regs = (volatile LEON3_Timer_Regs_Map *) \
>+ LEON3_Timer_Regs = (volatile struct gptimer_regs *) \
> DEV_TO_APB(adev)->start; \
>- clkirq = (LEON3_Timer_Regs->status & 0xf8) >> 3; \
>+ clkirq = (LEON3_Timer_Regs->cfg & 0xf8) >> 3; \
> Adjust_clkirq_for_node(); \
>@@ -83,7 +83,7 @@ static int clkirq;
> LEON3_Timer_Regs->timer[LEON3_CLOCK_INDEX].reload = \
> rtems_configuration_get_microseconds_per_tick() - 1; \
>- LEON3_Timer_Regs->timer[LEON3_CLOCK_INDEX].conf = \
>+ LEON3_Timer_Regs->timer[LEON3_CLOCK_INDEX].ctrl = \
> LEON3_GPTIMER_EN | LEON3_GPTIMER_RL | \
> LEON3_GPTIMER_LD | LEON3_GPTIMER_IRQEN; \
> } while (0)
>@@ -91,7 +91,7 @@ static int clkirq;
> #define Clock_driver_support_shutdown_hardware() \
> do { \
> LEON_Mask_interrupt(LEON_TRAP_TYPE(clkirq)); \
>- LEON3_Timer_Regs->timer[LEON3_CLOCK_INDEX].conf = 0; \
>+ LEON3_Timer_Regs->timer[LEON3_CLOCK_INDEX].ctrl = 0; \
> } while (0)
> uint32_t bsp_clock_nanoseconds_since_last_tick(void)
>diff --git a/c/src/lib/libbsp/sparc/leon3/console/console.c b/c/src/lib/libbsp/sparc/leon3/console/console.c
>index 0575468..94ad50c 100644
>--- a/c/src/lib/libbsp/sparc/leon3/console/console.c
>+++ b/c/src/lib/libbsp/sparc/leon3/console/console.c
>@@ -49,7 +49,7 @@ int syscon_uart_index __attribute__((weak)) = 0;
> extern void apbuart_outbyte_polled(
>- ambapp_apb_uart *regs,
>+ struct apbuart_regs *regs,
> unsigned char ch,
> int do_cr_on_newline,
> int wait_sent
>@@ -64,12 +64,12 @@ extern void apbuart_outbyte_polled(
> * This routine polls for a character.
>-extern int apbuart_inbyte_nonblocking(ambapp_apb_uart *regs);
>+extern int apbuart_inbyte_nonblocking(struct apbuart_regs *regs);
> /* body is in debugputs.c */
> struct apbuart_priv {
>- ambapp_apb_uart *regs;
>+ struct apbuart_regs *regs;
> unsigned int freq_hz;
> #if CONSOLE_USE_INTERRUPTS
> int irq;
>@@ -252,7 +252,7 @@ int find_matching_apbuart(struct ambapp_dev *dev, int index, void *arg)
> struct ambapp_apb_info *apb = (struct ambapp_apb_info *)dev->devinfo;
> /* Extract needed information of one APBUART */
>- apbuarts[uarts].regs = (ambapp_apb_uart *)apb->start;
>+ apbuarts[uarts].regs = (struct apbuart_regs *)apb->start;
> apbuarts[uarts].irq = apb->irq;
> #endif
>diff --git a/c/src/lib/libbsp/sparc/leon3/console/printk_support.c b/c/src/lib/libbsp/sparc/leon3/console/printk_support.c
>index 080d4fa..9815053 100644
>--- a/c/src/lib/libbsp/sparc/leon3/console/printk_support.c
>+++ b/c/src/lib/libbsp/sparc/leon3/console/printk_support.c
>@@ -29,7 +29,7 @@
> int debug_uart_index __attribute__((weak)) = 0;
>-ambapp_apb_uart *dbg_uart = NULL;
>+struct apbuart_regs *dbg_uart = NULL;
> /* Before UART driver has registered (or when no UART is available), calls to
> * printk that gets to bsp_out_char() will be filling data into the
>@@ -74,7 +74,7 @@ int bsp_debug_uart_init(void)
> * for printk
> apb = (struct ambapp_apb_info *)adev->devinfo;
>- dbg_uart = (ambapp_apb_uart *)apb->start;
>+ dbg_uart = (struct apbuart_regs *)apb->start;
> dbg_uart->ctrl |= LEON_REG_UART_CTRL_RE | LEON_REG_UART_CTRL_TE;
> dbg_uart->status = 0;
> return 1;
>@@ -88,7 +88,7 @@ int bsp_debug_uart_init(void)
> * This routine transmits a character using polling.
> unsigned char ch,
> int wait_sent
>@@ -121,7 +121,7 @@ send:
>-int apbuart_inbyte_nonblocking(ambapp_apb_uart *regs)
>+int apbuart_inbyte_nonblocking(struct apbuart_regs *regs)
> /* Clear errors */
> if (regs->status & LEON_REG_UART_STATUS_ERR)
>diff --git a/c/src/lib/libbsp/sparc/leon3/include/amba.h b/c/src/lib/libbsp/sparc/leon3/include/amba.h
>index 32b4a42..a4a0ac9 100644
>--- a/c/src/lib/libbsp/sparc/leon3/include/amba.h
>+++ b/c/src/lib/libbsp/sparc/leon3/include/amba.h
>@@ -27,6 +27,7 @@
> #define LEON3_APB_SLAVES 16
> #include <ambapp.h>
>+#include <grlib.h>
> #ifdef __cplusplus
> extern "C" {
>diff --git a/c/src/lib/libbsp/sparc/leon3/include/leon.h b/c/src/lib/libbsp/sparc/leon3/include/leon.h
>index da752b2..96a4262 100644
>--- a/c/src/lib/libbsp/sparc/leon3/include/leon.h
>+++ b/c/src/lib/libbsp/sparc/leon3/include/leon.h
>@@ -46,30 +46,6 @@ extern "C" {
> ( (_trap) >= 0x11 && \
> (_trap) <= 0x1F )
>-typedef struct {
>- volatile unsigned int value;
>- volatile unsigned int reload;
>- volatile unsigned int conf;
>- volatile unsigned int notused;
>-} LEON3_Timer_SubType;
>-typedef struct {
>- volatile unsigned int scaler_value; /* common timer registers */
>- volatile unsigned int scaler_reload;
>- volatile unsigned int status;
>- LEON3_Timer_SubType timer[8];
>-} LEON3_Timer_Regs_Map;
>-typedef struct {
>- volatile unsigned int iodata;
>- volatile unsigned int ioout;
>- volatile unsigned int iodir;
>- volatile unsigned int irqmask;
>- volatile unsigned int irqpol;
>- volatile unsigned int irqedge;
>-} LEON3_IOPORT_Regs_Map;
> /* * This is used to manipulate the on-chip registers. */
>@@ -139,8 +115,8 @@ typedef struct {
> #define LEON_REG_UART_CTRL_FL 0x00000040 /* Flow control enable */
> #define LEON_REG_UART_CTRL_LB 0x00000080 /* Loop Back enable */
>-extern volatile LEON3_IrqCtrl_Regs_Map *LEON3_IrqCtrl_Regs; /* LEON3 Interrupt Controller */
>-extern volatile LEON3_Timer_Regs_Map *LEON3_Timer_Regs; /* LEON3 GP Timer */
>+extern volatile struct irqmp_regs *LEON3_IrqCtrl_Regs; /* LEON3 Interrupt Controller */
>+extern volatile struct gptimer_regs *LEON3_Timer_Regs; /* LEON3 GP Timer */
> /* LEON3 CPU Index of boot CPU */
> extern int LEON3_Cpu_Index;
>diff --git a/c/src/lib/libbsp/sparc/leon3/leon_smc91111/leon_smc91111.c b/c/src/lib/libbsp/sparc/leon3/leon_smc91111/leon_smc91111.c
>index 9e582fb..9b9961d 100644
>--- a/c/src/lib/libbsp/sparc/leon3/leon_smc91111/leon_smc91111.c
>+++ b/c/src/lib/libbsp/sparc/leon3/leon_smc91111/leon_smc91111.c
>@@ -34,7 +34,7 @@ rtems_smc91111_driver_attach_leon3 (struct rtems_bsdnet_ifconfig *config,
> int attach)
> unsigned long addr_mctrl = 0;
>- LEON3_IOPORT_Regs_Map *io;
>+ struct grgpio_regs *io;
> struct ambapp_apb_info apbpio;
> struct ambapp_apb_info apbmctrl;
>@@ -63,7 +63,7 @@ rtems_smc91111_driver_attach_leon3 (struct rtems_bsdnet_ifconfig *config,
> /* Get controller address */
> addr_mctrl = (unsigned long) apbmctrl.start;
>- io = (LEON3_IOPORT_Regs_Map *) apbpio.start;
>+ io = (struct grgpio_regs *) apbpio.start;
> printk(
> "Activating Leon3 io port for smsc_lan91cxx (pio:%x mctrl:%x)\n",
>@@ -71,10 +71,10 @@ rtems_smc91111_driver_attach_leon3 (struct rtems_bsdnet_ifconfig *config,
> (unsigned int)addr_mctrl);
> /* Setup PIO IRQ */
>- io->irqmask |= (1 << leon_scmv91111_configuration.pio);
>- io->irqpol |= (1 << leon_scmv91111_configuration.pio);
>- io->irqedge |= (1 << leon_scmv91111_configuration.pio);
>- io->iodir &= ~(1 << leon_scmv91111_configuration.pio);
>+ io->imask |= (1 << leon_scmv91111_configuration.pio);
>+ io->ipol |= (1 << leon_scmv91111_configuration.pio);
>+ io->iedge |= (1 << leon_scmv91111_configuration.pio);
>+ io->dir &= ~(1 << leon_scmv91111_configuration.pio);
> /* Setup memory controller I/O waitstates */
> *((volatile unsigned int *) addr_mctrl) |= 0x10f80000; /* enable I/O area access */
>diff --git a/c/src/lib/libbsp/sparc/leon3/preinstall.am b/c/src/lib/libbsp/sparc/leon3/preinstall.am
>index 540e37b..dffbb5a 100644
>--- a/c/src/lib/libbsp/sparc/leon3/preinstall.am
>+++ b/c/src/lib/libbsp/sparc/leon3/preinstall.am
>@@ -89,6 +89,10 @@ $(PROJECT_INCLUDE)/ambapp_ids.h: ../../sparc/shared/include/ambapp_ids.h $(PROJE
> $(PROJECT_INCLUDE)/bsp/irq-generic.h: ../../shared/include/irq-generic.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
> $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/irq-generic.h
> PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/irq-generic.h
>diff --git a/c/src/lib/libbsp/sparc/leon3/timer/timer.c b/c/src/lib/libbsp/sparc/leon3/timer/timer.c
>index f747dd6..241ecb8 100644
>--- a/c/src/lib/libbsp/sparc/leon3/timer/timer.c
>+++ b/c/src/lib/libbsp/sparc/leon3/timer/timer.c
>@@ -35,7 +35,7 @@ bool benchmark_timer_find_average_overhead;
> bool benchmark_timer_is_initialized = false;
> void benchmark_timer_initialize(void)
>@@ -50,7 +50,7 @@ void benchmark_timer_initialize(void)
> } else {
> benchmark_timer_is_initialized = true;
>- LEON3_Timer_Regs->timer[LEON3_TIMER_INDEX].conf = LEON3_GPTIMER_EN | LEON3_GPTIMER_LD;
>+ LEON3_Timer_Regs->timer[LEON3_TIMER_INDEX].ctrl = LEON3_GPTIMER_EN | LEON3_GPTIMER_LD;
>diff --git a/c/src/lib/libbsp/sparc/shared/can/grcan.c b/c/src/lib/libbsp/sparc/shared/can/grcan.c
>index 3b0a14a..d592fba 100644
>--- a/c/src/lib/libbsp/sparc/shared/can/grcan.c
>+++ b/c/src/lib/libbsp/sparc/shared/can/grcan.c
>@@ -26,6 +26,7 @@
> #include <grcan.h>
> #include <ambapp.h>
>+#include <grlib.h>
> #define WRAP_AROUND_TX_MSGS 1
> #define WRAP_AROUND_RX_MSGS 2
>@@ -1097,11 +1098,11 @@ static rtems_device_driver grcan_initialize(
> /* LEON3: find timer address via AMBA Plug&Play info */
> struct ambapp_apb_info gptimer;
>- LEON3_Timer_Regs_Map *tregs;
>+ struct gptimer_regs *tregs;
> if (ambapp_find_apbslv (&ambapp_plb, VENDOR_GAISLER, GAISLER_GPTIMER, &gptimer)
> == 1) {
>- tregs = (LEON3_Timer_Regs_Map *) gptimer.start;
>+ tregs = (struct gptimer_regs *) gptimer.start;
> sys_freq_hz = (tregs->scaler_reload + 1) * 1000 * 1000;
> DBG("GRCAN: detected %dHZ system frequency\n\r", sys_freq_hz);
> } else {
>diff --git a/c/src/lib/libbsp/sparc/shared/can/occan.c b/c/src/lib/libbsp/sparc/shared/can/occan.c
>index 4fb932d..b1bf54e 100644
>--- a/c/src/lib/libbsp/sparc/shared/can/occan.c
>+++ b/c/src/lib/libbsp/sparc/shared/can/occan.c
>@@ -19,6 +19,7 @@
> #include <leon.h>
> #include <ambapp.h>
>+#include <grlib.h>
> #include <occan.h>
> /* RTEMS -> ERRNO decoding table
>@@ -936,11 +937,11 @@ static rtems_device_driver occan_initialize(rtems_device_major_number major, rte
> if ( ambapp_find_apbslv(&ambapp_plb, VENDOR_GAISLER,
> GAISLER_GPTIMER, &gptimer) == 1 ){
>- tregs = (LEON3_Timer_Regs_Map *)gptimer.start;
>+ tregs = (struct gptimer_regs *)gptimer.start;
> sys_freq_hz = (tregs->scaler_reload+1)*1000*1000;
> DBG("OCCAN: detected %dHZ system frequency\n\r",sys_freq_hz);
> }else{
>diff --git a/c/src/lib/libbsp/sparc/shared/i2c/i2cmst.c b/c/src/lib/libbsp/sparc/shared/i2c/i2cmst.c
>index 7ba7208..7acf17d 100644
>--- a/c/src/lib/libbsp/sparc/shared/i2c/i2cmst.c
>+++ b/c/src/lib/libbsp/sparc/shared/i2c/i2cmst.c
>@@ -17,6 +17,7 @@
> #include <bsp.h>
> #include <i2cmst.h>
> #include <ambapp.h>
>+#include <grlib.h>
> #include <rtems/libi2c.h>
> /* Enable debug printks? */
>@@ -318,11 +319,11 @@ rtems_status_code leon_register_i2c(struct ambapp_bus *abus)
> if (ambapp_find_apbslv(abus, VENDOR_GAISLER,
> GAISLER_GPTIMER, &gptimer) == 1 ) {
> gr_i2cmst_desc.prv.sysfreq = (tregs->scaler_reload+1)*1000;
> } else {
> gr_i2cmst_desc.prv.sysfreq = 40000; /* Default to 40MHz */
>diff --git a/c/src/lib/libbsp/sparc/shared/include/ambapp.h b/c/src/lib/libbsp/sparc/shared/include/ambapp.h
>index 5eb3f2a..c3fd13a 100644
>--- a/c/src/lib/libbsp/sparc/shared/include/ambapp.h
>+++ b/c/src/lib/libbsp/sparc/shared/include/ambapp.h
>@@ -355,49 +355,6 @@ extern int ambapp_find_ahbslvs(
> int maxno);
>-/******** AMBA DEVICES *******/
>-/* ESA MEMORY CONTROLLER */
>-typedef struct {
>- unsigned int mcfg1;
>- unsigned int mcfg2;
>- unsigned int mcfg3;
>-} ambapp_regmap_mctrl;
>-/* APB UART */
>-typedef struct {
>- volatile unsigned int data;
>- volatile unsigned int ctrl;
>- volatile unsigned int scaler;
>-} ambapp_apb_uart;
>-typedef struct {
>- volatile unsigned int ampctrl;
>- volatile unsigned int icsel[2];
>- /* Extended IRQ registers */
>- volatile unsigned int intid[16];
>- /* 0x100, align to 4Kb boundary */
>- volatile unsigned int resv1[(0x1000-0x100)/4];
> #ifdef __cplusplus
> #endif
>diff --git a/c/src/lib/libbsp/sparc/shared/include/grlib.h b/c/src/lib/libbsp/sparc/shared/include/grlib.h
>new file mode 100644
>index 0000000..7f1f7d0
>--- /dev/null
>+++ b/c/src/lib/libbsp/sparc/shared/include/grlib.h
>@@ -0,0 +1,91 @@
>+ * Common GRLIB AMBA Core Register definitions
>+ * COPYRIGHT (c) 2012
>+ * Aeroflex Gaisler
>+ * The license and distribution terms for this file may be
>+ * found in the file LICENSE in this distribution or at
>+ * http://www.rtems.com/license/LICENSE.
>+#ifndef __GRLIB_H__
>+#define __GRLIB_H__
>+#ifdef __cplusplus
>+extern "C" {
>+#endif
>+/* ESA MEMORY CONTROLLER */
>+struct mctrl_regs {
>+ unsigned int mcfg1;
>+ unsigned int mcfg2;
>+ unsigned int mcfg3;
>+/* APB UART */
>+struct apbuart_regs {
>+ volatile unsigned int data;
>+ volatile unsigned int status;
>+ volatile unsigned int ctrl;
>+ volatile unsigned int scaler;
>+/* IRQMP and IRQAMP interrupt controllers */
>+struct irqmp_regs {
>+ volatile unsigned int ilevel; /* 0x00 */
>+ volatile unsigned int ipend; /* 0x04 */
>+ volatile unsigned int iforce; /* 0x08 */
>+ volatile unsigned int iclear; /* 0x0c */
>+ volatile unsigned int mpstat; /* 0x10 */
>+ volatile unsigned int bcast; /* 0x14 */
>+ volatile unsigned int notused02; /* 0x18 */
>+ volatile unsigned int notused03; /* 0x1c */
>+ volatile unsigned int ampctrl; /* 0x20 */
>+ volatile unsigned int icsel[2]; /* 0x24,0x28 */
>+ volatile unsigned int notused13; /* 0x2c */
>+ volatile unsigned int notused20; /* 0x30 */
>+ volatile unsigned int notused21; /* 0x34 */
>+ volatile unsigned int notused22; /* 0x38 */
>+ volatile unsigned int notused23; /* 0x3c */
>+ volatile unsigned int mask[16]; /* 0x40 */
>+ volatile unsigned int force[16]; /* 0x80 */
>+ /* Extended IRQ registers */
>+ volatile unsigned int intid[16]; /* 0xc0 */
>+ /* 0x100, align to 4Kb boundary */
>+ volatile unsigned int resv1[(0x1000-0x100)/4];
>+/* GPTIMER Timer instance */
>+struct gptimer_timer_regs {
>+ volatile unsigned int value;
>+ volatile unsigned int reload;
>+ volatile unsigned int notused;
>+/* GPTIMER common registers */
>+struct gptimer_regs {
>+ volatile unsigned int scaler_value; /* common timer registers */
>+ volatile unsigned int scaler_reload;
>+ volatile unsigned int cfg;
>+ struct gptimer_timer_regs timer[7];
>+/* GRGPIO GPIO */
>+struct grgpio_regs {
>+ volatile unsigned int data; /* 0x00 I/O port data register */
>+ volatile unsigned int output; /* 0x04 I/O port output register */
>+ volatile unsigned int dir; /* 0x08 I/O port direction register */
>+ volatile unsigned int imask; /* 0x0C Interrupt mask register */
>+ volatile unsigned int ipol; /* 0x10 Interrupt polarity register */
>+ volatile unsigned int iedge; /* 0x14 Interrupt edge register */
>+ volatile unsigned int bypass; /* 0x18 Bypass register */
>+#ifdef __cplusplus
>+#endif
>+#endif
>diff --git a/c/src/lib/libbsp/sparc/shared/spw/grspw.c b/c/src/lib/libbsp/sparc/shared/spw/grspw.c
>index 8ab5020..55986ba 100644
>--- a/c/src/lib/libbsp/sparc/shared/spw/grspw.c
>+++ b/c/src/lib/libbsp/sparc/shared/spw/grspw.c
>@@ -83,6 +83,7 @@
> #include <ctype.h>
> #include <rtems/bspIo.h>
> #include <ambapp.h>
>+#include <grlib.h>
> #include <grspw.h>
> #define DBGSPW_IOCALLS 1
>@@ -390,11 +391,11 @@ int GRSPW_PREFIX(_register)(struct ambapp_bus *bus)
> sys_freq_khz = (tregs->scaler_reload+1)*1000;
> SPACEWIRE_DBG("GRSPW: detected %dkHZ system frequency\n\r",sys_freq_khz);
> }else{
>diff --git a/c/src/lib/libbsp/sparc/shared/uart/apbuart.c b/c/src/lib/libbsp/sparc/shared/uart/apbuart.c
>index d442e80..25d0373 100644
>--- a/c/src/lib/libbsp/sparc/shared/uart/apbuart.c
>+++ b/c/src/lib/libbsp/sparc/shared/uart/apbuart.c
>@@ -22,6 +22,7 @@
> #include <string.h>
> #include <ambapp.h>
>+#include <grlib.h>
> #include <apbuart.h>
> #ifndef DEFAULT_TXBUF_SIZE
>@@ -79,7 +80,7 @@ static rtems_device_driver apbuart_write(rtems_device_major_number major, rtems_
> static rtems_device_driver apbuart_control(rtems_device_major_number major, rtems_device_minor_number minor, void *arg);
> typedef struct {
> int irq;
> int minor;
> int scaler;
>@@ -153,7 +154,7 @@ static void apbuart_hw_open(apbuart_priv *uart);
> #endif
> #if 0
>-static int apbuart_outbyte_try(ambapp_apb_uart *regs, unsigned char ch)
>+static int apbuart_outbyte_try(struct apbuart_regs *regs, unsigned char ch)
> if ( (READ_REG(®s->status) & LEON_REG_UART_STATUS_THE) == 0 )
> return -1; /* Failed */
>@@ -164,7 +165,7 @@ static int apbuart_outbyte_try(ambapp_apb_uart *regs, unsigned char ch)
>-static int apbuart_inbyte_try(ambapp_apb_uart *regs)
>+static int apbuart_inbyte_try(struct apbuart_regs *regs)
> /* Clear errors if any */
>@@ -386,11 +387,11 @@ static rtems_device_driver apbuart_initialize(rtems_device_major_number major,
> DBG("APBUART: detected %dHZ system frequency\n\r",sys_freq_hz);
> }else{
>@@ -419,7 +420,7 @@ static rtems_device_driver apbuart_initialize(rtems_device_major_number major,
> printk("APBUART[%d]: at 0x%x irq %d (0x%x)\n\r",i,dev.start,dev.irq,(unsigned int)&apbuarts[i]);
>- apbuarts[i].regs = (ambapp_apb_uart *)dev.start;
>+ apbuarts[i].regs = (struct apbuart_regs *)dev.start;
> apbuarts[i].irq = dev.irq;
> apbuarts[i].minor = i;
>1.7.0.4
