pull request for atomic
yangwei weiyang wei.a.yang at gmail.com
Wed Aug 1 01:16:35 UTC 2012
Hi Gedare,
First really thank you for your detailed comments. I have modified all
the error you pointed. And there still a question about the 64-bit
support for atomic operations. In my opinion for a architecture it
maybe have 64-bit support or not. So there should be a macro to
indicate whether it supports 64-bit. Is there a macro in RTEMS?
2012/7/31 Gedare Bloom <gedare at rtems.org>:
> I have made some comments on your new version. If you have further
> questions or answers to any questions I put please send an email I am
> more likely to see it.
> -Gedare
> On Wed, Jul 25, 2012 at 2:00 AM,  <wei.a.yang at gmail.com> wrote:
>> 在 2012-7-25,2:42,Gedare Bloom <gedare at rtems.org> 写道:
>>> On Tue, Jul 24, 2012 at 12:29 PM, yangwei weiyang <wei.a.yang at gmail.com> wrote:
>>>> 2012/7/23 Gedare Bloom <gedare at rtems.org>:
>>>>> On Mon, Jul 23, 2012 at 4:45 AM, yangwei weiyang <wei.a.yang at gmail.com> wrote:
>>>>>> 2012/7/23 Sebastian Huber <sebastian.huber at embedded-brains.de>:
>>>>>>> Hi,
>>>>>>> is it possible to squash the commits together?  This makes it easier to
>>>>>>> review.
>>>>>> Hi Sebastian, firstly thank you for your comments. The commits are a
>>>>>> little trivial because all commits are submitted step by step. And i
>>>>>> do not know how to make a pull request on github with a single patch
>>>>>> from first commit to last commit. Or i can generate a patch manually
>>>>>> and send it to mail list.
>>>>> git rebase -i
>>>>> should let you specify revision range and squash commits together.
>>>>> then you can push a new branch and make new request.
>>>> Hi Gedare, Could you tell me more details about this command.
>>>> I use git rebase master atomic but all commits do not squash together.
>>> http://git-scm.com/book/en/Git-Tools-Rewriting-History#Squashing-Commits
>> Hi Gedare. Thank you for your material, it is very useful for me. And I have squash all the commits and create a new branch atomic-review to pull request. Any comments are welcome.
>>>>>>> Since you wrote the files probably on your own they should have your
>>>>>>> copyright.
>>>>>> OK, i will add the copyright to the appropriate files.
>>>>>>> The file "cpukit/score/cpu/i386/rtems/score/atomic_cpu.h" should include a
>>>>>>> generic file e.g. "cpukit/score/include/rtems/score/genericcpuatomic.h" with
>>>>>>> the type definitions.  I think we can use this generic file on every CPU
>>>>>>> port.
>>>>>> Yeah, agree. And RTEMS support so many architectures so i will think
>>>>>> about what types should be generic to all cpu architecture.
>>>>>>> I suggest to use the following type names:
>>>>>>> Atomic_Int
>>>>>>> Atomic_Long
>>>>>>> Atomic_Int32
>>>>>>> Atomic_Int64
>>>>>>> Atomic_Pointer
>>>>>> OK. and which file follow this rule that i can study the name rule on RTEMS?
>>>>>>> I suggest to rename "atomic_cpu.h" into "cpuatomic.h".  Currently there is
>>>>>>> no header file in the score with a "_".
>>>>>> OK.
>>>>>>> On 07/22/2012 06:08 PM, yangwei weiyang wrote:
>>>>>>>> Hi all,
>>>>>>>> I have made a pull request for review the source code of atomic, and
>>>>>>>> could you give me any comments? thank you!
>>>>>>>> pull request link is blow:
>>>>>>>> https://github.com/RTEMS/rtems/pull/1
>>>>>>> Sebastian Huber, embedded brains GmbH
>>>>>>> Address : Obere Lagerstr. 30, D-82178 Puchheim, Germany
>>>>>>> Phone   : +49 89 18 90 80 79-6
>>>>>>> Fax     : +49 89 18 90 80 79-9
>>>>>>> E-Mail  : sebastian.huber at embedded-brains.de
>>>>>>> PGP     : Public key available on request.
>>>>>>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
>>>>>>> _______________________________________________
>>>>>>> rtems-devel mailing list
>>>>>>> rtems-devel at rtems.org
>>>>>>> http://www.rtems.org/mailman/listinfo/rtems-devel
>>>>>> Wei Yang
>>>>>> Best Regards
>>>> Wei Yang
>>>> Best Regards
Wei Yang
Best Regards
