pull request for atomic
Gedare Bloom
gedare at rtems.org
Wed Aug 1 14:31:37 UTC 2012
I'm confused. I thought I read in the documentation that if an
operation is unsupported by an architecture then the operation does
nothing. Instead are you saying you would like to check at
compile-time whether 64-bit atomics are supported somehow?
Off the top of my head I do not know if that capability exists.
-Gedare
On Tue, Jul 31, 2012 at 9:16 PM, yangwei weiyang <wei.a.yang at gmail.com> wrote:
> Hi Gedare,
> First really thank you for your detailed comments. I have modified all
> the error you pointed. And there still a question about the 64-bit
> support for atomic operations. In my opinion for a architecture it
> maybe have 64-bit support or not. So there should be a macro to
> indicate whether it supports 64-bit. Is there a macro in RTEMS?
> 2012/7/31 Gedare Bloom <gedare at rtems.org>:
>> I have made some comments on your new version. If you have further
>> questions or answers to any questions I put please send an email I am
>> more likely to see it.
>> -Gedare
>> On Wed, Jul 25, 2012 at 2:00 AM, <wei.a.yang at gmail.com> wrote:
>>> 在 2012-7-25,2:42,Gedare Bloom <gedare at rtems.org> 写道:
>>>> On Tue, Jul 24, 2012 at 12:29 PM, yangwei weiyang <wei.a.yang at gmail.com> wrote:
>>>>> 2012/7/23 Gedare Bloom <gedare at rtems.org>:
>>>>>> On Mon, Jul 23, 2012 at 4:45 AM, yangwei weiyang <wei.a.yang at gmail.com> wrote:
>>>>>>> 2012/7/23 Sebastian Huber <sebastian.huber at embedded-brains.de>:
>>>>>>>> Hi,
>>>>>>>> is it possible to squash the commits together? This makes it easier to
>>>>>>>> review.
>>>>>>> Hi Sebastian, firstly thank you for your comments. The commits are a
>>>>>>> little trivial because all commits are submitted step by step. And i
>>>>>>> do not know how to make a pull request on github with a single patch
>>>>>>> from first commit to last commit. Or i can generate a patch manually
>>>>>>> and send it to mail list.
>>>>>> git rebase -i
>>>>>> should let you specify revision range and squash commits together.
>>>>>> then you can push a new branch and make new request.
>>>>> Hi Gedare, Could you tell me more details about this command.
>>>>> I use git rebase master atomic but all commits do not squash together.
>>>> http://git-scm.com/book/en/Git-Tools-Rewriting-History#Squashing-Commits
>>> Hi Gedare. Thank you for your material, it is very useful for me. And I have squash all the commits and create a new branch atomic-review to pull request. Any comments are welcome.
>>>>>>>> Since you wrote the files probably on your own they should have your
>>>>>>>> copyright.
>>>>>>> OK, i will add the copyright to the appropriate files.
>>>>>>>> The file "cpukit/score/cpu/i386/rtems/score/atomic_cpu.h" should include a
>>>>>>>> generic file e.g. "cpukit/score/include/rtems/score/genericcpuatomic.h" with
>>>>>>>> the type definitions. I think we can use this generic file on every CPU
>>>>>>>> port.
>>>>>>> Yeah, agree. And RTEMS support so many architectures so i will think
>>>>>>> about what types should be generic to all cpu architecture.
>>>>>>>> I suggest to use the following type names:
>>>>>>>> Atomic_Int
>>>>>>>> Atomic_Long
>>>>>>>> Atomic_Int32
>>>>>>>> Atomic_Int64
>>>>>>>> Atomic_Pointer
>>>>>>> OK. and which file follow this rule that i can study the name rule on RTEMS?
>>>>>>>> I suggest to rename "atomic_cpu.h" into "cpuatomic.h". Currently there is
>>>>>>>> no header file in the score with a "_".
>>>>>>> OK.
>>>>>>>> On 07/22/2012 06:08 PM, yangwei weiyang wrote:
>>>>>>>>> Hi all,
>>>>>>>>> I have made a pull request for review the source code of atomic, and
>>>>>>>>> could you give me any comments? thank you!
>>>>>>>>> pull request link is blow:
>>>>>>>>> https://github.com/RTEMS/rtems/pull/1
>>>>>>>> Sebastian Huber, embedded brains GmbH
>>>>>>>> Address : Obere Lagerstr. 30, D-82178 Puchheim, Germany
>>>>>>>> Phone : +49 89 18 90 80 79-6
>>>>>>>> Fax : +49 89 18 90 80 79-9
>>>>>>>> E-Mail : sebastian.huber at embedded-brains.de
>>>>>>>> PGP : Public key available on request.
>>>>>>>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
>>>>>>>> _______________________________________________
>>>>>>>> rtems-devel mailing list
>>>>>>>> rtems-devel at rtems.org
>>>>>>>> http://www.rtems.org/mailman/listinfo/rtems-devel
>>>>>>> Wei Yang
>>>>>>> Best Regards
>>>>> Wei Yang
>>>>> Best Regards
> Wei Yang
> Best Regards
