[rtems commit] Do not remove scripts upon ./bootstrap -c. Introduce ./ bootstrap -c -f.
Thu Aug 9 14:34:04 UTC 2012
Hi,
Do we need the -f flag here, or can we just add the deleted files that -f
removes to be deleted when doing a bootstrap -c ?
-Gedare
On Mon, Aug 6, 2012 at 12:39 PM, Gedare Bloom <gedare at rtems.org> wrote:
> Module:    rtems
> Branch:    master
> Commit:    aa96f47df12980ba786028f169b93e85563e8b39
> Changeset:
> http://git.rtems.org/rtems/commit/?id=aa96f47df12980ba786028f169b93e85563e8b39
> Author:    Ralf Corsépius <ralf.corsepius at rtems.org>
> Date:      Fri Jul 27 10:02:00 2012 +0200
> Do not remove scripts upon ./bootstrap -c. Introduce ./bootstrap -c -f.
>  bootstrap |   63
>  1 files changed, 49 insertions(+), 14 deletions(-)
> diff --git a/bootstrap b/bootstrap
> index 137b4ab..de5d626 100755
> --- a/bootstrap
> +++ b/bootstrap
> @@ -16,6 +16,7 @@ top_srcdir=`dirname $0`
>  verbose="";
>  quiet="false"
>  mode="autoreconf"
> +force=0
>  usage()
> @@ -81,6 +82,9 @@ case $1 in
>  -c|--cl|--cle|--clea|--clean)
>    mode="clean";
>    shift;;
> +-f|--fo|--for|--forc|--force)
> +  force=`expr $force + 1`
> +  shift;;
>  -p|--pr|--pre|--prei|--prein|--preins|--preinst)
>    mode="preinstall";
>    shift;;
> @@ -189,27 +193,58 @@ autoreconf)
>  clean)
>    test "$quiet" = "true" || echo "removing automake generated Makefile.in
> files"
>    files=`find . -name 'Makefile.am' -print | sed -e 's%\.am%\.in%g'` ;
> -  for i in $files; do if test -f $i; then
> -    rm -f $i
> -    test "$verbose" = "-v" && echo "$i"
> -  fi; done
> +  for i in $files; do
> +    if test -f $i; then
> +      rm -f $i
> +      test "$verbose" = "-v" && echo "$i"
> +    fi;
> +  done
>    test "$quiet" = "true" || echo "removing configure files"
>    files=`find . -name 'configure' -print` ;
> -  test "$verbose" = "-v" && test -n "$files" && echo "$files" ;
> -    rm -f $i config.sub config.guess install-sh missing mkinstalldirs
> -# rm -f depcomp compile texinfo.tex mdate-sh
> -  fi; done
> +      rm -f $i
> +    fi;
> +  done
> +  if test $force -gt 0; then
> +    needles=""
> +    if test $force -gt 1; then
> +      # Manually maintained
> +      needles="$needles config.sub"
> +      needles="$needles config.guess"
> +    fi
> +      # Inherited from automake
> +      needles="$needles compile"
> +      needles="$needles depcomp"
> +      needles="$needles install-sh"
> +      needles="$needles missing"
> +      needles="$needles mdate-sh"
> +      needles="$needles texinfo.tex"
> +    fi
> +    for j in $needles; do
> +      files=`find . -name "$j" -print`
> +          rm -f $i
> +        fi;
> +      done
> +    done
> +  fi
>    test "$quiet" = "true" || echo "removing aclocal.m4 files"
>    files=`find . -name 'aclocal.m4' -print` ;
> -    rm -f $i
> -  fi; done
> +      rm -f $i
> +    fi;
> +  done
>    find . -name '*~' -print | xargs rm -f
>    find . -name 'bspopts.h.in' -print | xargs rm -f
> rtems-vc mailing list
> rtems-vc at rtems.org
> http://www.rtems.org/mailman/listinfo/rtems-vc
URL: <http://lists.rtems.org/pipermail/devel/attachments/20120809/22e6ab10/attachment.html>
