[rtems commit] Do not remove scripts upon ./bootstrap -c. Introduce ./ bootstrap -c -f.
Gedare Bloom
gedare at rtems.org
Fri Aug 10 16:30:30 UTC 2012
For that matter, can we wrap bootstrap -p into bootstrap? I think the
default behavior for bootstrap should be to generate everything, and for
bootstrap -c to clean everything.
-Gedare
On Thu, Aug 9, 2012 at 10:34 AM, Gedare Bloom <gedare at rtems.org> wrote:
> Hi,
> Do we need the -f flag here, or can we just add the deleted files that -f
> removes to be deleted when doing a bootstrap -c ?
> -Gedare
> On Mon, Aug 6, 2012 at 12:39 PM, Gedare Bloom <gedare at rtems.org> wrote:
>> Module: rtems
>> Branch: master
>> Commit: aa96f47df12980ba786028f169b93e85563e8b39
>> Changeset:
>> http://git.rtems.org/rtems/commit/?id=aa96f47df12980ba786028f169b93e85563e8b39
>> Author: Ralf Corsépius <ralf.corsepius at rtems.org>
>> Date: Fri Jul 27 10:02:00 2012 +0200
>> Do not remove scripts upon ./bootstrap -c. Introduce ./bootstrap -c -f.
>> bootstrap | 63
>> 1 files changed, 49 insertions(+), 14 deletions(-)
>> diff --git a/bootstrap b/bootstrap
>> index 137b4ab..de5d626 100755
>> --- a/bootstrap
>> +++ b/bootstrap
>> @@ -16,6 +16,7 @@ top_srcdir=`dirname $0`
>> verbose="";
>> quiet="false"
>> mode="autoreconf"
>> +force=0
>> usage()
>> @@ -81,6 +82,9 @@ case $1 in
>> -c|--cl|--cle|--clea|--clean)
>> mode="clean";
>> shift;;
>> +-f|--fo|--for|--forc|--force)
>> + force=`expr $force + 1`
>> + shift;;
>> -p|--pr|--pre|--prei|--prein|--preins|--preinst)
>> mode="preinstall";
>> shift;;
>> @@ -189,27 +193,58 @@ autoreconf)
>> clean)
>> test "$quiet" = "true" || echo "removing automake generated
>> Makefile.in files"
>> files=`find . -name 'Makefile.am' -print | sed -e 's%\.am%\.in%g'` ;
>> - for i in $files; do if test -f $i; then
>> - rm -f $i
>> - test "$verbose" = "-v" && echo "$i"
>> - fi; done
>> + for i in $files; do
>> + if test -f $i; then
>> + rm -f $i
>> + test "$verbose" = "-v" && echo "$i"
>> + fi;
>> + done
>> test "$quiet" = "true" || echo "removing configure files"
>> files=`find . -name 'configure' -print` ;
>> - test "$verbose" = "-v" && test -n "$files" && echo "$files" ;
>> - rm -f $i config.sub config.guess install-sh missing mkinstalldirs
>> -# rm -f depcomp compile texinfo.tex mdate-sh
>> - fi; done
>> + rm -f $i
>> + fi;
>> + done
>> + if test $force -gt 0; then
>> + needles=""
>> + if test $force -gt 1; then
>> + # Manually maintained
>> + needles="$needles config.sub"
>> + needles="$needles config.guess"
>> + fi
>> + # Inherited from automake
>> + needles="$needles compile"
>> + needles="$needles depcomp"
>> + needles="$needles install-sh"
>> + needles="$needles missing"
>> + needles="$needles mdate-sh"
>> + needles="$needles texinfo.tex"
>> + fi
>> + for j in $needles; do
>> + files=`find . -name "$j" -print`
>> + rm -f $i
>> + fi;
>> + done
>> + done
>> + fi
>> test "$quiet" = "true" || echo "removing aclocal.m4 files"
>> files=`find . -name 'aclocal.m4' -print` ;
>> - rm -f $i
>> - fi; done
>> + rm -f $i
>> + fi;
>> + done
>> find . -name '*~' -print | xargs rm -f
>> find . -name 'bspopts.h.in' -print | xargs rm -f
>> rtems-vc mailing list
>> rtems-vc at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-vc
URL: <http://lists.rtems.org/pipermail/devel/attachments/20120810/6f1b1f28/attachment-0001.html>
