Named fields in Structure Initialization
Fri Aug 10 19:26:51 UTC 2012
Hi
I was looking at the definition of the default pthread_attr_t
in cpukit/posix/src/pthread.c. What's the consensus on
explicitly naming fields as opposed to using order to resolve
things.
In the filesystem code, I think it is all named now. I was thinking
of changing this over to something like this:
const pthread_attr_t _POSIX_Threads_Default_attributes = {
   .is_initialized = true,                       /* is_initialized */
   .stackaddr = NULL,                            /* stackaddr */
   .stacksize = 0,                               /* stacksize -- will be
adjusted to minimum */
   .contentionscope = PTHREAD_SCOPE_PROCESS,     /* contentionscope */
   .inheritsched = PTHREAD_INHERIT_SCHED,        /* inheritsched */
   .schedpolicy = SCHED_FIFO,                    /* schedpolicy */
   .schedparam = {                               /* schedparam */
     .sched_priority = 2,                        /* sched_priority */
     #if defined(_POSIX_SPORADIC_SERVER) || \
         defined(_POSIX_THREAD_SPORADIC_SERVER)
       .sched_ss_low_priority = 0,               /* sched_ss_low_priority */
       .sched_ss_repl_period = { 0L, 0 },        /* sched_ss_repl_period */
       .sched_ss_init_budget = { 0L, 0 }         /* sched_ss_init_budget */
     #endif
   #if defined(_POSIX_THREAD_CPUTIME)
     .cputime_clock_allowed = 1,                 /* cputime_clock_allowed */
   #endif
   .detachstate = PTHREAD_CREATE_JOINABLE,       /* detachstate */
Joel Sherrill, Ph.D.             Director of Research&   Development
