Named fields in Structure Initialization
Steven Grunza
sgrunza at ctdi.com
Fri Aug 10 19:36:47 UTC 2012
> -----Original Message-----
> From: rtems-devel-bounces at rtems.org [mailto:rtems-devel-
> bounces at rtems.org] On Behalf Of Joel Sherrill
> Sent: Friday, August 10, 2012 3:27 PM
> To: rtems-devel at rtems.org
> Subject: Named fields in Structure Initialization
> Hi
> I was looking at the definition of the default pthread_attr_t in
> cpukit/posix/src/pthread.c. What's the consensus on explicitly
> naming fields as opposed to using order to resolve things.
> In the filesystem code, I think it is all named now. I was thinking
> of changing this over to something like this:
> const pthread_attr_t _POSIX_Threads_Default_attributes = {
> .is_initialized = true, /* is_initialized
> .stackaddr = NULL, /* stackaddr */
> .stacksize = 0, /* stacksize --
> will be
> adjusted to minimum */
> .contentionscope = PTHREAD_SCOPE_PROCESS, /* contentionscope
> .inheritsched = PTHREAD_INHERIT_SCHED, /* inheritsched */
> .schedpolicy = SCHED_FIFO, /* schedpolicy */
> .schedparam = { /* schedparam */
> .sched_priority = 2, /* sched_priority
> #if defined(_POSIX_SPORADIC_SERVER) || \
> defined(_POSIX_THREAD_SPORADIC_SERVER)
> .sched_ss_low_priority = 0, /*
> sched_ss_low_priority */
> .sched_ss_repl_period = { 0L, 0 }, /*
> sched_ss_repl_period */
> .sched_ss_init_budget = { 0L, 0 } /*
> sched_ss_init_budget */
> #endif
> #if defined(_POSIX_THREAD_CPUTIME)
> .cputime_clock_allowed = 1, /*
> cputime_clock_allowed */
> #endif
> .detachstate = PTHREAD_CREATE_JOINABLE, /* detachstate */
> Joel Sherrill, Ph.D. Director of Research&
Wow, just goes to prove there's always something new to learn. I was
unaware of this ability in C to explicitly name fields like this.
It seems to me that using explicit naming would decrease problems caused
by adding a new field to the structure but neglecting to update the
initialization. I don't see a downside to this change, other than the
effort required to make the change.
