coverage analysis failed
Joel Sherrill
Joel.Sherrill at OARcorp.com
Mon Aug 13 11:57:27 UTC 2012
How did you invoke the do_coverage script?
Which any did it report using?
Can you run the pc386 script on hello with the coverage option and see what happens?
If it doesn't work on a simple case that is one thing.
Krzysztof Mięsowicz <krzysztof.miesowicz at gmail.com> wrote:
Hi all,
I'm Krzysztof and I'm this year ESA SOCIS student. I'm working on RTEMS coverage improvement. Actually I'm trying to prepare environment to run coverage analysis on my laptop and I have some troubles with it. I had some problems with was due to lack of qemu and path to qemu but this is solved.
I have run do_coverage script. It executed all tests but then I get a lot of warnings such as
"WARNING: Unable to read coverage file unlimited.exe.cov" and error:
"ERROR: No information to analyze"
FAILED: covoar failed
I'm very confused with it and hope anyone can help me :)
Regards
Krzysztof Miesowicz
krzysiekm13
URL: <http://lists.rtems.org/pipermail/devel/attachments/20120813/f7d357d5/attachment.html>
