[Bug 2073] New: Unnecessary check for alignment and unreachable code in cpukit/score/src/coremsg.c
Gedare Bloom
gedare at rtems.org
Wed Aug 15 14:08:31 UTC 2012
Hi,
Why remove the comment about rounding up the size?
Also, this code appears to have a latent bug that assumes the
size/alignment should be 32-bits.
I think we should actually have
+ allocated_message_size += sizeof(uintptr_t);
+ allocated_message_size &= ~(sizeof(uintptr_t) - 1);
On Wed, Aug 15, 2012 at 5:16 AM, <bugzilla-daemon at rtems.org> wrote:
> https://www.rtems.org/bugzilla/show_bug.cgi?id=2073
> Bug #: 2073
> Summary: Unnecessary check for alignment and unreachable code
> Classification: Unclassified
> Product: RTEMS
> Version: 4.10
> Platform: PC
> OS/Version: Linux
> Status: NEW
> Severity: enhancement
> Priority: P3
> Component: cpukit
> AssignedTo: joel.sherrill at oarcorp.com
> ReportedBy: krzysztof.miesowicz at gmail.com
> Created attachment 1484
> --> https://www.rtems.org/bugzilla/attachment.cgi?id=1484
> Patch to remove unreachable code in coremsg.c
> When analyzing coverage report
> http://www.rtems.org/ftp/pub/rtems/people/joel/coverage/erc32/erc32-Ospd-20120714-1625/annotated.html#range2
> I discovered that there is unreachable and unnecessary if-statement. It
> gives 2
> uncovered instructions. Checking if allocated_message_size is less than
> maximum_message_size is unnecessary as above code guarantee that
> allocated_message_size will be equal or greater than maximum_message_size.
> I am sending patch as attachment.
> Configure bugmail: https://www.rtems.org/bugzilla/userprefs.cgi?tab=email
> ------- You are receiving this mail because: -------
> You are watching all bug changes.
> rtems-bugs mailing list
> rtems-bugs at rtems.org
> http://rtems.org/mailman/listinfo/rtems-bugs
URL: <http://lists.rtems.org/pipermail/devel/attachments/20120815/1b0e18ca/attachment.html>
