[Bug 2073] New: Unnecessary check for alignment and unreachable code in cpukit/score/src/coremsg.c
Krzysztof Mięsowicz
krzysztof.miesowicz at gmail.com
Wed Aug 15 14:54:18 UTC 2012
I check this once again and re-analyze this code. I think I has done
mistake. After reading this comment once again it seems that second
if-statement which I supposed to be unnecessary is necessary... It checks
for overflow. When I was analyzing this code before I didn't see it.
Code above second if-statement can't make allocated_message_size variable
less than maximum_message_size normally. But maximum_message_size would be
very close to SIZE_MAX, adding an overhead to allocated_message_size can
cause an overflow. And then allocated_message_size will be less than
maximum_message_size.
I'm sorry for this error and mess. I should be more careful and remember
about possibility of overflow.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20120815/4743d714/attachment.html>
