[Bug 2073] New: Unnecessary check for alignment and unreachable code in cpukit/score/src/coremsg.c
Joel Sherrill
joel.sherrill at OARcorp.com
Wed Aug 15 14:23:46 UTC 2012
On 08/15/2012 09:08 AM, Gedare Bloom wrote:
> Hi,
> Why remove the comment about rounding up the size?
The comment was poorly written. A better comment is desirable.
> Also, this code appears to have a latent bug that assumes the
> size/alignment should be 32-bits.
> I think we should actually have
> + allocated_message_size += sizeof(uintptr_t);
> + allocated_message_size&= ~(sizeof(uintptr_t) - 1);
That's better.
> On Wed, Aug 15, 2012 at 5:16 AM, <bugzilla-daemon at rtems.org
> <mailto:bugzilla-daemon at rtems.org>> wrote:
> https://www.rtems.org/bugzilla/show_bug.cgi?id=2073
> Bug #: 2073
> Summary: Unnecessary check for alignment and
> unreachable code
> Classification: Unclassified
> Product: RTEMS
> Version: 4.10
> Platform: PC
> OS/Version: Linux
> Status: NEW
> Severity: enhancement
> Priority: P3
> Component: cpukit
> AssignedTo: joel.sherrill at oarcorp.com
> <mailto:joel.sherrill at oarcorp.com>
> ReportedBy: krzysztof.miesowicz at gmail.com
> <mailto:krzysztof.miesowicz at gmail.com>
> Created attachment 1484
> --> https://www.rtems.org/bugzilla/attachment.cgi?id=1484
> Patch to remove unreachable code in coremsg.c
> When analyzing coverage report
> http://www.rtems.org/ftp/pub/rtems/people/joel/coverage/erc32/erc32-Ospd-20120714-1625/annotated.html#range2
> I discovered that there is unreachable and unnecessary
> if-statement. It gives 2
> uncovered instructions. Checking if allocated_message_size is less
> than
> maximum_message_size is unnecessary as above code guarantee that
> allocated_message_size will be equal or greater than
> maximum_message_size.
> I am sending patch as attachment.
> Configure bugmail:
> https://www.rtems.org/bugzilla/userprefs.cgi?tab=email
> ------- You are receiving this mail because: -------
> You are watching all bug changes.
> rtems-bugs mailing list
> rtems-bugs at rtems.org <mailto:rtems-bugs at rtems.org>
> http://rtems.org/mailman/listinfo/rtems-bugs
Joel Sherrill, Ph.D. Director of Research& Development
URL: <http://lists.rtems.org/pipermail/devel/attachments/20120815/5319df12/attachment.html>
