pull request for atomic
yangwei weiyang wei.a.yang at gmail.com
Wed Aug 1 15:14:52 UTC 2012
2012/8/1 Gedare Bloom <gedare at rtems.org>:
> I'm confused. I thought I read in the documentation that if an
> operation is unsupported by an architecture then the operation does
> nothing. Instead are you saying you would like to check at
Right, If an operation is not supported by an architecture it will do
nothing. But if an atomic operation implementation differs according
to its architecture configure, such as for powerpc and powerpc-64 its
64-bit atomic implementation will differ.
> compile-time whether 64-bit atomics are supported somehow?
I do not mean check whether 64-bit atomic operation are supported,
instead of compiling different atomic implementation.
> Off the top of my head I do not know if that capability exists.
> -Gedare
> On Tue, Jul 31, 2012 at 9:16 PM, yangwei weiyang <wei.a.yang at gmail.com> wrote:
>> Hi Gedare,
>> First really thank you for your detailed comments. I have modified all
>> the error you pointed. And there still a question about the 64-bit
>> support for atomic operations. In my opinion for a architecture it
>> maybe have 64-bit support or not. So there should be a macro to
>> indicate whether it supports 64-bit. Is there a macro in RTEMS?
>> 2012/7/31 Gedare Bloom <gedare at rtems.org>:
>>> I have made some comments on your new version. If you have further
>>> questions or answers to any questions I put please send an email I am
>>> more likely to see it.
>>> -Gedare
>>> On Wed, Jul 25, 2012 at 2:00 AM,  <wei.a.yang at gmail.com> wrote:
>>>> 在 2012-7-25,2:42,Gedare Bloom <gedare at rtems.org> 写道:
>>>>> On Tue, Jul 24, 2012 at 12:29 PM, yangwei weiyang <wei.a.yang at gmail.com> wrote:
>>>>>> 2012/7/23 Gedare Bloom <gedare at rtems.org>:
>>>>>>> On Mon, Jul 23, 2012 at 4:45 AM, yangwei weiyang <wei.a.yang at gmail.com> wrote:
>>>>>>>> 2012/7/23 Sebastian Huber <sebastian.huber at embedded-brains.de>:
>>>>>>>>> Hi,
>>>>>>>>> is it possible to squash the commits together?  This makes it easier to
>>>>>>>>> review.
>>>>>>>> Hi Sebastian, firstly thank you for your comments. The commits are a
>>>>>>>> little trivial because all commits are submitted step by step. And i
>>>>>>>> do not know how to make a pull request on github with a single patch
>>>>>>>> from first commit to last commit. Or i can generate a patch manually
>>>>>>>> and send it to mail list.
>>>>>>> git rebase -i
>>>>>>> should let you specify revision range and squash commits together.
>>>>>>> then you can push a new branch and make new request.
>>>>>> Hi Gedare, Could you tell me more details about this command.
>>>>>> I use git rebase master atomic but all commits do not squash together.
>>>>> http://git-scm.com/book/en/Git-Tools-Rewriting-History#Squashing-Commits
>>>> Hi Gedare. Thank you for your material, it is very useful for me. And I have squash all the commits and create a new branch atomic-review to pull request. Any comments are welcome.
>>>>>>>>> Since you wrote the files probably on your own they should have your
>>>>>>>>> copyright.
>>>>>>>> OK, i will add the copyright to the appropriate files.
>>>>>>>>> The file "cpukit/score/cpu/i386/rtems/score/atomic_cpu.h" should include a
>>>>>>>>> generic file e.g. "cpukit/score/include/rtems/score/genericcpuatomic.h" with
>>>>>>>>> the type definitions.  I think we can use this generic file on every CPU
>>>>>>>>> port.
>>>>>>>> Yeah, agree. And RTEMS support so many architectures so i will think
>>>>>>>> about what types should be generic to all cpu architecture.
>>>>>>>>> I suggest to use the following type names:
>>>>>>>>> Atomic_Int
>>>>>>>>> Atomic_Long
>>>>>>>>> Atomic_Int32
>>>>>>>>> Atomic_Int64
>>>>>>>>> Atomic_Pointer
>>>>>>>> OK. and which file follow this rule that i can study the name rule on RTEMS?
>>>>>>>>> I suggest to rename "atomic_cpu.h" into "cpuatomic.h".  Currently there is
>>>>>>>>> no header file in the score with a "_".
>>>>>>>> OK.
>>>>>>>>> On 07/22/2012 06:08 PM, yangwei weiyang wrote:
>>>>>>>>>> Hi all,
>>>>>>>>>> I have made a pull request for review the source code of atomic, and
>>>>>>>>>> could you give me any comments? thank you!
>>>>>>>>>> pull request link is blow:
>>>>>>>>>> https://github.com/RTEMS/rtems/pull/1
>>>>>>>>> Sebastian Huber, embedded brains GmbH
>>>>>>>>> Address : Obere Lagerstr. 30, D-82178 Puchheim, Germany
>>>>>>>>> Phone   : +49 89 18 90 80 79-6
>>>>>>>>> Fax     : +49 89 18 90 80 79-9
>>>>>>>>> E-Mail  : sebastian.huber at embedded-brains.de
>>>>>>>>> PGP     : Public key available on request.
>>>>>>>>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
>>>>>>>>> _______________________________________________
>>>>>>>>> rtems-devel mailing list
>>>>>>>>> rtems-devel at rtems.org
>>>>>>>>> http://www.rtems.org/mailman/listinfo/rtems-devel
>>>>>>>> Wei Yang
>>>>>>>> Best Regards
>>>>>> Wei Yang
>>>>>> Best Regards
>> Wei Yang
>> Best Regards
Wei Yang
Best Regards
