[GSoC] gumstix and MMU
Sat Aug 11 03:02:30 UTC 2012
Hi,
On Fri, Aug 10, 2012 at 7:45 PM, Hesham Moustafa
<heshamelmatary at gmail.com>wrote:
> Hi,
> I have noticed that in ..../libbsp/arm/gumstix/start/start.S calls
> mmu_init, but i wanna know where mmu_init is implemented for gumstix or
> pxa255 cpu. I searched for it but i found that certain processors (
> libcpu/shared/arm920/mmu.c , libcpu/bfin/mmu/mmu.c) only implements
> mmu_init and no results for gumstix or pxa255.
> libcpu/arm/shared/arm920/mmu.c
41:void mmu_init(mmu_sect_map_t *map)
libcpu/arm/shared/include/mmu.h
26:void mmu_init(mmu_sect_map_t *map);
The libbsp/arm/gumstix/Makefile.am includes libcpu/arm/shared/arm920.rel,
which builds shared/arm920/mmu.c that contains the mmu_init function.
You might consider trying ctags, cscope, or just grep the sources in order
to find symbols.
-Gedare
> thanks,
> Hesham
> rtems-devel mailing list
> rtems-devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20120810/1e545b8b/attachment-0001.html>
