[rtems commit] bsp/mpc55xx: Set PPC_EXC_CONFIG_USE_FIXED_HANDLER
Ralf Corsepius ralf.corsepius at rtems.org
Mon Dec 3 13:38:02 UTC 2012
On 12/03/2012 01:14 PM, Sebastian Huber wrote:
> Module:    rtems
> Branch:    master
> Commit:    3ce66aabb5be97ee0bd216f735e224c317d9667e
> Changeset: http://git.rtems.org/rtems/commit/?id=3ce66aabb5be97ee0bd216f735e224c317d9667e
> Author:    Sebastian Huber <sebastian.huber at embedded-brains.de>
> Date:      Mon Nov 19 09:02:12 2012 +0100
>   c/src/lib/libbsp/powerpc/mpc55xxevb/Makefile.am    |    1 +
>   c/src/lib/libbsp/powerpc/mpc55xxevb/configure.ac   |    4 ++
>   .../libbsp/powerpc/mpc55xxevb/startup/bspstart.c   |    4 ++-
>   .../powerpc/mpc55xxevb/startup/exc-vector-base.S   |   18 +++++++++
>   c/src/lib/libcpu/powerpc/mpc55xx/irq/irq.c         |   39 +++++++++++++++-----
>   5 files changed, 55 insertions(+), 11 deletions(-)
> diff --git a/c/src/lib/libcpu/powerpc/mpc55xx/irq/irq.c b/c/src/lib/libcpu/powerpc/mpc55xx/irq/irq.c
> index c60a301..024ea80 100644
> --- a/c/src/lib/libcpu/powerpc/mpc55xx/irq/irq.c
> +++ b/c/src/lib/libcpu/powerpc/mpc55xx/irq/irq.c
> @@ -7,12 +7,13 @@
> - * Copyright (c) 2008
> - * Embedded Brains GmbH
> - * Obere Lagerstr. 30
> - * D-82178 Puchheim
> - * Germany
> - * rtems at embedded-brains.de
> + * Copyright (c) 2008-2012 embedded brains GmbH.  All rights reserved.
> + *  embedded brains GmbH
> + *  Obere Lagerstr. 30
> + *  82178 Puchheim
> + *  Germany
> + *  <rtems at embedded-brains.de>
Please be more careful about copyright disclaimers.
Your "2008"->"2008-2012" change above implies you to have applied
copyrightable material all consecutive years 2008 through 2012.
Without having checked the sources and pushing aside considerations on
whether your changes actually are copyrighable, I am having doubts, this
applies.
I believe you actually want to change the copyright disclaimer from
"2008" into "2008, 2012", denoting you applied major changes to your
works from 2008 in 2012.
Ralf
