[rtems commit] bsp/mpc55xx: Set PPC_EXC_CONFIG_USE_FIXED_HANDLER
Sebastian Huber
Mon Dec 3 16:51:35 UTC 2012
On 12/03/2012 02:38 PM, Ralf Corsepius wrote:
> On 12/03/2012 01:14 PM, Sebastian Huber wrote:
>> Module: rtems
>> Branch: master
>> Commit: 3ce66aabb5be97ee0bd216f735e224c317d9667e
>> Changeset:
>> http://git.rtems.org/rtems/commit/?id=3ce66aabb5be97ee0bd216f735e224c317d9667e
>> Author: Sebastian Huber <sebastian.huber at embedded-brains.de>
>> Date: Mon Nov 19 09:02:12 2012 +0100
>> c/src/lib/libbsp/powerpc/mpc55xxevb/Makefile.am | 1 +
>> c/src/lib/libbsp/powerpc/mpc55xxevb/configure.ac | 4 ++
>> .../libbsp/powerpc/mpc55xxevb/startup/bspstart.c | 4 ++-
>> .../powerpc/mpc55xxevb/startup/exc-vector-base.S | 18 +++++++++
>> c/src/lib/libcpu/powerpc/mpc55xx/irq/irq.c | 39 +++++++++++++++-----
>> 5 files changed, 55 insertions(+), 11 deletions(-)
>> diff --git a/c/src/lib/libcpu/powerpc/mpc55xx/irq/irq.c
>> b/c/src/lib/libcpu/powerpc/mpc55xx/irq/irq.c
>> index c60a301..024ea80 100644
>> --- a/c/src/lib/libcpu/powerpc/mpc55xx/irq/irq.c
>> +++ b/c/src/lib/libcpu/powerpc/mpc55xx/irq/irq.c
>> @@ -7,12 +7,13 @@
>> - * Copyright (c) 2008
>> - * Embedded Brains GmbH
>> - * Obere Lagerstr. 30
>> - * D-82178 Puchheim
>> - * Germany
>> - * rtems at embedded-brains.de
>> + * Copyright (c) 2008-2012 embedded brains GmbH. All rights reserved.
>> + * embedded brains GmbH
>> + * Obere Lagerstr. 30
>> + * 82178 Puchheim
>> + * Germany
>> + * <rtems at embedded-brains.de>
> Please be more careful about copyright disclaimers.
> Your "2008"->"2008-2012" change above implies you to have applied copyrightable
> material all consecutive years 2008 through 2012.
> Without having checked the sources and pushing aside considerations on whether
> your changes actually are copyrighable, I am having doubts, this applies.
> I believe you actually want to change the copyright disclaimer from
> "2008" into "2008, 2012", denoting you applied major changes to your works from
> 2008 in 2012.
Thanks for the hint. I will have a look at this.
Phone : +49 89 18 90 80 79-6
Fax : +49 89 18 90 80 79-9
