[PATCH] rtems misc: Clean up Doxygen GCI Task #7
Gedare Bloom
gedare at rtems.org
Wed Dec 5 18:39:34 UTC 2012
diff --git a/cpukit/rtems/include/rtems/rtems/clock.h
b/cpukit/rtems/include/rtems/rtems/clock.h
index c841d1a..fc6a584 100644
--- a/cpukit/rtems/include/rtems/rtems/clock.h
+++ b/cpukit/rtems/include/rtems/rtems/clock.h
@@ -243,7 +243,7 @@ void rtems_clock_get_uptime_timeval( struct timeval
*uptime );
time_t rtems_clock_get_uptime_seconds( void );
- * @brief _TOD_Validate
+ * @brief TOD Validate
* This support function returns true if @a the_tod contains
* a valid time of day, and false otherwise.
@@ -251,6 +251,8 @@ time_t rtems_clock_get_uptime_seconds( void );
* @param[in] the_tod is the TOD structure to validate
* @return This method returns true if the TOD is valid and false
otherwise.
+ * @note This routine only works for leap-years through 2099.
bool _TOD_Validate(
const rtems_time_of_day *the_tod
diff --git a/cpukit/rtems/include/rtems/rtems/dpmem.h
b/cpukit/rtems/include/rtems/rtems/dpmem.h
index a4cf251..2041ddd 100644
--- a/cpukit/rtems/include/rtems/rtems/dpmem.h
+++ b/cpukit/rtems/include/rtems/rtems/dpmem.h
@@ -149,11 +149,20 @@ rtems_status_code rtems_port_external_to_internal(
- * @brief rtems_port_internal_to_external
+ * @brief RTEMS Port Internal to External
* This routine implements the Port_internal_to_external directive.
* It returns the external port address which maps to the provided
- * internal port address for the specified port ID.
+ * internal port address for the specified port ID. If the given
+ * internal address is an invalid dual-ported address, then the
+ * external address is set to the given internal address.
+ * @param[in] id is the id of dual-ported memory object
+ * @param[in] internal is the internal address to set
+ * @param[in] external is the pointer to external address
+ * @return RTEMS_SUCCESSFUL and the external will be filled in
+ * with the external addresses
rtems_status_code rtems_port_internal_to_external(
rtems_id id,
diff --git a/cpukit/rtems/include/rtems/rtems/message.h
b/cpukit/rtems/include/rtems/rtems/message.h
index 9990b14..10da602 100644
--- a/cpukit/rtems/include/rtems/rtems/message.h
+++ b/cpukit/rtems/include/rtems/rtems/message.h
@@ -234,7 +234,7 @@ rtems_status_code rtems_message_queue_broadcast(
- * @brief rtems_message_queue_receive
+ * @brief RTEMS Message Queue Receive
* This routine implements the rtems_message_queue_receive directive.
* This directive is invoked when the calling task wishes to receive
@@ -242,7 +242,17 @@ rtems_status_code rtems_message_queue_broadcast(
* message is to be placed in buffer. If no messages are outstanding
* and the option_set indicates that the task is willing to block,
* then the task will be blocked until a message arrives or until,
- * optionally, timeout clock ticks have passed.
+ * optionally, timeout clock ticks have passed.
+ * @param[in] id is the queue id
+ * @param[in] buffer is the pointer to message buffer
+ * @param[in] size is the size of message receive
+ * @param[in] option_set is the options on receive
+ * @param[in] timeout is the number of ticks to wait
+ * @return This method returns RTEMS_SUCCESSFUL if there was not an
+ * error. Otherwise, a status code is returned indicating the
+ * source of the error.
rtems_status_code rtems_message_queue_receive(
rtems_id id,
diff --git a/cpukit/rtems/include/rtems/rtems/part.h
b/cpukit/rtems/include/rtems/rtems/part.h
index b6b5b3a..88af1eb 100644
--- a/cpukit/rtems/include/rtems/rtems/part.h
+++ b/cpukit/rtems/include/rtems/rtems/part.h
@@ -135,10 +135,17 @@ rtems_status_code rtems_partition_ident(
- * @brief rtems_partition_delete
+ * @brief RTEMS Delete Partition
* This routine implements the rtems_partition_delete directive. The
- * partition indicated by ID is deleted.
+ * partition indicated by ID is deleted, provided that none of its buffers
+ * are still allocated.
+ * @param[in] id is the partition id
rtems_status_code rtems_partition_delete(
rtems_id id
diff --git a/cpukit/rtems/include/rtems/rtems/ratemon.h
b/cpukit/rtems/include/rtems/rtems/ratemon.h
index 93c8e26..9b0d1de 100644
--- a/cpukit/rtems/include/rtems/rtems/ratemon.h
+++ b/cpukit/rtems/include/rtems/rtems/ratemon.h
@@ -269,6 +269,8 @@ RTEMS_RATEMON_EXTERN Objects_Information
_Rate_monotonic_Information;
* @brief Rate Monotonic Manager Initialization
* This routine performs the initialization necessary for this manager.
+ * @note The Rate Monotonic Manager is built on top of the Watchdog
Handler
void _Rate_monotonic_Manager_initialization(void);
@@ -285,11 +287,19 @@ rtems_status_code rtems_rate_monotonic_create(
- * @brief rtems_rate_monotonic_ident
+ * @brief RTEMS Rate Monotonic Name to Id
* This routine implements the rtems_rate_monotonic_ident directive.
* It returns the period ID associated with name. If more than one period
* is named name, then the period to which the ID belongs is arbitrary.
+ * @param[in] name is the user defined period name
+ * @param[in] id is the pointer to period id
+ * source of the error. If successful, the id will
+ * be filled in with the region id.
rtems_status_code rtems_rate_monotonic_ident(
rtems_name name,
@@ -314,10 +324,16 @@ rtems_status_code rtems_rate_monotonic_cancel(
- * @brief rtems_rate_monotonic_delete
+ * @brief RTEMS Delete Rate Monotonic
* This routine implements the rtems_rate_monotonic_delete directive. The
* period indicated by ID is deleted.
+ * @param[in] id is the rate monotonic id
rtems_status_code rtems_rate_monotonic_delete(
rtems_id id
@@ -328,6 +344,13 @@ rtems_status_code rtems_rate_monotonic_delete(
* This routine implements the rtems_rate_monotonic_get_status directive.
* Information about the period indicated by ID is returned.
+ * @param[in] status is the pointer to status control block
rtems_status_code rtems_rate_monotonic_get_status(
@@ -370,10 +393,13 @@ rtems_status_code
rtems_rate_monotonic_reset_statistics(
void rtems_rate_monotonic_reset_all_statistics( void );
- * @brief rtems_rate_monotonic_report_statistics
+ * @brief RTEMS Report Rate Monotonic Statistics
* This routine allows a thread to print the statistics information
* on ALL period instances which have non-zero counts using printk.
+ * The implementation of this directive straddles the fence between
+ * inside and outside of RTEMS. It is presented as part of the Manager
+ * but actually uses other services of the Manager.
void rtems_rate_monotonic_report_statistics_with_plugin(
void *context,
@@ -381,7 +407,7 @@ void rtems_rate_monotonic_report_statistics_with_plugin(
diff --git a/cpukit/rtems/include/rtems/rtems/region.h
b/cpukit/rtems/include/rtems/rtems/region.h
index 055e25d..269725a 100644
--- a/cpukit/rtems/include/rtems/rtems/region.h
+++ b/cpukit/rtems/include/rtems/rtems/region.h
@@ -154,11 +154,20 @@ rtems_status_code rtems_region_get_information(
- * @brief rtems_region_get_free_information
+ * @brief RTEMS Get Region Free Information
* This routine implements the rtems_region_get_free_information
directive.
* This directive returns information about the free blocks in the
- * heap associated with this region.
+ * heap associated with this region. Information about the used blocks
+ * will be returned as zero.
+ * @param[in] id is the region id
+ * @param[in] the_info is the pointer to region information block
+ * source of the error. If successful, the the_info will
+ * be filled in with the region information block.
rtems_status_code rtems_region_get_free_information(
rtems_id id,
diff --git a/cpukit/rtems/include/rtems/rtems/sem.h
b/cpukit/rtems/include/rtems/rtems/sem.h
index 2322088..3ab9a65 100644
--- a/cpukit/rtems/include/rtems/rtems/sem.h
+++ b/cpukit/rtems/include/rtems/rtems/sem.h
@@ -168,7 +168,7 @@ rtems_status_code rtems_semaphore_delete(
- * @brief rtems_semaphore_obtain
+ * @brief RTEMS Obtain Semaphore
* This routine implements the rtems_semaphore_obtain directive. It
* attempts to obtain a unit from the semaphore associated with ID.
@@ -177,6 +177,14 @@ rtems_status_code rtems_semaphore_delete(
* block waiting for a unit with an optional timeout of timeout
* clock ticks. Whether the task blocks or returns immediately
* is based on the RTEMS_NO_WAIT option in the option_set.
+ * @param[in] id is the semaphore id
+ * @param[in] option_set is the wait option
+ * @param[in] timeout is the number of ticks to wait (0 means wait
forever)
rtems_status_code rtems_semaphore_obtain(
rtems_id id,
diff --git a/cpukit/rtems/include/rtems/rtems/support.h
b/cpukit/rtems/include/rtems/rtems/support.h
index 99bf405..30716de 100644
--- a/cpukit/rtems/include/rtems/rtems/support.h
+++ b/cpukit/rtems/include/rtems/rtems/support.h
@@ -63,7 +63,7 @@ extern "C" {
- * @brief Gets workspace information.
+ * @brief Gets Workspace Information
* Returns information about the heap that is used as the RTEMS Executive
* Workspace in @a the_info.
@@ -75,7 +75,7 @@ bool rtems_workspace_get_information(
- * @brief Allocates memory from the workspace.
+ * @brief Allocates Memory from the Workspace
* A number of @a bytes bytes will be allocated from the RTEMS Executive
* Workspace and returned in @a pointer.
@@ -88,7 +88,7 @@ bool rtems_workspace_allocate(
- * @brief Frees memory allocated from the workspace.
+ * @brief Frees Memory Allocated from the Workspace
* This frees the memory indicated by @a pointer that was allocated from
the
* RTEMS Executive Workspace.
diff --git a/cpukit/rtems/include/rtems/rtems/tasks.h
b/cpukit/rtems/include/rtems/rtems/tasks.h
index 90379c1..dd3f20f 100644
--- a/cpukit/rtems/include/rtems/rtems/tasks.h
+++ b/cpukit/rtems/include/rtems/rtems/tasks.h
@@ -345,12 +345,19 @@ rtems_status_code rtems_task_set_note(
- * @brief rtems_task_mode
+ * @brief RTEMS Task Mode
* This routine implements the rtems_task_mode directive. The current
* values of the modes indicated by mask of the calling task are changed
* to that indicated in mode_set. The former mode of the task is
* returned in mode_set.
+ * @param[in] mode_set is the new mode
+ * @param[in] mask is the mask
+ * @param[in] previous_mode_set is the address of previous mode set
+ * @return RTEMS_SUCCESSFUL and previous_mode_set filled in with the
+ * previous mode set
rtems_status_code rtems_task_mode(
rtems_mode mode_set,
@@ -475,7 +482,7 @@ rtems_status_code rtems_task_is_suspended(
- * @brief rtems_task_variable_add
+ * @brief RTEMS Add Task Variable
* This directive adds a per task variable.
diff --git a/cpukit/rtems/include/rtems/rtems/timer.h
b/cpukit/rtems/include/rtems/rtems/timer.h
index ee35fec..e125f82 100644
--- a/cpukit/rtems/include/rtems/rtems/timer.h
+++ b/cpukit/rtems/include/rtems/rtems/timer.h
@@ -275,23 +275,38 @@ rtems_status_code rtems_timer_cancel(
- * @brief rtems_timer_delete
+ * @brief RTEMS Delete Timer
* This routine implements the rtems_timer_delete directive. The
* timer indicated by ID is deleted.
+ * @param[in] id is the timer id
rtems_status_code rtems_timer_delete(
rtems_id id
- * @brief rtems_timer_fire_after
+ * @brief RTEMS Timer Fire After
* This routine implements the rtems_timer_fire_after directive. It
* initiates the timer associated with ID to fire in ticks clock ticks.
* When the timer fires, the routine will be invoked in the context
* of the rtems_clock_tick directive which is normally invoked as
* part of servicing a periodic interupt.
+ * @param[in] ticks is the interval until routine is fired
+ * @param[in] routine is the routine to schedule
+ * @param[in] user_data is the passed as argument to routine when it is
fired
rtems_status_code rtems_timer_fire_after(
rtems_id id,
diff --git a/cpukit/rtems/src/clockgettickssinceboot.c
b/cpukit/rtems/src/clockgettickssinceboot.c
index 96a1c5e..cfd91b5 100644
--- a/cpukit/rtems/src/clockgettickssinceboot.c
+++ b/cpukit/rtems/src/clockgettickssinceboot.c
@@ -1,6 +1,11 @@
- * Clock Manager - Get Ticks Since Boot
+ * @file
+ * @brief Obtain Ticks Since Boot
+ * @ingroup ClassicClock
* COPYRIGHT (c) 1989-2008.
* On-Line Applications Research Corporation (OAR).
diff --git a/cpukit/rtems/src/clocktodvalidate.c
b/cpukit/rtems/src/clocktodvalidate.c
index 7aa854c..a56b1df 100644
--- a/cpukit/rtems/src/clocktodvalidate.c
+++ b/cpukit/rtems/src/clocktodvalidate.c
@@ -1,7 +1,11 @@
- * Time of Day (TOD) Handler -- Validate Classic TOD
+ * @file
* COPYRIGHT (c) 1989-2007.
@@ -29,21 +33,6 @@ const uint32_t _TOD_Days_per_month[ 2 ][ 13 ] = {
{ 0, 31, 29, 31, 30, 31, 30, 31, 31, 30, 31, 30, 31 }
- * _TOD_Validate
- * This kernel routine checks the validity of a date and time structure.
- * Input parameters:
- * the_tod - pointer to a time and date structure
- * Output parameters:
- * true - if the date, time, and tick are valid
- * false - if the the_tod is invalid
- * NOTE: This routine only works for leap-years through 2099.
bool _TOD_Validate(
diff --git a/cpukit/rtems/src/dpmeminternal2external.c
b/cpukit/rtems/src/dpmeminternal2external.c
index 6e61566..a6c8d83 100644
--- a/cpukit/rtems/src/dpmeminternal2external.c
+++ b/cpukit/rtems/src/dpmeminternal2external.c
@@ -1,6 +1,11 @@
- * Dual Port Memory Manager
+ * @file
+ * @ingroup ClassicDPMEM
@@ -22,24 +27,6 @@
#include <rtems/rtems/dpmem.h>
- * rtems_port_internal_to_external
- * This directive converts an internal dual-ported memory address to an
- * external dual-ported memory address. If the given internal address
- * is an invalid dual-ported address, then the external address is set
- * to the given internal address.
- * id - id of dual-ported memory object
- * internal - internal address to set
- * external - pointer to external address
- * external - external address
- * RTEMS_SUCCESSFUL - always succeeds
rtems_id id,
void *internal,
diff --git a/cpukit/rtems/src/msgqreceive.c b/cpukit/rtems/src/msgqreceive.c
index 00ed6c2..6be06ad 100644
--- a/cpukit/rtems/src/msgqreceive.c
+++ b/cpukit/rtems/src/msgqreceive.c
@@ -1,7 +1,11 @@
- * Message Queue Manager
+ * @file
+ * @ingroup ClassicMessageQueue
@@ -32,24 +36,6 @@
#include <rtems/rtems/options.h>
- * rtems_message_queue_receive
- * This directive dequeues a message from the designated message queue
- * and copies it into the requesting thread's buffer.
- * id - queue id
- * buffer - pointer to message buffer
- * size - size of message receive
- * option_set - options on receive
- * timeout - number of ticks to wait
- * RTEMS_SUCCESSFUL - if successful
- * error code - if unsuccessful
rtems_id id,
void *buffer,
diff --git a/cpukit/rtems/src/partdelete.c b/cpukit/rtems/src/partdelete.c
index 6cae308..6aeee4e 100644
--- a/cpukit/rtems/src/partdelete.c
+++ b/cpukit/rtems/src/partdelete.c
@@ -1,7 +1,11 @@
- * Partition Manager
+ * @file
+ * @ingroup ClassicPart
@@ -23,21 +27,6 @@
#include <rtems/score/sysstate.h>
- * rtems_partition_delete
- * This directive allows a thread to delete a partition specified by
- * the partition identifier, provided that none of its buffers are
- * still allocated.
- * id - partition id
rtems_id id
diff --git a/cpukit/rtems/src/ratemon.c b/cpukit/rtems/src/ratemon.c
index d2eba80..d96a9b0 100644
--- a/cpukit/rtems/src/ratemon.c
+++ b/cpukit/rtems/src/ratemon.c
@@ -1,7 +1,11 @@
- * Rate Monotonic Manager
+ * @file
+ * @brief Rate Monotonic Manager Initialization
+ * @ingroup ClassicRateMon
@@ -23,20 +27,6 @@
#include <rtems/rtems/ratemon.h>
- * _Rate_monotonic_Manager_initialization
- * This routine initializes all Rate Monotonic Manager related
- * data structures.
- * Input parameters: NONE
- * Output parameters: NONE
- * NOTE: The Rate Monotonic Manager is built on top of the Watchdog
- * Handler.
_Objects_Initialize_information(
diff --git a/cpukit/rtems/src/ratemondelete.c
b/cpukit/rtems/src/ratemondelete.c
index 751c7f5..15498ea 100644
--- a/cpukit/rtems/src/ratemondelete.c
+++ b/cpukit/rtems/src/ratemondelete.c
@@ -1,6 +1,11 @@
- * Rate Monotonic Manager -- Delete a Period
+ * @file
@@ -21,19 +26,6 @@
- * rtems_rate_monotonic_delete
- * This directive allows a thread to delete a rate monotonic timer.
- * id - rate monotonic id
rtems_id id
diff --git a/cpukit/rtems/src/ratemongetstatus.c
b/cpukit/rtems/src/ratemongetstatus.c
index 73c59ee..5d0d584 100644
--- a/cpukit/rtems/src/ratemongetstatus.c
+++ b/cpukit/rtems/src/ratemongetstatus.c
@@ -1,6 +1,11 @@
- * Rate Monotonic Manager -- Get Status
+ * @file
+ * @brief RTEMS Rate Monotonic Get Status
* COPYRIGHT (c) 1989-2009.
@@ -25,22 +30,6 @@
#include <rtems/score/timespec.h>
#endif
- * rtems_rate_monotonic_get_status
- * This directive allows a thread to obtain status information on a
- * period.
- * status - pointer to status control block
rtems_id id,
rtems_rate_monotonic_period_status *status
diff --git a/cpukit/rtems/src/ratemonident.c
b/cpukit/rtems/src/ratemonident.c
index 35e4195..def9580 100644
--- a/cpukit/rtems/src/ratemonident.c
+++ b/cpukit/rtems/src/ratemonident.c
@@ -1,6 +1,11 @@
- * Rate Monotonic Manager -- Name to Id Lookup
+ * @file
@@ -21,22 +26,6 @@
- * rtems_rate_monotonic_ident
- * This directive returns the system ID associated with
- * the rate monotonic period name.
- * name - user defined period name
- * id - pointer to period id
- * *id - region id
rtems_name name,
rtems_id *id
diff --git a/cpukit/rtems/src/ratemonreportstatistics.c
b/cpukit/rtems/src/ratemonreportstatistics.c
index c94171c..daf5fb5 100644
--- a/cpukit/rtems/src/ratemonreportstatistics.c
+++ b/cpukit/rtems/src/ratemonreportstatistics.c
@@ -1,6 +1,11 @@
- * Rate Monotonic Manager -- Report Statistics for All Periods
+ * @file
* COPYRIGHT (c) 1989-2010.
@@ -28,14 +33,6 @@
#define NANOSECONDS_FMT "%06" PRId32
#endif
- * This directive allows a thread to print the statistics information
- * on ALL period instances which have non-zero counts using printk.
- * The implementation of this directive straddles the fence between
- * inside and outside of RTEMS. It is presented as part of the Manager
- * but actually uses other services of the Manager.
void *context,
rtems_printk_plugin_t print
diff --git a/cpukit/rtems/src/regiongetfreeinfo.c
b/cpukit/rtems/src/regiongetfreeinfo.c
index 52b7135..bd16b0e 100644
--- a/cpukit/rtems/src/regiongetfreeinfo.c
+++ b/cpukit/rtems/src/regiongetfreeinfo.c
@@ -1,7 +1,11 @@
- * Region Manager
+ * @file
+ * @ingroup ClassicRegion
@@ -24,23 +28,6 @@
#include <rtems/score/apimutex.h>
- * rtems_region_get_free_information
- * This directive will return information about the free blocks
- * in the region specified. Information about the used blocks
- * will be returned as zero.
- * id - region id
- * the_info - pointer to region information block
- * *the_info - region information block filled in
rtems_id id,
Heap_Information_block *the_info
diff --git a/cpukit/rtems/src/rtemsobjectapimaximumclass.c
b/cpukit/rtems/src/rtemsobjectapimaximumclass.c
index 17ad518..abeee03 100644
--- a/cpukit/rtems/src/rtemsobjectapimaximumclass.c
+++ b/cpukit/rtems/src/rtemsobjectapimaximumclass.c
@@ -1,6 +1,11 @@
- * RTEMS Object Helper -- Get Greatest Valid Class for an API
+ * @file
+ * @brief Get Highest Valid Class Value
+ * @ingroup ClassicClassInfo
diff --git a/cpukit/rtems/src/rtemsobjectgetapiname.c
b/cpukit/rtems/src/rtemsobjectgetapiname.c
index 4976a92..2f10ce7 100644
--- a/cpukit/rtems/src/rtemsobjectgetapiname.c
+++ b/cpukit/rtems/src/rtemsobjectgetapiname.c
@@ -1,6 +1,11 @@
- * RTEMS Object Helper -- Obtain Name of API
+ * @file
+ * @brief Get API Name
diff --git a/cpukit/rtems/src/semobtain.c b/cpukit/rtems/src/semobtain.c
index 2faaff0..fe5710e 100644
--- a/cpukit/rtems/src/semobtain.c
+++ b/cpukit/rtems/src/semobtain.c
@@ -1,20 +1,11 @@
- * Semaphore Manager
- * DESCRIPTION:
- * This package is the implementation of the Semaphore Manager.
- * This manager utilizes standard Dijkstra counting semaphores to provide
- * synchronization and mutual exclusion capabilities.
- * Directives provided are:
- * + create a semaphore
- * + get an ID of a semaphore
- * + delete a semaphore
- * + acquire a semaphore
- * + release a semaphore
+ * @file
+ * @ingroup ClassicSem
@@ -47,21 +38,6 @@
#include <rtems/score/interr.h>
- * rtems_semaphore_obtain
- * This directive allows a thread to acquire a semaphore.
- * id - semaphore id
- * option_set - wait option
- * timeout - number of ticks to wait (0 means wait forever)
rtems_id id,
rtems_option option_set,
diff --git a/cpukit/rtems/src/taskmode.c b/cpukit/rtems/src/taskmode.c
index 9fab226..63fe29c 100644
--- a/cpukit/rtems/src/taskmode.c
+++ b/cpukit/rtems/src/taskmode.c
@@ -1,6 +1,11 @@
- * RTEMS Task Manager - Change Task Mode
+ * @file
+ * @ingroup ClassicTasks
@@ -28,22 +33,6 @@
#include <rtems/score/apiext.h>
- * rtems_task_mode
- * This directive enables and disables several modes of
- * execution for the requesting thread.
- * mode_set - new mode
- * mask - mask
- * previous_mode_set - address of previous mode set
- * Output:
- * *previous_mode_set - previous mode set
- * always return RTEMS_SUCCESSFUL;
rtems_mode mask,
diff --git a/cpukit/rtems/src/taskvariableadd.c
b/cpukit/rtems/src/taskvariableadd.c
index 415fe69..9a0bc3d 100644
--- a/cpukit/rtems/src/taskvariableadd.c
+++ b/cpukit/rtems/src/taskvariableadd.c
@@ -1,7 +1,11 @@
- * rtems_task_variable_add - Add a per-task variable
+ * @file
@@ -18,12 +22,6 @@
- * This directive registers a task variable.
rtems_status_code rtems_task_variable_add(
rtems_id tid,
void **ptr,
diff --git a/cpukit/rtems/src/timerdelete.c b/cpukit/rtems/src/timerdelete.c
index e7a0d15..f259280 100644
--- a/cpukit/rtems/src/timerdelete.c
+++ b/cpukit/rtems/src/timerdelete.c
@@ -1,7 +1,11 @@
- * Timer Manager - rtems_timer_delete directive
+ * @file
+ * @ingroup ClassicTimer
@@ -23,19 +27,6 @@
#include <rtems/score/tod.h>
- * rtems_timer_delete
- * This directive allows a thread to delete a timer.
- * id - timer id
rtems_id id
diff --git a/cpukit/rtems/src/timerfireafter.c
b/cpukit/rtems/src/timerfireafter.c
index f823a7b..267c1cf 100644
--- a/cpukit/rtems/src/timerfireafter.c
+++ b/cpukit/rtems/src/timerfireafter.c
@@ -1,7 +1,11 @@
- * Timer Manager - rtems_timer_fire_after directive
+ * @file
@@ -23,22 +27,6 @@
- * rtems_timer_fire_after
- * This directive allows a thread to start a timer.
- * id - timer id
- * ticks - interval until routine is fired
- * routine - routine to schedule
- * user_data - passed as argument to routine when it is fired
rtems_id id,
rtems_interval ticks,
diff --git a/cpukit/rtems/src/workspace.c b/cpukit/rtems/src/workspace.c
index 7af5897..38747be 100644
--- a/cpukit/rtems/src/workspace.c
+++ b/cpukit/rtems/src/workspace.c
@@ -1,6 +1,11 @@
- * Workspace Handler
+ * @file
+ * @brief RTEMS Workspace Support
+ * @ingroup ClassicRTEMSWorkspace
@@ -32,9 +37,6 @@ bool rtems_workspace_get_information(
return _Protected_heap_Get_information( &_Workspace_Area, the_info );
- * _Workspace_Allocate
size_t bytes,
void **pointer
@@ -62,9 +64,6 @@ bool rtems_workspace_allocate(
return true;
bool rtems_workspace_free(
void *pointer
URL: <http://lists.rtems.org/pipermail/devel/attachments/20121205/d783822a/attachment.html>
