[PATCH] rtems misc: Clean up Doxygen GCI Task #7
Wed Dec 5 18:40:42 UTC 2012
Author:    Alex Ivanov <alexivanov97 at gmail.com>
http://www.google-melange.com/gci/task/view/google/gci2012/7950206
On Wed, Dec 5, 2012 at 1:39 PM, Gedare Bloom <gedare at rtems.org> wrote:
> diff --git a/cpukit/rtems/include/rtems/rtems/clock.h
> b/cpukit/rtems/include/rtems/rtems/clock.h
> index c841d1a..fc6a584 100644
> --- a/cpukit/rtems/include/rtems/rtems/clock.h
> +++ b/cpukit/rtems/include/rtems/rtems/clock.h
> @@ -243,7 +243,7 @@ void rtems_clock_get_uptime_timeval( struct timeval
> *uptime );
>  time_t rtems_clock_get_uptime_seconds( void );
> - *  @brief _TOD_Validate
> + *  @brief TOD Validate
>   *  This support function returns true if @a the_tod contains
>   *  a valid time of day, and false otherwise.
> @@ -251,6 +251,8 @@ time_t rtems_clock_get_uptime_seconds( void );
>   *  @param[in] the_tod is the TOD structure to validate
>   *  @return This method returns true if the TOD is valid and false
> otherwise.
> + *  @note This routine only works for leap-years through 2099.
>  bool _TOD_Validate(
>    const rtems_time_of_day *the_tod
> diff --git a/cpukit/rtems/include/rtems/rtems/dpmem.h
> b/cpukit/rtems/include/rtems/rtems/dpmem.h
> index a4cf251..2041ddd 100644
> --- a/cpukit/rtems/include/rtems/rtems/dpmem.h
> +++ b/cpukit/rtems/include/rtems/rtems/dpmem.h
> @@ -149,11 +149,20 @@ rtems_status_code rtems_port_external_to_internal(
> - *  @brief rtems_port_internal_to_external
> + *  @brief RTEMS Port Internal to External
>   *  This routine implements the Port_internal_to_external directive.
>   *  It returns the external port address which maps to the provided
> - *  internal port address for the specified port ID.
> + *  internal port address for the specified port ID.  If the given
> + *  internal address is an invalid dual-ported address, then the
> + *  external address is set to the given internal address.
> + *  @param[in] id is the id of dual-ported memory object
> + *  @param[in] internal is the internal address to set
> + *  @param[in] external is the pointer to external address
> + *  @return RTEMS_SUCCESSFUL and the external will be filled in
> + *  with the external addresses
>  rtems_status_code rtems_port_internal_to_external(
>    rtems_id     id,
> diff --git a/cpukit/rtems/include/rtems/rtems/message.h
> b/cpukit/rtems/include/rtems/rtems/message.h
> index 9990b14..10da602 100644
> --- a/cpukit/rtems/include/rtems/rtems/message.h
> +++ b/cpukit/rtems/include/rtems/rtems/message.h
> @@ -234,7 +234,7 @@ rtems_status_code rtems_message_queue_broadcast(
> - *  @brief rtems_message_queue_receive
> + *  @brief RTEMS Message Queue Receive
>   *  This routine implements the rtems_message_queue_receive directive.
>   *  This directive is invoked when the calling task wishes to receive
> @@ -242,7 +242,17 @@ rtems_status_code rtems_message_queue_broadcast(
>   *  message is to be placed in buffer.  If no messages are outstanding
>   *  and the option_set indicates that the task is willing to block,
>   *  then the task will be blocked until a message arrives or until,
> - *  optionally, timeout clock ticks have passed.
> + *  optionally, timeout clock ticks have passed.
> + *  @param[in] id is the queue id
> + *  @param[in] buffer is the pointer to message buffer
> + *  @param[in] size is the size of message receive
> + *  @param[in] option_set is the options on receive
> + *  @param[in] timeout is the number of ticks to wait
> + *  @return This method returns RTEMS_SUCCESSFUL if there was not an
> + *          error.  Otherwise, a status code is returned indicating the
> + *          source of the error.
>  rtems_status_code rtems_message_queue_receive(
>    rtems_id        id,
> diff --git a/cpukit/rtems/include/rtems/rtems/part.h
> b/cpukit/rtems/include/rtems/rtems/part.h
> index b6b5b3a..88af1eb 100644
> --- a/cpukit/rtems/include/rtems/rtems/part.h
> +++ b/cpukit/rtems/include/rtems/rtems/part.h
> @@ -135,10 +135,17 @@ rtems_status_code rtems_partition_ident(
> - *  @brief rtems_partition_delete
> + *  @brief RTEMS Delete Partition
>   *  This routine implements the rtems_partition_delete directive.  The
> - *  partition indicated by ID is deleted.
> + *  partition indicated by ID is deleted, provided that none of its
> buffers
> + *  are still allocated.
> + *  @param[in] id is the partition id
>  rtems_status_code rtems_partition_delete(
>    rtems_id id
> diff --git a/cpukit/rtems/include/rtems/rtems/ratemon.h
> b/cpukit/rtems/include/rtems/rtems/ratemon.h
> index 93c8e26..9b0d1de 100644
> --- a/cpukit/rtems/include/rtems/rtems/ratemon.h
> +++ b/cpukit/rtems/include/rtems/rtems/ratemon.h
> @@ -269,6 +269,8 @@ RTEMS_RATEMON_EXTERN Objects_Information
> _Rate_monotonic_Information;
>   *  @brief Rate Monotonic Manager Initialization
>   *  This routine performs the initialization necessary for this manager.
> + *  @note The Rate Monotonic Manager is built on top of the Watchdog
> Handler
>  void _Rate_monotonic_Manager_initialization(void);
> @@ -285,11 +287,19 @@ rtems_status_code rtems_rate_monotonic_create(
> - *  @brief rtems_rate_monotonic_ident
> + *  @brief RTEMS Rate Monotonic Name to Id
>   *  This routine implements the rtems_rate_monotonic_ident directive.
>   *  It returns the period ID associated with name.  If more than one
> period
>   *  is named name, then the period to which the ID belongs is arbitrary.
> + *  @param[in] name is the user defined period name
> + *  @param[in] id is the pointer to period id
> + *          source of the error.  If successful, the id will
> + *          be filled in with the region id.
>  rtems_status_code rtems_rate_monotonic_ident(
>    rtems_name    name,
> @@ -314,10 +324,16 @@ rtems_status_code rtems_rate_monotonic_cancel(
> - *  @brief rtems_rate_monotonic_delete
> + *  @brief RTEMS Delete Rate Monotonic
>   *  This routine implements the rtems_rate_monotonic_delete directive.
> The
>   *  period indicated by ID is deleted.
> + *  @param[in] id is the rate monotonic id
>  rtems_status_code rtems_rate_monotonic_delete(
>    rtems_id   id
> @@ -328,6 +344,13 @@ rtems_status_code rtems_rate_monotonic_delete(
>   *  This routine implements the rtems_rate_monotonic_get_status directive.
>   *  Information about the period indicated by ID is returned.
> + *  @param[in] status is the pointer to status control block
>  rtems_status_code rtems_rate_monotonic_get_status(
> @@ -370,10 +393,13 @@ rtems_status_code
> rtems_rate_monotonic_reset_statistics(
>  void rtems_rate_monotonic_reset_all_statistics( void );
> - *  @brief rtems_rate_monotonic_report_statistics
> + *  @brief RTEMS Report Rate Monotonic Statistics
>   *  This routine allows a thread to print the statistics information
>   *  on ALL period instances which have non-zero counts using printk.
> + *  The implementation of this directive straddles the fence between
> + *  inside and outside of RTEMS.  It is presented as part of the Manager
> + *  but actually uses other services of the Manager.
>  void rtems_rate_monotonic_report_statistics_with_plugin(
>    void                  *context,
> @@ -381,7 +407,7 @@ void
> diff --git a/cpukit/rtems/include/rtems/rtems/region.h
> b/cpukit/rtems/include/rtems/rtems/region.h
> index 055e25d..269725a 100644
> --- a/cpukit/rtems/include/rtems/rtems/region.h
> +++ b/cpukit/rtems/include/rtems/rtems/region.h
> @@ -154,11 +154,20 @@ rtems_status_code rtems_region_get_information(
> - *  @brief rtems_region_get_free_information
> + *  @brief RTEMS Get Region Free Information
>   *  This routine implements the rtems_region_get_free_information
> directive.
>   *  This directive returns information about the free blocks in the
> - *  heap associated with this region.
> + *  heap associated with this region.  Information about the used blocks
> + *  will be returned as zero.
> + *  @param[in] id is the region id
> + *  @param[in] the_info is the pointer to region information block
> + *          source of the error.  If successful, the the_info will
> + *          be filled in with the region information block.
>  rtems_status_code rtems_region_get_free_information(
>    rtems_id                id,
> diff --git a/cpukit/rtems/include/rtems/rtems/sem.h
> b/cpukit/rtems/include/rtems/rtems/sem.h
> index 2322088..3ab9a65 100644
> --- a/cpukit/rtems/include/rtems/rtems/sem.h
> +++ b/cpukit/rtems/include/rtems/rtems/sem.h
> @@ -168,7 +168,7 @@ rtems_status_code rtems_semaphore_delete(
> - *  @brief rtems_semaphore_obtain
> + *  @brief RTEMS Obtain Semaphore
>   *  This routine implements the rtems_semaphore_obtain directive.  It
>   *  attempts to obtain a unit from the semaphore associated with ID.
> @@ -177,6 +177,14 @@ rtems_status_code rtems_semaphore_delete(
>   *  block waiting for a unit with an optional timeout of timeout
>   *  clock ticks.  Whether the task blocks or returns immediately
>   *  is based on the RTEMS_NO_WAIT option in the option_set.
> + *  @param[in] id is the semaphore id
> + *  @param[in] option_set is the wait option
> + *  @param[in] timeout is the number of ticks to wait (0 means wait
> forever)
>  rtems_status_code rtems_semaphore_obtain(
>    rtems_id       id,
> diff --git a/cpukit/rtems/include/rtems/rtems/support.h
> b/cpukit/rtems/include/rtems/rtems/support.h
> index 99bf405..30716de 100644
> --- a/cpukit/rtems/include/rtems/rtems/support.h
> +++ b/cpukit/rtems/include/rtems/rtems/support.h
> @@ -63,7 +63,7 @@ extern "C" {
> - * @brief Gets workspace information.
> + * @brief Gets Workspace Information
>   * Returns information about the heap that is used as the RTEMS Executive
>   * Workspace in @a the_info.
> @@ -75,7 +75,7 @@ bool rtems_workspace_get_information(
> - * @brief Allocates memory from the workspace.
> + * @brief Allocates Memory from the Workspace
>   * A number of @a bytes bytes will be allocated from the RTEMS Executive
>   * Workspace and returned in @a pointer.
> @@ -88,7 +88,7 @@ bool rtems_workspace_allocate(
> - * @brief Frees memory allocated from the workspace.
> + * @brief Frees Memory Allocated from the Workspace
>   * This frees the memory indicated by @a pointer that was allocated from
> the
>   * RTEMS Executive Workspace.
> diff --git a/cpukit/rtems/include/rtems/rtems/tasks.h
> b/cpukit/rtems/include/rtems/rtems/tasks.h
> index 90379c1..dd3f20f 100644
> --- a/cpukit/rtems/include/rtems/rtems/tasks.h
> +++ b/cpukit/rtems/include/rtems/rtems/tasks.h
> @@ -345,12 +345,19 @@ rtems_status_code rtems_task_set_note(
> - *  @brief rtems_task_mode
> + *  @brief RTEMS Task Mode
>   *  This routine implements the rtems_task_mode directive.  The current
>   *  values of the modes indicated by mask of the calling task are changed
>   *  to that indicated in mode_set.  The former mode of the task is
>   *  returned in mode_set.
> + *  @param[in] mode_set is the new mode
> + *  @param[in] mask is the mask
> + *  @param[in] previous_mode_set is the address of previous mode set
> + *  @return RTEMS_SUCCESSFUL and previous_mode_set filled in with the
> + *  previous mode set
>  rtems_status_code rtems_task_mode(
>    rtems_mode  mode_set,
> @@ -475,7 +482,7 @@ rtems_status_code rtems_task_is_suspended(
> - *  @brief rtems_task_variable_add
> + *  @brief RTEMS Add Task Variable
>   *  This directive adds a per task variable.
> diff --git a/cpukit/rtems/include/rtems/rtems/timer.h
> b/cpukit/rtems/include/rtems/rtems/timer.h
> index ee35fec..e125f82 100644
> --- a/cpukit/rtems/include/rtems/rtems/timer.h
> +++ b/cpukit/rtems/include/rtems/rtems/timer.h
> @@ -275,23 +275,38 @@ rtems_status_code rtems_timer_cancel(
> - *  @brief rtems_timer_delete
> + *  @brief RTEMS Delete Timer
>   *  This routine implements the rtems_timer_delete directive.  The
>   *  timer indicated by ID is deleted.
> + *  @param[in] id is the timer id
>  rtems_status_code rtems_timer_delete(
>    rtems_id   id
> - *  @brief rtems_timer_fire_after
> + *  @brief RTEMS Timer Fire After
>   *  This routine implements the rtems_timer_fire_after directive.  It
>   *  initiates the timer associated with ID to fire in ticks clock ticks.
>   *  When the timer fires, the routine will be invoked in the context
>   *  of the rtems_clock_tick directive which is normally invoked as
>   *  part of servicing a periodic interupt.
> + *  @param[in] ticks is the interval until routine is fired
> + *  @param[in] routine is the routine to schedule
> + *  @param[in] user_data is the passed as argument to routine when it is
> fired
>  rtems_status_code rtems_timer_fire_after(
>    rtems_id                           id,
> diff --git a/cpukit/rtems/src/clockgettickssinceboot.c
> b/cpukit/rtems/src/clockgettickssinceboot.c
> index 96a1c5e..cfd91b5 100644
> --- a/cpukit/rtems/src/clockgettickssinceboot.c
> +++ b/cpukit/rtems/src/clockgettickssinceboot.c
> @@ -1,6 +1,11 @@
> - *  Clock Manager - Get Ticks Since Boot
> + *  @file
> + *  @brief Obtain Ticks Since Boot
> + *  @ingroup ClassicClock
>   *  COPYRIGHT (c) 1989-2008.
>   *  On-Line Applications Research Corporation (OAR).
> diff --git a/cpukit/rtems/src/clocktodvalidate.c
> b/cpukit/rtems/src/clocktodvalidate.c
> index 7aa854c..a56b1df 100644
> --- a/cpukit/rtems/src/clocktodvalidate.c
> +++ b/cpukit/rtems/src/clocktodvalidate.c
> @@ -1,7 +1,11 @@
> - *  Time of Day (TOD) Handler -- Validate Classic TOD
> + *  @file
>   *  COPYRIGHT (c) 1989-2007.
> @@ -29,21 +33,6 @@ const uint32_t   _TOD_Days_per_month[ 2 ][ 13 ] = {
>    { 0, 31, 29, 31, 30, 31, 30, 31, 31, 30, 31, 30, 31 }
> - *  _TOD_Validate
> - *  This kernel routine checks the validity of a date and time structure.
> - *  Input parameters:
> - *    the_tod - pointer to a time and date structure
> - *  Output parameters:
> - *    true  - if the date, time, and tick are valid
> - *    false - if the the_tod is invalid
> - *  NOTE: This routine only works for leap-years through 2099.
>  bool _TOD_Validate(
> diff --git a/cpukit/rtems/src/dpmeminternal2external.c
> b/cpukit/rtems/src/dpmeminternal2external.c
> index 6e61566..a6c8d83 100644
> --- a/cpukit/rtems/src/dpmeminternal2external.c
> +++ b/cpukit/rtems/src/dpmeminternal2external.c
> @@ -1,6 +1,11 @@
> - *  Dual Port Memory Manager
> + *  @file
> + *  @ingroup ClassicDPMEM
> @@ -22,24 +27,6 @@
>  #include <rtems/score/thread.h>
>  #include <rtems/rtems/dpmem.h>
> - *  rtems_port_internal_to_external
> - *  This directive converts an internal dual-ported memory address to an
> - *  external dual-ported memory address.  If the given internal address
> - *  is an invalid dual-ported address, then the external address is set
> - *  to the given internal address.
> - *    id       - id of dual-ported memory object
> - *    internal - internal address to set
> - *    external - pointer to external address
> - *    external          - external address
> - *    RTEMS_SUCCESSFUL - always succeeds
>    rtems_id   id,
>    void      *internal,
> diff --git a/cpukit/rtems/src/msgqreceive.c
> b/cpukit/rtems/src/msgqreceive.c
> index 00ed6c2..6be06ad 100644
> --- a/cpukit/rtems/src/msgqreceive.c
> +++ b/cpukit/rtems/src/msgqreceive.c
> @@ -1,7 +1,11 @@
> - *  Message Queue Manager
> + *  @file
> + *  @ingroup ClassicMessageQueue
> @@ -32,24 +36,6 @@
>  #include <rtems/rtems/options.h>
>  #include <rtems/rtems/support.h>
> - *  rtems_message_queue_receive
> - *  This directive dequeues a message from the designated message queue
> - *  and copies it into the requesting thread's buffer.
> - *    id         - queue id
> - *    buffer     - pointer to message buffer
> - *    size       - size of message receive
> - *    option_set - options on receive
> - *    timeout    - number of ticks to wait
> - *    RTEMS_SUCCESSFUL - if successful
> - *    error code       - if unsuccessful
>    rtems_id        id,
>    void           *buffer,
> diff --git a/cpukit/rtems/src/partdelete.c b/cpukit/rtems/src/partdelete.c
> index 6cae308..6aeee4e 100644
> --- a/cpukit/rtems/src/partdelete.c
> +++ b/cpukit/rtems/src/partdelete.c
> @@ -1,7 +1,11 @@
> - *  Partition Manager
> + *  @file
> + *  @ingroup ClassicPart
> @@ -23,21 +27,6 @@
>  #include <rtems/score/sysstate.h>
> - *  rtems_partition_delete
> - *  This directive allows a thread to delete a partition specified by
> - *  the partition identifier, provided that none of its buffers are
> - *  still allocated.
> - *    id - partition id
>    rtems_id id
> diff --git a/cpukit/rtems/src/ratemon.c b/cpukit/rtems/src/ratemon.c
> index d2eba80..d96a9b0 100644
> --- a/cpukit/rtems/src/ratemon.c
> +++ b/cpukit/rtems/src/ratemon.c
> @@ -1,7 +1,11 @@
> - *  Rate Monotonic Manager
> + *  @file
> + *  @brief Rate Monotonic Manager Initialization
> + *  @ingroup ClassicRateMon
> @@ -23,20 +27,6 @@
>  #include <rtems/rtems/ratemon.h>
> - *  _Rate_monotonic_Manager_initialization
> - *  This routine initializes all Rate Monotonic Manager related
> - *  data structures.
> - *  Input parameters:   NONE
> - *  Output parameters:  NONE
> - *  NOTE: The Rate Monotonic Manager is built on top of the Watchdog
> - *        Handler.
>    _Objects_Initialize_information(
> diff --git a/cpukit/rtems/src/ratemondelete.c
> b/cpukit/rtems/src/ratemondelete.c
> index 751c7f5..15498ea 100644
> --- a/cpukit/rtems/src/ratemondelete.c
> +++ b/cpukit/rtems/src/ratemondelete.c
> @@ -1,6 +1,11 @@
> - *  Rate Monotonic Manager -- Delete a Period
> + *  @file
> @@ -21,19 +26,6 @@
> - *  rtems_rate_monotonic_delete
> - *  This directive allows a thread to delete a rate monotonic timer.
> - *    id - rate monotonic id
>    rtems_id id
> diff --git a/cpukit/rtems/src/ratemongetstatus.c
> b/cpukit/rtems/src/ratemongetstatus.c
> index 73c59ee..5d0d584 100644
> --- a/cpukit/rtems/src/ratemongetstatus.c
> +++ b/cpukit/rtems/src/ratemongetstatus.c
> @@ -1,6 +1,11 @@
> - *  Rate Monotonic Manager -- Get Status
> + *  @file
> + *  @brief RTEMS Rate Monotonic Get Status
>   *  COPYRIGHT (c) 1989-2009.
> @@ -25,22 +30,6 @@
>    #include <rtems/score/timespec.h>
>  #endif
> - *  rtems_rate_monotonic_get_status
> - *  This directive allows a thread to obtain status information on a
> - *  period.
> - *    status - pointer to status control block
>    rtems_id                            id,
>    rtems_rate_monotonic_period_status *status
> diff --git a/cpukit/rtems/src/ratemonident.c
> b/cpukit/rtems/src/ratemonident.c
> index 35e4195..def9580 100644
> --- a/cpukit/rtems/src/ratemonident.c
> +++ b/cpukit/rtems/src/ratemonident.c
> @@ -1,6 +1,11 @@
> - *  Rate Monotonic Manager -- Name to Id Lookup
> + *  @file
> @@ -21,22 +26,6 @@
> - *  rtems_rate_monotonic_ident
> - *  This directive returns the system ID associated with
> - *  the rate monotonic period name.
> - *    name - user defined period name
> - *    id   - pointer to period id
> - *    *id              - region id
>    rtems_name  name,
>    rtems_id   *id
> diff --git a/cpukit/rtems/src/ratemonreportstatistics.c
> b/cpukit/rtems/src/ratemonreportstatistics.c
> index c94171c..daf5fb5 100644
> --- a/cpukit/rtems/src/ratemonreportstatistics.c
> +++ b/cpukit/rtems/src/ratemonreportstatistics.c
> @@ -1,6 +1,11 @@
> - *  Rate Monotonic Manager -- Report Statistics for All Periods
> + *  @file
>   *  COPYRIGHT (c) 1989-2010.
> @@ -28,14 +33,6 @@
>    #define NANOSECONDS_FMT "%06" PRId32
>  #endif
> - *  This directive allows a thread to print the statistics information
> - *  on ALL period instances which have non-zero counts using printk.
> - *  The implementation of this directive straddles the fence between
> - *  inside and outside of RTEMS.  It is presented as part of the Manager
> - *  but actually uses other services of the Manager.
>    void                  *context,
>    rtems_printk_plugin_t  print
> diff --git a/cpukit/rtems/src/regiongetfreeinfo.c
> b/cpukit/rtems/src/regiongetfreeinfo.c
> index 52b7135..bd16b0e 100644
> --- a/cpukit/rtems/src/regiongetfreeinfo.c
> +++ b/cpukit/rtems/src/regiongetfreeinfo.c
> @@ -1,7 +1,11 @@
> - *  Region Manager
> + *  @file
> + *  @ingroup ClassicRegion
> @@ -24,23 +28,6 @@
>  #include <rtems/score/apimutex.h>
> - *  rtems_region_get_free_information
> - *  This directive will return information about the free blocks
> - *  in the region specified.  Information about the used blocks
> - *  will be returned as zero.
> - *    id         - region id
> - *    the_info   - pointer to region information block
> - *    *the_info   - region information block filled in
>    rtems_id                id,
>    Heap_Information_block *the_info
> diff --git a/cpukit/rtems/src/rtemsobjectapimaximumclass.c
> b/cpukit/rtems/src/rtemsobjectapimaximumclass.c
> index 17ad518..abeee03 100644
> --- a/cpukit/rtems/src/rtemsobjectapimaximumclass.c
> +++ b/cpukit/rtems/src/rtemsobjectapimaximumclass.c
> @@ -1,6 +1,11 @@
> - *  RTEMS Object Helper -- Get Greatest Valid Class for an API
> + *  @file
> + *  @brief Get Highest Valid Class Value
> + *  @ingroup ClassicClassInfo
> diff --git a/cpukit/rtems/src/rtemsobjectgetapiname.c
> b/cpukit/rtems/src/rtemsobjectgetapiname.c
> index 4976a92..2f10ce7 100644
> --- a/cpukit/rtems/src/rtemsobjectgetapiname.c
> +++ b/cpukit/rtems/src/rtemsobjectgetapiname.c
> @@ -1,6 +1,11 @@
> - *  RTEMS Object Helper -- Obtain Name of API
> + *  @file
> + *  @brief Get API Name
> diff --git a/cpukit/rtems/src/semobtain.c b/cpukit/rtems/src/semobtain.c
> index 2faaff0..fe5710e 100644
> --- a/cpukit/rtems/src/semobtain.c
> +++ b/cpukit/rtems/src/semobtain.c
> @@ -1,20 +1,11 @@
> - *  Semaphore Manager
> - *  DESCRIPTION:
> - *  This package is the implementation of the Semaphore Manager.
> - *  This manager utilizes standard Dijkstra counting semaphores to provide
> - *  synchronization and mutual exclusion capabilities.
> - *  Directives provided are:
> - *     + create a semaphore
> - *     + get an ID of a semaphore
> - *     + delete a semaphore
> - *     + acquire a semaphore
> - *     + release a semaphore
> + *  @file
> + *  @ingroup ClassicSem
> @@ -47,21 +38,6 @@
>  #include <rtems/score/interr.h>
> - *  rtems_semaphore_obtain
> - *  This directive allows a thread to acquire a semaphore.
> - *    id         - semaphore id
> - *    option_set - wait option
> - *    timeout    - number of ticks to wait (0 means wait forever)
>    rtems_id        id,
>    rtems_option    option_set,
> diff --git a/cpukit/rtems/src/taskmode.c b/cpukit/rtems/src/taskmode.c
> index 9fab226..63fe29c 100644
> --- a/cpukit/rtems/src/taskmode.c
> +++ b/cpukit/rtems/src/taskmode.c
> @@ -1,6 +1,11 @@
> - *  RTEMS Task Manager - Change Task Mode
> + *  @file
> + *  @ingroup ClassicTasks
> @@ -28,22 +33,6 @@
>  #include <rtems/score/apiext.h>
> - *  rtems_task_mode
> - *  This directive enables and disables several modes of
> - *  execution for the requesting thread.
> - *    mode_set          - new mode
> - *    mask              - mask
> - *    previous_mode_set - address of previous mode set
> - *  Output:
> - *    *previous_mode_set - previous mode set
> - *     always return RTEMS_SUCCESSFUL;
>    rtems_mode  mask,
> diff --git a/cpukit/rtems/src/taskvariableadd.c
> b/cpukit/rtems/src/taskvariableadd.c
> index 415fe69..9a0bc3d 100644
> --- a/cpukit/rtems/src/taskvariableadd.c
> +++ b/cpukit/rtems/src/taskvariableadd.c
> @@ -1,7 +1,11 @@
> - *  rtems_task_variable_add - Add a per-task variable
> + *  @file
> @@ -18,12 +22,6 @@
>  #include <rtems/rtems/tasks.h>
>  #include <rtems/score/wkspace.h>
> - *  This directive registers a task variable.
>  rtems_status_code rtems_task_variable_add(
>    rtems_id tid,
>    void **ptr,
> diff --git a/cpukit/rtems/src/timerdelete.c
> b/cpukit/rtems/src/timerdelete.c
> index e7a0d15..f259280 100644
> --- a/cpukit/rtems/src/timerdelete.c
> +++ b/cpukit/rtems/src/timerdelete.c
> @@ -1,7 +1,11 @@
> - *  Timer Manager - rtems_timer_delete directive
> + *  @file
> + *  @ingroup ClassicTimer
> @@ -23,19 +27,6 @@
>  #include <rtems/score/tod.h>
>  #include <rtems/score/watchdog.h>
> - *  rtems_timer_delete
> - *  This directive allows a thread to delete a timer.
> - *    id - timer id
>    rtems_id id
> diff --git a/cpukit/rtems/src/timerfireafter.c
> b/cpukit/rtems/src/timerfireafter.c
> index f823a7b..267c1cf 100644
> --- a/cpukit/rtems/src/timerfireafter.c
> +++ b/cpukit/rtems/src/timerfireafter.c
> @@ -1,7 +1,11 @@
> - *  Timer Manager - rtems_timer_fire_after directive
> + *  @file
> @@ -23,22 +27,6 @@
> - *  rtems_timer_fire_after
> - *  This directive allows a thread to start a timer.
> - *    id        - timer id
> - *    ticks     - interval until routine is fired
> - *    routine   - routine to schedule
> - *    user_data - passed as argument to routine when it is fired
>    rtems_id                           id,
>    rtems_interval                     ticks,
> diff --git a/cpukit/rtems/src/workspace.c b/cpukit/rtems/src/workspace.c
> index 7af5897..38747be 100644
> --- a/cpukit/rtems/src/workspace.c
> +++ b/cpukit/rtems/src/workspace.c
> @@ -1,6 +1,11 @@
> - *  Workspace Handler
> + *  @file
> + *  @brief RTEMS Workspace Support
> + *  @ingroup ClassicRTEMSWorkspace
> @@ -32,9 +37,6 @@ bool rtems_workspace_get_information(
>    return _Protected_heap_Get_information( &_Workspace_Area, the_info );
> - *  _Workspace_Allocate
>    size_t      bytes,
>    void      **pointer
> @@ -62,9 +64,6 @@ bool rtems_workspace_allocate(
>    return true;
>  bool rtems_workspace_free(
>    void *pointer
URL: <http://lists.rtems.org/pipermail/devel/attachments/20121205/162e2f05/attachment-0001.html>
