[PATCH] score: rtems_initialize_start_multitasking()
Sebastian Huber
Thu Dec 6 09:04:41 UTC 2012
Do not return from rtems_initialize_start_multitasking() and call
rtems_fatal() instead with a fatal source of RTEMS_FATAL_SOURCE_EXIT and
a fatal code with the exit status.
Remove all bsp_cleanup() functions. The boot_card() is now a no return
function.
c/src/lib/libbsp/arm/gdbarmsim/start/start.S | 2 -
c/src/lib/libbsp/lm32/milkymist/startup/bspclean.c | 5 ---
c/src/lib/libbsp/m68k/mcf5225x/startup/bspclean.c | 9 -----
c/src/lib/libbsp/m68k/mrm332/misc/interr.c | 5 ---
c/src/lib/libbsp/m68k/mrm332/spurious/spinit.c | 10 ++---
c/src/lib/libbsp/m68k/mvme136/startup/bspclean.c | 7 ----
c/src/lib/libbsp/m68k/mvme147/startup/bspclean.c | 7 ----
c/src/lib/libbsp/m68k/mvme162/startup/bspclean.c | 7 ----
c/src/lib/libbsp/m68k/mvme167/startup/bspclean.c | 29 +++------------
c/src/lib/libbsp/m68k/uC5282/startup/bspclean.c | 9 -----
.../lib/libbsp/powerpc/beatnik/startup/bspclean.c | 7 ----
.../lib/libbsp/powerpc/mvme5500/startup/bspclean.c | 7 ----
.../lib/libbsp/powerpc/virtex4/startup/bspclean.c | 8 +----
.../lib/libbsp/powerpc/virtex5/startup/bspclean.c | 8 +----
c/src/lib/libbsp/shared/bootcard.c | 23 +++----------
c/src/lib/libbsp/shared/bspclean.c | 7 ----
c/src/lib/libbsp/shared/include/bootcard.h | 12 ++----
cpukit/sapi/include/rtems/init.h | 20 +++++++----
cpukit/sapi/src/exinit.c | 7 +++-
doc/bsp_howto/init.t | 36 +++++++++-----------
doc/bsp_howto/support.t | 24 +++++++------
doc/user/init.t | 22 ++++++-----
22 files changed, 80 insertions(+), 191 deletions(-)
diff --git a/c/src/lib/libbsp/arm/gdbarmsim/start/start.S b/c/src/lib/libbsp/arm/gdbarmsim/start/start.S
index 0c5df48..5a5613a 100644
--- a/c/src/lib/libbsp/arm/gdbarmsim/start/start.S
+++ b/c/src/lib/libbsp/arm/gdbarmsim/start/start.S
@@ -311,8 +311,6 @@ __change_mode:
mov r0, #0
bl FUNCTION (boot_card)
- bl FUNCTION (bsp_cleanup) /* Should not return. */
#if defined(__thumb__) && !defined(__thumb2__)
/* Come out of Thumb mode. This code should be redundant. */
diff --git a/c/src/lib/libbsp/lm32/milkymist/startup/bspclean.c b/c/src/lib/libbsp/lm32/milkymist/startup/bspclean.c
index 6dcda18..b713642 100644
--- a/c/src/lib/libbsp/lm32/milkymist/startup/bspclean.c
+++ b/c/src/lib/libbsp/lm32/milkymist/startup/bspclean.c
@@ -56,8 +56,3 @@ void bsp_fatal_extension(
else
reboot();
-void bsp_cleanup(uint32_t status)
- rtems_fatal(RTEMS_FATAL_SOURCE_EXIT, status);
diff --git a/c/src/lib/libbsp/m68k/mcf5225x/startup/bspclean.c b/c/src/lib/libbsp/m68k/mcf5225x/startup/bspclean.c
index e8c70c3..15dd244 100644
--- a/c/src/lib/libbsp/m68k/mcf5225x/startup/bspclean.c
+++ b/c/src/lib/libbsp/m68k/mcf5225x/startup/bspclean.c
@@ -1,6 +1,4 @@
- * SBC5206 bsp_cleanup
* This routine returns control from RTEMS to the monitor.
* Author:
@@ -27,10 +25,3 @@ void bsp_fatal_extension(
printk("\nRTEMS exited!\n");
-void __attribute__((weak)) bsp_cleanup(
- uint32_t status
- rtems_fatal( RTEMS_FATAL_SOURCE_EXIT, status );
diff --git a/c/src/lib/libbsp/m68k/mrm332/misc/interr.c b/c/src/lib/libbsp/m68k/mrm332/misc/interr.c
index 356a247..d96f909 100644
--- a/c/src/lib/libbsp/m68k/mrm332/misc/interr.c
+++ b/c/src/lib/libbsp/m68k/mrm332/misc/interr.c
@@ -48,8 +48,3 @@ void bsp_fatal_extension(
outbyte( (char)(the_error & 0xff) );
RAW_PUTS(").\r\n");
-void bsp_cleanup( uint32_t status )
diff --git a/c/src/lib/libbsp/m68k/mrm332/spurious/spinit.c b/c/src/lib/libbsp/m68k/mrm332/spurious/spinit.c
index d5ebfba..c9c94fe 100644
--- a/c/src/lib/libbsp/m68k/mrm332/spurious/spinit.c
+++ b/c/src/lib/libbsp/m68k/mrm332/spurious/spinit.c
@@ -72,12 +72,10 @@ rtems_isr Spurious_Isr(
RAW_PUTI(sp);
RAW_PUTS("\n\r");
#endif
- bsp_cleanup(1);
- /* BDM SIGEMT */
- __asm__ (" .word 0x4afa");
- for(;;);
+ rtems_fatal(
+ RTEMS_FATAL_SOURCE_BSP_GENERIC,
+ BSP_GENERIC_FATAL_SPURIOUS_INTERRUPT
void Spurious_Initialize(void)
diff --git a/c/src/lib/libbsp/m68k/mvme136/startup/bspclean.c b/c/src/lib/libbsp/m68k/mvme136/startup/bspclean.c
index 50feb5a..fa9fb55 100644
--- a/c/src/lib/libbsp/m68k/mvme136/startup/bspclean.c
+++ b/c/src/lib/libbsp/m68k/mvme136/startup/bspclean.c
@@ -44,10 +44,3 @@ void bsp_fatal_extension(
M68Kvec[ 45 ] = bsp_return_to_monitor_trap; /* install handler */
__asm__ volatile( "trap #13" ); /* insures SUPV mode */
-void bsp_cleanup(
- uint32_t status
diff --git a/c/src/lib/libbsp/m68k/mvme147/startup/bspclean.c b/c/src/lib/libbsp/m68k/mvme147/startup/bspclean.c
index 405d926..e566c1d 100644
--- a/c/src/lib/libbsp/m68k/mvme147/startup/bspclean.c
+++ b/c/src/lib/libbsp/m68k/mvme147/startup/bspclean.c
@@ -43,10 +43,3 @@ void bsp_fatal_extension(
__asm__ volatile( "trap #13" ); /* ensures SUPV mode */
-void bsp_cleanup(
- uint32_t status
diff --git a/c/src/lib/libbsp/m68k/mvme162/startup/bspclean.c b/c/src/lib/libbsp/m68k/mvme162/startup/bspclean.c
index 3b275d9..ca59739 100644
--- a/c/src/lib/libbsp/m68k/mvme162/startup/bspclean.c
+++ b/c/src/lib/libbsp/m68k/mvme162/startup/bspclean.c
@@ -55,10 +55,3 @@ void bsp_fatal_extension(
-void bsp_cleanup(
- uint32_t status
diff --git a/c/src/lib/libbsp/m68k/mvme167/startup/bspclean.c b/c/src/lib/libbsp/m68k/mvme167/startup/bspclean.c
index 68e127f..820ffe8 100644
--- a/c/src/lib/libbsp/m68k/mvme167/startup/bspclean.c
+++ b/c/src/lib/libbsp/m68k/mvme167/startup/bspclean.c
@@ -49,19 +49,7 @@ static void bsp_return_to_monitor_trap( void )
__asm__ volatile( "jmp %0@" : "=a" (start_addr) : "0" (start_addr) );
-void bsp_fatal_extension(
- rtems_fatal_source source,
- bool is_internal,
- rtems_fatal_code error
- M68Kvec[ 45 ] = bsp_return_to_monitor_trap;
- __asm__ volatile( "trap #13" );
- * bsp_cleanup
* This code was copied from other MC680x0 MVME BSPs.
* Our guess is that someone was concerned about the CPU no longer being in
* supervisor mode when they got here. This function forces the CPU back to
@@ -73,18 +61,13 @@ void bsp_fatal_extension(
* problems if 167Bug is invoked before we get to switch the VBR back to
* 167Bug because trap 13 is documented as being reserved for the internal
* use of the debugger.
- * Prototyped in rtems/c/src/lib/libbsp/m68k/mvme167/include/bsp.h
- * Input parameters: NONE
- * Output parameters: NONE
- * Return values: DOES NOT RETURN
-void bsp_cleanup(
- uint32_t status
+void bsp_fatal_extension(
+ rtems_fatal_source source,
+ bool is_internal,
+ rtems_fatal_code error
+ M68Kvec[ 45 ] = bsp_return_to_monitor_trap;
+ __asm__ volatile( "trap #13" );
diff --git a/c/src/lib/libbsp/m68k/uC5282/startup/bspclean.c b/c/src/lib/libbsp/m68k/uC5282/startup/bspclean.c
index dc17af7..37aac9e 100644
--- a/c/src/lib/libbsp/m68k/uC5282/startup/bspclean.c
+++ b/c/src/lib/libbsp/m68k/uC5282/startup/bspclean.c
@@ -1,6 +1,4 @@
* Author: W. Eric Norum <norume at aps.anl.gov>
@@ -24,10 +22,3 @@ void bsp_fatal_extension(
bsp_reset();
-void bsp_cleanup(
- uint32_t status
diff --git a/c/src/lib/libbsp/powerpc/beatnik/startup/bspclean.c b/c/src/lib/libbsp/powerpc/beatnik/startup/bspclean.c
index 1539e44..f4369b5 100644
--- a/c/src/lib/libbsp/powerpc/beatnik/startup/bspclean.c
+++ b/c/src/lib/libbsp/powerpc/beatnik/startup/bspclean.c
@@ -17,10 +17,3 @@ void bsp_fatal_extension(
bsp_reset();
-void bsp_cleanup(
- uint32_t status
diff --git a/c/src/lib/libbsp/powerpc/mvme5500/startup/bspclean.c b/c/src/lib/libbsp/powerpc/mvme5500/startup/bspclean.c
index fc488ea..0494696 100644
--- a/c/src/lib/libbsp/powerpc/mvme5500/startup/bspclean.c
+++ b/c/src/lib/libbsp/powerpc/mvme5500/startup/bspclean.c
@@ -24,10 +24,3 @@ void bsp_fatal_extension(
printk("RTEMS terminated; Boot manually or turn on AUTO_BOOT.\n");
#endif
-void bsp_cleanup(
- uint32_t status
diff --git a/c/src/lib/libbsp/powerpc/virtex4/startup/bspclean.c b/c/src/lib/libbsp/powerpc/virtex4/startup/bspclean.c
index 3a2af55..5c7fe3d 100644
--- a/c/src/lib/libbsp/powerpc/virtex4/startup/bspclean.c
+++ b/c/src/lib/libbsp/powerpc/virtex4/startup/bspclean.c
@@ -1,5 +1,4 @@
-/* bsp_cleanup()
* This routine normally is part of start.s and usually returns
* control to a monitor.
@@ -53,8 +52,3 @@ void bsp_fatal_extension(
/* All done. Hang out. */
BSP_ask_for_reset();
diff --git a/c/src/lib/libbsp/powerpc/virtex5/startup/bspclean.c b/c/src/lib/libbsp/powerpc/virtex5/startup/bspclean.c
--- a/c/src/lib/libbsp/powerpc/virtex5/startup/bspclean.c
+++ b/c/src/lib/libbsp/powerpc/virtex5/startup/bspclean.c
@@ -1,5 +1,4 @@
-/* bsp_cleanup()
diff --git a/c/src/lib/libbsp/shared/bootcard.c b/c/src/lib/libbsp/shared/bootcard.c
index 33ad0ee..a928bb2 100644
--- a/c/src/lib/libbsp/shared/bootcard.c
+++ b/c/src/lib/libbsp/shared/bootcard.c
@@ -31,8 +31,7 @@
* - 1st task executes C++ global constructors
* .... appplication runs ...
* - exit
- * + back to here eventually
- * + bspclean.c: bsp_cleanup
+ * + will not return to here
* This style of initialization ensures that the C++ global
* constructors are executed after RTEMS is initialized.
@@ -69,12 +68,11 @@ const char *bsp_boot_cmdline;
* the system while maximizing shared code and keeping BSP code in C
* as much as possible.
-uint32_t boot_card(
+void boot_card(
const char *cmdline
rtems_interrupt_level bsp_isr_level;
- uint32_t status = 0;
* Special case for PowerPC: The interrupt disable mask is stored in SPRG0.
@@ -164,22 +162,11 @@ uint32_t boot_card(
* Complete initialization of RTEMS and switch to the first task.
* Global C++ constructors will be executed in the context of that task.
- status = rtems_initialize_start_multitasking();
+ rtems_initialize_start_multitasking();
- * APPLICATION RUNS HERE!!! When it shuts down, we return!!! *
+ * APPLICATION RUNS NOW!!! We will not return to here!!! *
- * Perform any BSP specific shutdown actions which are written in C.
- bsp_cleanup( status );
- * Now return to the start code.
- return status;
diff --git a/c/src/lib/libbsp/shared/bspclean.c b/c/src/lib/libbsp/shared/bspclean.c
index 3e48c29..40955c6 100644
--- a/c/src/lib/libbsp/shared/bspclean.c
+++ b/c/src/lib/libbsp/shared/bspclean.c
@@ -1,6 +1,4 @@
- * This is a dummy bsp_cleanup routine.
* COPYRIGHT (c) 1989-1999.
* On-Line Applications Research Corporation (OAR).
@@ -45,8 +43,3 @@ void bsp_fatal_extension(
bsp_reset();
#endif
diff --git a/c/src/lib/libbsp/shared/include/bootcard.h b/c/src/lib/libbsp/shared/include/bootcard.h
index 237b76d..f3de760 100644
--- a/c/src/lib/libbsp/shared/include/bootcard.h
+++ b/c/src/lib/libbsp/shared/include/bootcard.h
@@ -55,7 +55,8 @@ extern "C" {
typedef enum {
BSP_GENERIC_FATAL_EXCEPTION_INITIALIZATION,
- BSP_GENERIC_FATAL_INTERRUPT_INITIALIZATION
+ BSP_GENERIC_FATAL_INTERRUPT_INITIALIZATION,
} bsp_generic_fatal_code;
@@ -71,8 +72,6 @@ void bsp_predriver_hook(void);
void bsp_postdriver_hook(void);
-void bsp_cleanup(uint32_t status);
void bsp_reset(void);
@@ -107,15 +106,12 @@ void bsp_reset(void);
* - .... application runs ...
* - exit
- * - back to here eventually
- * - bsp_cleanup()
- * If something goes wrong bsp_cleanup() will be called out of order.
+ * - will not return to here
* This style of initialization ensures that the C++ global constructors are
* executed after RTEMS is initialized.
-uint32_t boot_card(const char *cmdline);
+void boot_card(const char *cmdline) RTEMS_COMPILER_NO_RETURN_ATTRIBUTE;
#ifdef CONFIGURE_MALLOC_BSP_SUPPORTS_SBRK
diff --git a/cpukit/sapi/include/rtems/init.h b/cpukit/sapi/include/rtems/init.h
index e3a5fdf..95b7cc7 100644
--- a/cpukit/sapi/include/rtems/init.h
+++ b/cpukit/sapi/include/rtems/init.h
@@ -69,16 +69,22 @@ void rtems_initialize_before_drivers(void);
void rtems_initialize_device_drivers(void);
- * @brief rtems_initialize_start_multitasking
+ * @brief Starts the multitasking.
- * This routine implements the early portion of rtems_initialize_executive
- * directive up to the pretasking hook. This directive is invoked at system
- * startup to initialize the RTEMS multitasking environment.
+ * This directive initiates multitasking and performs a context switch to the
+ * first user application task and may enable interrupts as a side-effect of
+ * that context switch. The context switch saves the executing context. The
+ * application runs now. The directive rtems_shutdown_executive() will return
+ * to the saved context. The exit() function will use this directive.
- * @return This method returns the status code passed into the
- * @ref rtems_shutdown_executive directive.
+ * After a return to the saved context a fatal system state is reached. The
+ * fatal source is RTEMS_FATAL_SOURCE_EXIT with a fatal code set to the value
+ * passed to rtems_shutdown_executive().
+ * This directive does not return.
-uint32_t rtems_initialize_start_multitasking(void);
+void rtems_initialize_start_multitasking(void)
+ RTEMS_COMPILER_NO_RETURN_ATTRIBUTE;
* @brief rtems_shutdown_executive
diff --git a/cpukit/sapi/src/exinit.c b/cpukit/sapi/src/exinit.c
index 2c68434..a48ad9b 100644
--- a/cpukit/sapi/src/exinit.c
+++ b/cpukit/sapi/src/exinit.c
@@ -217,8 +217,10 @@ void rtems_initialize_device_drivers(void)
_API_extensions_Run_postdriver();
+ uint32_t status;
_System_state_Set( SYSTEM_STATE_BEGIN_MULTITASKING );
_Thread_Start_multitasking();
@@ -232,5 +234,6 @@ uint32_t rtems_initialize_start_multitasking(void)
- return _Per_CPU_Information[0].idle->Wait.return_code;
+ status = _Per_CPU_Information[0].idle->Wait.return_code;
+ rtems_fatal( RTEMS_FATAL_SOURCE_EXIT, status );
diff --git a/doc/bsp_howto/init.t b/doc/bsp_howto/init.t
index f91d15f..d1486cc 100644
--- a/doc/bsp_howto/init.t
+++ b/doc/bsp_howto/init.t
@@ -41,7 +41,6 @@ for this functionality.
@example
../../sparc/shared/start.S
-../../sparc/shared/bspclean.c
@end example
@b{NOTE:} In most BSPs, the directory named @code{start340} in the
@@ -93,10 +92,9 @@ to the shared @code{bootcard.c} framework then through the C Library,
RTEMS, device driver initialization phases, and the context switch
to the first application task. After this, the application executes
until it calls @code{exit}, @code{rtems_shutdown_executive}, or some
-other normal termination initiating routine and control is returned
-to @code{bootcard.c} which allows the BSP to perform some cleanup in C
-(@code{bsp_cleanup}) and then @code{boot_card} returns to the assembly
-language which initially invoked it.
+other normal termination initiating routine and a fatal system state is
+reached. The optional @code{bsp_fatal_extension} initial extension can perform
+BSP specific system termination.
The routines invoked during this will be discussed and their location
in the RTEMS source tree pointed out as we discuss each.
@@ -197,28 +195,26 @@ this point in the initialization sequence. This is the last opportunity
for the BSP to insert BSP specific code into the initialization sequence.
@item It invokes the RTEMS directive
- at code{rtems_initialize_start_multitasking()} which starts multitasking and context switches to the first task. @code{boot_card()} will not return until the application is shutdown. As part of this sequence the following actions occur:
+ at code{rtems_initialize_start_multitasking()}
+which initiates multitasking and performs a context switch to the
+first user application task and may enable interrupts as a side-effect of
+that context switch. The context switch saves the executing context. The
+application runs now. The directive rtems_shutdown_executive() will return
+to the saved context. The exit() function will use this directive.
- at itemize @bullet
+After a return to the saved context a fatal system state is reached. The
+fatal source is RTEMS_FATAL_SOURCE_EXIT with a fatal code set to the value
+passed to rtems_shutdown_executive().
- at item RTEMS will context switch to the first application task. As a
-side-effect of this context switch, processor interrupts will be enabled.
-This is often the source of a fatal error during BSP development because
-the BSP did not clear and/or disable all interrupt sources and a spurious
-interrupt will occur .
+The enabling of interrupts during the first context switch is often the source
+for fatal errors during BSP development because the BSP did not clear and/or
+disable all interrupt sources and a spurious interrupt will occur.
- at item When in the context of the first task but before its body has been
+When in the context of the first task but before its body has been
entered, any C++ Global Constructors will be invoked.
@end itemize
- at item Finally after the application shutsdown RTEMS and control is
-return to @code{boot_card()} from RTEMS, it invokes the BSP specific
-routine @code{bsp_cleanup()} to perform any necessary board specific
-shutdown actions.
- at end itemize
That's it. We just went through the entire sequence.
@subsection bsp_start() - BSP Specific Initialization
diff --git a/doc/bsp_howto/support.t b/doc/bsp_howto/support.t
index 9856deb..5f8eb1a 100644
--- a/doc/bsp_howto/support.t
+++ b/doc/bsp_howto/support.t
@@ -179,23 +179,25 @@ this operation.
@findex CONFIGURE_MALLOC_BSP_SUPPORTS_SBRK
If your BSP does not want to support dynamic heap extension, then you do not have to do anything special. However, if you want to support @code{sbrk}, you must provide an implementation of this method and define @code{CONFIGURE_MALLOC_BSP_SUPPORTS_SBRK} in @code{bsp.h}. This informs @code{rtems/confdefs.h} to configure the Malloc Family Extensions which support @code{sbrk}.
- at section bsp_cleanup(uint32_t status) - Cleanup the Hardware
+ at section bsp_fatal_extension() - Cleanup the Hardware
-The @code{bsp_cleanup()} is the last C code invoked. Most of the BSPs
-use the same shared version of @code{bsp_cleanup()} that does nothing.
-This implementation is located in the following file:
+The @code{bsp_fatal_extension()} is an optional BSP specific initial extension
+invoked once a fatal system state is reached. Most of the BSPs use the same
+shared version of @code{bsp_fatal_extension()} that does nothing or performs a
+system reset. This implementation is located in the following file:
@example
@end example
-The @code{bsp_cleanup()} routine can be used to return to a ROM monitor,
-insure that interrupt sources are disabled, etc.. This routine is the
-last place to ensure a clean shutdown of the hardware. The @code{status}
-argument is the value passed to the service which initiated shutting
-down RTEMS. All of the non-fatal shutdown sequences ultimately pass
-their exit status to @code{rtems_shutdown_executive} and this is what
-is passed to this routine.
+The @code{bsp_fatal_extension()} routine can be used to return to a ROM
+monitor, insure that interrupt sources are disabled, etc.. This routine is the
+last place to ensure a clean shutdown of the hardware. The fatal source,
+internal error indicator, and the fatal code arguments are available to
+evaluate the fatal condition. All of the non-fatal shutdown sequences
+ultimately pass their exit status to @code{rtems_shutdown_executive} and this
+is what is passed to this routine in case the fatal source is
+RTEMS_FATAL_SOURCE_EXIT.
On some BSPs, it prints a message indicating that the application
completed execution and waits for the user to press a key before
diff --git a/doc/user/init.t b/doc/user/init.t
index d7da360..4fe4926 100644
--- a/doc/user/init.t
+++ b/doc/user/init.t
@@ -346,7 +346,7 @@ the first context switch.
@ifset is-C
@findex rtems_initialize_start_multitasking
@example
+void rtems_initialize_start_multitasking(void);
@end example
@end ifset
@@ -358,21 +358,23 @@ NOT SUPPORTED FROM Ada BINDING
@subheading DIRECTIVE STATUS CODES:
-This directive returns the status code passed in to the
- at code{@value{DIRPREFIX}shutdown_executive}.
+NONE
@subheading DESCRIPTION:
-This directive is called after the other Initialization Manager
-directives have successfully completed. This directive
-initiates multitasking and performs a context switch to
-the first user application task and enables interrupts as
-a side-effect of that context switch.
+This directive initiates multitasking and performs a context switch to the
@subheading NOTES:
-This directive @b{DOES NOT RETURN} to the caller until the
- at code{@value{DIRPREFIX}shutdown_executive} is invoked.
+This directive @b{DOES NOT RETURN} to the caller.
This directive causes all nodes in the system to
verify that certain configuration parameters are the same as
1.7.7
