[PATCH] libcsupport: Clean up Doxygen Task #1
Sat Dec 8 14:08:36 UTC 2012
http://www.google-melange.com/gci/task/view/google/gci2012/7985214
 cpukit/libcsupport/include/rtems/assoc.h           |   11 +++++++++++
 cpukit/libcsupport/include/rtems/libio.h           |   13 +++++++++----
 cpukit/libcsupport/include/rtems/malloc.h          |   11 +++++++++++
 cpukit/libcsupport/include/sys/statvfs.h           |    8 ++++++++
 cpukit/libcsupport/include/sys/termios.h           |   12 ++++++++++++
 cpukit/libcsupport/src/_malloc_r.c                 |    8 ++++++--
 .../libcsupport/src/assoclocalbyremotebitfield.c   |    8 +++++---
 cpukit/libcsupport/src/assocremotebylocal.c        |    8 +++++---
 cpukit/libcsupport/src/fstat.c                     |    9 +++++++--
 cpukit/libcsupport/src/ftrylockfile.c              |   11 ++++++++++-
 cpukit/libcsupport/src/getpgrp.c                   |   10 ++++++++--
 cpukit/libcsupport/src/getrusage.c                 |    7 +++++++
 cpukit/libcsupport/src/lchown.c                    |   14 +++++++++++---
 cpukit/libcsupport/src/lseek.c                     |    9 +++++++--
 .../src/malloc_report_statistics_plugin.c          |    9 +++++++--
 cpukit/libcsupport/src/mount-mgr.c                 |   19 ++++++++++++++-----
 cpukit/libcsupport/src/newlibc_exit.c              |   17 +++++++++++++----
 cpukit/libcsupport/src/open_dev_console.c          |   12 +++++++-----
 cpukit/libcsupport/src/rtems_heap_null_extend.c    |    7 +++++++
 cpukit/libcsupport/src/setuid.c                    |   10 ++++++++--
 cpukit/libcsupport/src/statvfs.c                   |    7 +++++++
 cpukit/libcsupport/src/strlcpy.c                   |   12 +++++++++---
 cpukit/libcsupport/src/tcflush.c                   |    7 +++++++
 cpukit/libcsupport/src/termios.c                   |    9 +++++++--
 cpukit/libcsupport/src/writev.c                    |    9 +++++++--
 25 files changed, 210 insertions(+), 47 deletions(-)
diff --git a/cpukit/libcsupport/include/rtems/assoc.h b/cpukit/libcsupport/include/rtems/assoc.h
index f55d3fe..eb03cb6 100644
--- a/cpukit/libcsupport/include/rtems/assoc.h
+++ b/cpukit/libcsupport/include/rtems/assoc.h
@@ -15,6 +15,14 @@
 extern "C" {
 #endif
+ * @defgroup AssocSupport RTEMS Associativity Support
+ * @ingroup libcsupport
+ * @brief RTEMS Associativity Routines
 typedef struct {
     const char  *name;
     uint32_t     local_value;
@@ -83,6 +91,9 @@ char *rtems_assoc_name_by_remote_bitfield(
   char *
+ *  @brief RTEMS Assoc Local by Remote Bitfield
 uint32_t     rtems_assoc_local_by_remote_bitfield(
   const rtems_assoc_t *,
   uint32_t
diff --git a/cpukit/libcsupport/include/rtems/libio.h b/cpukit/libcsupport/include/rtems/libio.h
index 9374f3a..ba2736f 100644
--- a/cpukit/libcsupport/include/rtems/libio.h
+++ b/cpukit/libcsupport/include/rtems/libio.h
@@ -1146,7 +1146,7 @@ int rtems_filesystem_default_fcntl(
 typedef off_t rtems_off64_t __attribute__((deprecated));
- * @brief Gets the mount handler for the file system @a type.
+ * @brief Gets the Mount Handler for the File System
  * @return The file system mount handler associated with the @a type, or
  * @c NULL if no such association exists.
@@ -1378,6 +1378,11 @@ void rtems_filesystem_initialize( void );
 typedef void (*rtems_libio_init_functions_t)(void);
 extern  rtems_libio_init_functions_t rtems_libio_init_helper;
+ *  @brief Open a Developer Console
+ *  This is a replaceable stub which opens the console, if present.
 void    open_dev_console(void);
 typedef void (*rtems_libio_supp_functions_t)(void);
@@ -1496,7 +1501,7 @@ extern const rtems_filesystem_table_t rtems_filesystem_table [];
 extern rtems_chain_control rtems_filesystem_mount_table;
- * @brief Registers a file system @a type.
+ * @brief Registers a File System
  * The @a mount_h handler will be used to mount a file system of this @a type.
@@ -1509,7 +1514,7 @@ int rtems_filesystem_register(
- * @brief Unregisters a file system @a type.
+ * @brief Unregisters a File System
  * @retval 0 Successful operation.
  * @retval -1 An error occured.  The @c errno indicates the error.
@@ -1616,7 +1621,7 @@ typedef bool (*rtems_per_filesystem_routine)(
- * @brief Iterates over all file system types.
+ * @brief Iterates over all File System Types
  * For each file system type the @a routine will be called with the entry and
  * the @a routine_arg parameter.
diff --git a/cpukit/libcsupport/include/rtems/malloc.h b/cpukit/libcsupport/include/rtems/malloc.h
index 9d475d3..54a2324 100644
--- a/cpukit/libcsupport/include/rtems/malloc.h
+++ b/cpukit/libcsupport/include/rtems/malloc.h
@@ -27,6 +27,14 @@ extern "C" {
 #endif
+ * @defgroup MallocSupport Malloc Support
+ * @brief RTEMS extensions to the Malloc Family
  *  @brief C program heap control.
  *  This is the pointer to the heap control structure used to manage the C
@@ -85,6 +93,9 @@ void *rtems_heap_extend_via_sbrk(
   size_t alloc_size
+ *  @brief RTEMS Extend NULL Heap
 void *rtems_heap_null_extend(
   Heap_Control *heap,
   size_t alloc_size
diff --git a/cpukit/libcsupport/include/sys/statvfs.h b/cpukit/libcsupport/include/sys/statvfs.h
index 13185e7..c5be7d2 100644
--- a/cpukit/libcsupport/include/sys/statvfs.h
+++ b/cpukit/libcsupport/include/sys/statvfs.h
@@ -27,6 +27,14 @@
 extern "C" {
 #endif
+ * @defgroup StatvfsSupport File System Information Support
+ * @brief File System Information
 typedef uint64_t fsblkcnt_t;
 typedef uint32_t fsfilcnt_t;
diff --git a/cpukit/libcsupport/include/sys/termios.h b/cpukit/libcsupport/include/sys/termios.h
index d763c89..1b9a5e4 100644
--- a/cpukit/libcsupport/include/sys/termios.h
+++ b/cpukit/libcsupport/include/sys/termios.h
@@ -22,6 +22,14 @@
 extern "C" {
 #endif
+ * @defgroup TermiosSupport POSIX Termios Support
+ * @brief POSIX Termios Implementation for RTEMS Console Device Driver
 typedef unsigned char	cc_t;
 typedef unsigned int	speed_t;
 typedef unsigned int	tcflag_t;
@@ -186,6 +194,10 @@ struct termios {
 int	tcdrain(int);
 int	tcflow(int, int);
+ *  @brief Flush non-transmitted Output Data, non-read Input Data or Both
 int	tcflush(int, int);
 int	tcgetattr(int, struct termios *);
 int	tcsetattr(int, int, struct termios *);
diff --git a/cpukit/libcsupport/src/_malloc_r.c b/cpukit/libcsupport/src/_malloc_r.c
index e3d1911..a4c74a6 100644
--- a/cpukit/libcsupport/src/_malloc_r.c
+++ b/cpukit/libcsupport/src/_malloc_r.c
@@ -1,6 +1,10 @@
- *  _malloc_r Implementation
+ *  @file
+ *  @brief  Request Allocation of an Object
  *  COPYRIGHT (c) 1989-2007.
  *  On-Line Applications Research Corporation (OAR).
diff --git a/cpukit/libcsupport/src/assoclocalbyremotebitfield.c b/cpukit/libcsupport/src/assoclocalbyremotebitfield.c
index 23b4c72..b4b4b65 100644
--- a/cpukit/libcsupport/src/assoclocalbyremotebitfield.c
+++ b/cpukit/libcsupport/src/assoclocalbyremotebitfield.c
@@ -1,6 +1,8 @@
- * assoc.c
- *      rtems assoc routines
+ *  @file
+ *  @ingroup AssocSupport
 #if HAVE_CONFIG_H
diff --git a/cpukit/libcsupport/src/assocremotebylocal.c b/cpukit/libcsupport/src/assocremotebylocal.c
index cd5fa0c..b981873 100644
--- a/cpukit/libcsupport/src/assocremotebylocal.c
+++ b/cpukit/libcsupport/src/assocremotebylocal.c
@@ -1,6 +1,8 @@
- * assoc.c
+ *  @file
+ *  @brief RTEMS Assoc Remote by Local
 #if HAVE_CONFIG_H
diff --git a/cpukit/libcsupport/src/fstat.c b/cpukit/libcsupport/src/fstat.c
index ca0aa51..1655f86 100644
--- a/cpukit/libcsupport/src/fstat.c
+++ b/cpukit/libcsupport/src/fstat.c
@@ -1,6 +1,11 @@
- *  fstat() - POSIX 1003.1b 5.6.2 - Get File Status
+ *  @file
+ *  @brief Get File Status
  *  COPYRIGHT (c) 1989-1999.
diff --git a/cpukit/libcsupport/src/ftrylockfile.c b/cpukit/libcsupport/src/ftrylockfile.c
index 54d5419..1aee952 100644
--- a/cpukit/libcsupport/src/ftrylockfile.c
+++ b/cpukit/libcsupport/src/ftrylockfile.c
@@ -1,3 +1,10 @@
+ *  @file
+ *  @brief Stdio Locking
  * Copyright (c) 2009 by
  * Ralf Corsépius, Ulm, Germany. All rights reserved.
@@ -16,7 +23,9 @@
 #include <rtems/seterr.h>
-/* This is a non-functional stub */
+ *  This is a non-functional stub
 int ftrylockfile(FILE* file __attribute__((unused)))
   rtems_set_errno_and_return_minus_one( ENOTSUP );
diff --git a/cpukit/libcsupport/src/getpgrp.c b/cpukit/libcsupport/src/getpgrp.c
index 9ff1dd6..98f250b 100644
--- a/cpukit/libcsupport/src/getpgrp.c
+++ b/cpukit/libcsupport/src/getpgrp.c
@@ -1,3 +1,10 @@
+ *  @file
+ *  @brief Get Process Group IDs
 #if HAVE_CONFIG_H
 #include "config.h"
 #endif
@@ -5,10 +12,9 @@
 #include <unistd.h>
  *  4.3.1 Get Process Group IDs, P1003.1b-1993, p. 89
 pid_t getpgrp( void )
diff --git a/cpukit/libcsupport/src/getrusage.c b/cpukit/libcsupport/src/getrusage.c
index a94c4c6..85fdc0d 100644
--- a/cpukit/libcsupport/src/getrusage.c
+++ b/cpukit/libcsupport/src/getrusage.c
@@ -1,3 +1,10 @@
+ *  @file
+ *  @brief Get Resource Usage
  *  COPYRIGHT (c) 1989-2010.
diff --git a/cpukit/libcsupport/src/lchown.c b/cpukit/libcsupport/src/lchown.c
index 406ac59..81deea8 100644
--- a/cpukit/libcsupport/src/lchown.c
+++ b/cpukit/libcsupport/src/lchown.c
@@ -1,7 +1,11 @@
- *  lchown() - POSIX 1003.1b 5.6.5 - Change Owner and Group of a File
- *             But Do Not Follow a Symlink
+ *  @file
+ *  @brief Change Owner and Group of a File
  *  Written by: Vinu Rajashekhar <vinutheraj at gmail.com>
  *  The license and distribution terms for this file may be
@@ -17,6 +21,10 @@
 #include <rtems/libio_.h>
+ * POSIX 1003.1b 5.6.5 - Change Owner and Group of a File
+ *             But Do Not Follow a Symlink
 int lchown( const char *path, uid_t owner, gid_t group )
   return rtems_filesystem_chown(
diff --git a/cpukit/libcsupport/src/lseek.c b/cpukit/libcsupport/src/lseek.c
index 18cf446..e8a917f 100644
--- a/cpukit/libcsupport/src/lseek.c
+++ b/cpukit/libcsupport/src/lseek.c
@@ -1,6 +1,11 @@
- *  lseek() - POSIX 1003.1b 6.5.3 - Reposition Read/Write File Offset
+ *  @file
+ *  @brief Reposition Read and Write File Offset
diff --git a/cpukit/libcsupport/src/malloc_report_statistics_plugin.c b/cpukit/libcsupport/src/malloc_report_statistics_plugin.c
index 04c7bb4..bc1e5b6 100644
--- a/cpukit/libcsupport/src/malloc_report_statistics_plugin.c
+++ b/cpukit/libcsupport/src/malloc_report_statistics_plugin.c
@@ -1,6 +1,11 @@
- *  malloc_report_statistics with plugin Implementation
+ *  @file
+ *  @brief Print Malloc Statistic Usage Report
+ *  @ingroup MallocSupport
diff --git a/cpukit/libcsupport/src/mount-mgr.c b/cpukit/libcsupport/src/mount-mgr.c
index 49eb6ab..7e25393 100644
--- a/cpukit/libcsupport/src/mount-mgr.c
+++ b/cpukit/libcsupport/src/mount-mgr.c
@@ -1,9 +1,11 @@
- *  mount()
- *  Mange the mount table. You can iterate on mounts and file systems, as well
- *  as add and remove file systems not in the file system confiration table.
+ *  @file
+ *  @brief RTEMS File System Support
+ *  @ingroup LibIO
  *  COPYRIGHT (c) Chris Johns <chrisj at rtems.org> 2010.
  *  Copyright (c) 2010 embedded brains GmbH.
@@ -29,6 +31,13 @@
+ *  mount()
+ *  Mange the mount table. You can iterate on mounts and file systems, as well
+ *  as add and remove file systems not in the file system confiration table. *
 typedef struct {
   rtems_chain_node node;
   rtems_filesystem_table_t entry;
diff --git a/cpukit/libcsupport/src/newlibc_exit.c b/cpukit/libcsupport/src/newlibc_exit.c
index 8e47b17..9896227 100644
--- a/cpukit/libcsupport/src/newlibc_exit.c
+++ b/cpukit/libcsupport/src/newlibc_exit.c
@@ -1,8 +1,11 @@
- *  Implementation of hooks for the CYGNUS newlib libc
- *  These hooks set things up so that:
- *       + '_REENT' is switched at task switch time.
+ *  @file
+ *  @brief Newlibc Exit Support
  *  COPYRIGHT (c) 1994 by Division Incorporated
@@ -34,6 +37,12 @@
+ *  Implementation of hooks for the CYGNUS newlib libc
+ *  These hooks set things up so that:
+ *       + '_REENT' is switched at task switch time.
 int _fwalk(struct _reent *ptr, int (*function) (FILE *) );
 /* do we think we are reentrant? */
diff --git a/cpukit/libcsupport/src/open_dev_console.c b/cpukit/libcsupport/src/open_dev_console.c
index d204dee..711adcc 100644
--- a/cpukit/libcsupport/src/open_dev_console.c
+++ b/cpukit/libcsupport/src/open_dev_console.c
@@ -1,6 +1,11 @@
- *  open_dev_console - open /dev/console
+ *  @file
+ *  @ingroup LibIO
  *  COPYRIGHT (c) 1989-2009.
@@ -17,9 +22,6 @@
 #include <rtems/libio.h>
 #include <fcntl.h>
- *  This is a replaceable stub which opens the console, if present.
   int      stdin_fd;
diff --git a/cpukit/libcsupport/src/rtems_heap_null_extend.c b/cpukit/libcsupport/src/rtems_heap_null_extend.c
index a821ef4..1b9e037 100644
--- a/cpukit/libcsupport/src/rtems_heap_null_extend.c
+++ b/cpukit/libcsupport/src/rtems_heap_null_extend.c
@@ -1,3 +1,10 @@
+ *  @file
  * Copyright (c) 2012 embedded brains GmbH.  All rights reserved.
diff --git a/cpukit/libcsupport/src/setuid.c b/cpukit/libcsupport/src/setuid.c
index 8173976..135fce2 100644
--- a/cpukit/libcsupport/src/setuid.c
+++ b/cpukit/libcsupport/src/setuid.c
@@ -1,3 +1,10 @@
+ *  @file
+ *  @brief Set User and Group IDs
@@ -15,8 +22,7 @@
 #include <rtems/userenv.h>
  *  4.2.2 Set User and Group IDs, P1003.1b-1993, p. 84
 int setuid(
diff --git a/cpukit/libcsupport/src/statvfs.c b/cpukit/libcsupport/src/statvfs.c
index 163d51e..01d18f7 100644
--- a/cpukit/libcsupport/src/statvfs.c
+++ b/cpukit/libcsupport/src/statvfs.c
@@ -1,3 +1,10 @@
+ *  @file
+ *  @brief Get File System Statistics
+ *  @ingroup StatvfsSupport
  *  COPYRIGHT (c) 2009 Chris Johns <chrisj at rtems.org>
diff --git a/cpukit/libcsupport/src/strlcpy.c b/cpukit/libcsupport/src/strlcpy.c
index 2773e87..3f97e1a 100644
--- a/cpukit/libcsupport/src/strlcpy.c
+++ b/cpukit/libcsupport/src/strlcpy.c
@@ -1,6 +1,11 @@
- * utils.c - various utility functions used in pppd.
+ *  @file
+ *  @brief Copy null-terminated String
  * Copyright (c) 1999 The Australian National University.
  * All rights reserved.
@@ -24,7 +29,8 @@
 #ifndef HAVE_STRLCPY
  * strlcpy - like strcpy/strncpy, doesn't overflow destination buffer,
  * always leaves destination null-terminated (for len > 0).
diff --git a/cpukit/libcsupport/src/tcflush.c b/cpukit/libcsupport/src/tcflush.c
index d528c2a..70aaa96 100644
--- a/cpukit/libcsupport/src/tcflush.c
+++ b/cpukit/libcsupport/src/tcflush.c
@@ -1,3 +1,10 @@
+ *  @file
+ *  @ingroup TermiosSupport
  *  tcflush() - POSIX 1003.1b 7.2.2 - Line Control Functions
diff --git a/cpukit/libcsupport/src/termios.c b/cpukit/libcsupport/src/termios.c
index bcf8d8a..163742d 100644
--- a/cpukit/libcsupport/src/termios.c
+++ b/cpukit/libcsupport/src/termios.c
@@ -1,6 +1,11 @@
- * TERMIOS serial line support
+ *  @file
+ *  @brief Termios Serial Line Support
  *  Author:
  *    W. Eric Norum
  *    Saskatchewan Accelerator Laboratory
diff --git a/cpukit/libcsupport/src/writev.c b/cpukit/libcsupport/src/writev.c
index 47605a4..3416420 100644
--- a/cpukit/libcsupport/src/writev.c
+++ b/cpukit/libcsupport/src/writev.c
@@ -1,6 +1,11 @@
- *  writev() - POSIX 1003.1 - Read a Vector
+ *  @file
+ *  @brief Write a Vector
  *  OpenGroup URL:
  *  http://www.opengroup.org/onlinepubs/009695399/functions/writev.html
1.7.1
