[rtems commit] libcsupport: Revert documentation changes
Gedare Bloom
gedare at rtems.org
Thu Dec 13 12:34:35 UTC 2012
I think we will try to generate new GCI tasks to replace the @brief
descriptions with a "topic sentence" rather than "section title", and
enforce single-space formatting. Joel has most of that infrastructure,
so I think he can do it when he gets back.
On Thu, Dec 13, 2012 at 5:29 AM, Sebastian Huber <sebh at rtems.org> wrote:
> Module: rtems
> Branch: master
> Commit: 8e3a7f4f8d10e9ba6fc5faa5ce01e98461f05922
> Changeset: http://git.rtems.org/rtems/commit/?id=8e3a7f4f8d10e9ba6fc5faa5ce01e98461f05922
> Author: Sebastian Huber <sebastian.huber at embedded-brains.de>
> Date: Thu Dec 13 11:29:06 2012 +0100
> cpukit/libcsupport/include/rtems/libio_.h | 18 +++++++++---------
> cpukit/libcsupport/include/rtems/malloc.h | 2 +-
> 2 files changed, 10 insertions(+), 10 deletions(-)
> diff --git a/cpukit/libcsupport/include/rtems/libio_.h b/cpukit/libcsupport/include/rtems/libio_.h
> index 19b8661..f56926a 100644
> --- a/cpukit/libcsupport/include/rtems/libio_.h
> +++ b/cpukit/libcsupport/include/rtems/libio_.h
> @@ -62,7 +62,7 @@ extern const rtems_filesystem_file_handlers_r rtems_filesystem_null_handlers;
> extern rtems_filesystem_mount_table_entry_t rtems_filesystem_null_mt_entry;
> - * @brief The Global NULL Location
> + * @brief The global null location.
> * Every operation and the open and fstat handlers of this location returns an
> * error status. The errno is not touched by these operations and handlers.
> @@ -194,15 +194,15 @@ void rtems_filesystem_location_clone(
> - * @brief Returns the Type of a Node
> + * @brief Returns the type of a node.
> - * This function obtains and releases the file system instance lock.
> + * This function obtains and releases the file system instance lock.
> - * @param[in] loc The location of the node.
> + * @param[in] loc The location of the node.
> - * @return The node type.
> + * @return The node type.
> - * @see rtems_filesystem_instance_lock().
> + * @see rtems_filesystem_instance_lock().
> rtems_filesystem_node_types_t rtems_filesystem_node_type(
> const rtems_filesystem_location_info_t *loc
> @@ -773,10 +773,10 @@ void rtems_filesystem_eval_path_error(
> - * @brief Checks that the Locations Exist in the Same File System Instance
> + * @brief Checks that the locations exist in the same file system instance.
> - * @retval 0 The locations exist and are in the same file system instance.
> - * @retval -1 An error occured. The @c errno indicates the error.
> + * @retval 0 The locations exist and are in the same file system instance.
> + * @retval -1 An error occured. The @c errno indicates the error.
> int rtems_filesystem_location_exists_in_same_instance_as(
> const rtems_filesystem_location_info_t *a,
> diff --git a/cpukit/libcsupport/include/rtems/malloc.h b/cpukit/libcsupport/include/rtems/malloc.h
> index fdb57f3..877bdbc 100644
> --- a/cpukit/libcsupport/include/rtems/malloc.h
> +++ b/cpukit/libcsupport/include/rtems/malloc.h
> @@ -222,7 +222,7 @@ rtems_status_code rtems_heap_extend(
> - * @brief Greedy Allocate that Empties the Heap
> + * @brief Greedy allocate that empties the heap.
> * Afterward the heap has at most @a block_count allocatable blocks of sizes
> * specified by @a block_sizes. The @a block_sizes must point to an array with
> rtems-vc mailing list
> rtems-vc at rtems.org
> http://www.rtems.org/mailman/listinfo/rtems-vc
