[rtems commit] libcsupport: Revert documentation changes
Thu Dec 13 12:37:24 UTC 2012
Are there other formatting changes required?
Another common error I noticed was that not all defgroups have @{ @},
so we can probably add that.
On Thu, Dec 13, 2012 at 7:34 AM, Gedare Bloom <gedare at rtems.org> wrote:
> I think we will try to generate new GCI tasks to replace the @brief
> descriptions with a "topic sentence" rather than "section title", and
> enforce single-space formatting. Joel has most of that infrastructure,
> so I think he can do it when he gets back.
> On Thu, Dec 13, 2012 at 5:29 AM, Sebastian Huber <sebh at rtems.org> wrote:
>> Module:    rtems
>> Branch:    master
>> Commit:    8e3a7f4f8d10e9ba6fc5faa5ce01e98461f05922
>> Changeset: http://git.rtems.org/rtems/commit/?id=8e3a7f4f8d10e9ba6fc5faa5ce01e98461f05922
>> Author:    Sebastian Huber <sebastian.huber at embedded-brains.de>
>> Date:      Thu Dec 13 11:29:06 2012 +0100
>>  cpukit/libcsupport/include/rtems/libio_.h |   18 +++++++++---------
>>  cpukit/libcsupport/include/rtems/malloc.h |    2 +-
>>  2 files changed, 10 insertions(+), 10 deletions(-)
>> diff --git a/cpukit/libcsupport/include/rtems/libio_.h b/cpukit/libcsupport/include/rtems/libio_.h
>> index 19b8661..f56926a 100644
>> --- a/cpukit/libcsupport/include/rtems/libio_.h
>> +++ b/cpukit/libcsupport/include/rtems/libio_.h
>> @@ -62,7 +62,7 @@ extern const rtems_filesystem_file_handlers_r rtems_filesystem_null_handlers;
>>  extern rtems_filesystem_mount_table_entry_t rtems_filesystem_null_mt_entry;
>> - *  @brief The Global NULL Location
>> + * @brief The global null location.
>>   * Every operation and the open and fstat handlers of this location returns an
>>   * error status.  The errno is not touched by these operations and handlers.
>> @@ -194,15 +194,15 @@ void rtems_filesystem_location_clone(
>> - *  @brief Returns the Type of a Node
>> + * @brief Returns the type of a node.
>> - *  This function obtains and releases the file system instance lock.
>> + * This function obtains and releases the file system instance lock.
>> - *  @param[in] loc The location of the node.
>> + * @param[in] loc The location of the node.
>> - *  @return The node type.
>> + * @return The node type.
>> - *  @see rtems_filesystem_instance_lock().
>> + * @see rtems_filesystem_instance_lock().
>>  rtems_filesystem_node_types_t rtems_filesystem_node_type(
>>    const rtems_filesystem_location_info_t *loc
>> @@ -773,10 +773,10 @@ void rtems_filesystem_eval_path_error(
>> - *  @brief Checks that the Locations Exist in the Same File System Instance
>> + * @brief Checks that the locations exist in the same file system instance.
>> - *  @retval 0 The locations exist and are in the same file system instance.
>> - *  @retval -1 An error occured.  The @c errno indicates the error.
>> + * @retval 0 The locations exist and are in the same file system instance.
>> + * @retval -1 An error occured.  The @c errno indicates the error.
>>  int rtems_filesystem_location_exists_in_same_instance_as(
>>    const rtems_filesystem_location_info_t *a,
>> diff --git a/cpukit/libcsupport/include/rtems/malloc.h b/cpukit/libcsupport/include/rtems/malloc.h
>> index fdb57f3..877bdbc 100644
>> --- a/cpukit/libcsupport/include/rtems/malloc.h
>> +++ b/cpukit/libcsupport/include/rtems/malloc.h
>> @@ -222,7 +222,7 @@ rtems_status_code rtems_heap_extend(
>> - *  @brief Greedy Allocate that Empties the Heap
>> + * @brief Greedy allocate that empties the heap.
>>   * Afterward the heap has at most @a block_count allocatable blocks of sizes
>>   * specified by @a block_sizes.  The @a block_sizes must point to an array with
>> rtems-vc mailing list
>> rtems-vc at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-vc
