[RFA] [PATCH] mips*el support for RTEMS
feng Gao gf91597 at gmail.com
Tue Dec 18 05:19:00 UTC 2012
Hello Sebastian,
Thankyou very much. I understand.
2012/12/15 Sebastian Huber <sebastian.huber at embedded-brains.de>:
> Hello Feng,
> it would really help if you can explain why you need this mips*el-rtems*
> target.  All targets have the pattern $arch-rtems*.  Here $arch is "mips"
> for example.  The RTEMS tool chain comes with so called multilibs.  These
> are basic libraries like libc and libgcc compiled for different ABIs and
> instruction sets.  Since the MIPS tool chain already provides a -mel
> multilib your patch makes no sense from my point of view.
> On 13/12/12 09:40, Sebastian Huber wrote:
>> On 12/13/2012 04:51 AM, feng Gao wrote:
>>> Hello Sebastian,
>>> We do need mips*el-*rtems*  as defaut, so I hope the patch can be
>>> approved.
>>> May you please apply it?
>> Why do you need a mips*el-*rtems* target?  Why can you not simply use
>> mips-rtems* with the -mel option?
> Address : Obere Lagerstr. 30, D-82178 Puchheim, Germany
> Phone   : +49 89 18 90 80 79-6
> Fax     : +49 89 18 90 80 79-9
> rtems-devel mailing list
> rtems-devel at rtems.org
