GCI Task review: breaking up long lines
Wed Dec 5 02:08:18 UTC 2012
Joel Sherrill wrote:
> Would an objdump and diff on the before and after .o be sufficient?
What happens with a macro in a header file ? You would need to diff all
objects.
An ELF diff would require all text, const, string and data sections be
the same and all variable names be the same. I am not sure this is
possible with just objdump. I like the idea of an ELF diff. I might look
into this later in the week and report back.
