Coding Style for RTEMS
Gedare Bloom
gedare at rtems.org
Wed Dec 5 14:52:54 UTC 2012
Thanks, sounds good. I don't think anyone ever suggested we reformat
external project's code. Also, enforcing contributions to RTEMS by external
parties, e.g. BSPs, to follow a certain coding standard would be beneficial
in the long-term, but such enforcement can be discussed later.
On Wed, Dec 5, 2012 at 9:41 AM, Sebastian Huber <
> Ok, I will try to make the wiki page about the score coding style more
> verbose and add examples.
> http://www.rtems.org/wiki/**index.php/Coding_Conventions<http://www.rtems.org/wiki/index.php/Coding_Conventions>
> I started this discussion since some file in RTEMS are really hard to
> read. If you want to change something more complicated it is beneficial to
> increase the readability with a tool and then do the functional changes as
> a second step. For this you need a clear enough description of the target
> style.
> I do not intend to do format changes without good reason. It is also
> madness to format source code of external projects e.g. the network stack.
> Address : Obere Lagerstr. 30, D-82178 Puchheim, Germany
> Phone : +49 89 18 90 80 79-6
> Fax : +49 89 18 90 80 79-9
> E-Mail : sebastian.huber at embedded-**brains.de<sebastian.huber at embedded-brains.de>
> ______________________________**_________________
> rtems-devel mailing list
> rtems-devel at rtems.org
> http://www.rtems.org/mailman/**listinfo/rtems-devel<http://www.rtems.org/mailman/listinfo/rtems-devel>
URL: <http://lists.rtems.org/pipermail/devel/attachments/20121205/2aff323d/attachment-0001.html>
