libi2c low-level implementation question again
Sebastian Huber
Tue Dec 11 10:40:33 UTC 2012
Hello,
I wrote some drivers for the I2C library, but unfortunately this library is so
complicated to use that I have to relearn it every time I use it again. You
should first read the README file:
http://git.rtems.org/rtems/tree/cpukit/libi2c/README_libi2c
Here is a sample driver:
http://git.rtems.org/rtems/tree/c/src/lib/libbsp/arm/lpc24xx/i2c/i2c.c
http://git.rtems.org/rtems/tree/c/src/lib/libbsp/arm/lpc24xx/i2c/i2c-config.c
I hope this helps a bit.
Phone : +49 89 18 94 80 741-16
Fax : +49 89 18 94 80 741-09
