[RFA] [PATCH] mips*el support for RTEMS
feng Gao gf91597 at gmail.com
Thu Dec 13 03:51:18 UTC 2012
Hello Sebastian,
We do need mips*el-*rtems* as defaut, so I hope the patch can be approved.
May you please apply it?
2012/12/7 Sebastian Huber <sebastian.huber at embedded-brains.de>:
> Hello,
> I think the normal way to get little endian support for MIPS on RTEMS would
> be to add the appropriate multilibs to GCC.  See in the GCC sources
> "gcc/config/mips/t-rtems".  It seems that we already have -mel variant:
> mips-rtems4.11-gcc -print-multi-lib
> mips32;@mips32
> soft-float;@msoft-float
> mips3/el;@mips3 at EL
> mips3/el/soft-float;@mips3 at EL@msoft-float
> mips32/soft-float;@mips32 at msoft-float
> Phone   : +49 89 18 94 80 741-16
> Fax     : +49 89 18 94 80 741-09
> rtems-devel mailing list
> rtems-devel at rtems.org
