AG patches chunk A
Daniel Hellstrom
daniel at gaisler.com
Thu Feb 2 14:39:30 UTC 2012
Hello,
I summarize the first chunk of patches, PATCH means I will send them on the rtems-devel list, PR means I will file a bugzilla PR. Feel free to comment.. and apply :)
Patches are listed in reverse apply order, thus IO_MANAGER patch comes last.
Thanks,
Daniel
+ SPARC specific enhancements
c1afe98 LEON3: fix compiler warning in SHM driver
+ SPARC specific bugs
3e2aa5e LEON3BSP MP: may wake one more CPU than expected
fe9dc9e SPARC BSPs: workspace must be aligned on a 8-byte boundary
124e68d LEON3: CPU index intialization moved to bspstart.c
c7d92b6 LEON3: change d-cache snoop detect implementation
LEON specific because GRETH driver only used by LEON:
7a92dba GRETH: Moved print to remove potential deadlock
6c66b13 GRETH: performance improvements and one bugfix
+ General bugs, (but not in any release, so PR not filed)
839ef7b MP06 TEST: avoid program failure when slow UART on CPU core 0
+ General enhancements
fe2ee40 bootstrap: handy --root switch for bootstrapping subdirs
11ae399 IO_MANAGER: early dynamic driver registration
PATCH commit 8713dbeead0fb5ce880793ef391916cc422efce5
Author: Daniel Hellstrom <daniel at gaisler.com>
Date: Thu Nov 24 16:54:28 2011 +0100
Adds the possibility to register drivers before the IO Manager has
completed the initialization. Sometimes the BSP may want to register
a driver dynamically early in the boot process.
Signed-off-by: Daniel Hellstrom <daniel at gaisler.com>
PATCH commit b2a54a1af400bf731855fe26c8c4550a7cc0697b
Date: Fri Nov 25 13:58:07 2011 +0100
Use the "--root DIR" to process only a subdir, for example
$ ./bootstrap --root c/src/lib/libbsp/sparc
will only generate Makefiles for all SPARC BSPs, saves some
time when working with a specific BSP.
PR commit 6c66b134e18dc24b3fe8b2d9a9a6954c6bc6840e
Date: Fri Dec 2 10:47:58 2011 +0100
GRETH driver updated, 10-15% performance improvements for GBIT MAC,
unnecessary RX interrupts not taken which under heavy load saves approx.
1500 interrupts/s, one task removed saving about 5kb memory and 1 bug
solved.
BUG: RX interrupt was enabled before the RX-daemon was created which could
result in a faulty call to rtems_event_send.
PR commit 7a92dba76fa113ab9fba1ddc90a2578ea8ff8d0a
Date: Fri Dec 2 10:45:10 2011 +0100
Deadlock may arise when the EDCL bug link is used to tunnel
console output over Ethernet, when Ethernet is down one should
avoid using console (only during debugging of LEON targets)
Author: Marko Isomaki <marko at gaisler.com>
PR[DEP-1] commit c7d92b6562014f85a29bd94ceb2c3292f36dfb32
Date: Fri Nov 25 14:02:00 2011 +0100
The previous code only checked if d-cache snooping was implemented,
however snooping may be available but not enabled which may lead
to driver bugs.
PR commit 124e68d114f1ae6489ee86167357e6b6b16503e5
Date: Fri Nov 25 14:15:16 2011 +0100
All LEON3/4 systems have a CPU-id, if on a single-CPU system the
ID is always zero. On a multicore system it ranges from 0 to 15.
The CPU index should always by updated even in a non-MP RTEMS OS
since the CPU running RTEMS may not always be CPU0. For example
when RTEMS runs on CPU1 and Linux on CPU0 in a mixed ASMP system.
The old code executed within the IRQ controller initialization code
makes no sense since the ASR register is a CPU register, it has
nothing to do with AMBA initialization either.
PATCH commit 839ef7ba191dc65ecbb777bbd108758025259d34
Date: Wed Nov 16 16:56:46 2011 +0100
PR commit fe9dc9e1a55c1e71980eaa290f193cdae79141ca
Date: Fri Nov 25 10:54:28 2011 +0100
The linker-script already declares a 8-byte aligned symbol (_end)
which can be used instead of "variable aligned" symbol end.
PR commit 3e2aa5ed2415ff02dac7545930f0a07c546dac77
Date: Wed Nov 9 16:09:55 2011 +0100
The SHM code always wakes one CPU more that configured, however
this has never been a problem since RTEMS will be running on all CPUs
or only two cores were available.
PATCH commit c1afe981bf63c79f695b6ff826c5109a9f7f1dd7
Date: Fri Nov 25 11:33:11 2011 +0100
