AG patches chunk A
Joel Sherrill
joel.sherrill at OARcorp.com
Thu Feb 2 14:54:46 UTC 2012
On 02/02/2012 08:39 AM, Daniel Hellstrom wrote:
> Hello,
> I summarize the first chunk of patches, PATCH means I will send them on the rtems-devel list, PR means I will file a bugzilla PR. Feel free to comment.. and apply :)
I am putting my first thought on whether or not a PR is required.
Correct me if I am wrong.
> Patches are listed in reverse apply order, thus IO_MANAGER patch comes last.
> Thanks,
> Daniel
> + SPARC specific enhancements
> c1afe98 LEON3: fix compiler warning in SHM driver
This sounds like an easy one to review. Probably completely
benign and applies to 4.10 branch. Bugzilla.
> + SPARC specific bugs
> 3e2aa5e LEON3BSP MP: may wake one more CPU than expected
Head only.
> fe9dc9e SPARC BSPs: workspace must be aligned on a 8-byte boundary
Bugzilla.
> 124e68d LEON3: CPU index intialization moved to bspstart.c
I thought head but I read your description. This sounds like
a bug fix to include in 4.10.
> c7d92b6 LEON3: change d-cache snoop detect implementation
Your description below makes this sound like it is a bug which
needs to be a Bugzilla PR so it can be in a 4.10 release.
> LEON specific because GRETH driver only used by LEON:
> 7a92dba GRETH: Moved print to remove potential deadlock
> 6c66b13 GRETH: performance improvements and one bugfix
Treat as one PR in Bugzilla.
> + General bugs, (but not in any release, so PR not filed)
> 839ef7b MP06 TEST: avoid program failure when slow UART on CPU core 0
How is this not in a release?
> + General enhancements
> fe2ee40 bootstrap: handy --root switch for bootstrapping subdirs
> 11ae399 IO_MANAGER: early dynamic driver registration
Definitely through devel.
> PATCH commit 8713dbeead0fb5ce880793ef391916cc422efce5
> Author: Daniel Hellstrom<daniel at gaisler.com>
> Date: Thu Nov 24 16:54:28 2011 +0100
> Adds the possibility to register drivers before the IO Manager has
> completed the initialization. Sometimes the BSP may want to register
> a driver dynamically early in the boot process.
> Signed-off-by: Daniel Hellstrom<daniel at gaisler.com>
> PATCH commit b2a54a1af400bf731855fe26c8c4550a7cc0697b
> Date: Fri Nov 25 13:58:07 2011 +0100
> Use the "--root DIR" to process only a subdir, for example
> $ ./bootstrap --root c/src/lib/libbsp/sparc
> will only generate Makefiles for all SPARC BSPs, saves some
> time when working with a specific BSP.
> PR commit 6c66b134e18dc24b3fe8b2d9a9a6954c6bc6840e
> Date: Fri Dec 2 10:47:58 2011 +0100
> GRETH driver updated, 10-15% performance improvements for GBIT MAC,
> unnecessary RX interrupts not taken which under heavy load saves approx.
> 1500 interrupts/s, one task removed saving about 5kb memory and 1 bug
> solved.
> BUG: RX interrupt was enabled before the RX-daemon was created which could
> result in a faulty call to rtems_event_send.
> PR commit 7a92dba76fa113ab9fba1ddc90a2578ea8ff8d0a
> Date: Fri Dec 2 10:45:10 2011 +0100
> Deadlock may arise when the EDCL bug link is used to tunnel
> console output over Ethernet, when Ethernet is down one should
> avoid using console (only during debugging of LEON targets)
> Author: Marko Isomaki<marko at gaisler.com>
> PR[DEP-1] commit c7d92b6562014f85a29bd94ceb2c3292f36dfb32
> Date: Fri Nov 25 14:02:00 2011 +0100
> The previous code only checked if d-cache snooping was implemented,
> however snooping may be available but not enabled which may lead
> to driver bugs.
> PR commit 124e68d114f1ae6489ee86167357e6b6b16503e5
> Date: Fri Nov 25 14:15:16 2011 +0100
> All LEON3/4 systems have a CPU-id, if on a single-CPU system the
> ID is always zero. On a multicore system it ranges from 0 to 15.
> The CPU index should always by updated even in a non-MP RTEMS OS
> since the CPU running RTEMS may not always be CPU0. For example
> when RTEMS runs on CPU1 and Linux on CPU0 in a mixed ASMP system.
> The old code executed within the IRQ controller initialization code
> makes no sense since the ASR register is a CPU register, it has
> nothing to do with AMBA initialization either.
> PATCH commit 839ef7ba191dc65ecbb777bbd108758025259d34
> Date: Wed Nov 16 16:56:46 2011 +0100
> PR commit fe9dc9e1a55c1e71980eaa290f193cdae79141ca
> Date: Fri Nov 25 10:54:28 2011 +0100
> The linker-script already declares a 8-byte aligned symbol (_end)
> which can be used instead of "variable aligned" symbol end.
> PR commit 3e2aa5ed2415ff02dac7545930f0a07c546dac77
> Date: Wed Nov 9 16:09:55 2011 +0100
> The SHM code always wakes one CPU more that configured, however
> this has never been a problem since RTEMS will be running on all CPUs
> or only two cores were available.
> PATCH commit c1afe981bf63c79f695b6ff826c5109a9f7f1dd7
> Date: Fri Nov 25 11:33:11 2011 +0100
> rtems-devel mailing list
> rtems-devel at rtems.org
Joel Sherrill, Ph.D. Director of Research& Development
