[PR 05] LEON3: CPU index intialization moved to bspstart.c
Daniel Hellstrom daniel at gaisler.com
Thu Feb 2 14:46:26 UTC 2012
All LEON3/4 systems have a CPU-id, if on a single-CPU system the
ID is always zero. On a multicore system it ranges from 0 to 15.
The CPU index should always by updated even in a non-MP RTEMS OS
since the CPU running RTEMS may not always be CPU0. For example
when RTEMS runs on CPU1 and Linux on CPU0 in a mixed ASMP system.
The old code executed within the IRQ controller initialization code
makes no sense since the ASR register is a CPU register, it has
nothing to do with AMBA initialization either.
Signed-off-by: Daniel Hellstrom <daniel at gaisler.com>
 c/src/lib/libbsp/sparc/leon3/amba/amba.c        |   18 ------------------
 c/src/lib/libbsp/sparc/leon3/startup/bspstart.c |   18 ++++++++++++++++++
 2 files changed, 18 insertions(+), 18 deletions(-)
diff --git a/c/src/lib/libbsp/sparc/leon3/amba/amba.c b/c/src/lib/libbsp/sparc/leon3/amba/amba.c
index 1932cee..b0a43f9 100644
--- a/c/src/lib/libbsp/sparc/leon3/amba/amba.c
+++ b/c/src/lib/libbsp/sparc/leon3/amba/amba.c
@@ -21,8 +21,6 @@ amba_confarea_type amba_conf;
 /* Pointers to Interrupt Controller configuration registers */
 volatile LEON3_IrqCtrl_Regs_Map *LEON3_IrqCtrl_Regs;
-int LEON3_Cpu_Index = 0;
  *  amba_initialize
@@ -33,16 +31,6 @@ int LEON3_Cpu_Index = 0;
  *  amba_ahb_masters, amba_ahb_slaves and amba.
-unsigned int getasr17(void);
-__asm__ (" .text  \n"
-    "getasr17:   \n"
-    "retl \n"
-    "mov %asr17, %o0\n"
-extern rtems_configuration_table Configuration;
 extern int scan_uarts(void);
 void amba_initialize(void)
@@ -58,12 +46,6 @@ void amba_initialize(void)
   if ( i > 0 ){
     /* Found APB IRQ_MP Interrupt Controller */
     LEON3_IrqCtrl_Regs = (volatile LEON3_IrqCtrl_Regs_Map *) dev.start;
-#if defined(RTEMS_MULTIPROCESSING)
-      if (rtems_configuration_get_user_multiprocessing_table() != NULL) {
-        unsigned int tmp = getasr17();
-        LEON3_Cpu_Index = (tmp >> 28) & 3;
-#endif
   /* find GP Timer */
diff --git a/c/src/lib/libbsp/sparc/leon3/startup/bspstart.c b/c/src/lib/libbsp/sparc/leon3/startup/bspstart.c
index a4b9ffa..82054e8 100644
--- a/c/src/lib/libbsp/sparc/leon3/startup/bspstart.c
+++ b/c/src/lib/libbsp/sparc/leon3/startup/bspstart.c
@@ -27,6 +27,9 @@
 int CPU_SPARC_HAS_SNOOPING;
+/* Index of CPU, in an AMP system CPU-index may be non-zero */
+int LEON3_Cpu_Index = 0;
 extern void amba_initialize(void);
@@ -48,6 +51,14 @@ static inline int set_snooping(void)
   return (tmp >> 27) & 1;
+/* ASM-function used to get the CPU-Index on calling LEON3 CPUs */
+static inline unsigned int get_asr17(void)
+  unsigned int reg;
+  __asm__ (" mov %%asr17, %0 " : "=r"(reg) :);
+  return reg;
  *  bsp_start
@@ -57,6 +68,13 @@ void bsp_start( void )
   CPU_SPARC_HAS_SNOOPING = set_snooping();
+  /* Get the LEON3 CPU index, normally 0, but for MP systems we do
+   * _not_ assume that this is CPU0. One may run another OS on CPU0
+   * and RTEMS on this CPU, and AMP system with mixed operating
+   * systems
+  LEON3_Cpu_Index = (get_asr17() >> 28) & 3;
   /* Find UARTs */
   amba_initialize();
1.7.0.4
