[PR 05] LEON3: CPU index intialization moved to bspstart.c
Thu Feb 2 15:45:12 UTC 2012
On Thu, Feb 2, 2012 at 9:46 AM, Daniel Hellstrom <daniel at gaisler.com> wrote:
> All LEON3/4 systems have a CPU-id, if on a single-CPU system the
> ID is always zero. On a multicore system it ranges from 0 to 15.
> The CPU index should always by updated even in a non-MP RTEMS OS
> since the CPU running RTEMS may not always be CPU0. For example
> when RTEMS runs on CPU1 and Linux on CPU0 in a mixed ASMP system.
> The old code executed within the IRQ controller initialization code
> makes no sense since the ASR register is a CPU register, it has
> nothing to do with AMBA initialization either.
> Signed-off-by: Daniel Hellstrom <daniel at gaisler.com>
>  c/src/lib/libbsp/sparc/leon3/amba/amba.c        |   18 ------------------
>  c/src/lib/libbsp/sparc/leon3/startup/bspstart.c |   18 ++++++++++++++++++
>  2 files changed, 18 insertions(+), 18 deletions(-)
> diff --git a/c/src/lib/libbsp/sparc/leon3/amba/amba.c b/c/src/lib/libbsp/sparc/leon3/amba/amba.c
> index 1932cee..b0a43f9 100644
> --- a/c/src/lib/libbsp/sparc/leon3/amba/amba.c
> +++ b/c/src/lib/libbsp/sparc/leon3/amba/amba.c
> @@ -21,8 +21,6 @@ amba_confarea_type amba_conf;
>  /* Pointers to Interrupt Controller configuration registers */
>  volatile LEON3_IrqCtrl_Regs_Map *LEON3_IrqCtrl_Regs;
> -int LEON3_Cpu_Index = 0;
>  *  amba_initialize
> @@ -33,16 +31,6 @@ int LEON3_Cpu_Index = 0;
>  *  amba_ahb_masters, amba_ahb_slaves and amba.
> -unsigned int getasr17(void);
> -__asm__ (" .text  \n"
> -    "getasr17:   \n"
> -    "retl \n"
> -    "mov %asr17, %o0\n"
> -extern rtems_configuration_table Configuration;
>  extern int scan_uarts(void);
>  void amba_initialize(void)
> @@ -58,12 +46,6 @@ void amba_initialize(void)
>   if ( i > 0 ){
>     /* Found APB IRQ_MP Interrupt Controller */
>     LEON3_IrqCtrl_Regs = (volatile LEON3_IrqCtrl_Regs_Map *) dev.start;
> -#if defined(RTEMS_MULTIPROCESSING)
> -      if (rtems_configuration_get_user_multiprocessing_table() != NULL) {
> -        unsigned int tmp = getasr17();
> -        LEON3_Cpu_Index = (tmp >> 28) & 3;
> -#endif
>   /* find GP Timer */
> diff --git a/c/src/lib/libbsp/sparc/leon3/startup/bspstart.c b/c/src/lib/libbsp/sparc/leon3/startup/bspstart.c
> index a4b9ffa..82054e8 100644
> --- a/c/src/lib/libbsp/sparc/leon3/startup/bspstart.c
> +++ b/c/src/lib/libbsp/sparc/leon3/startup/bspstart.c
> @@ -27,6 +27,9 @@
>  int CPU_SPARC_HAS_SNOOPING;
> +/* Index of CPU, in an AMP system CPU-index may be non-zero */
> +int LEON3_Cpu_Index = 0;
>  extern void amba_initialize(void);
> @@ -48,6 +51,14 @@ static inline int set_snooping(void)
>   return (tmp >> 27) & 1;
> +/* ASM-function used to get the CPU-Index on calling LEON3 CPUs */
> +static inline unsigned int get_asr17(void)
> +  unsigned int reg;
> +  __asm__ (" mov %%asr17, %0 " : "=r"(reg) :);
> +  return reg;
Might get_asr17 make sense as a function defined by
cpukit/score/cpu/sparc/rtems/score/sparc.h? Or is it really only
useful for getting the cpu index as used below?
>  *  bsp_start
> @@ -57,6 +68,13 @@ void bsp_start( void )
>   CPU_SPARC_HAS_SNOOPING = set_snooping();
> +  /* Get the LEON3 CPU index, normally 0, but for MP systems we do
> +   * _not_ assume that this is CPU0. One may run another OS on CPU0
> +   * and RTEMS on this CPU, and AMP system with mixed operating
> +   * systems
> +  LEON3_Cpu_Index = (get_asr17() >> 28) & 3;
Would it make sense to also define something like
sparc_get_cpu_index()? Or does it only ever need to be done during bsp
initialization?
>   /* Find UARTs */
>   amba_initialize();
> 1.7.0.4
> rtems-devel mailing list
> rtems-devel at rtems.org
