[PATCH 09 v2] bootstrap: handy --base switch for bootstrapping subdirs
Ralf Corsepius ralf.corsepius at rtems.org
Fri Feb 3 18:00:13 UTC 2012
On 02/03/2012 04:14 PM, Daniel Hellstrom wrote:
> Use the "-b/--base DIR" to process only a subdir, for example
>   $ ./bootstrap --base c/src/lib/libbsp/sparc
> will only generate Makefiles for all SPARC BSPs, saves some
> time when working with a specific BSP.
> Signed-off-by: Daniel Hellstrom<daniel at gaisler.com>
I do not consider this change useful, because bootstrap must be run
inside of the source tree. Therefore, specifying an arbitrary "basedir"
is not useful.
Ralf
