git reset HEAD~1
    Gedare Bloom
    gedare at rtems.org
    Mon Feb 13 17:52:54 UTC 2012
Thanks this does help clarify some of the syntactical goo.
On Mon, Feb 13, 2012 at 12:49 PM, Cláudio Silva
<claudiodcsilva at gmail.com> wrote:
> I think the hyphen does not exist in git. You have carrot (^) and
> tilda(~). The difference is that tilda(~) is used for a linear history
> whereas the carrot(^) is able to follow commits with multiple parents.
> The following syntax applies:
> HEAD^(parallel parent number)
> HEAD~(linear ancestor number)
> E.g.
>  If you have a commit A which has two parents B and C (someone screwed
> up with a merge). Also consider a D that is B's parent:
> HEAD = A
> HEAD^ == HEAD^1 = B (1st parent)
> HEAD^2 = C (2nd parent)
> HEAD^3 = N/A (only two parents)
> HEAD~ = B
> HEAD~2 = D (parent of the first parent) = HEAD^^1 = HEAD^1^1
> HEAD^2^1 would yield the (first) parent of C. This notation is
> impossible using only tilda~
> The following equivalences apply:
> HEAD = HEAD
> HEAD^ = HEAD~
> HEAD^^ = HEAD~2
> HEAD^^^ = HEAD~3
> Both syntaxes can be stacked:
> HEAD~3^2 - (second parent of the third previous commit)
> (sorry for the mess, just trying to explain)
> Regards,
> Cláudio
> On Mon, Feb 13, 2012 at 5:10 PM, Gedare Bloom <gedare at rtems.org> wrote:
>> I've updated the wiki with these new examples. I think there is a
>> difference when you use a ~ (tilda) and a - (hyphen). Now the wiki
>> avoids using hyphens.
>> On Mon, Feb 13, 2012 at 10:22 AM, Cláudio Silva
>>> Hi,
>>> I think that description is wrong. Let's try a longer description
>>> (hopefully correct) of git reset:
>>> "git reset HEAD~" will undo the last commit and unstage those changes.
>>> Your working directory will remain the same, therefore a "git status"
>>> will yield any changes you made plus the changes made in your last
>>> commit. This can be used to fix the last commit. You will need to add
>>> the files again.
>>> "git reset --soft HEAD~" will just undo the last commit.The changes
>>> from last commit will still be staged (just as if you finished git'
>>> adding them).  This can be used to amend the last commit (e.g. I
>>> forgot to add a file to the last commit).
>>> "git reset --hard HEAD~" will revert everything, including the working
>>> directory, to the previous commit. This is dangerous and can lead to
>>> you losing all your changes.
>>> "git reset HEAD" will unstage any change. This is used to revert a
>>> wrong git add. (e.g. I added a file that shouldn't be there, but i
>>> haven't 'commited')
>>> "git reset --hard HEAD" will revert your working directory to a HEAD
>>> state. (You will lose any change you made to files after the last
>>> commit). This is used when you just want to destroy all changes you
>>> made since the last commit.
>>> Regards,
>>> Cláudio
>>> On Mon, Feb 13, 2012 at 2:13 PM, Ralf Corsepius
>>> <ralf.corsepius at rtems.org> wrote:
>>>> Hi,
>>>> http://wiki.rtems.org/wiki/index.php/Git
>>>> tells:
>>>>  git reset HEAD-1
>>>> Removes the last 1 (or any other number you put) commit from the current
>>>> branch. git reset should only be used on local branches that no one else is
>>>> accessing remotely. This is a very powerful and tricky command; A good
>>>> description of what it enables to do can be found here
>>>> Either there is a language barrier causing me to misunderstand this sentence
>>>> or this sentence doesn't seem right:
>>>> git reset HEAD  ... removes the last commit
>>>> git reset HEAD~1 ... remove the last 2 commits
>>>> The human factor had just hit me (I needed to revert my last commit),
>>>> causing me to exercise this to trip over this.
>>>> Ralf
>>>> _______________________________________________
>>>> rtems-devel mailing list
>>>> rtems-devel at rtems.org
>>>> http://www.rtems.org/mailman/listinfo/rtems-devel
