Please avoid merge commits
Thu Feb 23 17:52:58 UTC 2012
On 02/23/2012 11:40 AM, Sebastian Huber wrote:
> Hello,
> please rebase your work to the current branch head and avoid merge commits like
> this:
> http://git.rtems.org/rtems/commit/?id=8f7f6caaef26f9067aeb2feaa85a2d50c0853ba8
This is my fault. I passed along a command sequence to Jennifer.
> This makes browsing the history quite painful.
Agreed.
> git rebase --help
The command sequence which is doing this is from
the wiki http://wiki.rtems.org/wiki/index.php/RTEMS_GIT_Repository
Section 5.2.3 Update from upstream master (RTEMS head)
# git fetch upstream
# git merge upstream/master
Should the merge command be dropped? Or is the proper
sequence this?
# git rebase upstream/master
Advice appreciated.  We need to make sure that the instructions
are right and that I am properly retrained. :)
Joel Sherrill, Ph.D.             Director of Research&   Development
