Please avoid merge commits
Cláudio Silva claudiodcsilva at gmail.com
Thu Feb 23 18:43:36 UTC 2012
Hi,
> On 02/23/2012 11:40 AM, Sebastian Huber wrote:
>> Hello,
>> please rebase your work to the current branch head and avoid merge commits
>> like
>> this:
>> http://git.rtems.org/rtems/commit/?id=8f7f6caaef26f9067aeb2feaa85a2d50c0853ba8
> This is my fault. I passed along a command sequence to Jennifer.
>> This makes browsing the history quite painful.
> Agreed.
>> git rebase --help
> The command sequence which is doing this is from
> the wiki http://wiki.rtems.org/wiki/index.php/RTEMS_GIT_Repository
> Section 5.2.3 Update from upstream master (RTEMS head)
> # git fetch upstream
> # git merge upstream/master
> Should the merge command be dropped? Or is the proper
> sequence this?
> # git rebase upstream/master
> Advice appreciated.  We need to make sure that the instructions
> are right and that I am properly retrained. :)
 # git checkout master
You can use this command sequence to update your local master branch
when you have no changes in it (it is the same as a git pull).
When you have changes and you want to propagate them upstream: (if you
have those changes on a separate branch)
# git checkout new_features
# git push upstream new_features:master
If those new commits are in your local master (this is -not- very advisable):
# git checkout master (if you are not already in master)
# git push upstream master:master
You can also replace the git rebase with "git rebase --interactive".
An interactive rebase allows you to edit commit messages, squash
commits together or ignore them.
Regards,
Cláudio
