[PATCH 11 v2] SPARC: added libcpu lowlevel access and byteorder routines/definitions
Daniel Hellstrom
daniel at gaisler.com
Wed Feb 8 14:57:03 UTC 2012
The low level routines can be used in different occasions, it will be
required when accessing PCI.
Note the difference between byteorder.h (inlined functions) and access.S
where the functions will be declared in the library archive librtemscpu.a.
Function names starting with _ are in library and can be referenced by
function pointers.
Signed-off-by: Daniel Hellstrom <daniel at gaisler.com>
c/src/lib/libbsp/sparc/erc32/Makefile.am | 4 +-
c/src/lib/libbsp/sparc/leon2/Makefile.am | 1 +
c/src/lib/libbsp/sparc/leon3/Makefile.am | 4 +-
c/src/lib/libcpu/sparc/Makefile.am | 7 ++
c/src/lib/libcpu/sparc/access/access.S | 81 +++++++++++++++++++++
c/src/lib/libcpu/sparc/access/access_le.c | 32 ++++++++
c/src/lib/libcpu/sparc/include/libcpu/access.h | 50 +++++++++++++
c/src/lib/libcpu/sparc/include/libcpu/byteorder.h | 66 +++++++++++++++++
c/src/lib/libcpu/sparc/preinstall.am | 8 ++
9 files changed, 251 insertions(+), 2 deletions(-)
create mode 100644 c/src/lib/libcpu/sparc/access/access.S
create mode 100644 c/src/lib/libcpu/sparc/access/access_le.c
create mode 100644 c/src/lib/libcpu/sparc/include/libcpu/access.h
create mode 100644 c/src/lib/libcpu/sparc/include/libcpu/byteorder.h
diff --git a/c/src/lib/libbsp/sparc/erc32/Makefile.am b/c/src/lib/libbsp/sparc/erc32/Makefile.am
index abe44c3..cecfe14 100644
--- a/c/src/lib/libbsp/sparc/erc32/Makefile.am
+++ b/c/src/lib/libbsp/sparc/erc32/Makefile.am
@@ -68,7 +68,9 @@ erc32sonic_rel_CPPFLAGS = $(AM_CPPFLAGS) $(erc32sonic_CPPFLAGS)
erc32sonic_rel_LDFLAGS = $(RTEMS_RELLDFLAGS)
endif
-libbsp_a_LIBADD = ../../../libcpu/@RTEMS_CPU@/cache.rel \
+libbsp_a_LIBADD = \
+ ../../../libcpu/@RTEMS_CPU@/access.rel \
+ ../../../libcpu/@RTEMS_CPU@/cache.rel \
../../../libcpu/@RTEMS_CPU@/reg_win.rel \
../../../libcpu/@RTEMS_CPU@/syscall.rel
if HAS_NETWORKING
diff --git a/c/src/lib/libbsp/sparc/leon2/Makefile.am b/c/src/lib/libbsp/sparc/leon2/Makefile.am
index 9c7819c..9df3c7d 100644
--- a/c/src/lib/libbsp/sparc/leon2/Makefile.am
+++ b/c/src/lib/libbsp/sparc/leon2/Makefile.am
@@ -118,6 +118,7 @@ leon_open_eth_rel_LDFLAGS = $(RTEMS_RELLDFLAGS)
endif
libbsp_a_LIBADD = \
diff --git a/c/src/lib/libbsp/sparc/leon3/Makefile.am b/c/src/lib/libbsp/sparc/leon3/Makefile.am
index 5edbe9d..8eae306 100644
--- a/c/src/lib/libbsp/sparc/leon3/Makefile.am
+++ b/c/src/lib/libbsp/sparc/leon3/Makefile.am
@@ -126,7 +126,9 @@ libbsp_a_SOURCES += shmsupp/addrconv.c shmsupp/getcfg.c shmsupp/lock.c \
shmsupp/mpisr.c
endif
diff --git a/c/src/lib/libcpu/sparc/Makefile.am b/c/src/lib/libcpu/sparc/Makefile.am
index 7bebd94..711d6b1 100644
--- a/c/src/lib/libcpu/sparc/Makefile.am
+++ b/c/src/lib/libcpu/sparc/Makefile.am
@@ -10,6 +10,8 @@ noinst_PROGRAMS =
include_libcpudir = $(includedir)/libcpu
include_libcpu_HEADERS = ../shared/include/cache.h
+include_libcpu_HEADERS += include/libcpu/byteorder.h
+include_libcpu_HEADERS += include/libcpu/access.h
noinst_PROGRAMS += cache.rel
cache_rel_SOURCES = cache/cache.c cache/cache_.h \
@@ -31,5 +33,10 @@ reg_win_rel_SOURCES = reg_win/window.S
reg_win_rel_CPPFLAGS = $(AM_CPPFLAGS)
reg_win_rel_LDFLAGS = $(RTEMS_RELLDFLAGS)
+noinst_PROGRAMS += access.rel
+access_rel_SOURCES = access/access.S access/access_le.c
+access_rel_CPPFLAGS = $(AM_CPPFLAGS)
+access_rel_LDFLAGS = $(RTEMS_RELLDFLAGS)
include $(srcdir)/preinstall.am
include $(top_srcdir)/../../../automake/local.am
diff --git a/c/src/lib/libcpu/sparc/access/access.S b/c/src/lib/libcpu/sparc/access/access.S
new file mode 100644
index 0000000..bad296e
--- /dev/null
+++ b/c/src/lib/libcpu/sparc/access/access.S
@@ -0,0 +1,81 @@
+ * Optimized access routines for SPARC.
+ * Note the difference between byteorder.h (inlined functions) and access.S
+ * where the functions will be declared in the library archive librtemscpu.a.
+ * Function names starting with _ are in library and can be referenced by
+ * function pointers.
+ * _ldN, _stN standard machine endianess access (SPARC: big-endian)
+ * _ld_beN, _st_beN forced big-endian
+ * _ld_leN, _st_leN forced little-endian (defined in access_le.C)
+ * This file is written in assembly because the big-endian functions maps to
+ * machine dependant access methods, i.e. same function has two names.
+ * COPYRIGHT (c) 2011
+ * Aeroflex Gaisler.
+ * http://www.rtems.com/license/LICENSE.
+#include <rtems/asm.h>
+ .align 4
+ .seg "text"
+ PUBLIC(_ld8)
+ PUBLIC(_ld16)
+ PUBLIC(_ld32)
+ PUBLIC(_ld64)
+ PUBLIC(_st8)
+ PUBLIC(_st16)
+ PUBLIC(_st32)
+ PUBLIC(_st64)
+ PUBLIC(_ld_be16)
+ PUBLIC(_ld_be32)
+ PUBLIC(_ld_be64)
+ PUBLIC(_st_be16)
+ PUBLIC(_st_be32)
+ PUBLIC(_st_be64)
+SYM(_ld8):
+ retl
+ ldub [%o0], %o0
+SYM(_ld_be16):
+SYM(_ld16):
+ retl
+ lduh [%o0], %o0
+SYM(_ld_be32):
+SYM(_ld32):
+ retl
+ ld [%o0], %o0
+SYM(_ld_be64):
+SYM(_ld64):
+ retl
+ ldd [%o0], %o0
+SYM(_st8):
+ retl
+ stub %o1, [%o0]
+SYM(_st_be16):
+SYM(_st16):
+ retl
+ stuh %o1, [%o0]
+SYM(_st_be32):
+SYM(_st32):
+ retl
+ st %o1, [%o0]
+SYM(_st_be64):
+SYM(_st64):
+ mov %o2, %o3
+ mov %o1, %o2
+ retl
+ std %o2, [%o0]
diff --git a/c/src/lib/libcpu/sparc/access/access_le.c b/c/src/lib/libcpu/sparc/access/access_le.c
index 0000000..15031cc
--- /dev/null
+++ b/c/src/lib/libcpu/sparc/access/access_le.c
@@ -0,0 +1,32 @@
+ * Little-endian access routines for SPARC
+#include <libcpu/byteorder.h>
+uint16_t _ld_le16(uint16_t *addr)
+ return ld_le16(addr);
+void _st_le16(uint16_t *addr, uint16_t val)
+ st_le16(addr, val);
+uint32_t _ld_le32(uint32_t *addr)
+ return ld_le32(addr);
+void _st_le32(uint32_t *addr, uint32_t val)
+ st_le32(addr, val);
diff --git a/c/src/lib/libcpu/sparc/include/libcpu/access.h b/c/src/lib/libcpu/sparc/include/libcpu/access.h
index 0000000..16bf2dc
--- /dev/null
+++ b/c/src/lib/libcpu/sparc/include/libcpu/access.h
@@ -0,0 +1,50 @@
+ * access.h - access routines for SPARC. SPARC is big endian only.
+#ifndef _LIBCPU_ACCESS_H
+#define _LIBCPU_ACCESS_H
+#include <rtems/system.h>
+#include <rtems/score/cpu.h>
+#ifdef __cplusplus
+extern "C" {
+#endif
+/* "Raw" access */
+extern uint8_t _ld8(uint8_t *addr);
+extern void _st8(uint8_t *addr, uint8_t val);
+extern uint16_t _ld16(uint16_t *addr);
+extern void _st16(uint16_t *addr, uint16_t val);
+extern uint32_t _ld32(uint32_t *addr);
+extern void _st32(uint32_t *addr, uint32_t val);
+extern uint64_t _ld64(uint64_t *addr);
+extern void _st64(uint64_t *addr, uint64_t val);
+/* Aliases for Big Endian */
+extern uint16_t _ld_be16(uint16_t *addr);
+extern void _st_be16(uint16_t *addr, uint16_t val);
+extern uint32_t _ld_be32(uint32_t *addr);
+extern void _st_be32(uint32_t *addr, uint32_t val);
+extern uint64_t _ld_be64(uint64_t *addr);
+extern void _st_be64(uint64_t *addr, uint64_t val);
+/* Little endian */
+extern uint16_t _ld_le16(uint16_t *addr);
+extern void _st_le16(uint16_t *addr, uint16_t val);
+extern uint32_t _ld_le32(uint32_t *addr);
+extern void _st_le32(uint32_t *addr, uint32_t val);
+#ifdef __cplusplus
+#endif
+#endif
diff --git a/c/src/lib/libcpu/sparc/include/libcpu/byteorder.h b/c/src/lib/libcpu/sparc/include/libcpu/byteorder.h
index 0000000..d626f28
--- /dev/null
+++ b/c/src/lib/libcpu/sparc/include/libcpu/byteorder.h
@@ -0,0 +1,66 @@
+ * byteorder.h - Endian conversion for SPARC. SPARC is big endian only.
+#ifndef _LIBCPU_BYTEORDER_H
+#define _LIBCPU_BYTEORDER_H
+#ifdef __cplusplus
+extern "C" {
+#endif
+RTEMS_INLINE_ROUTINE uint16_t ld_le16(volatile uint16_t *addr)
+ return CPU_swap_u16(*addr);
+RTEMS_INLINE_ROUTINE void st_le16(volatile uint16_t *addr, uint16_t val)
+ *addr = CPU_swap_u16(val);
+RTEMS_INLINE_ROUTINE uint32_t ld_le32(volatile uint32_t *addr)
+ return CPU_swap_u32(*addr);
+RTEMS_INLINE_ROUTINE void st_le32(volatile uint32_t *addr, uint32_t val)
+ *addr = CPU_swap_u32(val);
+RTEMS_INLINE_ROUTINE uint16_t ld_be16(volatile uint16_t *addr)
+ return *addr;
+RTEMS_INLINE_ROUTINE void st_be16(volatile uint16_t *addr, uint16_t val)
+ *addr = val;
+RTEMS_INLINE_ROUTINE uint32_t ld_be32(volatile uint32_t *addr)
+ return *addr;
+RTEMS_INLINE_ROUTINE void st_be32(volatile uint32_t *addr, uint32_t val)
+ *addr = val;
+#ifdef __cplusplus
+#endif
+#endif
diff --git a/c/src/lib/libcpu/sparc/preinstall.am b/c/src/lib/libcpu/sparc/preinstall.am
index 412b683..2efe38b 100644
--- a/c/src/lib/libcpu/sparc/preinstall.am
+++ b/c/src/lib/libcpu/sparc/preinstall.am
@@ -22,3 +22,11 @@ $(PROJECT_INCLUDE)/libcpu/cache.h: ../shared/include/cache.h $(PROJECT_INCLUDE)/
$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libcpu/cache.h
PREINSTALL_FILES += $(PROJECT_INCLUDE)/libcpu/cache.h
+$(PROJECT_INCLUDE)/libcpu/byteorder.h: include/libcpu/byteorder.h $(PROJECT_INCLUDE)/libcpu/$(dirstamp)
+ $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libcpu/byteorder.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libcpu/byteorder.h
+$(PROJECT_INCLUDE)/libcpu/access.h: include/libcpu/access.h $(PROJECT_INCLUDE)/libcpu/$(dirstamp)
+ $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libcpu/access.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/libcpu/access.h
1.7.0.4
