[PATCH 11 v2] SPARC: added libcpu lowlevel access and byteorder routines/definitions
Gedare Bloom
gedare at rtems.org
Wed Feb 8 15:33:09 UTC 2012
Looks good to me.
On Wed, Feb 8, 2012 at 9:57 AM, Daniel Hellstrom <daniel at gaisler.com> wrote:
> The low level routines can be used in different occasions, it will be
> required when accessing PCI.
> Note the difference between byteorder.h (inlined functions) and access.S
> where the functions will be declared in the library archive librtemscpu.a.
> Function names starting with _ are in library and can be referenced by
> function pointers.
> Signed-off-by: Daniel Hellstrom <daniel at gaisler.com>
> c/src/lib/libbsp/sparc/erc32/Makefile.am | 4 +-
> c/src/lib/libbsp/sparc/leon2/Makefile.am | 1 +
> c/src/lib/libbsp/sparc/leon3/Makefile.am | 4 +-
> c/src/lib/libcpu/sparc/Makefile.am | 7 ++
> c/src/lib/libcpu/sparc/access/access.S | 81 +++++++++++++++++++++
> c/src/lib/libcpu/sparc/access/access_le.c | 32 ++++++++
> c/src/lib/libcpu/sparc/include/libcpu/access.h | 50 +++++++++++++
> c/src/lib/libcpu/sparc/include/libcpu/byteorder.h | 66 +++++++++++++++++
> c/src/lib/libcpu/sparc/preinstall.am | 8 ++
> 9 files changed, 251 insertions(+), 2 deletions(-)
> create mode 100644 c/src/lib/libcpu/sparc/access/access.S
> create mode 100644 c/src/lib/libcpu/sparc/access/access_le.c
> create mode 100644 c/src/lib/libcpu/sparc/include/libcpu/access.h
> create mode 100644 c/src/lib/libcpu/sparc/include/libcpu/byteorder.h
> diff --git a/c/src/lib/libbsp/sparc/erc32/Makefile.am b/c/src/lib/libbsp/sparc/erc32/Makefile.am
> index abe44c3..cecfe14 100644
> --- a/c/src/lib/libbsp/sparc/erc32/Makefile.am
> +++ b/c/src/lib/libbsp/sparc/erc32/Makefile.am
> @@ -68,7 +68,9 @@ erc32sonic_rel_CPPFLAGS = $(AM_CPPFLAGS) $(erc32sonic_CPPFLAGS)
> erc32sonic_rel_LDFLAGS = $(RTEMS_RELLDFLAGS)
> endif
> -libbsp_a_LIBADD = ../../../libcpu/@RTEMS_CPU@/cache.rel \
> +libbsp_a_LIBADD = \
> + ../../../libcpu/@RTEMS_CPU@/access.rel \
> + ../../../libcpu/@RTEMS_CPU@/cache.rel \
> ../../../libcpu/@RTEMS_CPU@/reg_win.rel \
> ../../../libcpu/@RTEMS_CPU@/syscall.rel
> if HAS_NETWORKING
> diff --git a/c/src/lib/libbsp/sparc/leon2/Makefile.am b/c/src/lib/libbsp/sparc/leon2/Makefile.am
> index 9c7819c..9df3c7d 100644
> --- a/c/src/lib/libbsp/sparc/leon2/Makefile.am
> +++ b/c/src/lib/libbsp/sparc/leon2/Makefile.am
> @@ -118,6 +118,7 @@ leon_open_eth_rel_LDFLAGS = $(RTEMS_RELLDFLAGS)
> endif
> libbsp_a_LIBADD = \
> diff --git a/c/src/lib/libbsp/sparc/leon3/Makefile.am b/c/src/lib/libbsp/sparc/leon3/Makefile.am
> index 5edbe9d..8eae306 100644
> --- a/c/src/lib/libbsp/sparc/leon3/Makefile.am
> +++ b/c/src/lib/libbsp/sparc/leon3/Makefile.am
> @@ -126,7 +126,9 @@ libbsp_a_SOURCES += shmsupp/addrconv.c shmsupp/getcfg.c shmsupp/lock.c \
> shmsupp/mpisr.c
> endif
> diff --git a/c/src/lib/libcpu/sparc/Makefile.am b/c/src/lib/libcpu/sparc/Makefile.am
> index 7bebd94..711d6b1 100644
> --- a/c/src/lib/libcpu/sparc/Makefile.am
> +++ b/c/src/lib/libcpu/sparc/Makefile.am
> @@ -10,6 +10,8 @@ noinst_PROGRAMS =
> include_libcpudir = $(includedir)/libcpu
> include_libcpu_HEADERS = ../shared/include/cache.h
> +include_libcpu_HEADERS += include/libcpu/byteorder.h
> +include_libcpu_HEADERS += include/libcpu/access.h
> noinst_PROGRAMS += cache.rel
> cache_rel_SOURCES = cache/cache.c cache/cache_.h \
> @@ -31,5 +33,10 @@ reg_win_rel_SOURCES = reg_win/window.S
> reg_win_rel_CPPFLAGS = $(AM_CPPFLAGS)
> reg_win_rel_LDFLAGS = $(RTEMS_RELLDFLAGS)
> +noinst_PROGRAMS += access.rel
> +access_rel_SOURCES = access/access.S access/access_le.c
> +access_rel_CPPFLAGS = $(AM_CPPFLAGS)
> +access_rel_LDFLAGS = $(RTEMS_RELLDFLAGS)
> include $(srcdir)/preinstall.am
> include $(top_srcdir)/../../../automake/local.am
> diff --git a/c/src/lib/libcpu/sparc/access/access.S b/c/src/lib/libcpu/sparc/access/access.S
> new file mode 100644
> index 0000000..bad296e
> --- /dev/null
> +++ b/c/src/lib/libcpu/sparc/access/access.S
> @@ -0,0 +1,81 @@
> + * Optimized access routines for SPARC.
> + * Note the difference between byteorder.h (inlined functions) and access.S
> + * where the functions will be declared in the library archive librtemscpu.a.
> + * Function names starting with _ are in library and can be referenced by
> + * function pointers.
> + * _ldN, _stN standard machine endianess access (SPARC: big-endian)
> + * _ld_beN, _st_beN forced big-endian
> + * _ld_leN, _st_leN forced little-endian (defined in access_le.C)
> + * This file is written in assembly because the big-endian functions maps to
> + * machine dependant access methods, i.e. same function has two names.
> + * COPYRIGHT (c) 2011
> + * Aeroflex Gaisler.
> + * The license and distribution terms for this file may be
> + * found in the file LICENSE in this distribution or at
> + * http://www.rtems.com/license/LICENSE.
> +#include <rtems/asm.h>
> + .align 4
> + .seg "text"
> + PUBLIC(_ld8)
> + PUBLIC(_ld16)
> + PUBLIC(_ld32)
> + PUBLIC(_ld64)
> + PUBLIC(_st8)
> + PUBLIC(_st16)
> + PUBLIC(_st32)
> + PUBLIC(_st64)
> + PUBLIC(_ld_be16)
> + PUBLIC(_ld_be32)
> + PUBLIC(_ld_be64)
> + PUBLIC(_st_be16)
> + PUBLIC(_st_be32)
> + PUBLIC(_st_be64)
> +SYM(_ld8):
> + retl
> + ldub [%o0], %o0
> +SYM(_ld_be16):
> +SYM(_ld16):
> + retl
> + lduh [%o0], %o0
> +SYM(_ld_be32):
> +SYM(_ld32):
> + retl
> + ld [%o0], %o0
> +SYM(_ld_be64):
> +SYM(_ld64):
> + retl
> + ldd [%o0], %o0
> +SYM(_st8):
> + retl
> + stub %o1, [%o0]
> +SYM(_st_be16):
> +SYM(_st16):
> + retl
> + stuh %o1, [%o0]
> +SYM(_st_be32):
> +SYM(_st32):
> + retl
> + st %o1, [%o0]
> +SYM(_st_be64):
> +SYM(_st64):
> + mov %o2, %o3
> + mov %o1, %o2
> + retl
> + std %o2, [%o0]
> diff --git a/c/src/lib/libcpu/sparc/access/access_le.c b/c/src/lib/libcpu/sparc/access/access_le.c
> index 0000000..15031cc
> --- /dev/null
> +++ b/c/src/lib/libcpu/sparc/access/access_le.c
> @@ -0,0 +1,32 @@
> + * Little-endian access routines for SPARC
> +#include <libcpu/byteorder.h>
> +uint16_t _ld_le16(uint16_t *addr)
> + return ld_le16(addr);
> +void _st_le16(uint16_t *addr, uint16_t val)
> + st_le16(addr, val);
> +uint32_t _ld_le32(uint32_t *addr)
> + return ld_le32(addr);
> +void _st_le32(uint32_t *addr, uint32_t val)
> + st_le32(addr, val);
> diff --git a/c/src/lib/libcpu/sparc/include/libcpu/access.h b/c/src/lib/libcpu/sparc/include/libcpu/access.h
> index 0000000..16bf2dc
> --- /dev/null
> +++ b/c/src/lib/libcpu/sparc/include/libcpu/access.h
> @@ -0,0 +1,50 @@
> + * access.h - access routines for SPARC. SPARC is big endian only.
> +#ifndef _LIBCPU_ACCESS_H
> +#define _LIBCPU_ACCESS_H
> +#include <rtems/system.h>
> +#include <rtems/score/cpu.h>
> +#ifdef __cplusplus
> +extern "C" {
> +#endif
> +/* "Raw" access */
> +extern uint8_t _ld8(uint8_t *addr);
> +extern void _st8(uint8_t *addr, uint8_t val);
> +extern uint16_t _ld16(uint16_t *addr);
> +extern void _st16(uint16_t *addr, uint16_t val);
> +extern uint32_t _ld32(uint32_t *addr);
> +extern void _st32(uint32_t *addr, uint32_t val);
> +extern uint64_t _ld64(uint64_t *addr);
> +extern void _st64(uint64_t *addr, uint64_t val);
> +/* Aliases for Big Endian */
> +extern uint16_t _ld_be16(uint16_t *addr);
> +extern void _st_be16(uint16_t *addr, uint16_t val);
> +extern uint32_t _ld_be32(uint32_t *addr);
> +extern void _st_be32(uint32_t *addr, uint32_t val);
> +extern uint64_t _ld_be64(uint64_t *addr);
> +extern void _st_be64(uint64_t *addr, uint64_t val);
> +/* Little endian */
> +extern uint16_t _ld_le16(uint16_t *addr);
> +extern void _st_le16(uint16_t *addr, uint16_t val);
> +extern uint32_t _ld_le32(uint32_t *addr);
> +extern void _st_le32(uint32_t *addr, uint32_t val);
> +#ifdef __cplusplus
> +#endif
> +#endif
> diff --git a/c/src/lib/libcpu/sparc/include/libcpu/byteorder.h b/c/src/lib/libcpu/sparc/include/libcpu/byteorder.h
> index 0000000..d626f28
> --- /dev/null
> +++ b/c/src/lib/libcpu/sparc/include/libcpu/byteorder.h
> @@ -0,0 +1,66 @@
> + * byteorder.h - Endian conversion for SPARC. SPARC is big endian only.
> +#ifndef _LIBCPU_BYTEORDER_H
> +#define _LIBCPU_BYTEORDER_H
> +#ifdef __cplusplus
> +extern "C" {
> +#endif
> +RTEMS_INLINE_ROUTINE uint16_t ld_le16(volatile uint16_t *addr)
> + return CPU_swap_u16(*addr);
> +RTEMS_INLINE_ROUTINE void st_le16(volatile uint16_t *addr, uint16_t val)
> + *addr = CPU_swap_u16(val);
> +RTEMS_INLINE_ROUTINE uint32_t ld_le32(volatile uint32_t *addr)
> + return CPU_swap_u32(*addr);
> +RTEMS_INLINE_ROUTINE void st_le32(volatile uint32_t *addr, uint32_t val)
> + *addr = CPU_swap_u32(val);
> +RTEMS_INLINE_ROUTINE uint16_t ld_be16(volatile uint16_t *addr)
> + return *addr;
> +RTEMS_INLINE_ROUTINE void st_be16(volatile uint16_t *addr, uint16_t val)
> + *addr = val;
> +RTEMS_INLINE_ROUTINE uint32_t ld_be32(volatile uint32_t *addr)
> + return *addr;
> +RTEMS_INLINE_ROUTINE void st_be32(volatile uint32_t *addr, uint32_t val)
> + *addr = val;
> +#ifdef __cplusplus
> +#endif
> +#endif
> diff --git a/c/src/lib/libcpu/sparc/preinstall.am b/c/src/lib/libcpu/sparc/preinstall.am
> index 412b683..2efe38b 100644
> --- a/c/src/lib/libcpu/sparc/preinstall.am
> +++ b/c/src/lib/libcpu/sparc/preinstall.am
> @@ -22,3 +22,11 @@ $(PROJECT_INCLUDE)/libcpu/cache.h: ../shared/include/cache.h $(PROJECT_INCLUDE)/
> $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libcpu/cache.h
> PREINSTALL_FILES += $(PROJECT_INCLUDE)/libcpu/cache.h
> +$(PROJECT_INCLUDE)/libcpu/byteorder.h: include/libcpu/byteorder.h $(PROJECT_INCLUDE)/libcpu/$(dirstamp)
> + $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libcpu/byteorder.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/libcpu/byteorder.h
> +$(PROJECT_INCLUDE)/libcpu/access.h: include/libcpu/access.h $(PROJECT_INCLUDE)/libcpu/$(dirstamp)
> + $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libcpu/access.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/libcpu/access.h
> 1.7.0.4
> rtems-devel mailing list
> rtems-devel at rtems.org
